| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
I think I'd be ok going up from 2.60 load to 2.70, killing it at 7000rpms. I also think that it's just a tiny bit over 2.60 is where I'm getting the cut. I'd like to see if anyone else has an idea on this. or to help explain to me the detrimental side effects of upping the load another .1 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Was hitting boost cut, upgraded MAP, now I'm getting load cut. Eventual goal = 22PSI with no cutting at all. only really want 350-360 AWHP. Need to know if it's OK upping my load cut threshold from 2.6 to 2.7, and what the side effects of doing so would be. (as far as fueling issues or stresses on certain components. I know all eventually leads to boom, but i'd like a little explanation on what parts are stressed.) THANKS!
__________________ Last edited by p057; 08-09-2012 at 11:00 AM. |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score Do you have any logs of the problem happening? Tapa
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
Groans: 220
(Thread Starter) | Not Ranked : 0 score At home, i'll upload them tonight. But everything looks good, just tipping into load cut at 2.59 (cut set at 2.6) My AP is old, so it logs slower, but you can still see it. fuel, BATs, trims, everything shows OK. Just the load max is being reached so it kicks the car back with fuel cut. or, what would cause load to go up when basically nothing really changed on the car, with the exception of a little higher ambient heat and some E85 in the tank?
__________________ Last edited by p057; 08-09-2012 at 07:28 AM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 566
| Not Ranked : 0 score if you tuned for e85 using a maf cal that could do it, also if you have a boost cut and the guardian angel, just set your max loads to unattainable limits, bingo bango done
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
| The Following User Says Thank You to speedms6 For This Useful Post: | smoogs12 (08-09-2012) |
Groans: 220
(Thread Starter) | Not Ranked : 0 score No tune for e85, just a couple gallons mixed in to reduce knock at high temps. LTFTs are around 0.12% at higher throttle input, about 6% (negative i think?) at idle. So it's really close and im not worrying about it. Knock prevention is awesome. so nothing to worry about with ... for example 2.8 or 3.X level loads? I do have the GA and boost cut will be set to 25. I really dont want to go too high on torque, since that's what really kills the motors (or so i've been told )
__________________ |
| Not Ranked : 0 score raise your load cut limits above the max you see by .2. boost cut is more important then load cut anyway but you still want both of them somewhat close to what you actually see. P.S. why diddent u just go back to @Lex for help?
Groans: 220
If I bugged him for every dumb question I had, he'd probably ignore me. I thought I'll save it for the real important ones. ![]() Figured someone would be bored at work and have an answer
__________________ | |
im sure he would have been more then willing to help you. he does have his own vendor section now which you could make a thread and ask him for some quick map changes because of the problems you were experiencing. its not like you were asking for a retune, just some advice on how to get rid of your cut.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following User Says Thank You to superskaterxes For This Useful Post: | p057 (08-09-2012) |
| Not Ranked : 0 score Contact me anytime with tuning issues as Anthony mentioned. Post up in my section or drop me an e-mail with a log. Adjusting load cuts is very easy.
| The Following 5 Users Say Thank You to Lex For This Useful Post: | atvfreek (08-11-2012), Boosted Beluga (08-09-2012), p057 (08-09-2012), smoogs12 (08-09-2012), superskaterxes (08-09-2012) |
Groans: 220
(Thread Starter) | Not Ranked : 0 score OK, so then can a mod move this thread into ST's subforum? I'll attach log(s) tonight. I've already altered the map to go up to 2.70. I'll change it so it goes up to 2.80 when i get some time. I just wanted to know if it was ok to do so, and it looks like it is so I am good. We'll see how the car likes it.
| Not Ranked : 0 score moved
| Not Ranked : 0 score Here's the best way to do this. Please email me with the map you are running now and a log with said map. Tell me which Stratified map yu started from and what changes you made. I will look at all this and if it just needs a load cut bump I will get that done right away. If you have other goals in mind or changes just write me and let me know and we will discuss these to see how to best achieve them. Sent from Stratified Mobile Headquarters
| The Following User Says Thank You to Lex For This Useful Post: | atvfreek (08-11-2012) |
Groans: 220
(Thread Starter) | Not Ranked : 0 score ok, sending to you in a few mins. today was awful, and now knock is showing up with it...
