E-Tuners / Custom Hardparts
  • 1 Post By Lex
 Old 06-18-2012, 01:19 AM   #1
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Default Guardian Angel BPC compatibility.
I just found out that my HKS SSQ is not compatible with the Guardian Angel. I am looking for the best performing BPV for a BNR Stage 3 setup. The Forge BPV seems to be the only compatible one for sure. I need to know what else is compatible so the I can place my order at edgeautosports asap for my upcoming Turbo Build this saturday.
Please Help!!
Pickles Tune in progress
 Old 06-18-2012, 01:23 AM   #2
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Groans: 179
the forge should do you just fine, i think any "push" type blow off valve/bypass valve will work, just not a pull type like the HKS, worse comes to worse just instalall of your parts except your gaurdian angel until your new valve comes in, then instal it
ZOOM ZOOM BOOM
 Old 06-18-2012, 02:56 AM   #3
3mazdaspeed's Avatar
Posts: 485   (View Stats)
3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world
or trade me for my forge
3mazdaspeed is offline   Reply With Quote
 Old 06-18-2012, 09:21 AM   #4
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
Lex just reviewed the Turbosmart no? Said that worked like a charm. Or am i confused.
dantes5823 is offline   Reply With Quote
 Old 06-18-2012, 09:26 AM   #5
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
My forge works great with the bnr. Blue + 2 shims. Not sure about it's compatibility with GA although it should work fine as a Push type valve like Hamilton said.
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
 Old 06-18-2012, 10:02 AM   #6
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
@Lex
 Old 06-18-2012, 11:19 AM   #7
himurax13's Avatar
Groans: 255
I like the bone stock looks of the Forge but I am also looking at the Cobb and the Turbosmart ones as well. I sent Lex a message already but he is a busy guy.
 Old 06-18-2012, 12:10 PM   #8
Zbrit00x's Avatar
Posts: 541   (View Stats)
Just swap someone for a forge and be done with it if you want everything installed at once . Either the v1 or v2. Both hold boost well and differ in sound. I'm running the v2 with my GA right now and it's perfect. You installing at nator?
You could always ask someone with other push type valves to check for you too by using the test method in the install PDF
2010 ms3-sold
ww evo x -385/360
Zbrit00x is offline   Reply With Quote
 Old 06-18-2012, 12:18 PM   #9
himurax13's Avatar
Groans: 255
Unfortunately the NATOR day is the same day that I had planned on doing my turbo build with RamiLP. We are going to start the install at the buttcrack of dawn because we will be doing the following installs all at once:
BNR Stage III
CS Boost Tubes
CS SRI & TIP Stage 2
JBR Stage II Oil Catch Can
JBR Thermal Insulating Gaskets
Possibly a TS, Cobb, or Forge BPV
Guardian Angel EBC
3 Bar MAP Sensor
Injector Studs and Seals
Grimspeed EBCS
 Old 06-18-2012, 12:29 PM   #10
Zbrit00x's Avatar
I can't go to nator anymore and install my bt since I have to go to work. Let me know how the install goes so when I get a chance to do mine il be prepared! And which seals did you go with
2010 ms3-sold
ww evo x -385/360
 Old 06-18-2012, 12:38 PM   #11
himurax13's Avatar
Groans: 255
Well it will either be a success or an epic fail. I am actually bribing RamiLP (who used to be a real mechanic) so I expect a higher level of success than the typically boozed up auto weekend mechanic.
I just went with the Toyota Seals.
I am sure there will be a build thread posted by this time next week.
 Old 06-18-2012, 06:32 PM   #12
Zbrit00x's Avatar
Be sure to include many pictures!
2010 ms3-sold
ww evo x -385/360
 Old 06-18-2012, 06:50 PM   #13
himurax13's Avatar
Groans: 255
Well I may be able to get pictures. However don't expect me to know what exactly is going on.
 Old 06-18-2012, 07:40 PM   #14
Sorry for all the confusion. The GA works with ANY PUSH type BPV or BOV. These valves are designed so that boost PUSHES against the valve piston trying to open it. The piston is therefore facing the charge piping.
See the picture attached.
 Old 06-18-2012, 08:37 PM   #15
himurax13's Avatar
Groans: 255
So is there a list of BOV/BPV that is not a Push Type variety?
I am glad I did some research today because the VTA Mod for the GA is going is probably going to make a lot of people happy.
 Old 06-18-2012, 09:04 PM   #16
The HKS is the one that is the most common. Synapse might be as well but I have not tested that particular valve while I have tested the HKS and it is not compatible.
himurax13 likes this.
 Old 06-19-2012, 03:32 PM   #17
himurax13's Avatar
Groans: 255
I see you are going BT.
