E-Tuners / Custom Hardparts
Like Tree3Likes
  • 1 Post By dooderek
  • 2 Post By rfinkle2
 Old 03-08-2012, 10:29 PM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Default Guardian Angel Installed and Reviewed
Packaging
As you can see the device itself is a good looking piece of gear
i chose to mount it on top of the intake manifold (not the best location, but will test the GA against the heat and vibrations)
to tap for power youll want a 12V ign source. eng bar fuse is a great spot to use to tap for power
good way to test for a proper ground around the engine bay is to use a multimeter, the wires (were the red prong is resting on) is a 12v constant so that can be used to find your ground)
mounted and ready to go
extending the LED wires (may not be required depending on mounting location)
wires hooked up and tucked
log with GA turned OFF
log with GA turned ON @ 10 psi
video of external testing with bike pump
video of actual car testing
__________________________________________________ _______
how i score (work in progress)
install difficulty (does not effect final score)
requires invasive mechanical/electrical experience
requires mechanical/electrical experience
requires minor mechanical/electrical experience superficial procedures
plug and play
packaging
2 or below lowers final score, 3 or above does not effect
product was damaged during shipping and handling from poor packaging
packaging had the potential to cause damage to product
normal packaging
exceptional presentation of product
construction (how well the product was made)
product broke due to poor construction/cheap material
possibility of product failure due to poor construction/cheap material
normal construction/material
exceptional presentation, very nice to look at/sturdy
performance
product does not work
product partially works
product works with minor issues
product works as stated without issues
pricing (relative to similar products on the market)
expensive
normal
cheap
third world country cheap
Instructions
nonexistent
vague/confusing
enough to install
descriptive
Aftermarket support
nonexistent
illusive/long wait time
normal
active
Tuning
extremely frustrating to use all guess work
hard to diffcult to use alot of guess work
simple and easy with some guess work
simple and easy to use no guess work
Score:
install:
notes: simple install minor electrical experience recommended, roughly same amount of work needed for installing a boost gauge
packaging:
normal packaging
construction:
notes: very sturdy, and looks very good. tad heavier and larger than i imagined though
performance:
notes: works without issue
pricing:
notes: pricing is good though possibly a tad expensive depending on who you are. however this product still dwarfs the price of new engine if you were to sustain critical damage from an overboost situation
instructions:
notes: precise and clear
aftermarket support:
notes: active member on msf/website with full support
tuning:
notes: some guess work involved with setting the correct psi, markers are only guidelines
final score: 3.5/4
final notes: awesome product to safe guard your engine from overboosting! imo very well priced although tad expensive to some. in the long run the price of a guardian angel is alot cheaper than a brand new engine, and at the same time when driving/racing one doesnt have the ability to watch the road and monitor parameters at the same time. GA is a very worthwhile investment that can possibly save your engine if an overboost situation were to ever occur. on a side note for those who are very finicky about precision the GA requires some trial and error tuning to get the arrow at the exact psi you want.
The Following 39 Users Say Thank You to dooderek For This Useful Post:
86AmishMs3 (03-08-2012), ak_spray (03-13-2012), AZSPEED3 (03-08-2012), bertrand_CX_7 (03-20-2012), bigriver (03-14-2012), Bucker (03-09-2012), captain slow (03-13-2012), charlesfist (03-14-2012), daafisch (03-09-2012), djuosnteisn (03-12-2012), helmetface (03-09-2012), HPFPUPGRADE (03-14-2012), IMASA (06-17-2012), Ingle (03-09-2012), JacksonMS30 (03-09-2012), Jh8909 (03-08-2012), jman46 (03-09-2012), jracer (03-09-2012), kgb (03-13-2012), Lex (03-08-2012), manelscout4life (03-08-2012), mayer (03-09-2012), McGee (03-08-2012), MS3G35 (06-20-2012), MS6FL (03-09-2012), Naaman (03-08-2012), p057 (03-23-2012), Phoenix Speed3 (03-08-2012), rigor (03-13-2012), Sid3wayS (03-08-2012), skeurton (03-09-2012), SleeperHatch (03-09-2012), speed d3mon (12-11-2014), speedms6 (03-13-2012), SWAY (03-08-2012), TWOptSL0W (03-09-2012), uncorked11 (03-08-2012), wankular (03-09-2012), zpele (03-15-2012)
 Old 03-08-2012, 10:31 PM   #2
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
Nice review bud!
