E-Tuners / Custom Hardparts
Like Tree21Likes
 Old 05-19-2014, 06:35 PM   #81
bshotts422's Avatar
Posts: 183   (View Stats)
bshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond repute
BNR S3 V2, Cork Sport TMIC, Cobb Down pipe, Speed Daddy Cat Back, Auto Tech fuel internals, Cobb AP V3, Cobb TIH, K&N SRI, Cobb RMM, Cobb 3 port, Bosch 3 bar, Cork Sport BPV, Cork Sport hood struts, MD SSP, NGX one step colder plugs, Nitto Invo 235/40zr18, and Guarded by an Angel.
Stratified tune with 3/9 E85 mix.
Waiting to install MD OCC
Up next: Cork Sport 3" intake and WMI
bshotts422 is offline   Reply With Quote
 Old 05-19-2014, 06:49 PM   #82
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
You need a ; after
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following User Says Thank You to chaser27 For This Useful Post:
bshotts422 (05-19-2014)
 Old 05-20-2014, 03:23 PM   #83
scubasteve711's Avatar
Posts: 1,238   (View Stats)
Groans: 70
Originally Posted by Mike@Stratified View Post
If you can get before and after logs in similar conditions on the same road I'd be really interested in seeing them.
I'll try to incorporate some fixes into the tune for any over boosting before I do the DP so that I can do a 1:1 on the tune. I'll definitely do a before and after!
07' Speed6 Velocity Red Mica
scubasteve711 is offline   Reply With Quote
 Old 05-20-2014, 05:51 PM   #84
btstarcher's Avatar
Posts: 4,852   (View Stats)
Wonder where that data is..... @Jtaylor;
SnailTune in progress
chaser27 (05-20-2014)
 Old 05-21-2014, 06:46 AM   #85
Jtaylor's Avatar
Posts: 656   (View Stats)
Give me a second
08 MazdaSpeed3
 Old 05-21-2014, 01:02 PM   #86
MS3inDC's Avatar
Posts: 3,070   (View Stats)
MS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the world
Groaned at 56 Times in 37 Posts
Originally Posted by spdandpwr View Post
Wish this was done on the same car. Not that my anecdote is scientific, but as someone who when from a @superskaterxes; tune with intake, sri, and cbe to that same tune with a catless dp and step lower sparkplugs, I felt a huge difference. To gauge the difference, I used a car race as my control. Before I was neck and neck. After catless dp, I pulled a car length with each gear. After a revised tune, I pulled slightly harder still.
I'm gonna give Ant the benefit of the doubt and say that he just pushed your tune further after you had mods to support it. Ant is a very careful tuner.
I was one of the first to have a Superskaterxes RichTune, and with every revision the car pulled harder. He's tuned me from intake and internals only all the way to fully bolted, and with each revision the car came alive more and more. At this point and power level, all that he can do is "change the curve" unless I run some form of alcohol or go BT.
cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp
jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob
ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com
311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM]
12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14]
I would wear a pink unicorn shirt, and still call someone a faggot. Since when did MSFers begin to give fucks?...
MS3inDC is offline   Reply With Quote
The Following User Says Thank You to MS3inDC For This Useful Post:
spdandpwr (05-28-2014)
 Old 05-28-2014, 04:31 AM   #87
Mfinlay04's Avatar
Posts: 827   (View Stats)
I did my DP solely for more WGDC head room. I was maxed out 95-99% even with my 3 port EBCS and only gettings 16 psi over 5.5k. Since my dp i've been able to hold a little more boost towards redline, but a k04 is gonna be a k04
2006 MS6 Titanium Grey
Tuned with
 Old 05-28-2014, 07:18 AM   #88
btstarcher's Avatar
Still waiting LOL
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
chaser27 (06-23-2014), yourname2221 (05-29-2014)
 Old 06-04-2014, 12:19 PM   #89
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Another reason I love my OBX exhaust, $510 shipped for the whole TBE, and everything was awesome.
