(Thread Starter) | Not Ranked : 0 score Had a chance to look at the difference a gutted stock DP makes versus a non gutted OEM unit. This is similar to installing a downpipe on the car and wrote a blog post about this since it's a question that comes up often. Many people on here, once fully bolted, talk about the downpipe not having a huge impact with the stock turbo. They are more or less correct. A large and well flowing intake will have a larger impact on flow but the downpipe will improve response. Have a read below: http://stratifiedauto.com/blog/does-...o-mazdaspeed3/
| The Following 31 Users Say Thank You to Lex For This Useful Post: | 08.5MS3 (10-01-2012), ABolewski (04-06-2013), Awesomesauce (01-07-2013), AZSPEED3 (10-01-2012), breakfstincluded (10-01-2012), Brennan (09-09-2013), Code Monkey (01-07-2013), CosmicArkie (10-01-2012), Dash08 (10-01-2012), Dmurray06 (10-01-2012), Easter Bunny (10-01-2012), exentix (10-01-2012), helmetface (10-01-2012), kritz (10-01-2012), KusteLokal (10-01-2012), lilred (10-01-2012), manila (10-01-2012), MD1032 (01-17-2015), Menace1 (01-30-2013), mike w (01-07-2013), moomooz12 (10-01-2012), Nliiitend1 (10-01-2012), Onelovesoccer (10-01-2012), Pointless (10-01-2012), Pseud0logik (10-01-2012), sadak (10-17-2013), SpeedNess (01-07-2013), SWAY (10-01-2012), TheProYodler (01-26-2016), TRex (10-01-2012), Vader (10-01-2012) |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score so a 3" intake on a stock turbo (even given the restriction) is a better mod than a dp on a stock turbo? (not saying one or the other, just saying most gains for the mod) incoming intake price jump |
| The Following User Says Thank You to TRex For This Useful Post: | Lex (10-01-2012) |
(Thread Starter) | Not Ranked : 0 score Yes, opening up the compressor side (before and after the compressor) allows for higher mass flow than a downpipe.
| The Following User Says Thank You to Lex For This Useful Post: | TRex (10-01-2012) |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score Is this peak hp or area under the curve? |
(Thread Starter) | Not Ranked : 0 score This is upper RPM flow from about 5-5.5k up where the WG is maxed out (and the comparison can be drawn).
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
| Not Ranked : 0 score So its safe to say a true 3'' dp would definitely make more power. I picked up 20+whp on my dp alone but it was 3" all the way through This is only comparing stock vs stock (one being gutted) correct? |
| The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post: | helmetface (10-01-2012), Lex (10-01-2012) |
(Thread Starter) | Not Ranked : 0 score Correct - the DP will allow for more power for sure. It's a matter of how much and there are many variables involved including the setup for the rest of the car. The compressor end seems more of a bottleneck than the exhaust end on the stock turbo.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | EdgeAutosport.com (10-01-2012), helmetface (10-01-2012) |
![]() Join Date: Jul 2010 Location: Little Rock, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,444
| Not Ranked : 0 score I'd like to see what difference a full catless dp would make replacing the 2nd cat as well.
__________________ BNR S3 // E85 Mix // Freektune 348tq/367whp -21.5 psi Now - 25-26 psi + JBR 3.5 Intake |
| The Following User Says Thank You to ckMS3 For This Useful Post: | Lex (10-01-2012) |
IMO the test pipe is worth it from the cost/time perspective as a first exhaust modification. The next focus would be the intake tract including the IC and then finish off with a DP.
| The Following 5 Users Say Thank You to Lex For This Useful Post: | atvfreek (10-01-2012), ckMS3 (10-01-2012), Menace1 (01-30-2013), Pseud0logik (10-01-2012), whatsabrooklyn (09-12-2019) |
![]() Join Date: Jun 2010 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,633
Groaned at 34 Times in 31 Posts
| Not Ranked : 0 score It's funny you drop this tidbit right around the same time that Eric announces a group buy on IC's.
__________________ ![]() |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
| Not Ranked : 0 score I had to dig deep for this, but I feel it may be relevant. Here is an old thread from back in the day when @bioevolve was still running around. Yet again went got another dyno! NATOR Style DownPipe!!! The first link is the results of Bioevolve gutting his downpipe and midpipe. The second link is just his how to. Just thought I'd share his findings...