Did you buy all of the support equipment that you will need? I have been selling and purchasing stuff for weeks to get ready for this weekend. I just hope the delivery guys don't fail me.
 Old 06-19-2012, 10:13 PM   #18
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Woah man! We have done like 6 BT at Nator without any problems. We ain't REAL mechanics too.
But whatever works for you.
And as for 3 bar MAP you need if you want to be able to log above 22.xx psi.
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
The Following User Says Thank You to TRSpeed For This Useful Post:
lilred (06-19-2012)
 Old 06-20-2012, 08:44 AM   #19
himurax13's Avatar
Groans: 255
I wasn't talking about the NATOR folks, I was referring to my local talent that has helped me keep my 00 Protege alive for 12 years .
Hmm, I don't think it would be right to impose a BT build on the SoCal Nator crew at the last second. Do you think they would have the time?
If I don't hear back from my motorcycle mechanic, I might have time to redo my brakes, brake lines, and instal my CS Tip & SRI at the upcoming NATOR.
 Old 06-21-2012, 03:00 AM   #20
Liquid3Speed's Avatar
Posts: 110   (View Stats)
Liquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant futureLiquid3Speed has a brilliant future
The synapse bpv should work with it as it can be used in push or pull configurations, all you have to do is swap the adapters around. But this is hypothetical not tested.
Cobb AP // Cobb SRI // Cobb TIP // Autotech Internals // Synapse BPV // JBR 88a // H&R Springs
Liquid3Speed is offline   Reply With Quote
The Following User Says Thank You to Liquid3Speed For This Useful Post:
Lex (06-21-2012)
 Old 07-08-2012, 05:12 PM   #21
FistPump20fo7's Avatar
Posts: 88   (View Stats)
FistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the worldFistPump20fo7 is the leader of the world
I emailed Forge asking about their V2 valve and confirmed it is a pull type valve; part of the redesign in order to change the sound of the pressure release. What confuses me is your success with the GA with the v2 valve @Zbrit00x
2011 VR Non-tech Speed3
e30 Stratified tuned
Michelin Pilot Super Sports - Cobb AP v3 - AT Internals - Cobb DP - HTP 3" Intake - CP-E Safe Seals/studs - MD OCC - EGR self made B/O - JBR IM & TB TIGs - JBR Battery Tray -TB Coolant Bypass - JBR SSP/Shifter Anchors - Turbosmart Dual Port - Stratified GA - CP-E TMIC - Denso ITV22 - SpeedPerformance VC Breather - Bnoon Spec BB - TRS Bi-Xenon Retrofit - JBR RSB - Moog endlinks - Misc other shit
FistPump20fo7 is offline   Reply With Quote
 Old 07-09-2012, 12:32 AM   #22
Zbrit00x's Avatar
Though it was a push style since the spring pressure is keeping the valve closed while the pressure on the valve and vacuum assisting it is pushing the valve open. Maybe @Lex can shed some light on this. Regardless it is working flawlessly for me.
2010 ms3-sold
ww evo x -385/360
The Following User Says Thank You to Zbrit00x For This Useful Post:
Lex (07-09-2012)
 Old 07-09-2012, 12:44 AM   #23
I don't have drawings or a Forge V2 to take a look at how it functions. That being said the proof is in the pudding. If Zayn has tested the GA with that BPV and it works ... it works.
Another test you can perform is to pull the vacuum line from the back of the valve and see if will hold boost. If it leaks under boost and won't hold boost, it will work with the GA.
@Zbrit00x, what does your boost pressure drop to when the GA activates?
 Old 07-09-2012, 12:52 AM   #24
I just found a picture of the Forge V2 taken apart.
It should work fine with the GA. This is not a true pull type BPV as the piston is not held closed by boost like it is on the HKS.
 Old 07-09-2012, 05:54 AM   #25
Thanks for clearing this up Lex
 Old 07-09-2012, 06:10 AM   #26
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Im debating whether or not to switch my synapse DV to push type and try the GA..
The Guardian Angel for your motor Lex Stratified Automotive Controls 158 10-28-2015 12:55 PM
Guardian Angel help? MS6FL Mazdaspeed3/6 General Discussion 2 04-28-2012 07:13 PM
How To: fine tune your guardian angel dooderek Stratified Automotive Controls 2 04-02-2012 07:40 PM
How-To Install Guardian Angel Dano Stratified Automotive Controls 5 03-31-2012 03:04 PM
Guardian Angel Install the_rolex_guy Stratified Automotive Controls 7 03-25-2012 06:03 AM
Page generated in 0.44872 seconds with 31 queries
