E-Tuners / Custom Hardparts
Like Tree21Likes
 Old 04-27-2014, 01:16 PM   #41
AndyW716's Avatar
Posts: 16   (View Stats)
AndyW716 is a jewel in the roughAndyW716 is a jewel in the roughAndyW716 is a jewel in the roughAndyW716 is a jewel in the rough
Groaned at 35 Times in 5 Posts
I'm in the market soon to start adding some more go-fast toys to my Gen 2 (TMIC, HPFP internals, and AP...already have a CS intake/TIP), and messaged CS regarding running stage 1 vs stage 2 maps.
I was advised NOT to run stage 2 maps without upgrading my downpipe. I've had good experience with CS in the past, and everybody on here seems to agree that Spencer's the man, so I'd hate to believe that advising me to upgrade the DP was a sales tactic.
I can only assume that at 300+ whp, the cars of the posted dyno graphs are running tunes at least as aggressive/with at least as much boost as the stage 2 maps would.
Sooooo....why can't I run stage 2 on a stock DP? I'm not trying to max out the car and run as much boost as is possible...but, I'd like a little more gain than I've seen from stage 1 tunes/setups.
AndyW716 is offline   Reply With Quote
The Following User Says Thank You to AndyW716 For This Useful Post:
Mike@Stratified (04-27-2014)
The Following User Says NO Thank You to AndyW716 For This Un-useful Post:
jack_hammer (05-19-2014)
 Old 04-27-2014, 01:28 PM   #42
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
You need fuel pump internals before you worry about anything else
The Following 3 Users Say Thank You to timmcc02 For This Useful Post:
Elvisrosales88 (04-28-2014), himurax13 (06-04-2014), Mike@Stratified (04-27-2014)
 Old 04-27-2014, 01:37 PM   #43
speed23's Avatar
Posts: 1,480   (View Stats)
You absolutely can run stage 2 without a full downpipe as long as you have internals. May just have to tweak wastegate values a bit.
Also, the maps being run in the OP are WAY WAY more agressive and would be running a ton more timing that a stage 2 map. They are safe because those guys are running e85 blends.
The Following 2 Users Say Thank You to speed23 For This Useful Post:
AndyW716 (04-28-2014), Mike@Stratified (04-27-2014)
 Old 04-27-2014, 04:20 PM   #44
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
The basic requirements for most stage 2 maps are HPFP internal and omission of 1 catalytic converter. Get a test pipe and you don't have to replace the DP to meet that requirement. I can't speak to CS's OTS maps however, so if you want to run their map, you need to do what they say I suppose.
The Following 2 Users Say Thank You to Mike@Stratified For This Useful Post:
AndyW716 (04-28-2014), himurax13 (06-04-2014)
 Old 04-27-2014, 08:00 PM   #45
macdiesel's Avatar
Posts: 825   (View Stats)
Awesome info stratified, especially since I'm new to the mod path and the risks of a dp install made me weary. Now I know. Thanks lex and mike.
 Old 04-28-2014, 10:07 AM   #46
jdspeed3's Avatar
Posts: 966   (View Stats)
jdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the world
Here are my logs from ENM, BNR on 93, as promised.
2011 Black Mica Mazdaspeed3
Autotech Internals//BNR S3//JBR 3' Intake//Cobb EBCS//3 Bar w/ PnP Harness//UR-CS TBE//CPe RMM//CXRacing FMIC//TurboXS BPV//NGK Iridium IX
BNR S3 numbers coming soon
277 WHP/327 WTQ (93) Moore 2013
jdspeed3 is offline   Reply With Quote
The Following User Says Thank You to jdspeed3 For This Useful Post:
Mike@Stratified (04-28-2014)
 Old 04-28-2014, 10:50 AM   #47
ihasmazda's Avatar
Posts: 1,011   (View Stats)
Everyone seems to only look at the peak numbers, but no one really mentions the power curves. After I installed a catted CS DP last week I noticed a big difference in power at lower RPM. Now I can hear and feel the turbo spooling up just after 2000rpm (about 400 rpm sooner than before) which lets me keep the car in a higher gear while cruising and made it a lot better to drive conservatively as I don't have to downshift as much. Maybe it's more due to a stg1 to stg2 map change, but the overall feel of the power delivery is significantly improved, even if the peak numbers may only be slightly increased. I guess if all you're looking for is drag racing power then it might not be worth it, but I'm blown away how much better the car drives normally, not to mention the increase in power when WOT.
