(Thread Starter) | Not Ranked : 0 score The ECU uses the throttle, WGDC, AFRs to limit power/wheelspin when turning and this is more aggressive in lower gears since wheelspin is more prominent - yes we know this. I was having bucking/poor performance with SWAS active in corners to the point that it was dangerous in the low gears. I then drove a closer to stock speed3 and the system was not nearly as intrusive. Felt pretty decent actually. I could chalk this up to BT and heavier modifications but something wasn't adding up as I also wasn't remembering it being this bad in the past and I realized something many people overlook. When the ECU changes throttle (abruptly) mid corner as the turbo spools this affects the manifold/charge pipe pressure ratio. This in turn triggers/opens the BPV. The OEM BPV is a twin chamber design with a very stiff spring that is very quick acting. A lot of the aftermarket ones (I run a Forge V1 since the OEM leaked at high boost) do not share the response of the OEM BPV. The forge is notorious for this as it loses lubrication on the sealing o-rings. This causes the response time of the valve to be significantly affected and causes/exacerbates the bucking/sputtering phenomenon and it affects how SWAS interacts. Overall this mismatch between the ESP software and BPV can make you hate SWAS/ESP more than you should. For those of you where SWAS interferes violently, consider the BPV and that it is an important part of the overall system and it should be tuned to work well with it. Holding boost/pressure is important but so is response time and tunability the multi chamber designs with fast reaction times are better than the older designs with lots of internal friction and slow response. This will affect spool, lag between gears, shifting smoothness, and SWAS. Poor valve response can even cause bucking on throttle tip in or acceleration in a straight line. I recommend pressure testing your system to the boost level you want to run and stick with the OEM BPV unless you go over 20-21psi (ie bigger turbo). If you need to swap out the BPV, choose a multi chamber design with a fast response and low friction parts where you can adjust the spring/preload. It will make the car drive better in all conditions.
| The Following 84 Users Say Thank You to Lex For This Useful Post: | 08blackmicaspeed3 (06-08-2013), 1sicms3 (09-06-2013), ABloodBrother (06-09-2013), ABolewski (06-09-2013), Ace Protege (06-09-2013), Addikted To Boost (04-03-2015), Agent_Orange (06-09-2013), aggierandy (06-09-2013), Andrewbox (12-30-2013), atvfreek (08-13-2013), BackRoads (09-04-2014), beachshoer (06-09-2013), BigRedSpecial (06-13-2013), Big_Burd (06-09-2013), bladerunner10121 (09-18-2013), bob^3 (08-26-2013), Boosted Beluga (06-09-2013), BPASPEED (06-08-2013), brandonf (09-06-2013), breakfstincluded (06-09-2013), Brennan (09-07-2013), btstarcher (06-08-2013), chaser27 (12-31-2013), Cheapspeed (06-09-2013), Chron (06-09-2013), Claysan (09-17-2014), cshunter (06-09-2013), Dahouse702 (06-09-2013), DAN MPS 3 (06-09-2013), Dash08 (06-09-2013), DaUberSchwebel (02-16-2014), Dr. Speed (06-08-2013), Dralphy (06-08-2013), Easter Bunny (08-13-2013), Fatguy729 (06-09-2013), Finchee (08-12-2014), flapjack (01-26-2018), forcedinduktion (06-09-2013), Format (09-13-2013), Funkster777 (12-16-2013), garf (08-14-2013), Gr8Speed (02-11-2014), hnda etr (09-06-2013), Hush (06-09-2013), IMASA (06-08-2013), ink28 (09-07-2013), jabeel00 (12-01-2015), jack_hammer (06-09-2013), JeffroMS3 (11-07-2013), Johnny_Law (09-15-2013), jseams (06-09-2013), kabobulate (06-09-2013), Karmat (06-09-2013), Kyle Undefined (06-09-2013), Lancer-AM (09-06-2013), load (09-16-2014), LumberJack (06-08-2013), magicka (06-08-2013), manila (06-09-2013), Mauro_Penguin (06-09-2013), MD1032 (01-20-2015), Mike@Stratified (06-09-2013), mituc (05-19-2018), MMMSpeed3 (01-04-2014), mxlplx71 (06-09-2013), Nliiitend1 (06-08-2013), Pointless (06-08-2013), Quigs (06-08-2013), Raymond (09-26-2013), redboat (01-20-2014), SLOWHATCH (08-13-2013), smoogs12 (06-09-2013), speed23 (06-09-2013), speedaholic (09-15-2014), SpeedLife (09-06-2013), SpeedRebirth (06-08-2013), TMOtester (09-19-2014), Tokay444 (06-09-2013), torquemaniac (08-27-2014), trancehead (09-06-2013), twowheelrides (06-09-2013), uncorked11 (09-06-2013), v8killer (08-14-2013), vtdone (11-27-2015) |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
Groans: 57
| Great read, awesome info fuckin yo couch
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score @Lex; forgive my amatuer question, but I thought your GA when paired with the proper BPV would help eliminate leaks associated with loose spring tension. Wouldn't your GA help in keeping the system functioning quickly and properly in addition to the overboost protection?
