| View Poll Results: Would you buy the Guardian Angel? | |||
| Yes - no more overboost fears! | | 141 | 92.16% |
No ... | | 12 | 7.84% |
| Voters: 153. You may not vote on this poll | |||
![]() | | #281 | ![]() |
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score
I will be wiring this thing up next weekend(hopefully). The safeinject sends out a 12v signal when it detects flow rate drops below a preset point. I have a toggle switch override on the pump so i can simulate a "low flow" event and see how long it takes for the safeinject to react and then the GA to react on top of that and pop the valve. this should be fun ![]() I think that completes the full safety circle at that point. aaaand next month my motor will just blow for no reason whatsoever.
__________________ | |
| The Following User Says Thank You to p057 For This Useful Post: | Lex (02-15-2014) |
![]() | | #282 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | p057 (02-15-2014) |
![]() | | #283 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score If it has just a ground trigger, can't you put a relay in and convert it to a 12v trigger?
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
![]() | | #284 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes this is the simplest solution.
![]() | | #285 | ![]() |
Groans: 220
| Not Ranked : 0 score if it has a ground trigger, yeah, i'll do a relay to switch it. oh how I love relays and more wiring in the car.... :/ Thanks guys.
![]() | | #286 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score Can anyone outline how to wire a relay to take a +0.5V trigger and convert it into a +12V signal the GA can handle?
__________________ ![]() [SIGPIC][/SIGPIC] |
![]() | | #287 | ![]() |
| Not Ranked : 0 score 0.5V or 5V?
| The Following User Says Thank You to theurgy For This Useful Post: | hnda etr (02-27-2014) |
![]() | | #288 | ![]() |
| Not Ranked : 0 score Here's some good info for you: FAQ: RELAYS; how they work and how to wire it up...
![]() | | #289 | ![]() |
(Thread Starter) | Not Ranked : 0 score I will try and do a simple diagram. You want a single pole, single throw relay.
| The Following User Says Thank You to Lex For This Useful Post: | hnda etr (02-27-2014) |
![]() | | #290 | ![]() |
Groans: 90
| Not Ranked : 0 score 0.5 V
Thanks again!
__________________ ![]() [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to hnda etr For This Useful Post: | Lex (02-27-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/gi-guardian-angel-overboost-protection-104486/ | ||||
| Mazda MPS Owners Club • View topic - Overboost protection... | This thread | Refback | 03-25-2012 04:24 AM | |
| The Guardian Angel for your motor | Lex | Stratified Automotive Controls | 158 | 10-28-2015 12:55 PM |
| Angel Eyes? | Sparky_86 | MazdaSpeed 6 - How-To's | 26 | 05-20-2010 04:58 PM |
| Angel Eyes | TXspeed3 | MazdaSpeed 3/6 - Appearance | 2 | 06-28-2009 08:36 PM |
| Angel Eyes Ballast | kingpin748 | Mazdaspeed3/6 General Discussion | 0 | 04-20-2009 04:53 PM |