It would have been interesting to observe the difference if I had gotten an e-tune before the DP install to determine just how much of the gain was map vs DP, but with a DP planned I wasn't going to spend money on an e-tune beforehand.
my two cents
EcKid1974 likes this.
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
The Following 3 Users Say Thank You to ihasmazda For This Useful Post:
12blkms3 (04-28-2014), 86AmishMs3 (04-30-2014), bshotts422 (05-19-2014)
 Old 04-28-2014, 11:27 AM   #48
mazdaspeeding's Avatar
Posts: 260   (View Stats)
mazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the world
Groaned at 8 Times in 4 Posts
Originally Posted by Mike@Stratified View Post
It is true that there are a lot of inexpensive options out there for a long catless DP, and the quality of some is pretty good. Adding a cat though, for those of us that have to deal with emissions, adds cost. For me the 8hp difference just wasn't worth the trouble or money. For someone debating about upgrading to a 3-3.5" intake versus a DP, or an upgraded IC versus a DP, I think this will help make decision a bit easier.
Incidentally, whenever I get around to strapping my BNR on the car I plan to see how far I can push the OEM DP and CBE before upgrading as well
^^This. I am planning on doing the same thing. BNRS3 with the stock DP a TP and stock Cat-back. I understand an aftermarket DP would help but I still expect to achieve noticeable gains running a TP only. What do you expect from this combo? (Personally, I'm looking for a slight increase in power, but more specifically to stretch it out further over the rpm band and negate the instant TQ plateau that the tiny KO4 delivers and the resulting loss of traction in 2nd and 3rd when I hammer it. Basically, I expect to go much faster with only a minimal peak increase in power but by bringing in the TQ slower and pulling harder, longer up top.)
mazdaspeeding is offline   Reply With Quote
The Following User Says Thank You to mazdaspeeding For This Useful Post:
 Old 04-28-2014, 11:31 AM   #49
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
I'd be a test car if mike wants to through in a free e-tune. Lol.
I'm currently rocking the testpipe and next month have plans to buy the CPE Downpipe and I'm debating the MagnaFlow CBE. But for testing purposes I'd be willing to hold off on the cbe.
@Mike@Stratified; you guys still offer fluff tunes? It would be great to get real comparisons and on a street car running pump gas.
Big Dog is offline   Reply With Quote
 Old 04-28-2014, 11:47 AM   #50
omgvance's Avatar
Posts: 1,221   (View Stats)
Great write up @Mike@Stratified;
Partnered with DeftMotion
deftmotion.com
2013 Mica Black Pu
Performance
Suspension
Ricer Shit
 Old 04-28-2014, 12:35 PM   #51
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
I think sometimes people get confused about what we mean by DP. Being that most (I assume) go with a full "long" DP when they upgrade, they see a jump in power from the stock DP AND TP. Your comparison is between just a TP and full catless DP's. From the people I've talked to, they understand that the majority of the benefits come from getting rid of the second cat. I'm afraid people are going to look at this, fail to read more than the title and assume both a DP and TP are worthless.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following 2 Users Say Thank You to chaser27 For This Useful Post:
JgamB (05-19-2014), yourname2221 (05-24-2014)
 Old 04-28-2014, 12:37 PM   #52
youngwonder's Avatar
Posts: 147   (View Stats)
youngwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond repute
I just bought a full CP-E catless DP from somebody. I'm glad I got a brand name DP for an excellent price, but I'm sure I would be just as happy with one from ebay. I really would like to get on a dyno before it's installed.
08 Mazdaspeed3
Hypnotic Tuned: e85
BNR s3 v2
AEM Meth Kit 100% Meth w/ DO10 (not using now)
Accessport V3
DNP Exhaust Manifold
Corksport Exhaust
JBR OCC s2
TR8 FMIC
CPE RMM Stage 2
HTP 3" Full Intake
Autotech Internals
CP-E downpipe - Catless
JBR short throw shifter
JBR shift knob
Corksport short shift plate
SS brakelines
Koni Yellow
H&R Springs
Low beam headlights - HID 6000k
Fog lights - HID 6000k
youngwonder is offline   Reply With Quote
 Old 04-28-2014, 12:46 PM   #53
jbmazda6's Avatar
Posts: 1,230   (View Stats)
I will be looking into the differences in a dp as well. There will be before and after dynos and I will try to have the same ambient temps. Here is the link to the thread i created. There will be more comparisons done as well. JB's Journey with JBR and Stratified
 Old 04-28-2014, 01:03 PM   #54
Big Dog's Avatar
Groans: 89
Every test is on "E" I would love to see just pump gas results.