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
| The Following User Says Thank You to Mauro_Penguin For This Useful Post: | Lex (06-09-2013) |
![]() Join Date: Aug 2012 Location: San Mateo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,022
| Not Ranked : 0 score Heh, this is why I'm happy my stock BPV holds fine at 20psi... although I'm in line to pick up a friends Forge V2 soon when he parts out - I won't be using it until there is a need. Anyhow, does anybody have a complete link or a list of all the quick reacting two chamber designs currently available? Most reviews seem simply focused on the "sound" and ignore the performance of the unit.
__________________ CRMetallic 2019 Mercedes C43 AMG SOLD MNBlue 2012 S4 Prestige... a few mods SOLD IB 2015 3.8 Gencoupe Ultimate BLOWED UP DIB 2014 Mustang 5.0... a few mods SOLD - LS 2012 MS3 Cobb AP//SF//CAB Autotech HPFP Corksport TMIC//BPV//TIP//BTbs JBR 88a RMM Sure M3 TP OBX CBE Tanabe NF210's ADVAN RG-D 18x8 +38 Freektuned 50/50 E85 |
| The Following 4 Users Say Thank You to jseams For This Useful Post: |
If you try several BPVs (with or without the GA) you will notice changes in driving characteristics during these throttle transitions
| The Following 6 Users Say Thank You to Lex For This Useful Post: | ABolewski (06-09-2013), breakfstincluded (06-09-2013), btstarcher (06-09-2013), jabeel00 (12-01-2015), Mauro_Penguin (06-09-2013), Nliiitend1 (06-09-2013) |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
| Not Ranked : 0 score Yes that's the one thing this forum cannot seem to teach me, what a good BPV is to go with. I could give two shits about how it sounds. Great read though Lex, interesting stuff.
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
| The Following 3 Users Say Thank You to ABolewski For This Useful Post: |
Groans: 171
| Not Ranked : 0 score Indeed, thank you Lex!
![]() Join Date: Jul 2012 Location: South San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,074
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score So ur bpv could scream "I love cock!" And u would be ok with it cuz it works good? Lol. J/k. Lex, u never cease to amaze me. I don't understand half the stuff u try and teach us but I do learn shit I had no clue about. This is why u will be getting my monies when all my parts are finally on!
__________________ 2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's to be installed : 3 Port EBCS HTP 3" intake/ MAF/ TIH Autotech internals Corksport Pmm Test pipe SBC Rear Camber Arms |
| The Following 7 Users Say Thank You to Playaj For This Useful Post: | ABolewski (06-09-2013), Big_Burd (06-09-2013), emag remrofni (01-12-2014), Keko (06-09-2013), Mattcinnc1 (06-09-2013), Micha (08-14-2013), v8killer (08-14-2013) |
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... | |
| The Following 4 Users Say Thank You to ABolewski For This Useful Post: |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
We treat it like it plays no part in engine operation whatsoever. Like it's some bullshit accessory that doesn't do anything. Lex has overlooked this and delved into the inner workings of them and how they affect our engine's performance on a multitude of levels. On top of what Lex has discovered here with SWAS and ESP, BPV's have a relatively profound effect on fuel trims as well. So, BPV's affect driveability, throttle response, SWAS/ESP operation, and fuel trims... That's not fucking rice, that's important shit. I think we need a more serious approach to BPV's from now on. | |
| The Following 20 Users Say Thank You to Dash08 For This Useful Post: | 802MS3 (06-09-2013), ABolewski (06-09-2013), Agent_Orange (06-09-2013), BigRedSpecial (06-13-2013), Big_Burd (06-09-2013), breakfstincluded (06-09-2013), BrianB6 (09-06-2013), btstarcher (06-09-2013), chaser27 (11-18-2014), Cheapspeed (06-09-2013), Chron (06-09-2013), eppopipe (02-09-2014), Fjager (03-07-2014), jabeel00 (12-01-2015), jseams (06-09-2013), Mauro_Penguin (06-09-2013), Raymond (09-26-2013), silvapain (09-06-2013), uncorked11 (09-06-2013), v8killer (08-14-2013) |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score I suppose Ill be the one to ask, which of the BPVs on the market are dual chambered, if any?
