E-Tuners / Custom Hardparts
 Old 11-09-2013, 03:15 PM   #1
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Default Guardian Angel VTA mode
Okay I've been messing with this all day. Got it installed but I can't seem to figure out how to enable VTA mode. I read the PDF on the website and I must be retarded. I put the trigger wire to the battery positive plug in the gta and the light just stays solid. I don't see 2 flashes. HELP! I've already converted the car to VTA mode so it's running pretty turrible right now.
 Old 11-09-2013, 03:30 PM   #2
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Unplug it, put the trigger wire to positive, plug it back in, it will do like a clicking sound thats how u know u did it right.
TEAM LUXURY
rfinkle2 (11-10-2013)
 Old 11-09-2013, 03:36 PM   #3
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
http://www.stratifiedauto.com/Strati...204-0006.2.pdf
Page 13-15.
The Following 2 Users Say Thank You to Dmurray06 For This Useful Post:
NCspecV81 (11-09-2013), rfinkle2 (11-10-2013)
 Old 11-09-2013, 03:44 PM   #4
btstarcher's Avatar
Posts: 4,852   (View Stats)
Which BPV are you running? Or BOV?
SnailTune in progress
 Old 11-09-2013, 03:56 PM   #5
NCspecV81's Avatar
using the cobb xle and I read the PDF. I can't tell if it's on or off. I know it's working b/c I tested it at 10psi and it felt like a gradual loss in power once i breached the 10psi threshold. Now getting VTA to work.
I spoke with Lex and he confirmed it should work with the cobb xle since it's push type. I just can't tell if it's VTA mode is on or off.
 Old 11-09-2013, 04:01 PM   #6
Dmurray06's Avatar
Groans: 189
Light will be on at idle if its on.
 Old 11-09-2013, 06:34 PM   #7
NCspecV81's Avatar
Light only stays lit when car is off abs turns off when I start it. I'm frustrated
 Old 11-09-2013, 06:41 PM   #8
Dmurray06's Avatar
Groans: 189
Hmmm...weird, wiring is all good?
 Old 11-09-2013, 09:39 PM   #9
NCspecV81's Avatar
I'm assuming. It works when it's cutting boost.
My wiring consists of add-a-fuse connected to ENG-BAR and ground going to OEM location where the battery is grounded. Took it up the road and breached the 10psi setting, and it sounded like a mini wastegate with my boost and power gradually decreasing.
I just can't seem to get VTA mode to take. I turn the car to the on position and unplug the connector. I attach the blue wire to the positive terminal and plug the unit back up. The led lights up and goes off momentarily and lights up again when there is a sound like a valve moving in the GA. I continue to hold it the blue wire there for a few seconds and release. I then push the button on the ignition to cut the car off. I push the button another two times to get the ignition on but the car not started. I check the LED on the GA and it's lit. I crank the car at that point and the LED shuts off and the car idles pretty bad. I repeat it another two or three times with the same result. I can't seem to get this fucker into VTA mode.
Anyways TLDR cliff notes - I'm apparently stupid as shit.
 Old 11-10-2013, 12:03 AM   #10
Is this GA bought new or one of the early ones. The very early ones did not have the VTA feature on the software
NCspecV81 (11-10-2013)
 Old 11-10-2013, 06:50 AM   #11
NCspecV81's Avatar
I'm not sure. Bought it used. How would I find out by inspecting the ga?
 Old 11-12-2013, 03:33 PM   #12
NCspecV81's Avatar
@Lex; thanks for the PM.
Guardian Angel Cevaes_64 Stratified Automotive Controls 6 06-09-2013 07:45 PM
Guardian Angel VTA...how? iammike 2010 MS3 - Engine, Transmission & Driveline 21 11-23-2012 12:41 AM
A Guardian Angel Looking Over Me...... Novej Stratified Automotive Controls 3 09-07-2012 05:22 PM
Page generated in 0.31209 seconds with 24 queries
