E-Tuners / Custom Hardparts
Like Tree21Likes
 Old 07-08-2015, 11:20 AM   #1
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
Thats it... I am selling my brand new Corksport Downpipe I got coated with ceramic... just gotta get to 150 posts!
 Old 01-20-2017, 07:06 AM   #2
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Originally Posted by Mike@Stratified View Post
Food for thought:
Vdyno from 09 juan-
Both oem cats
OEM tmic
4" htp intake
E25-E30
AFR line has lb/min data in it.
-feejay
-wetzel
 Old 01-21-2017, 08:48 AM   #3
macdiesel's Avatar
Posts: 825   (View Stats)
That's a tasty morsel @zenit;
zenit (01-22-2017)
 Old 01-21-2017, 11:51 AM   #4
Posts: 2,826   (View Stats)
It seems most of the people claiming a 3" downpipe produces no gains on the K04 are running E25 or other higher ethanol fuel and ethanol specific tunes.
That data may not translate to the same conclusion for those of us who do not have ready access to ethanol blends and are running pump gas 93 octane.
On pump 93 I experienced significant gains with a 3" catless dp/rp, a CAI intake and a modest tune, reaching 300/300. That's about all you can squeeze out of the stock turbo without adding more ethanol.
My datalogs support a significant gain from increased exhaust side flow upstream (3" dp and rp) when limited to pump gas and the stock turbo.
 Old 01-21-2017, 12:24 PM   #5
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
The comparison here is catless downpipe/testpipe vs catless testpipe only. Of course there are gains to be found by removing either of the cats (particularly the second) over stock exhaust; the question is how much additional gain do you see by also deleting the first cat after already having deleted the second.
Genpoo stuff
The Following 2 Users Say Thank You to sharksinspace For This Useful Post:
btstarcher (01-21-2017), MSMS3 (01-24-2017)
 Old 01-21-2017, 12:51 PM   #6
But, the comparisons being made are with E25 or higher tunes. I'm saying the extra cylinder cooling effect of more ethanol, allowing higher boost and timing at leaner AFR must be accounted for. The extra ethanol is letting the higher boost at redline max out the turbo anyway.
On pump gas, we can use the extra exhaust side flow to increase lower - not as well as higher ethanol, but better than with stock dp/rp.
 Old 01-24-2017, 06:33 AM   #7
Forgive me for seeming or being dense. I realize the comparison being made. My point is that the comparison is on cars running higher ethanol blends. I believe that for those of us running pump gas, adding the catless downpipe helps us more than those running ethanol blends, because you are already close to maxing out the K04. We need the extra exhaust side flow to compensate for the greater cylinder cooling, higher boost at redline without knock you are getting from the extra ethanol.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
sharksinspace (01-24-2017), WetzMS3 (01-24-2017)
 Old 01-24-2017, 07:01 AM   #8
Groans: 126
Nah man, I dig it; maybe my undies were bunched that day to be such a nitpicker. I totally agree with you about wanting to see this same comparison done on pump gas tunes; even if the final conclusion is the same, it'd be nice to know for certain.
Genpoo stuff
MSMS3 (01-27-2017)
 Old 01-21-2017, 01:04 PM   #9
Groans: 126
But you talked about how you saw gains by going to 3" DP/TP together, which, well...obviously. The discussion at the heart of this thread is how much additional gain was it versus just a 3" catless TP. I'd also be curious to see a 93 comparo in addition to the E mixes, I'm just taking umbrage with the way you're relating it to your jump from stock exhaust to a 3" long DP, having skipped the step in between of running only the TP.
Genpoo stuff
 Old 01-22-2017, 09:03 AM   #10
zenit's Avatar
Groans: 57
I agree with you on this. Tuning 93 is a different beast, and is far more sensitive to heat, and I can imagine that anything you can do to help move the exhaust charge away from the combustion chamber (i.e. removing restrictions) would help remove heat, too.
The comparison here is catless downpipe/testpipe vs catless testpipe only. ..... the question is how much additional gain do you see by also deleting the first cat after already having deleted the second.
The no cat vs 1 cat debate was the purpose of this thread; however, based on my data above I'd like to propose a followup question- with a K04, E mix and a large intake- can you keep the exhaust stock (both cats) and see comparable power numbers with those who have 1 or 0 cats?
I think what @Lex; has said earlier in the thread supports this idea:
.... the k04 can't be spun much faster regardless, and the majority of the pumping losses come from the small turbo hotside and turbine.
^ that's not to say there are no gains with going test pipe/downpipe on the K04&E mix, but I'm thinking that the stock exhaust pieces (both cats) can create a hotside pressure differential sufficient to spin the turbine/compressors wheel up to and maintain maximum wheel speed through the engine rev range (3-6.5k) @ 100% WGDC.
