E-Tuners / Custom Hardparts
Like Tree4Likes
  • 1 Post By Lex
  • 1 Post By Ryan1926
  • 1 Post By Lex
 Old 03-02-2016, 06:27 PM   #1
Ryan1926's Avatar
Posts: 25   (View Stats)
Ryan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to behold
Default Another Happy Stratified Customer!!!
I just want to say thanks to @Lex; at Stratified for helping me transform my Speed3 from an already capable car on 91 Octane to a beast on a custom E30 Tune. It was a pleasure working with Alex on my custom 91 and E30 eTunes. Alex was very professional and explained things as we worked on the tune and made sure that he catered to my needs with regards to maximizing my tunes based on my car being my daily driver. I can't believe how much of a difference an E85 blend makes on these cars. The torque is simply amazing! Thanks again Alex and if anyone if on the fence about doing an E85 blend custom tune, don't hesitate and be sure to drop Alex a message! Happy Boosting!
2008 Mazdaspeed3 (Cosmic Blue Mica)
Stratified Tuned (91 oct and E30), BNR S3, CPE Xcel Intake 3.25, HTP Inlet Pipe, CPE Downpipe, COBB AP, HKS Hi-Power Exhaust, Forge BPV, Treadstone TR8c FMIC, CPE Motor Mounts, CPE Safe Seals, JBR Thermal Gaskets, COBB 3 port ECBS, Autotech HPFP Internals, Guardian Angel, 18x8 Rays Gram Lights Optimize in Shining Silver, Koni Sports, Seift Springs, JBR Rear Sway Bar, SPC Rear Camber Arms, Whiteline Rear Endlinks
Ryan1926 is offline   Reply With Quote
The Following 4 Users Say Thank You to Ryan1926 For This Useful Post:
aviator79 (03-04-2016), Code Monkey (03-05-2016), Lex (03-04-2016), rob ms6gt (03-06-2016)
 Old 03-02-2016, 06:59 PM   #2
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
307 on 91 Cali piss on BNR S3?
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
gdawg25 is offline   Reply With Quote
 Old 03-02-2016, 07:14 PM   #3
hollar1211's Avatar
Posts: 495   (View Stats)
hollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond repute
So you got roughly 80 hp and 80 tq from an e30 blend? Was anything else installed since the 91 octane tune? Great numbers.
2008.5 Speed3 GT
Freek Tuned e33: Cobb AP, Autotech Internals, UR Test Pipe, CPE TMIC, JBR Power Path Stage 2 SRI-TIP/ Short Shifter/ Solid Shifter Bushings/ Heavy Shift Knob/ 88 Duro RMM/ EGR Delete & Block Off Plate/ Throttle Body TIG, NGK IX 6510, 18x8 +35 Drag DR-49
hollar1211 is offline   Reply With Quote
 Old 03-02-2016, 07:23 PM   #4
Ryan1926's Avatar
Attached is a real dyno pull I did on 91 octane prior to doing the E30 blend. I'm probably going to go back to the same dyno and do a pull on E85 to compare. So, I'm hoping an actual pull on my E85 blend will be proportional to the Virtual Dyno #'s.
To answer the 2 questions in the previous posts....
(1) yes...BNR S3 on 91 Oct.
(2) No additional mods were done. Alex and I did the 91 octane tune first then a month later did the E30 tune.
The Following 3 Users Say Thank You to Ryan1926 For This Useful Post:
gdawg25 (03-02-2016), Lex (03-04-2016), speed23 (03-03-2016)
 Old 03-04-2016, 05:04 PM   #5
Pleasure was mine Ryan and looking forward to the updated dyno numbers!
Ryan1926 likes this.
 Old 03-04-2016, 07:07 PM   #6
Ryan1926's Avatar
Found the video of the run as well.