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - | |
| The Following 9 Users Say Thank You to JacksonMS30 For This Useful Post: | 08.5MS3 (10-01-2012), atvfreek (10-01-2012), Easter Bunny (10-01-2012), EdgeAutosport.com (10-01-2012), jack_hammer (10-01-2012), Lex (10-01-2012), Menace1 (01-30-2013), mike w (01-07-2013), Ms3_Miami (10-01-2012) |
![]() Join Date: May 2011 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,224
Yeah, but that was when OTS maps sucked too.
__________________ '08 Polar White Saturn SKY Redline - "The RAWRmobile" BorgWarner EFR 6758 + IWG Mani, forge v2 BPV, Energy Full Suspension Bushings, GMPP 3-Bars, Vibrant Racing Catted HiFlow Downpipe, WERKS Boost Tubes, Intake, Power-Steering Relocation Kit, Radiator Hoses, and Race FMIC, Koni Yellows + Eibach Pro-Kit's, RPi GT CBE, HP Tuner SquishyTooned on E40, RK Sport Rotors/Pads, DDMWorks 2-gauge Pillarpod and Armrest, Prosport HALO Electronic Wideband and Boost Gauges, Spec Stage 2+ Clutch + Fidanza Single-Mass FryWhee, XTUNERS Gauge Cluster, GM Roadster.com HID/LED Full Exterior and Interior Light Conversion Dyno: Uhh... fast as hell?'08.0 Cosmic Blue MS3 - "The Daily" STOCKED OUT (almost) COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install Dyno: 319 / 331CWP_MS3 is my mackdaddy | |
| The Following User Says Thank You to Eric28243 For This Useful Post: | Lex (10-01-2012) |
| Not Ranked : 0 score Yeah, but its not really about which map he was on because he was on the same map for both the before and the after dyno pull. Its about the gains between the two pulls with nothing different except for the gutted cats and the colder plugs.
| The Following User Says Thank You to JacksonMS30 For This Useful Post: | btstarcher (10-27-2012) |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Neutral : +1 score i will say i have no numbers / vids just tons of racing experience with the downpipes. myself and 2 friends were all bolted (same intakes / testpipes-catbacks) with e85 blends (50/50) and of course had to establish who had the fastest mazda in the group. I have the catted ultimate racing downpipe, my buddy Aaron has the ATP i believe it is catless DP and Jeff had stock. honestly, we were all so close that 95% of the time it just came down to whoever actually pushed the gas first won, however consistently we saw maybe two things. Aarons car being catless did tend to have a slightly stronger top end from time to time, typically when it was warmer or more humid and the turbos were being pushed harder, makes sense. Jeffs car on the stock downpipe could not match Aaron and i on the hit, he would fall behind by maybe a nose / half a car at best and would hold there the continuation of the run. i would give the downpipe more of a torque gain than horsepower gain after seeing how different cars have responded, but being that we were all on E85 and that gives you such massive torque anyways, it is a bit biased. We were all also tuned by the same guy so the tunes were damn near identical. Just my little tidbit
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following 6 Users Say Thank You to Voltwings For This Useful Post: | atvfreek (10-01-2012), AZSPEED3 (10-01-2012), Easter Bunny (10-01-2012), Lex (10-01-2012), Menace1 (01-30-2013), Pseud0logik (10-01-2012) |
| Not Ranked : 0 score Yeah, you have a point. I think you may be right. And since I'm nearly certain the leaning afr's for highway cruising does not produce any added mileage (tried it a billion times with different tuning approaches and most others feel the same that the gain is negligable unless you're very attentive to your speed/load/temps/windows up or down/air conditioner, etc) the added heat that would destroy stock cats is unnecessary as well. I will truthfully say I do believe a torque advantage exists, as 3rd gear is much easier to spin now that I have no cats. I noticed this as I left the garage where the generous fayetteville folks helped me out. I was already running a very aggressive e85 dyno self-tune that I didn't change after the downpipe. Let's not forget the overwhelming advantage being able to hear the turbines at low RPMs has on one's confidence/self esteem.
| The Following 3 Users Say Thank You to Eric28243 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score 27 whp difference from gutting the dp is hard to swallow. It would be nice to know what his boost, timing, etc. were doing in bioevlove's case. Edit: it also looks like bioevolve gutted both cats at the same time. In the scenario above, the car already had a race pipe. The response and low end torque are of course improved as the turbine can be accelerated at a higher rate without a cat/with an aftermarket DP.
| Not Ranked : 0 score also went from 53% humidity in the 1st run to 31% in the 2nd run...denser air charge makes more power and can probably account for some of the HP gain...if we are talking uncorrected numbers....I didn't follow the link. air temp can make a difference as well.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score Lex, which 3" intake to you recommend?
