E-Tuners / Custom Hardparts
  • 2 Post By dooderek
 Old 03-29-2012, 04:29 PM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Default How To: fine tune your guardian angel
tools needed:
bike pump (or means of compressing air)
vacuum T
vacuum lines
optional : passenger
step 1: turn key on ignition
step 2: setup your system to look like this WARNING: make sure your meth controller is not tapped into the line or else it will spray (applies to boost based meth controllers i.e hobbs etc.)
step 3: pressurize the air until the GA kicks on, then note where the marker is set and what psi it kicks off on.
heres a video to demonstrate:
p057 and bigriver like this.
The Following 6 Users Say Thank You to dooderek For This Useful Post:
bigriver (03-29-2012), Dano (03-30-2012), dspider (03-30-2012), Lex (03-29-2012), maisonvi (03-25-2014), p057 (03-30-2012)
 Old 03-30-2012, 06:33 AM   #2
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
nice simple write up that doesn't require me to go drive, test, park, adjust. Rinse, repeat x10.
p057 is offline   Reply With Quote
 Old 04-02-2012, 07:40 PM   #3
m4tic's Avatar
Posts: 4,928   (View Stats)
Bad bad.. We don't use the trunk of an FD go hold your junk.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Guardian Angel for your motor Lex Stratified Automotive Controls 158 10-28-2015 12:55 PM
Guardian Angel Installed and Reviewed dooderek Stratified Automotive Controls 21 06-17-2012 10:27 PM
How To: fine tune your guardian angel dooderek MazdaSpeed 3 - How-To's 0 03-29-2012 04:28 PM
How To: fine tune your guardian angel dooderek MazdaSpeed 6 - How-To's 0 03-29-2012 04:23 PM
Guardian Angel Install the_rolex_guy Stratified Automotive Controls 7 03-25-2012 06:03 AM
Page generated in 0.25489 seconds with 22 queries