The Following User Says Thank You to Big Dog For This Useful Post:
 Old 04-28-2014, 01:54 PM   #55
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
Everyone seems to only look at the peak numbers, but no one really mentions the power curves. After I installed a catted CS DP last week I noticed a big difference in power at lower RPM. Now I can hear and feel the ...
The OP has complete dynos from all cars and the curves are virtually identical. He didn't just post peak numbers. The differences are so minor that it wouldn't change your "seat of the pants" experience.
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
The Following User Says Thank You to jseams For This Useful Post:
Playaj (04-28-2014)
 Old 04-28-2014, 02:09 PM   #56
chaser27's Avatar
Groans: 42
We need stock, TP only and full DP curves. I think we all agree that the margin between TP and DP isn't all that great. The difference is in the second cat
ECU: self-tuned
The Following User Says Thank You to chaser27 For This Useful Post:
 Old 04-28-2014, 03:32 PM   #57
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
looks like my catless long dp will be staying in the garage until I swap the turbo lol. I'll be happy at 300awhp w/ a test pipe until my stock turbo shits the bed
08 cwp ms3
 Old 04-28-2014, 06:17 PM   #58
ABOSWORTH's Avatar
Posts: 467   (View Stats)
I've been looking forward to this post. Thanks Mike! Coming from the WRX platform where a DP is one of the best mods you can add, I naturally planning on getting one as one of my first mods. I'm glad I like to read because I saw the Lex thread and many other posts saying that the DP isn't as great of an upgrade on this platform.
Current Mods
 Old 04-28-2014, 07:19 PM   #59
EcKid1974's Avatar
Posts: 34   (View Stats)
EcKid1974 will become famous soon enoughEcKid1974 will become famous soon enough
I too just put in the CS DP and it has the catted RP on it and I can tell the difference in power I can only imagine what a tune and e85 would do for me. Even after reading this thread I would still get a DP I love it and the install wasn't as bad at least for me.
EcKid1974 is offline   Reply With Quote
 Old 04-28-2014, 07:28 PM   #60
The other things to remember is that if you install a DP and you don't adjust the tune, the boost response and overall boost will change (go up).
The sheets Mike posted however are cars that were tuned to as much as they could make in each configuration.
BigjohnB20 (05-14-2014)
 Old 04-28-2014, 08:13 PM   #61
Fjager's Avatar
Posts: 246   (View Stats)
Fjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the world
I didn't see a STOCK dp vs upgraded DP at same boost levels comparison. With all the info and data on downpipes it seems like power under the curve is the real benefit of a DP. The graphs in the first article show that g/s was held higher for longer than the catted one. Even though max g/s was only 5 at the top end, in the middle it was much more than that.
2013 White Pearl MS3
JBR SSP/bushings/RMM/EGR delete
Corksport 3ID Intake/Radiator
Cobb APV3/AT Internals
Grimmspeed 3 port EBCS/Matt Damond CC
FMIC W/DIY Sprayer
CPE DP
Fjager is offline   Reply With Quote
 Old 04-28-2014, 09:33 PM   #62
scubasteve711's Avatar
Posts: 1,238   (View Stats)
Groans: 70
eventually when I have the chance, I'll post up the differences for my car - I've had an ebay pipe in my basement for a year now probably. I've been pretty lazy about putting the DP in because I know its going to be a good bit of work for a questionable gain over already having the TP. Personally i'm more looking forward to getting a meth kit put together and installed...
Great post and thread!
07' Speed6 Velocity Red Mica
scubasteve711 is offline   Reply With Quote
 Old 05-14-2014, 01:28 PM   #63
bigspender's Avatar
Posts: 854   (View Stats)
bigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the world
Groaned at 46 Times in 21 Posts
I went stock dp and test pipe. I am getting an etune and will post up my #s when done.
bigspender is offline   Reply With Quote
 Old 05-14-2014, 02:05 PM   #64
Jtaylor's Avatar
Posts: 656   (View Stats)
I will still take my catless DP over stock any day considering how it felt after install.
