E-Tuners / Custom Hardparts
 Old 02-28-2014, 07:10 PM   #1
SaveMelMac's Avatar
Posts: 485   (View Stats)
Default GA stuck in VTA mode??
It appears my GA is stuck in VTA mode. Get the two led blinks at start up and a solid light at idle. Tried numerous times to switch to the normal mode. Followed the directions word for word with still no change. I disconnected GA, applied 12volts to blue wire and then reconnected GA, then removed blue wire after 2 seconds. Any insight would be great. Thanks
 Old 03-01-2014, 10:13 AM   #2
SaveMelMac's Avatar
Nevermind problem solved.
The Following User Says Thank You to SaveMelMac For This Useful Post:
Lex (03-01-2014)
 Old 03-01-2014, 05:49 PM   #3
What was the issue?
HU stuck sega_rt MazdaSpeed 3/6 - Car Audio & Electronics 0 06-14-2013 11:32 AM
Stuck on my next upgrades Cashin Mazdaspeed3/6 General Discussion 14 08-05-2012 09:08 AM
tcs light stuck on turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-26-2010 06:30 PM
stuck shifter Jake_MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 12-13-2009 09:08 AM
Page generated in 0.24138 seconds with 21 queries