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 1301 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
| Not Ranked : 0 score Yee do what lex says, if you just bump up load too high, boost and everything will go nuts!
__________________ Sold: 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Brakes: CorkSport Pads; Centric Blanks Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Official 60-100mph Times Official Video battles Official Youtube Channels
:-( 2014 - Dodge Dart.. (Blue Turtle) | |
Groans: 220
(Thread Starter) | Not Ranked : 0 score I'm figuring a major thing I need to do is change out spark plugs. I have about 40k on these Denso ITV22s. What do you guys think? Go with the NGKs? or ITV22s again OR try the ITV24s for two-step? I don't think i'm making enough horsepower for it, but I want to see what you guys think before I put an order in for it.
| The Following User Says Thank You to Lex For This Useful Post: | p057 (08-12-2012) |
Groans: 220
(Thread Starter) | Not Ranked : 0 score Going on my hunch about the spark blowout... Ordered new NGK plugs and started installing. quickly took a look at old Denso ITV22s, show nice signs of wear in my opinion, even if a little hot. 4-3-2-1 Well... gaps on the old plugs were all fairly even... but they were at ~.033 each... wow, lots of erosion after a few years and 40k miles. Very possible that this explains my dips of power. No wonder it was so spotty, has to be spark blowout :\ Regapped the new NGK plugs to ~.027 Installed everything back up and fired car up, it's happy so far. Haven't gone test driving yet. Haven't eaten today. going to do that soon and post back results. --EDIT--- OK, tested over a 40 mile drive. Other than the extreme heat today causing my BATs to be stuck around 120 (and was unable to get E85 ) and giving me points of knock here and there, the "cutting" feeling is completely gone. Smooth pull in 5th gear from 70-120 MPH. That used to mean positively getting cut, now it's gone. awesometimes.Waiting until tonight when the temps go down to try it out some more. maybe if i get some E later in the week, i'll be able to do some longer and harder pulls with logs. Too nervous to install meth just yet, even though my kit is due to arrive on Monday.
__________________ Last edited by p057; 08-19-2012 at 02:18 PM. |
| The Following User Says Thank You to p057 For This Useful Post: | Lex (08-19-2012) |
| Not Ranked : 0 score Those plugs are definitely gapped too wide and worn out. Good choice on new plugs.
Groans: 220
Once I get the nerve to install the meth, i'l let you know for a retune, @Lex. Thanks
| The Following User Says Thank You to p057 For This Useful Post: | Lex (08-20-2012) |
| The Following User Says Thank You to Lex For This Useful Post: | p057 (08-20-2012) |
Groans: 220
(Thread Starter) | Not Ranked : 0 score Just out of curiosity, what do you think of the condition of the plugs? they look almost identical in real life as those photos, just a little more of a pinkish/tan hue. if they are indeed a little "hot" looking, what can I do to combat it? 2-step colder is overkill, but anything else I can do?
| Not Ranked : 0 score What makes you think they are hot looking? For heat you look at the strap and see where the blue marks are. From just the pics they don't look too hot.
Groans: 220
If you think they're OK, then cool. Been turning up my boost after i had to drop it to around 16psi. around 21.5ish now. absolutely no pulling back or any other bad feelings of before. Only thing i'm seeing is a little more knock (friggen heat) and my AFRs going lower than i've ever seen them before. Usually they're around tens at the lowest, but now i've seen mid nines. I'm sure this really isn't an issue. Just wanted to bring it up and see if you had a comment. Otherwise, i'll just consider it OK.
![]() | | #24 | ![]() |
Glad the hesitation is gone though.
| BPV Experiences | ak_spray | MazdaSpeed 3/6 - Turbo Induction | 45 | 04-07-2011 11:54 AM |
| Experiences with Xcarlink? | event | MazdaSpeed 3/6 - Car Audio & Electronics | 2 | 03-27-2011 03:26 AM |
| My Dyno experiences 09 MS3 | C!ph3r | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 28 | 11-24-2010 03:55 PM |
| Dashdyno Experiences | Super Unique | MazdaSpeed 3/6 - ECU Computer Tuning | 26 | 05-21-2010 02:58 PM |
