![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
(Thread Starter) | Not Ranked : 0 score Please Help!!
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
| COOL STORY BRO ![]() Join Date: Nov 2010 Location: Cape Girardeau Mo/San Diego CA
Rep Power: 2238 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,863
Groans: 179
| Not Ranked : 0 score the forge should do you just fine, i think any "push" type blow off valve/bypass valve will work, just not a pull type like the HKS, worse comes to worse just instalall of your parts except your gaurdian angel until your new valve comes in, then instal it
__________________ ![]() JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley ZOOM ZOOM BOOM |
![]() Join Date: Jun 2010 Location: APO AE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
| Not Ranked : 0 score or trade me for my forge |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
Groaned at 52 Times in 48 Posts
| Not Ranked : 0 score Lex just reviewed the Turbosmart no? Said that worked like a charm. Or am i confused. |
![]() Join Date: Jul 2010 Location: Little Rock, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,444
| Not Ranked : 0 score My forge works great with the bnr. Blue + 2 shims. Not sure about it's compatibility with GA although it should work fine as a Push type valve like Hamilton said.
__________________ BNR S3 // E85 Mix // Freektune 348tq/367whp -21.5 psi Now - 25-26 psi + JBR 3.5 Intake Last edited by ckMS3; 06-18-2012 at 10:05 AM. |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score @Lex
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
Groans: 255
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() Join Date: Feb 2011 Location: Irvine,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
| Not Ranked : 0 score Just swap someone for a forge and be done with it if you want everything installed at once . Either the v1 or v2. Both hold boost well and differ in sound. I'm running the v2 with my GA right now and it's perfect. You installing at nator? You could always ask someone with other push type valves to check for you too by using the test method in the install PDF
__________________ 2010 ms3-sold ww evo x -385/360 |
Groans: 255
BNR Stage III CS Boost Tubes CS SRI & TIP Stage 2 JBR Stage II Oil Catch Can JBR Thermal Insulating Gaskets Possibly a TS, Cobb, or Forge BPV Guardian Angel EBC 3 Bar MAP Sensor Injector Studs and Seals Grimspeed EBCS
| Not Ranked : 0 score I can't go to nator anymore and install my bt since I have to go to work. Let me know how the install goes so when I get a chance to do mine il be prepared! And which seals did you go with
Groans: 255
![]() I just went with the Toyota Seals. I am sure there will be a build thread posted by this time next week.
Be sure to include many pictures!
__________________ 2010 ms3-sold ww evo x -385/360 | |
Groans: 255
(Thread Starter) | Not Ranked : 0 score Well I may be able to get pictures. However don't expect me to know what exactly is going on.
| Not Ranked : 0 score Sorry for all the confusion. The GA works with ANY PUSH type BPV or BOV. These valves are designed so that boost PUSHES against the valve piston trying to open it. The piston is therefore facing the charge piping. See the picture attached.
Groans: 255
I am glad I did some research today because the VTA Mod for the GA is going is probably going to make a lot of people happy.
| Not Ranked : 0 score The HKS is the one that is the most common. Synapse might be as well but I have not tested that particular valve while I have tested the HKS and it is not compatible.
Groans: 255
Did you buy all of the support equipment that you will need? I have been selling and purchasing stuff for weeks to get ready for this weekend. I just hope the delivery guys don't fail me.
![]() Join Date: Jul 2011 Location: hesperia, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 295
But whatever works for you. And as for 3 bar MAP you need if you want to be able to log above 22.xx psi. Sent from my DROID4 using Tapatalk 2
__________________ 2008.05 True Red Mazdaspeed3 Lex Tuned GTX3071r | 38mm Tial WG | Hallman MBC Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod | Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM | Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs | |
| The Following User Says Thank You to TRSpeed For This Useful Post: | lilred (06-19-2012) |
Groans: 255
. Hmm, I don't think it would be right to impose a BT build on the SoCal Nator crew at the last second. Do you think they would have the time? If I don't hear back from my motorcycle mechanic, I might have time to redo my brakes, brake lines, and instal my CS Tip & SRI at the upcoming NATOR.
![]() Join Date: Mar 2012 Location: Burlington, WI
| Not Ranked : 0 score The synapse bpv should work with it as it can be used in push or pull configurations, all you have to do is swap the adapters around. But this is hypothetical not tested.
__________________ Cobb AP // Cobb SRI // Cobb TIP // Autotech Internals // Synapse BPV // JBR 88a // H&R Springs |
| The Following User Says Thank You to Liquid3Speed For This Useful Post: | Lex (06-21-2012) |
![]() Join Date: Jul 2011 Location: Levittown, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 209
| Not Ranked : 0 score I emailed Forge asking about their V2 valve and confirmed it is a pull type valve; part of the redesign in order to change the sound of the pressure release. What confuses me is your success with the GA with the v2 valve @Zbrit00x
__________________ 2011 VR Non-tech Speed3 e30 Stratified tuned Michelin Pilot Super Sports - Cobb AP v3 - AT Internals - Cobb DP - HTP 3" Intake - CP-E Safe Seals/studs - MD OCC - EGR self made B/O - JBR IM & TB TIGs - JBR Battery Tray -TB Coolant Bypass - JBR SSP/Shifter Anchors - Turbosmart Dual Port - Stratified GA - CP-E TMIC - Denso ITV22 - SpeedPerformance VC Breather - Bnoon Spec BB - TRS Bi-Xenon Retrofit - JBR RSB - Moog endlinks - Misc other shit |
| The Following User Says Thank You to Zbrit00x For This Useful Post: | Lex (07-09-2012) |
Another test you can perform is to pull the vacuum line from the back of the valve and see if will hold boost. If it leaks under boost and won't hold boost, it will work with the GA. @Zbrit00x, what does your boost pressure drop to when the GA activates?
![]() | | #24 | ![]() |
| Not Ranked : 0 score I just found a picture of the Forge V2 taken apart. It should work fine with the GA. This is not a true pull type BPV as the piston is not held closed by boost like it is on the HKS.
![]() | | #25 | ![]() |
| Not Ranked : 0 score Thanks for clearing this up Lex
![]() | | #26 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Im debating whether or not to switch my synapse DV to push type and try the GA..
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
| The Guardian Angel for your motor | Lex | Stratified Automotive Controls | 158 | 10-28-2015 12:55 PM |
| Guardian Angel help? | MS6FL | Mazdaspeed3/6 General Discussion | 2 | 04-28-2012 07:13 PM |
| How To: fine tune your guardian angel | dooderek | Stratified Automotive Controls | 2 | 04-02-2012 07:40 PM |
| How-To Install Guardian Angel | Dano | Stratified Automotive Controls | 5 | 03-31-2012 03:04 PM |
| Guardian Angel Install | the_rolex_guy | Stratified Automotive Controls | 7 | 03-25-2012 06:03 AM |
