![]() Join Date: Apr 2013 Location: Montreal,QC,Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score You can see this guy is passionate about what he is doing. Every time I tought it was the final map but it's like he never wants to stop until he's got everything he can out op the car. I'm very thankful to Alex and I highly recommend Stratified if you want your can tuned to perfection.
__________________ 2012 Red Mica, Stratified tuned |
| The Following 13 Users Say Thank You to Mikesp3 For This Useful Post: | bcmountainspeed (07-14-2013), BPASPEED (07-16-2013), Dimenus (07-17-2013), Dmurray06 (07-14-2013), Lex (07-14-2013), Minne_Speed3 (07-17-2013), ms3rick (07-14-2013), ms6mil (07-14-2013), Raymond (07-17-2013), RoyalDex (07-17-2013), snailD (07-17-2013), speed23 (07-14-2013), Speed3_BigV (07-14-2013) |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score Nice! Any VD results or logs?
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
![]() Join Date: Aug 2009 Location: Toronto, Ontario, CANADA
Rep Power: 545 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
Groans: 44
| Not Ranked : 0 score 300+ HP with a Intake/TIP/TP? Whoa... I hope I can get those numbers... Lets get to it LEX!
__________________ |
| The Following User Says Thank You to starscream For This Useful Post: | Lex (07-16-2013) |
![]() Join Date: Aug 2011 Location: Murrieta, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,535
Groans: 60
| Not Ranked : 0 score The guy is very good at what he does, I'd say one of the best. Maybe it's time for my corn tune.
__________________ 2011 MS3. Cobb AP V3, GTX3071, CPE LTR mani, Tial 44mm EWG, 3 bar MAP sensor and PnP harness, JBR WP intake, HTP battery tray with a 51 Optima Yellow battery, ITV22s, GFB BOV, Autotech internals, CPE injector seals and studs, VTCS delete, COBB FMIC, UR DP and TP, CNT CBE, JBR TIGs and Coolant bypass, JBR EGR delete, JBR RMM, PMM, and TMM, JBR OCC, PERM Plate, JBR RSB, JBR Rear Camber arms, 17X8 RPF1, TWM full replacement shifter with a PERM buttplug shift knob. Waiting to install:Built block, NJspeed PNP IM, Prosport boost and water temp gauges, coilovers and shit. |
| The Following 2 Users Say Thank You to BPASPEED For This Useful Post: | Lex (07-16-2013), Mike@Stratified (07-16-2013) |
| Not Ranked : 0 score We had some nice numbers from 91 alone so I am sure you will enjoy adding some E85 to the mix. Let me know whenever you're ready.
| The Following User Says Thank You to Lex For This Useful Post: | BPASPEED (07-16-2013) |
![]() Join Date: Oct 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,593
| Not Ranked : 0 score Wow, good stuff! I'll definitely be going Stratified when the time comes.
__________________ 2009 Mazdaspeed3 Bolted, Mounted, Hypnotic Tuned 2000 Mazda Miata MX-5 NASA TTE build ongoing |
| The Following User Says Thank You to Quigs For This Useful Post: | Lex (07-16-2013) |
| Not Ranked : 0 score The common correction factor to compare your vdyno #'s to others on msf is 1.01. I'm sure the tune is solid, but the correction factor is a little high. Last edited by rfinkle2; 07-16-2013 at 09:01 AM. |
![]() Join Date: Nov 2012 Location: Winston-Salem, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,946
| Not Ranked : 0 score Going on what rfinkle just said, use CF 1.01. I'm interested in seeing the numbers when corrected
__________________ Past 2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love ![]() Present 2014 Chevy Silverado Z71 |
| The Following User Says Thank You to CrawlingMS3 For This Useful Post: | rfinkle2 (07-16-2013) |
(Thread Starter) | Not Ranked : 0 score Anyone could explain me how to change the CF on Vdyno? A bit noob here
| The Following User Says Thank You to Mikesp3 For This Useful Post: | rfinkle2 (07-17-2013) |
Groans: 307
| Not Ranked : 0 score Open up VD, go to File>Options click on the Dyno tab, check "custom", type in 1.01, smoothing factor 2/3.
| The Following User Says Thank You to ms6mil For This Useful Post: | rfinkle2 (07-17-2013) |
(Thread Starter) | Not Ranked : 0 score Makes more sense to me with these numbers. Thanks a lot ms6mil!
| The Following 5 Users Say Thank You to Mikesp3 For This Useful Post: | CrawlingMS3 (07-18-2013), Lex (07-17-2013), memin (07-20-2013), ms6mil (07-17-2013), Raymond (07-17-2013) |
| Not Ranked : 0 score Good looking numbers @Mikesp3; Impressive if you ask me for just having intake+TIP and a testpipe on tune. Results like these are what makes me want to get tuned by @Lex; once I get a downpipe
| The Following User Says Thank You to CrawlingMS3 For This Useful Post: | Lex (07-17-2013) |
![]() Join Date: Jul 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 385
Anyways, thanks for sharing and I hope you keep enjoying being Stratified like I do.