The Following 3 Users Say Thank You to UnknownSuperhero For This Useful Post:
Bucker (03-09-2012), Lex (03-08-2012), rfinkle2 (03-09-2012)
 Old 03-08-2012, 10:36 PM   #3
Thanks for posting this up Derek! Great and thorough review! It will be interesting how it will live on top of the intake manifold - electronics are generally NOT mounted on the engine due to heat and vibration. I recommend mounting it off the motor in the engine bay but Derek's going to test the limits
One small correction to the video that you guys may pick up on. Derek mentions that you need to restart your car to turn the GA off. This is not correct, the GA will reset once your foot is off the gas and car will operate normally past that point until you trip it again.
atvfreek (03-09-2012), AZSPEED3 (03-08-2012), charlesfist (03-14-2012), Nliiitend1 (03-14-2012), rfinkle2 (03-09-2012), uncorked11 (03-09-2012)
 Old 03-08-2012, 10:44 PM   #4
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
I believe this to be your best how-to yet.. Thank you good sir for making the install that much easier for us dumb folk.
TEAM LUXURY
Lex (03-08-2012)
 Old 03-08-2012, 10:50 PM   #5
Phoenix Speed3's Avatar
Posts: 714   (View Stats)
Phoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the world
Clean up your garage.
tapatalk whore
Phoenix Speed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to Phoenix Speed3 For This Useful Post:
memin (03-15-2012), rigor (03-13-2012)
 Old 03-08-2012, 10:56 PM   #6
2zz mr-s
dooderek's Avatar
Groans: 239
TIS TRUE!! i apologize for any confusion, bike pump did not provide vacuum during test and my lack of understanding for this device perceived it as normal function
The Following 3 Users Say Thank You to dooderek For This Useful Post:
Lex (03-08-2012), Nliiitend1 (03-14-2012), rfinkle2 (03-09-2012)
 Old 03-08-2012, 11:03 PM   #7
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Turn the boost controller up all the way...and hope that divine powers will protect your engine from the dark depths of hell.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
Lex (03-08-2012), mrmonk7663 (03-08-2012)
 Old 03-08-2012, 11:17 PM   #8
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Ugly spot for it lol
I will eventually invest in one.
It's on the list...
2012 WRX HB w/mudflaps yo!
Lex (03-08-2012)
 Old 03-08-2012, 11:47 PM   #9
Naaman's Avatar
Posts: 344   (View Stats)
Naaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the world
Strange mounting location, but great review of what looks to be a quality product! Now if only money didn't hate me quite so much...
Naaman is offline   Reply With Quote
The Following User Says Thank You to Naaman For This Useful Post:
Lex (03-08-2012)
 Old 03-09-2012, 02:10 AM   #10
2zz mr-s
dooderek's Avatar
Groans: 239
review finished
The Following User Says Thank You to dooderek For This Useful Post:
Lex (03-09-2012)
 Old 03-09-2012, 02:17 AM   #11
leon78's Avatar
Posts: 2,595   (View Stats)
Good write up, thanks.
2013 Scion FR-S (Whiteout)
Less parking more racing
The Following User Says Thank You to leon78 For This Useful Post:
Lex (03-09-2012)
 Old 03-09-2012, 01:08 PM   #12
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Good review, retarded mounting spot. I laughed pretty hard in the first vid where you kicked something and almost tripped and said "ugh mother fucker".