 Old 06-23-2014, 04:58 AM   #90
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
@Lex; I know you've talked about using cats to prevent the stock turbo from smoking, but wouldn't this be contrary to that? You talk about how well the oem cat flows so wouldn't that mean it is really just covering up the smoke rather than provide an increase in back pressure to keep it from smoking? I'm not trying to call you out, just looking for some clarification.
In my experiences my car used to slowly sip on oil when I had the stock dp and after I threw my catless dp on it still slowly ate oil, the only difference being that now I see smoke.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 06-23-2014, 07:43 AM   #91
iammike's Avatar
Posts: 1,415   (View Stats)
Any cat will provide some extra back pressure. How much I wouldn't begin to be able to tell you.
Also, yes, I believe a cat does more to mask the smoke than actually stopping the problem in the first place. That's just my opinion though.
Mike
 Old 06-23-2014, 10:16 AM   #92
It's a little bit of both. There is definitely more back pressure with a cat versus without a cat. Then smoke might be cleared up a bit more with having a cat in the way as well. The purpose of the cat is to covert CO to CO2 and it will do little to actually prevent the smoke from exiting the tail pipe once it is burned. The backpressure is preventing the pressure differential between the CHRA and turbine housing from being too large in turn preventing some of the oil from exiting the CHRA and burning in the first place.
The more effective methods to stop smoking is to increase vacuum at the crankcase (Mazdas OEM fix) run a higher idle to get higher vacuum, and run a thicker oil.
Snip (06-23-2014)
 Old 06-23-2014, 11:06 AM   #93
Yatta's Avatar
Posts: 1,862   (View Stats)
I get a deal on a CPE catted dp and now wonder if it was because of this post having a gutted stock secondary already wondering if I should wait, which brings me to my second question, a catted/long DP (elimination of second cat) should weigh less then the stock combo? how much less? these comparisons are for dyno results but that might not be the whole picture? I suppose if I install it I could weigh it and weigh the DP/TP combo it replaces.
 Old 06-23-2014, 11:14 AM   #94
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Definitely not enough to make a difference. That's splitting hairs.
Sent from my SAMSUNG-SGH-I777 using Tapatalk
 Old 06-23-2014, 12:33 PM   #95
Snip's Avatar
Posts: 329   (View Stats)
And upgrade the oil restriction bolt to one with a smaller diameter hole (on the stock k04 that is) so lesser oil goes to the turbo.
I believe damond motorsport sells them
Stock turbo, oil restrictor banjo bolt
MazdaSpeed3 GT '07
AccessPort V2 Self tuned
 Old 06-23-2014, 01:16 PM   #96
If the problem can be resolved without restrictors I prefer this. I like the CHRA to get as much oil as possible without having it end up on the turbine side.
chaser27 (06-23-2014), ItsNox (07-14-2014), Snip (06-24-2014)
 Old 07-09-2014, 10:11 AM   #97
El Beaner's Avatar
Posts: 4,262   (View Stats)
I want to thank you @Mike@Stratified
I was on the fence a lot between getting a TP vs a full DP - then had a local mention this post and it solidified my decision and I went TP only.
SOLD 2012 LSM Tech - 11/17/17
The Following 4 Users Say Thank You to El Beaner For This Useful Post:
btstarcher (07-09-2014), InkedInspector (07-09-2014), Lex (07-09-2014), Mike@Stratified (07-09-2014)
 Old 07-09-2014, 10:29 AM   #98
anodizedeeznutz's Avatar
Posts: 2,796   (View Stats)
anodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the world
@Undertaker;
2013 CWP Mazdaspeed3 - SOLD
2014 Mitsubishi Evo X - time for some fun.
anodizedeeznutz is offline   Reply With Quote
The Following User Says Thank You to anodizedeeznutz For This Useful Post:
Undertaker (07-09-2014)
 Old 07-10-2014, 09:17 AM   #99
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
I've had a similar experience since adding my Axleback as well.
With a full DP and axleback, my k04 isn't even trying very hard to hit load targets at redline (especially on pump).