08 MazdaSpeed3
The Following User Says Thank You to Jtaylor For This Useful Post:
mxlplx71 (05-16-2014)
 Old 05-15-2014, 08:43 PM   #65
iammike's Avatar
Posts: 1,415   (View Stats)
I'm in it for the sounds. lol Oh, and the smell...and fire spitting...and and leaving clouds for people behind me!
memin likes this.
Mike
The Following 4 Users Say Thank You to iammike For This Useful Post:
Easter Bunny (05-19-2014), Mike@Stratified (05-16-2014), MS3inDC (05-21-2014), mxlplx71 (05-16-2014)
 Old 05-16-2014, 12:11 PM   #66
Jtaylor's Avatar
Exactly. All of these people claiming increasing flow for turbos make's no difference it spool time or power. SMH
08 MazdaSpeed3
 Old 05-16-2014, 12:22 PM   #67
chaser27's Avatar
Groans: 42
I'm confused? Trolling?
ECU: self-tuned
 Old 05-16-2014, 12:35 PM   #68
If you have proof to counter my claim in the original post, please share. The dynos in the OP tell the story on power. As for your other comment, you might be the first person ever that I've seen concerned about spool time with a K04.
Sent while Stratified.
jseams likes this.
The Following 3 Users Say Thank You to Mike@Stratified For This Useful Post:
himurax13 (06-04-2014), MechEnix (06-02-2014), Playaj (05-16-2014)
 Old 05-16-2014, 12:37 PM   #69
iammike's Avatar
I would rather that bitch spool a little slower...at least at the low RPM's. lol WTB tracshun.
Mike
The Following 2 Users Say Thank You to iammike For This Useful Post:
himurax13 (06-04-2014), Mike@Stratified (05-16-2014)
 Old 05-16-2014, 12:38 PM   #70
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
this is a good post to keep these things fresh.
however, i thought it has been long established that the differences between a stock DP & test pipe and a catted DP are negligible. and, on top of that, the differences between a catted DP and a catless were exaggerated.
maybe i'm assuming new members read old posts.
glad to see a refresher with quantifiable numbers included in a single post. i respect stratified for their recurring efforts of putting out informative-only posts without selling something.
keep it up!
it's fun to do bad things
Easter Bunny (05-19-2014), jseams (05-20-2014), Mike@Stratified (05-16-2014)
 Old 05-16-2014, 12:42 PM   #71
chaser27's Avatar
Groans: 42
The only thing I worry about is that with so many full DPs on the market. People are going to read the title of this thread and assume the test pipe doesn't make a difference either.
This I don't care about until they start trying to spread misinformation to others.
ECU: self-tuned
The Following 3 Users Say Thank You to chaser27 For This Useful Post:
Easter Bunny (05-19-2014), JgamB (05-19-2014), [R]usty (05-16-2014)
 Old 05-16-2014, 04:00 PM   #72
Raider YOLO'd my mom
spdandpwr's Avatar
Posts: 965   (View Stats)
spdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the world
Wish this was done on the same car. Not that my anecdote is scientific, but as someone who when from a @superskaterxes; tune with intake, sri, and cbe to that same tune with a catless dp and step lower sparkplugs, I felt a huge difference. To gauge the difference, I used a car race as my control. Before I was neck and neck. After catless dp, I pulled a car length with each gear. After a revised tune, I pulled slightly harder still.
Sold: 2013 Mazdaspeed 3 Tech
JBR PowerPath Stage 2 Intake // JBR "Trilogoy" 70a Mounts // Autotech Fuel Pump Internals // Magnaflow 3" Cat-back Exhaust // Cobb AccessPort v3 // Ultimate Racing Catless DP // Ultimate Racing Catless Testpipe // RichTune
Current: 2015 Ford Focus ST
When in fear, drop a gear and disappear
spdandpwr is offline   Reply With Quote
 Old 05-19-2014, 06:47 AM   #73
Jtaylor's Avatar
Yeah give me a few seconds
08 MazdaSpeed3
 Old 05-19-2014, 08:52 AM   #74
Groans: 549
wait, so you contacted corksport to find out what OTS tune you should run on your cobb tuner?
Easter Bunny (05-19-2014), himurax13 (06-04-2014), WetzMS3 (10-07-2015)
 Old 05-19-2014, 09:54 AM   #75
Groans: 70
You all are convincing me to put my DP on... For the sake of logs...