2009 CWP Speed3
The Following 3 Users Say Thank You to SleeperHatch For This Useful Post:
Lex (03-09-2012), p057 (03-23-2012), rigor (03-13-2012)
 Old 03-09-2012, 01:14 PM   #13
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
"Take a look at the engine bay" ---> gets in car lol
Great review though, glad it was problem-free.
Lex (03-09-2012), p057 (03-23-2012), rfinkle2 (03-09-2012)
 Old 03-09-2012, 01:22 PM   #14
Thanks Derek, very much for the review and write-up.
I was thinking of another great use for the GA... when you are having someone else drive your car, you can use it as a manual valet mode without changing your tune.
Sid3wayS and wake2011 like this.
The Following 10 Users Say Thank You to rfinkle2 For This Useful Post:
Bucker (03-09-2012), charlesfist (03-14-2012), guitarzan134 (03-14-2012), Lex (03-09-2012), Mauro_Penguin (12-12-2013), Sid3wayS (03-09-2012), skeurton (03-09-2012), SLOWHATCH (03-13-2012), SofaKingAwesome (03-09-2012), uncorked11 (03-15-2012)
 Old 03-09-2012, 01:24 PM   #15
COCKSTRONG
Groans: 890
Good point!
Lex (03-09-2012), rfinkle2 (03-09-2012)
 Old 03-09-2012, 02:54 PM   #16
Good point. Set it to 10psi and after they run up against that a couple of times they won't try and race the guy next to them anymore.
ljudgeii (03-09-2012), rigor (03-13-2012)
 Old 03-13-2012, 08:45 PM   #17
Sid3wayS's Avatar
Groans: 97
@Daddy Chinkus where did you get the 15amp add a fuse? All the ones im finding are 10amp max.
TEAM LUXURY
 Old 03-13-2012, 08:54 PM   #18
COCKSTRONG
Groans: 890
I had this happen too. Bought ten amp rated one, put in 15 amp fuse no problem
Sid3wayS (03-13-2012)
 Old 03-13-2012, 09:10 PM   #19
madspd6's Avatar
Posts: 1,009   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
Seems like an awesome product.
Any chance it will become smaller in the future?
Velocity Red Mica 06 Speed6 (ricer) #834
Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary.
Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights.
madspd6 is offline   Reply With Quote
The Following User Says Thank You to madspd6 For This Useful Post:
Lex (03-14-2012)
 Old 03-14-2012, 10:50 PM   #20
The way it is configured at the moment it would be difficult to get smaller ... but this is something I can keep in mind if an overhaul of the product is needed. I hope that it fits most engine bays in the current form factor although smaller is always better in this case.
 Old 03-15-2012, 12:43 AM   #21
madspd6's Avatar
well i mean perhaps like how the hid kits went to a slim style... it was a suggestion at best.
40 retards thinking together could eventually come up with a million dollar idea right?
 Old 06-17-2012, 10:27 PM   #22
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Is there a good place to install this to keep it out of view for dealer visits but still able to adjust it when needed?
Pickles Tune in progress
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/guardian-angel-installed-reviewed-107523/
Blog : Stratified Automotive Controls This thread Refback 03-02-2014 06:37 PM
Blog : Tech Talk : Stratified Automotive Controls This thread Refback 07-27-2013 04:45 AM
Blog : Overboost protection and why it’s important : Stratified Automotive Controls This thread Pingback 06-05-2012 12:26 PM
The Guardian Angel for your motor Lex Stratified Automotive Controls 158 10-28-2015 12:55 PM
GI: Guardian Angel (Overboost Protection) Lex Stratified Automotive Controls 289 02-27-2014 01:50 AM
COBB SRI installed and reviewed NinjaT1985 2010 MS3 - Turbo Induction 15 10-10-2012 06:59 PM
MS Intake installed/reviewed Danish MazdaSpeed 3/6 - Turbo Induction 9 12-17-2010 11:41 PM
Reviewed: Bridgestone 3G RFT Tires take the shock out of run-flats Haltech Automotive News 0 07-06-2009 10:10 AM
Page generated in 0.50491 seconds with 34 queries