So yes, powerwise you might not gain much, but having the extra headroom on the stock turbo is nice. I don't really know if not having to use the full wastegate decreases load on the turbo, but it makes me feel better lol.
Edit: The Corksport ABE has no muffler though so it is definitely loud.
2012 Velocity Red Mica
 Old 07-10-2014, 10:51 AM   #100
iammike's Avatar
Neutral  +1 score
You sissies running catalytic converters and stock downpipes are missing out on the fun of scaring Prius drivers at WOT.
Mfinlay04 and Jtaylor like this.
Mike
 Old 07-10-2014, 11:13 AM   #101
El Beaner's Avatar
Coal Rolling is better
Mfinlay04 likes this.
 Old 07-10-2014, 11:22 AM   #102
Cheapspeed's Avatar
I still dump with my high flow cat and not just at tip in.
 Old 07-10-2014, 12:12 PM   #103
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Meh, I am over that.
Pickles Tune in progress
jack_hammer (07-15-2014)
 Old 07-31-2014, 08:22 PM   #104
Cheapspeed's Avatar
So.. @Mike@Stratified; @Lex; and @jbmazda6;
We should be seeing a dyno comparison with tuned stock dp vs tuned cpe catted dp yes?
 Old 08-01-2014, 01:20 AM   #105
himurax13's Avatar
Groans: 255
On the same car?
 Old 08-01-2014, 04:43 AM   #106
Cheapspeed's Avatar
On the same car?
Yes.
 Old 08-01-2014, 07:44 AM   #107
btstarcher's Avatar
@jbmazda6; did you guys do any before and after dyno comparisons?
 Old 08-01-2014, 08:14 AM   #108
jbmazda6's Avatar
Posts: 1,230   (View Stats)
Im hopping on the dyno saturday. We will have to determine what significant gains are. I would say 15+hp to even make it worth buying. Thats just my opinion though and I believe I will achieve that Saturday. I will be writing up a full review of everything in my journey thread and will post up just an answer here.
We will also have to look at differences in temperature and humidity. Even though the dyno "corrects" for that, the car still runs differently in different weather (not a boost based tune) so that will have to come into consideration.
Thank you everyone (who is interested) for being patient.. the time has almost come.
The Following 2 Users Say Thank You to jbmazda6 For This Useful Post:
JgamB (08-01-2014), Lex (08-01-2014)
 Old 08-01-2014, 11:42 AM   #109
We were able to get better stability before knock with the DP installed so the knock threshold was pushed out further. We will see the exact comparisons very soon.
btstarcher (08-01-2014), Easter Bunny (08-02-2014)
 Old 08-01-2014, 11:58 AM   #110
himurax13's Avatar
Groans: 255
Does the stock dp in this conparison have a race pipe?
 Old 08-01-2014, 12:01 PM   #111
jbmazda6's Avatar
No, full stock exhaust
 Old 08-01-2014, 12:17 PM   #112
himurax13's Avatar
Groans: 255
So both the cats then? I think it would make more sense to have a racepipe/nator midpipe installed since that is the easier/cheaper option than a full downpipe install. Not to mention you should remove a cat in order to use a stage 2 OTS tune.
jseams (08-01-2014)
 Old 08-01-2014, 12:20 PM   #113
nb6179505's Avatar
Posts: 348   (View Stats)
nb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond reputenb6179505 has a reputation beyond repute
But effectively tp with oem cat is comparable to long catted dp stage 2 ots should be attainable
nb6179505 is offline   Reply With Quote
 Old 08-01-2014, 12:52 PM   #114
Cheapspeed's Avatar
Cpe replaces both oem cats with 1 high flow cat.
 Old 08-01-2014, 12:55 PM   #115
jbmazda6's Avatar
The title of this thread is "does a downpipe make a difference", all but ONE of the options for the speed6 is a long downpipe so replacing the downpipe generally means replacing both cats. Its not saying whether a test pipe or downpipe is better. I have an opinion on that but dont feel like even touching on it until I see the numbers saturday.