__________________ 2009 Genwon Mazda3 MPS Sleeper Style JBR Stage 2 Intake (SRI+TIP) JBR Boost Tubes + BPV Hose Autotech HPFP Internals COBB AP V3 SURE Test Pipe CP-E Stage 1 RMM/CP-E Stage 2 RMM CP-E Triple Gauge Pod Defi Advance BF Gauges: Boost, Oil Temp, Oil Pressure Eonon D5151 Dvd Player [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to Raymond For This Useful Post: | Lex (07-17-2013) |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score |
| The Following User Says Thank You to RoyalDex For This Useful Post: | Lex (07-17-2013) |
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 866
| Not Ranked : 0 score Nice numbers! I'm looking at the graph and the numbers, and the highest RPM is @4212. Why didn't you pull until redline?
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle |
| Not Ranked : 0 score The graph goes well beyond 6000 RPM. Take a look at the x/bottom-axis.
| The Following User Says Thank You to Lex For This Useful Post: | manila (07-17-2013) |
| Not Ranked : 0 score @Lex; Sorry my mistake!
| The Following User Says Thank You to manila For This Useful Post: | Lex (07-17-2013) |
Groans: 307
| Not Ranked : 0 score peak tq on VD graph
| The Following User Says Thank You to ms6mil For This Useful Post: | Raymond (07-17-2013) |
(Thread Starter) | Not Ranked : 0 score I thought that was why people from Ontario hated us ![]() @Raymond: Yes I do have an Hpfp upgrade
| The Following User Says Thank You to Mikesp3 For This Useful Post: | Raymond (07-19-2013) |
![]() Join Date: May 2013 Location: Hawkesbury, ON
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Ummm in Ontario we also have the Petro Ultra 94 dude... But if you guys wanna hate us more here in Ottawa we have some E85 ![]() Now back on topic, that's a very decent increase in power, those custom tunes from Lex are amazing. I want one myself but I want to finish getting the mods I want 1st, so it won't be until next spring unfortunately. Couple people around town gonna be like WTF is in that car come next year lol
__________________ | 2010 Mazdaspeed with Tech Pkg / 18x8.5" Enkei T6S w/ Nitto NT05 245/40 | Cobb AccessPORT / Self Tuned | Ultimate Racing Turboback Exhaust (Catted, Non-resonated) / Ultimate Racing FMIC | Grimmspeed EBCS / Turbosmart Dual Port BPV / Denso ITV22 / Autotech Internals / JBR EGR Delete / Corksport OCC | JBR Chrome-Moly 88A RMM / Corksport TMM Insert / Corksport Shifter Bushings | Prosport Halo Boost Gauge / Corksport LED DRL and Foglight Bulbs / Rally Armor Mudflaps |
| The Following User Says Thank You to Speed3_BigV For This Useful Post: | Lex (07-19-2013) |
![]() | | #24 | ![]() |
In petawawa and Renfrew best I can get is v-power, E-85 is a fabled myth to us. I'm going to get a strat tune when I pull the trigger on my upgrades however That seems like a wicked increase. | |
| The Following User Says Thank You to RoyalDex For This Useful Post: | Lex (07-20-2013) |
| Edge Autosport, highly satisfied customer | Wicked | EdgeAutosport.com | 3 | 07-10-2012 02:54 PM |
| another satisfied STRATIFIED customer | ruthless013 | Stratified Automotive Controls | 0 | 04-26-2012 09:05 AM |
| Yet another more than satisfied customer... | CCC | JAMES BARONE RACING | 6 | 11-12-2010 12:33 PM |
| Another satisfied JBR SSP Customer | mazdaspeeding | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 07-14-2010 10:51 AM |
| Another satisfied customer. MS6 SSP | fhaze | JAMES BARONE RACING | 1 | 05-03-2010 10:04 AM |