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
![]() Join Date: Mar 2010 Location: Scottsdale, AZ
Rep Power: 599 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,198
Groans: 118
| Not Ranked : 0 score Sooooooo what BOV should I get?! I kid I kid I don't need one but, seriously.
__________________ 2008 Speed3// Cobb SRI / Cobb TI/ Cobb STS Koni Yellows, stock springs/ JBR 88 Trilogy / JBR RSB / JBR CamberArms/ Hotchkis FSB |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
| Not Ranked : 0 score So many people were haphazardly replacing oem bpvs without them leaking. Now we see that not only is it often a waste of money on the ko4 it may actually be a detriment to engine operation. Great thread. Sent from my DROID RAZR using Tapatalk 2
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score So you're saying... Stratified Tuning will be releasing a BPV next week? (:
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
| The Following 8 Users Say Thank You to breakfstincluded For This Useful Post: | ABolewski (06-09-2013), AZSPEED3 (06-09-2013), BigRedSpecial (06-13-2013), Easter Bunny (08-13-2013), Mauro_Penguin (06-09-2013), rfinkle2 (06-09-2013), v8killer (08-14-2013), zxhoya (06-10-2013) |
| Not Ranked : 0 score What about valves like the HKS? I freely admit I know nothing about them; I don't even remember what factored into my decision when I purchased mine.
(Thread Starter) | Not Ranked : 0 score A BPV should be evaluated on several performance criteria: - First, do you need to replace the OEM and how do you know? What I found with the BNRS3 is that once boost pushed past the 21psi mark or so; although boost continued to climb, the airflow did not increase. This is because the BPV had cracked open and instead of the turbo drawing in more air, it was simply recirculating what it had already compressed. So the symptom was not a lack of boost, but rather it was a stall in the increase of airflow. Once the BPV was swapped, it was in line with what the turbo should have been flowing at that boost level and RPM. Boost remained the same, airflow increased. Most aftermarket BPVs are able to seal well under boost but there is more to it than this. - Controlling compressor surge in all conditions. A BPV should allow minimal to no surge under both heavy and light throttle lift. The HKS seals great under boost since it is a pull type valve but allows for compressor surge under part throttle. The TS valve with the heavy 20psi spring is terrible for surge although it is a push valve. The valve should also flow enough to control compressor surge under high boost and high airflow conditions as well. - Response time. How quickly a valve is able to open and close with varying pressure differentials is important. Not only does is effectively allow fast throttle modulation without surging or bucking but it works well with drive by wire systems where the ECU modulates the throttle on top of what the driver is doing. Fast valves close under boost quickly promoting spool as well. Fast response time is about low friction lightweight parts, smart construction, multi chamber construction, and high airflow rates out of the valve. - Ability to tune the valve. This is important for improving driveability and making the valve work well with the electronic control in the car, your turbo, your boost levels. Some of the multi chamber valves allow you to use one or more of the chambers. The ability to replace spring is nice but I prefer a dial where the same spring can be put under more or less pressure as well. - Construction, fitment, servicing. The valve should not require a lot of attention or servicing because if it does it means that the performance deteriorates as you get closer to the service period. I want the valve to work the same all the time. I've seen plenty of aftermarket valves leak, have poor seals, etc. You want a high quality piece that will last a long time. - Sounds and VTA. Yes you want a pleasing sound and we all do. It's not a performance feature but it's something to consider since after all we must enjoy driving the car. Some people like VTA and they can use the Guardian Angel to limit the VTA effects on engine operation or use a 50/50 valve. The GA closes the valve much sooner after a shift so if you run the GA in VTA mode you can get some response improvements but the valve should be tunable somehow so that you can soften the spring and walk the fine line between surge and fast response. You can also use the VTA feature on the GA to increase response time of a fully recirculating valve.
