E-Tuners / Custom Hardparts
 Old 01-24-2014, 02:48 PM   #1
ep87's Avatar
Posts: 114   (View Stats)
ep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the world
Default Boost control- Question for Lex
Lex Hi still building up for a tune from you, getting my MAF & WOT logs together. and have one last question before I start. I use my V3 Ap for a boost gauge and have noticed that if I'm in say 3rd or 4th and in the upper end of the RPM range, say 4500+ and stomp on the throttle, boost peaks for just a second at anywhere from 20-21.5 lbs. I know this is not good on the stock lower end and have been avoiding it since I first noticed it. So question is can this be tuned out of it, or do will I need some sort of boost control. I would like to avoid this since I have no further plans on engine mods.
Thanks Richard
mods in sig.
CS RMM CS SS brake line,CS brake pads,CS SRI/TIP,CS OCC.Autotech internals,Cobb V3 AP, ETS TMIC, UR RP, Magnaflow CBE. Sure RSB Momo Revenge wheels 8.00x18 et40 stock 225/40 rubber.
Current Rides
2013 Mazda Speed3 CRYSTAL WHITE PEARL W/tech package
2012 VW GTI Black DSG w/Nav & sunroof
1970 Plymouth Duster 360 10.5:1 904w/ 2400 stall 3:73
1993 Ford Mustang LX 5.0 Vortech V-3 S/C
1996 Suzuki GSXF 750
1989 Suzuki GSXF 600 Project
2005 Yamaha WR450F
2005 Yamaha YZ450F
and coming this winter Ducati multistrada 1200
ep87 is offline   Reply With Quote
 Old 01-24-2014, 03:42 PM   #2
Hi Richard, 20psi (if the fuel can support it) and the tune is designed for it is not dangerous. When creating the tune, boost, timing, fueling are all considered to arrive at the correct mix for your car and fuel you are using. The tune controls all of these parameters and no additional hardware is needed to do so .
 Old 01-24-2014, 06:37 PM   #3
ep87's Avatar
Thanks Lex - That the exact info I needed. Looking forward to purchasing my tune next week.
Current Rides
2005 Yamaha WR450F
2005 Yamaha YZ450F
The Following User Says Thank You to ep87 For This Useful Post:
Lex (01-25-2014)
No control over boost. Turbo4banger MazdaSpeed 3/6 - ECU Computer Tuning 19 12-29-2013 09:58 AM
3 Port Boost Control Solenoid / Boost Question Badinfluence MazdaSpeed 3/6 - ECU Computer Tuning 24 06-24-2013 02:59 PM
Question about boost control? contreras MazdaSpeed 3/6 - Turbo Induction 3 04-26-2012 11:46 AM
Possible to control boost with... demonspeed MazdaSpeed 3/6 - Turbo Induction 6 02-04-2010 12:09 AM
Wastegate control, Boost spikes, PID control FreeFlyFreak
Cobb ATR Support
83 11-05-2009 12:40 PM
Page generated in 0.24400 seconds with 21 queries