Currently running a just a TP with stock DP off the turbo.
The Following User Says Thank You to scubasteve711 For This Useful Post:
 Old 05-19-2014, 10:06 AM   #76
Jtaylor's Avatar
You won't regret it.
08 MazdaSpeed3
 Old 05-19-2014, 10:18 AM   #77
jbmazda6's Avatar
I will have legit dyno backed info soon. Cpe full catted dp has been ordered.
The Following 3 Users Say Thank You to jbmazda6 For This Useful Post:
Easter Bunny (05-19-2014), jack_hammer (05-19-2014), Mike@Stratified (05-19-2014)
 Old 05-19-2014, 05:38 PM   #78
I'd love to see your data.
No doubt he won't regret it. I'm not arguing that installing a DP is something people will regret, I'm arguing that it isn't the end-all-be-all mod that some people make it out to be.
If you can get before and after logs in similar conditions on the same road I'd be really interested in seeing them.
Last edited by Mike@Stratified; 05-19-2014 at 05:38 PM. Reason: MSF Database - Automerged Doublepost
btstarcher (05-20-2014), Easter Bunny (05-19-2014), himurax13 (06-04-2014)
 Old 05-19-2014, 06:20 PM   #79
bshotts422's Avatar
Posts: 183   (View Stats)
bshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond repute
I have to Cobb dp with the speed daddy cb and I love it. Car sounds amazing as long as you don't mind some noise. I fucked up by not getting tuned right away and think that helped caused my ko4 to shit out. But shit happens and we learn. Now I have have a BNR S3 on and doing my tune with @Lex; now. Really looking forward to the numbers I'll be getting. @JgamB; is running similar setup and got to take a ride in his car and I was very impressed.
BNR S3 V2, Cork Sport TMIC, Cobb Down pipe, Speed Daddy Cat Back, Auto Tech fuel internals, Cobb AP V3, Cobb TIH, K&N SRI, Cobb RMM, Cobb 3 port, Bosch 3 bar, Cork Sport BPV, Cork Sport hood struts, MD SSP, NGX one step colder plugs, Nitto Invo 235/40zr18, and Guarded by an Angel.
Stratified tune with 3/9 E85 mix.
Waiting to install MD OCC
Up next: Cork Sport 3" intake and WMI
bshotts422 is offline   Reply With Quote
The Following 3 Users Say Thank You to bshotts422 For This Useful Post:
JgamB (05-19-2014), Lex (05-19-2014), Mike@Stratified (05-19-2014)
 Old 05-19-2014, 06:25 PM   #80
xx5PEEDxx's Avatar
Posts: 113   (View Stats)
xx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the worldxx5PEEDxx is the leader of the world
Subbed
Silver 2013 w/ Tech -- CorkSport Intake / CorkSport Turbo Inlet Pipe / CorkSport CatBack Exhaust / CorkSport Race Pipe / Go Fast Bits Respons BOV / H&R Coilovers / H&R 15mm Spacers / Cobb Shift Knob / 33% Suntech Cermaic Tints w/ 18% rear hatch / Escort Passport 9500ix / Corksport Stubby Antenna / Xexon Yellow 3000k HID fogs / Head light Armor Yellow Fog Light Covers / LED Parking Lights and License Plate Lights / STI Limited Lip / Bayson Motor Sports Rear lip / Auto Tech Internals / Cobb Access Port v3
xx5PEEDxx is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/does-downpipe-make-difference-part-2-a-169390/
[ALL STATES] Forum Beginners Thread - Page 2 This thread Refback 07-04-2014 05:54 PM
Ver Tema - Downpipe mazda 3 mps This thread Refback 05-12-2014 03:41 AM
Larger intercoolers don't make a difference? Nevoie Gen2 MS3 General Discussion 19 11-11-2013 11:20 PM
Does a downpipe make a difference? Lex Stratified Automotive Controls 31 01-09-2013 08:40 AM
Difference Between Testpipe, Racepipe and Downpipe KevinWP 2010 MS3 - Engine, Transmission & Driveline 31 08-02-2012 03:23 PM
VIDEO: How much of a difference does a few mph make? Haltech Automotive News 0 12-29-2009 03:40 PM
Buy a Great RX-7 - Make a Difference Haltech Automotive News 0 12-05-2008 12:20 PM
Page generated in 0.58118 seconds with 47 queries