| The Following 14 Users Say Thank You to Lex For This Useful Post: | ABolewski (06-09-2013), Agent_Orange (06-21-2013), BackRoads (09-04-2014), Big_Burd (06-09-2013), breakfstincluded (06-09-2013), Dash08 (06-09-2013), hnda etr (09-06-2013), IMASA (06-09-2013), jseams (06-09-2013), Mauro_Penguin (06-09-2013), Nliiitend1 (06-09-2013), Raymond (09-26-2013), torquemaniac (08-27-2014), vtdone (11-27-2015) |
| Not Ranked : 0 score Thanks, now I remember. I liked that there are no springs to replace and no maintenance. That and I thought that it works for any boost level. Or any reasonable boost level anyway. Dumb question: would running it as a BOV eliminate compressor surge? Or is my understanding of compressor surge incorrect? And yes, I understand that I can't use the HKS with the GA....it was the main reason I almost didn't get it.
![]() Join Date: Aug 2009 Location: Toronto, Ontario, CANADA
Rep Power: 545 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
Groans: 44
| Not Ranked : 0 score Just so I understand this right.... STOCK BPV = Good for K04 up to 20psi (basically =<20psi) AFTERMARKET BPV = Good for K04 beyond 20psi (basically >20psi), BNRS3, Big Turbo (GT30/35...etc) That would be a good way to look at it? Seems like the stock valve is the way to go if you want function for up to 20psi, yes?
__________________ |
| The Following User Says Thank You to starscream For This Useful Post: | btstarcher (06-09-2013) |
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
Groans: 171
| Not Ranked : 0 score @Lex; I love your brain and articulation. That is all.
| The Following User Says Thank You to Mauro_Penguin For This Useful Post: | allo80 (09-20-2013) |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
| Not Ranked : 0 score I can confirm @Lex; 's findings, though not related to swas. I was getting a strange bucking when in stop and go traffic. It would happen when trying to hold a low rpm in 1st and secong gear, and also when going from deceleration to accleleration (lighlty). I dont want to go through all the details of what i was seeing in logs (trying to diagnose it) because i am on my phone right now, but long story short, i cleaned and lubed my forge v1, and voila! Gone!
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
| The Following 2 Users Say Thank You to Fatguy729 For This Useful Post: | Easter Bunny (08-13-2013), eppopipe (02-09-2014) |
![]() Join Date: Sep 2012 Location: Sharpsburg, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
I went with the GFB Respons and I think it fits all of your criteria. I just don't know if it is multi-chambered though. I know a lot of other people run this bpv as well and like it. It has the dial up top for the spring and it has a knob you turn to control how much you vta so you can crack it like 10%vta and get the sound without causing problems to how to the car runs. Go Fast Bits Blowoff Valve Dual Port Mazdaspeed 3 6 MS3 MS6
__________________ 08.5 CWP MS3 FreekTune // Cobb AP // AT HPFP // Corksport SRI // COBB TIH // GFB BPV R.I.P. // M2 Full DP // JBR 80a RMM // JBR SSP 18" TRmotorsports C2 // Yellow Fogs // Eonon D5151 Soon™: TouchUp Tune // OCC // FMIC | |
| The Following User Says Thank You to RageATL For This Useful Post: | cshunter (06-10-2013) |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score you have done it again lex, good work
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
| The Following User Says Thank You to blackms3_71 For This Useful Post: | freakms3 (11-09-2014) |
![]() | | #24 | ![]() |
![]() Join Date: Feb 2010 Location: NoVA/ Norfolk
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
Groans: 133
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score So @Lex; will you be removing your Forge and going back to stock or are you tuning around it? P.S. blue spring one shim? :p
__________________ 08.5 CWP MS3 GT PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC |
![]() | | #25 | ![]() |
![]() Join Date: Feb 2011 Location: Aurora, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,094
Groans: 39
| Not Ranked : 0 score NEWB comment: with the above explanation from Lex explain why i have never had an issue with my SWAS pissing me off mid turn or any issues like that? I will say that i did have an issue with my OEM BPV giving up on life on a stage 1 OTS map. I would get a bad boost leak and the car would buck constantly under heavy acceleration (not even WOT). I replaced with the Cobb valve, and issues were gone. Obviously now i'm on the synapse valve, and this thing responds fast as fuck, and like i said, i don't have any issues with SWAS.
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" |
![]() | | #26 | ![]() |
Groans: 82
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Mine never leaked, but I'll be pushing the limits of the K04....
