E-Tuners / Custom Hardparts
 Old 11-25-2013, 12:48 AM   #1
theurgy's Avatar
Posts: 2,580   (View Stats)
Default Guardian Angel Installation pics
Finally got around to installing my Guardian Angel this weekend.
I ended up opting to mount it to the front panel of the battery box.
I also ran the power and ground wires through the stock loom of the junction box.
I also opted to use my own LED and LED mount. In talking with @Lex;, the resistor for the included LED is on the board of the controller. It's a 1K Ohm resistor so it was enough for the LED I bought.
I also added a custom 2-wire harness so I can disconnect the light from the switch panel should I ever need to take the dash pieces out and apart.
The Following 2 Users Say Thank You to theurgy For This Useful Post:
Lex (11-25-2013), Mike@Stratified (11-25-2013)
 Old 11-25-2013, 01:23 AM   #2
Very clean installation - thanks for posting! Did you use the included hose clamps? I don't see them on there.
 Old 11-25-2013, 01:28 AM   #3
theurgy's Avatar
No I didn't, I just used some zip ties.
Guardian Angel VTA...how? iammike 2010 MS3 - Engine, Transmission & Driveline 21 11-23-2012 12:41 AM
Guardian Angel help? MS6FL Mazdaspeed3/6 General Discussion 2 04-28-2012 07:13 PM
Page generated in 0.24322 seconds with 21 queries