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
(Thread Starter) | Not Ranked : 0 score Without bringing specific brands into the discussion: - Bigger is better in this case but keep in mind you can only fit a 3" down to the turbo without relocating the ECU. - Air filters make a difference so whatever intake you have on there, a high flowing filter will help out. You can PM me for more specific details if you like.
| The Following User Says Thank You to Lex For This Useful Post: | mike w (01-07-2013) |
Groans: 63
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." | |
| Not Ranked : 0 score my 3.5 JBR was super easy to dial in and idles like OE...other parts of my motor are preventing me from quantifying the gains.
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Easter Bunny (10-01-2012), Menace1 (01-30-2013) |
Groans: 63
| Not Ranked : 0 score did you previously have a 3" intake or typical sri? I'm not saying that the JBR one is too big, I'm just wondering if there's any gain from it over a cp-e or sure full 3".
(Thread Starter) | Not Ranked : 0 score You can probably be fine idling a 4" but it's hard to find and fit on the intake side. You can also run blow through with some customization and just a filter on the turbo inlet ... again if you can fit it.
| The Following User Says Thank You to Lex For This Useful Post: | Nliiitend1 (10-02-2012) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score This seems like it should be a really old thread... but there's totally a reason for it and I'm surprised it's not all been addressed at once. Probably would've made a different decision besides COBB for intake products, but I didn't intend to do much more than that... of course. Then one thing led to another... Then again I think there are definitely worse options.
![]() | | #25 | ![]() |
| Not Ranked : 0 score well for the longest time the a DP was considered THE mod to really wake the car up there were very little options for big intakes on stock turbos (read none) and the BT guys that were using them didnt notice anything because well....BT im glad it got a revisit....changing an intake is soooo much less of a pain in the ass than the DP |
| The Following User Says Thank You to TRex For This Useful Post: | Nliiitend1 (10-02-2012) |
![]() | | #26 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score @Lex; Have you ever tuned someone with a Corksport DP? I like the divorced design, but does it offer anything over a bellmouth design in this application?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
| The Following User Says Thank You to sidekick For This Useful Post: | magicka (01-07-2013) |
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
Groans: 47
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #29 | ![]() |
Actually if i'm not mistaken, the corksport one doesnt even separate the turbine / wastegate because the hotside isnt shaped in a way that makes this possible. Basically you're blending air now through two different pipes... would almost think it would be worse o_O pretty sure its covered in a thread somewhere though before someone takes my speculation for fact.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #30 | ![]() |
![]() Join Date: Oct 2012 Location: Long Beach, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 255
| Not Ranked : 0 score with a downpipe and TUNE. I picked up some good ponies....peak hp was a little more but the main thing is power didnt fall off as much after 5500 rpms.
__________________ Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned. Freektuned e85 Focus st as the daily. |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score There is a little lip on the flange to separate the 2. I personally prefer a car bellmouth for longevity but very heavy duty steel and solid welds would do as well.
| The Following 6 Users Say Thank You to Lex For This Useful Post: | magicka (01-09-2013), Menace1 (01-30-2013), Nliiitend1 (01-09-2013), Pseud0logik (01-09-2013), sidekick (01-30-2013), Voltwings (01-09-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/does-downpipe-make-difference-126226/ | ||||
| Club de Usuarios de Mazda ? Ver Tema - Downpipe mazda 3 mps | This thread | Refback | 08-08-2014 02:51 AM | |
| Ver Tema - Downpipe mazda 3 mps | This thread | Refback | 05-11-2014 09:35 PM | |
| 3.5" intakes come at me bro | This thread | Refback | 04-29-2013 06:43 AM | |
| Difference Between Testpipe, Racepipe and Downpipe | KevinWP | 2010 MS3 - Engine, Transmission & Driveline | 31 | 08-02-2012 03:23 PM |
| GM CFO races to 'make a difference' before 'window' shuts | Haltech | Automotive News | 0 | 07-20-2012 10:10 PM |
| Street Unit Boost tubes make a difference? | jwilson0514 | Mazdaspeed3/6 General Discussion | 16 | 05-16-2011 07:46 PM |
| VIDEO: How much of a difference does a few mph make? | Haltech | Automotive News | 0 | 12-29-2009 03:40 PM |
| Buy a Great RX-7 - Make a Difference | Haltech | Automotive News | 0 | 12-05-2008 12:20 PM |
