E-Tuners / Custom Hardparts
 Old 03-31-2012, 02:36 PM   #1
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Default How-To Install Guardian Angel
Well I finally got around to getting the GA installed and must say its an excellent device and the package is well put together. Not that I would have expected anything less from brother Lex.
I know there are some other How-to's out there so this is probably a bit redundant but I took the time to take the pics so here is my 15 minutes...lol
so on to the eye candy.
Installation:
Since I already had my Labonte WMI controller and failsafe installed on the top of my fuse box I decided to mount the GA on an aluminum bracket hung off the strut tower just above the fuse box. It is a guardian angel after all and so should be above all the other equipment looking down over things.
I grounded it to my existing WMI ground harness which attaches at the same location the battery uses.
Ran the power connection up to the fuse box and shared it with my switched WMI stuff.
Ran the indicator LED up and mounted it along with my WMI fuel level indicator on the right side of the upper dash pod. My WMI trigger [green] and FS indicator [red] are on the left hand side. This way there is no confusion as to what light is telling me what of the 4 mounted there...lol In the pic with flash you can see the LED harnesses better than you can normally...that is to say normally night or day you can only see the bulbs and not the wires.
To see just how to mount the LEDs you can take a look at my WMI install thread.
Labonte WMI Install How-to w failsafe
Lastly a little plumbing
vac block to distribute boost source to my gauge, WMI trigger and GA/BPV
Once things settle down I will take the GA aux trigger wire and connect it to my WMI failsafe and so some testing and report back. It should work like a charm. I currently only use the WMI failsafe to power the LEDs. When I first installed it with the boost cut solenoid it caused issues with building boost so I removed it.
Impressions:
The GA works just as advertised and will gently reduce power once it is tripped. I am having a strange boost surging issue after the GA is tripped and the throttle is held open that I just haven't figured out yet. Its like the BPV is opening then partially closing allowing boost to build until it over comes spring pressure and the process repeats. Weird but I don't have time to worry about it right now.
You can see what I am talking about in the attached logs. 3 each with the GA set at ~19PSI and ~12PSI on a 22PSI map.
Great product @Lex!
Lex (03-31-2012), MS6FL (04-25-2012), redmnsterut (03-31-2012)
 Old 03-31-2012, 02:46 PM   #2
Excellent review and write-up Dan - I know you are busy so thanks so much for this!
You certainly have a lot of vacuum ports/lines going on in there!
Dano (03-31-2012)
 Old 03-31-2012, 02:56 PM   #3
Trail of Fail
Dano's Avatar
haha yeah really only 3 one inlet on the top left that exits on the top right, one for boost gauge and one for WMI...the rest are caps.
the block beats a bunch of tees that can be prone to breaking.
SLOWHATCH (03-31-2012)
 Old 03-31-2012, 02:56 PM   #4
redmnsterut's Avatar
Posts: 838   (View Stats)
redmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the world
This is a great write up. Thanks, if i get one ill definitely come back and look this over.
SURE RMM | SURE Shift Weight | SURE SSP | CP-E CAI | CP-E DP | CP-E TIP | COBB AP |SnailD Tunned| TEIN Springs | SU Turbosmart BPV | Autotech HPFP Internals | Autolite XP step colder plugs | JBR Heavy Shift Knob | CXracing FMIC | Block8 Single Gauge Pod | MSD DashHawk
Waiting to be installed: SURE Dreadnaught | JBR Shifter Bushings | SU Boost Tubes | P&P Intake Manifold
Soon to come:SURE Intake/TB TIG | SURE Juggernaught | RSB |
286awhp / 346lbs tq @4500 ft ASL
redmnsterut is offline   Reply With Quote
The Following User Says Thank You to redmnsterut For This Useful Post:
Dano (03-31-2012)
 Old 03-31-2012, 03:01 PM   #5
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
cough cough*
The Following User Says Thank You to dooderek For This Useful Post:
Dano (03-31-2012)
 Old 03-31-2012, 03:04 PM   #6
Trail of Fail
Dano's Avatar
hahah yes your write up was the one I was referring to...BTW good job!
The Guardian Angel for your motor Lex Stratified Automotive Controls 158 10-28-2015 12:55 PM
GI: Guardian Angel (Overboost Protection) Lex Stratified Automotive Controls 289 02-27-2014 01:50 AM
Guardian Angel Installed and Reviewed dooderek Stratified Automotive Controls 21 06-17-2012 10:27 PM
How To: fine tune your guardian angel dooderek Stratified Automotive Controls 2 04-02-2012 07:40 PM
Guardian Angel Install the_rolex_guy Stratified Automotive Controls 7 03-25-2012 06:03 AM
Page generated in 0.28137 seconds with 24 queries