The Following User Says Thank You to Ryan1926 For This Useful Post:
Lex (03-07-2016)
 Old 03-16-2016, 08:31 PM   #7
Ryan1926's Avatar
Attached is an acutal dyno pull after the E85 blend tune by Alex. This was done on the same dyno as my initial 91 Octane run as evident by the baseline graph.
The Following 2 Users Say Thank You to Ryan1926 For This Useful Post:
Lex (03-18-2016), speed23 (03-16-2016)
 Old 03-17-2016, 05:55 AM   #8
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Meth too or just e85?
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 03-17-2016, 09:29 AM   #9
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
Ryan 1926 what were your final numbers. The link you posted does not open.
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
 Old 03-17-2016, 09:41 AM   #10
Ryan1926's Avatar
Just the E85 Blend
Weird....the .pdf shows up and opens up on my end. Final #'s were...
91 Oct - 320whp / 352tq
E85 Blend - 391whp / 386tq
Nitro likes this.
CWP_MS3 (03-17-2016)
 Old 03-17-2016, 09:47 AM   #11
Nitro's Avatar
Thanks Ryan 1926
Stratified Tune
 Old 03-17-2016, 09:48 AM   #12
Ryan1926's Avatar
Thanks Ryan 1926
No problem. I see that you have a similar set-up as well as meth. What were your #'s?
 Old 03-17-2016, 10:05 AM   #13
Nitro's Avatar
My numbers are around 341tq / 350hp. Tune is not complete although Alex feels this is a good safe place. I have to run some more logs for him. The numbers seem low compared to yours. I am running Shell 92, E85, and meth. Can you post a recent log? I would like to compare them.
Stratified Tune
 Old 03-17-2016, 10:45 AM   #14
Ryan1926's Avatar
No Problem. Attached is the log from the actual Dyno run as well as 2 logs I sent to Alex after my last E85 revision.
 Old 03-17-2016, 10:51 AM   #15
Nitro's Avatar
Thx. 2 things that are likely making the difference is your intake and exhaust. I have a 3 inch JBR and stock catback.
Stratified Tune
 Old 03-17-2016, 11:14 AM   #16
Ryan1926's Avatar
I see. Time to open her up then.
Nitro likes this.
 Old 03-17-2016, 11:22 AM   #17
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Different people probably asking for different things. If Alex is saying he likes the level of power you're at, I'd be willing to bet its based off of what he feels matches what you asked from him.
Just saying. I know the poor tuners catch the brunt of it. The customer sees someone else make way more power than them, and they're like well WTF. Well, you wanted safety and they wanted power. lol Can't get all the powerz and none the risks...
Rich Tuned
330WHP and 363TQ
 Old 03-17-2016, 12:46 PM   #18
Nitro's Avatar
CWP_MS3 I know Alex very well. This is not meant to complain at all. He is an excellent tuner. I am just curious on the difference considering the quality of fuel used on a 91 tune. I am more than happy with the way the car runs
Stratified Tune
 Old 03-18-2016, 10:08 AM   #19
The differences you guys are seeing here mostly come down to the dyno you tested on. Ryan had his car run on a Dynapack while Nitro tested his car on a Mustang dyno.
The two are on opposite sides of the spectrum in terms of how they read; the Dynapack being known to read high and Mustang to read low.
Nitro likes this.
Another Happy Stratified Customer!!! Ryan1926 MazdaSpeed 3/6 - Dyno Sheets/Discussions 3 03-16-2016 08:33 PM
Another Stratified Customer crazyspeed6 Stratified Automotive Controls 4 06-10-2013 09:10 AM
Stratified customer service??? TheFlash Stratified Automotive Controls 8 06-01-2013 03:40 PM
Happy Holidays from Stratified! Lex Stratified Automotive Controls 4 12-25-2012 07:03 AM
another satisfied STRATIFIED customer ruthless013 Stratified Automotive Controls 0 04-26-2012 09:05 AM
Page generated in 0.38356 seconds with 26 queries