In short- I'm suggesting that due to the smaller size of the housing and turbine wheel, the K04 doesn't necessarily need a much larger hotside pressure differential created by replacing or removing OEM exhaust components.
I think that there's some evidence too with @JgamB;s post with the BNR which has a larger turbine wheel- and maybe a K04 based hotside, depending on which version it is. He saw substantial gains not seen in this thread's K04 comparison from upgrading to aftermarket catless DP, particularly at the top end of the rev range. Perhaps the larger turbine wheel needs a larger hotside pressure differential to maintain wheel velocity at the top end?
With my work on the modified K04- which is using a ported hotside and a larger turbine wheel, I'm beginning to believe that I may have to uncork the exhaust a bit (a larger hotside pressure differential) to get maximum speed/flow from the turbine wheel at the top end of the rev range.
-feejay
-wetzel
sharksinspace (01-22-2017), WetzMS3 (01-24-2017)
 Old 01-23-2017, 02:38 PM   #11
There are 2 things to consider.
1. Pumping losses. The easier it is to get exhaust out, the less power you lose doing so. This is a bit of a moot point on turbo cars as the turbo acts as a really big restriction.
2. Pressure differential across the turbine. The higher the differential the more energy you can put into spinning the turbo. This means higher turbo speeds and response times. This is where most see gains - with a catless setup the pressure differential across the downpipe increases and allows you to put more energy into the turbo.
MSMS3 (01-24-2017), zenit (01-23-2017)
 Old 01-29-2017, 11:42 AM   #12
MS3Zoom24's Avatar
Posts: 317   (View Stats)
MS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond reputeMS3Zoom24 has a reputation beyond repute
So on the topic of this thread.
I have all mods that are in my sig and feel that my little K04 pulls really good.
Self tuned to 19.5 tapering to 17 @6k I typical Via AP show peak about 20.2 with 308g/s, Now from reading this thread it seems like I'm flowing really good?, NO?
Anywho I was debating on getting DP, but doesnt seem it is worth it. Going to get A CNT CBE cause I want it for sound, but My question is IF I upped my Intake to 3-3.5 MAF It seems I would pick up more power g/s Per second but would that also drop my WGDC since it would be flowing more g/s making Boost Achieved more Easily?
Does that sound about right?
Also trying to find a local e85 but having trouble finding one. since that seems to be some very easy power made
Thanks
08.5 MS3
Cobb AP-ATR tune; AEM CAI; COBB TIP; Test Pipe; PG piping/GS FMIC; AT Internals; HKS SSQV; Denso ITV22s; SURE counter weight; Cobb RSB; Swift spec R springs; Koni Sports; SU RMM, shifter bushings; Hankook Ventus V12 EVO 2
Team Beachbody Coach, Contact me to get started
GF2revolution.com
MS3Zoom24 is offline   Reply With Quote
 Old 01-29-2017, 01:50 PM   #13
joecg1996's Avatar
Posts: 15   (View Stats)
joecg1996 is an unknown quantity at this point
so confused as to why people buy such expensive downpipes. i got mine for 125 and it does the same thing :/
joecg1996 is offline   Reply With Quote
 Old 01-29-2017, 03:06 PM   #14
nindoja's Avatar
Posts: 2,395   (View Stats)
Because not all downpipes are the same. Different flange designs, different fitment, different ease of install.
joecg1996 likes this.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
sharksinspace (01-29-2017)
 Old 01-29-2017, 03:19 PM   #15
Groans: 126
Could be wrong, but I believe the Corksport DP is the only one that offers a 'divorced' design; so if that's someone's preference, they have to pay a bit more for it than an ebay special.
Genpoo stuff
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/does-downpipe-make-difference-part-2-a-169390/
[ALL STATES] Forum Beginners Thread - Page 2 This thread Refback 07-04-2014 05:54 PM
Ver Tema - Downpipe mazda 3 mps This thread Refback 05-12-2014 03:41 AM
Larger intercoolers don't make a difference? Nevoie Gen2 MS3 General Discussion 19 11-11-2013 11:20 PM
Does a downpipe make a difference? Lex Stratified Automotive Controls 31 01-09-2013 08:40 AM
Difference Between Testpipe, Racepipe and Downpipe KevinWP 2010 MS3 - Engine, Transmission & Driveline 31 08-02-2012 03:23 PM
VIDEO: How much of a difference does a few mph make? Haltech Automotive News 0 12-29-2009 03:40 PM
Buy a Great RX-7 - Make a Difference Haltech Automotive News 0 12-05-2008 12:20 PM
Page generated in 0.43370 seconds with 29 queries