The Following User Says Thank You to jbmazda6 For This Useful Post:
 Old 08-01-2014, 01:06 PM   #116
himurax13's Avatar
Groans: 255
Well downpipes usually eliminate both cats or replaces one of them with a high flow cat. So if the purpose of this test is to compare a stock downpipe and midpipe to an aftermarket downpipe with no cats or one high flow cat, I suspect that a 15 HP difference will be seen and I doubt anyone will disagree with that.
Most of the arguements I have had involves a stock downpipe + race pipe/NATOR midpipe vs any aftermarket downpipe, catted or not on a stock turbo.
Seriously, who is going to tune with both stock cats in the car?
jseams likes this.
The Following 5 Users Say Thank You to himurax13 For This Useful Post:
adamizme (08-01-2014), chaser27 (08-05-2014), Easter Bunny (08-02-2014), jseams (08-01-2014), Neverlift (08-01-2014)
 Old 08-02-2014, 05:49 AM   #117
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
I have seen dyno charts that show a stock dp/gutted test pipe can make comparable power to a full catless dp. Not the same car, day, weather, and moon cycle, but the results were there just the same.
They are buried in old threads, though, and I'm not going to search for them.
it's fun to do bad things
 Old 07-07-2015, 09:47 PM   #118
AnubisFSU's Avatar
Posts: 117   (View Stats)
AnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond repute
So... What happened to all these test results.
2010 Mazdaspeed3 Tech
JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings
Cobb Accessport v3 / XLE BPV / Cobb Knob
Damond Motorsports License Plate Tow Mount / EGR Delete
Ultimate Racing Test Pipe
Autotech Fuel Pump Internals
CP-E XFlex Stage2 RMM
Stratified Stage 3 93oct OTS+
AnubisFSU is offline   Reply With Quote
 Old 07-07-2015, 10:54 PM   #119
JgamB's Avatar
Posts: 2,566   (View Stats)
With so many people going to mid turbos, I can offer some data that won't mean much to the K04 crowd. Better than nothing I spose...
Same dyno, similar mid ~70F temps for all pulls. The E85 K04 setup was 68mm intake and test pipe only. The BNR S3 pulls were Gutted UPPER DP and stock test pipe vs ATP long catless. The results were impressive - so I would use the same train of thought we typically use for intakes - if you might go bigger later, you may as well go full 3" out the hiney now, unless you're concerned about expediting K04 seal failure.
dale_gribble likes this.
The Following 4 Users Say Thank You to JgamB For This Useful Post:
AnubisFSU (07-08-2015), chaser27 (07-08-2015), Cheapspeed (07-08-2015), WetzMS3 (10-07-2015)
 Old 07-08-2015, 09:59 AM   #120
Cheapspeed's Avatar
I'm stuck around 320whp on my 3076. High flow cat, resonated testpipe, and stock catback. Also, low compression in cylinder 3. But I'm definitely leaning towards opening up the catback now. I keep reading that I'm leaving about 15hp on the table, which seems to line up with your numbers.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/does-downpipe-make-difference-part-2-a-169390/
[ALL STATES] Forum Beginners Thread - Page 2 This thread Refback 07-04-2014 05:54 PM
Ver Tema - Downpipe mazda 3 mps This thread Refback 05-12-2014 03:41 AM
Larger intercoolers don't make a difference? Nevoie Gen2 MS3 General Discussion 19 11-11-2013 11:20 PM
Does a downpipe make a difference? Lex Stratified Automotive Controls 31 01-09-2013 08:40 AM
Difference Between Testpipe, Racepipe and Downpipe KevinWP 2010 MS3 - Engine, Transmission & Driveline 31 08-02-2012 03:23 PM
VIDEO: How much of a difference does a few mph make? Haltech Automotive News 0 12-29-2009 03:40 PM
Buy a Great RX-7 - Make a Difference Haltech Automotive News 0 12-05-2008 12:20 PM
Page generated in 0.57127 seconds with 43 queries
