![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score Unplug it, put the trigger wire to positive, plug it back in, it will do like a clicking sound thats how u know u did it right.
__________________ TEAM LUXURY |
| The Following User Says Thank You to Sid3wayS For This Useful Post: | rfinkle2 (11-10-2013) |
![]() Join Date: Dec 2011 Location: Red Deer,AB Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,855
Groans: 189
__________________ 2010 Mazdaspeed 3 Black Mica w/ Tech Package - Traded In 2014 Ford F150 FX4 Ecoboost - Current |
| Not Ranked : 0 score Which BPV are you running? Or BOV?
(Thread Starter) | Not Ranked : 0 score using the cobb xle and I read the PDF. I can't tell if it's on or off. I know it's working b/c I tested it at 10psi and it felt like a gradual loss in power once i breached the 10psi threshold. Now getting VTA to work. I spoke with Lex and he confirmed it should work with the cobb xle since it's push type. I just can't tell if it's VTA mode is on or off. |
Groans: 189
| Not Ranked : 0 score Light will be on at idle if its on.
(Thread Starter) | Not Ranked : 0 score Light only stays lit when car is off abs turns off when I start it. I'm frustrated |
Groans: 189
| Not Ranked : 0 score Hmmm...weird, wiring is all good?
(Thread Starter) | Not Ranked : 0 score I'm assuming. It works when it's cutting boost. My wiring consists of add-a-fuse connected to ENG-BAR and ground going to OEM location where the battery is grounded. Took it up the road and breached the 10psi setting, and it sounded like a mini wastegate with my boost and power gradually decreasing. I just can't seem to get VTA mode to take. I turn the car to the on position and unplug the connector. I attach the blue wire to the positive terminal and plug the unit back up. The led lights up and goes off momentarily and lights up again when there is a sound like a valve moving in the GA. I continue to hold it the blue wire there for a few seconds and release. I then push the button on the ignition to cut the car off. I push the button another two times to get the ignition on but the car not started. I check the LED on the GA and it's lit. I crank the car at that point and the LED shuts off and the car idles pretty bad. I repeat it another two or three times with the same result. I can't seem to get this fucker into VTA mode. Anyways TLDR cliff notes - I'm apparently stupid as shit. Last edited by NCspecV81; 11-09-2013 at 10:00 PM. |
| Not Ranked : 0 score Is this GA bought new or one of the early ones. The very early ones did not have the VTA feature on the software
| The Following User Says Thank You to Lex For This Useful Post: | NCspecV81 (11-10-2013) |
(Thread Starter) | Not Ranked : 0 score I'm not sure. Bought it used. How would I find out by inspecting the ga? |
(Thread Starter) | Not Ranked : 0 score @Lex; thanks for the PM. |
| Guardian Angel | Cevaes_64 | Stratified Automotive Controls | 6 | 06-09-2013 07:45 PM |
| Guardian Angel VTA...how? | iammike | 2010 MS3 - Engine, Transmission & Driveline | 21 | 11-23-2012 12:41 AM |
| A Guardian Angel Looking Over Me...... | Novej | Stratified Automotive Controls | 3 | 09-07-2012 05:22 PM |