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score I mentioned the importance of the BPV earlier this year and finally got to do some testing with one of the fastest valves on the market. The results were great. SWAS and stability control no longer got in the way. No more bucking, loss of boost, jerkiness when taking a hard corner in a lower gear. So if you want SWAS and the stability control to work with you and not against you, get a BPV that is as fast as possible. A fast valve also helps response and spool.
| The Following 12 Users Say Thank You to Lex For This Useful Post: | 2.0t03speed (08-13-2013), BackRoads (09-04-2014), bcmountainspeed (08-13-2013), Cheapspeed (10-28-2014), hnda etr (09-06-2013), Johnny_Law (09-15-2013), ledfootrob (08-14-2013), Mauro_Penguin (08-13-2013), Mortose (08-13-2013), Raymond (09-26-2013), SLOWHATCH (08-13-2013), YABBAMZR (08-13-2013) |
![]() | | #29 | ![]() |
![]() Join Date: Jun 2012 Location: Elgin, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 656
__________________ 2008 Speed 3 CS 3" Intake//BNRS3v2//GS EBCS//3BAR MAP SENSOR//AT FP Internals//ATP DP catless//Custom FMIC//JBR Stage 3 SSP//CP-e Stage 2 RMM//MD OCC w/Sight Tube//EGR Del//NGK Iridium IX Plugs//Cobb AP//FreekTuned!!!!! | |
![]() | | #30 | ![]() |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | btstarcher (08-13-2013), SneakySin (08-13-2013) |
![]() | | #31 | ![]() |
Groans: 39
| Not Ranked : 0 score Lex = faster than me.
| The Following User Says Thank You to Mortose For This Useful Post: | Lex (08-13-2013) |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score Lex, this is the BPV I am running currently; if you have run and logged this, can you quantify the effects of it leaking while not under boost (it does this by design, essentially bypassing the turbo and IC while under vacuum) I can hear it leaking while in this state, if you take the throttle right to the threshold at atm (no vacuum, no boost) you can hear the transition from it being opened to it being closed. Given that it uses the bypass outlet as a intake inlet while under vacuum I have wondered if a TIP that brings the BPV inlet closer to the MAF would make sense. Synapse has claimed positive effects and I believe throttle response is better but it would be interesting to see real test data on this. The sound is definitely like no other BPV I have run (stock, Greddy Type S and a Turbosmart )
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
| The Following User Says Thank You to Yatta For This Useful Post: | Lex (08-13-2013) |
![]() | | #34 | ![]() |
At the same time the charge piping is at a higher pressure level than the intake itself. By allowing air to bleed in front of the turbo by keeping the BPV open when not under boost there is less load on the compressor which results in less load on the turbine and this decreases pumping losses. Less pumping loss should marginally improve economy.
![]() | | #35 | ![]() |
| Not Ranked : 0 score I'm interested to see if Corksport is taking any of the data into consideration with their new bpv that's coming out
![]() | | #36 | ![]() |
Anyhow, thanks for the analysis, I have been quite happy with mine, it just works and it didn't need any adjustments, just bolted it on and forgot about it until your post.
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// | |
![]() | | #37 | ![]() |
What is your port setup on the Synapse? Also are you running it in push or pull mode?
![]() | | #38 | ![]() |
| Not Ranked : 0 score Tried push and pull; with the stock turbo I think anyone running pull will experience/hear part throttle fluttering on the valve (I did), so I configured it like stock (push), running single port (b used, a VTA) no additional preload.
![]() | | #39 | ![]() |
Groans: 171
| Not Ranked : 0 score @Lex; how would you say the synapse DV compares to the cobb bpv? I understand the configuration on the synapse can change from push to pull, but I mean in a apples to apples set up, how is the response and stability between the two? Just curious as I was sold on the cobb unit for my future upgrade list.
![]() | | #40 | ![]() |
1. Valve speed 2. Does it need to be serviced or lubricated. I am not a fan of these types of valves as they "lose" performance as the lube wears. 3. Reliability - are there wear or breakable items like diaphragms? 3. Adjustability 4. Fit and quality 5. I prefer push design for least surge
| The Following User Says Thank You to Lex For This Useful Post: | Mauro_Penguin (08-13-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/importance-boost-bypass-valve-147545/ | ||||
| What's the max psi on standard recirc? ? Mazda MPS Owners Club | This thread | Refback | 01-31-2015 06:21 PM | |
| What's the max psi on standard recirc? ? Mazda MPS Owners Club | This thread | Refback | 10-25-2014 10:40 AM | |
| The importance of good camber lol | AustinK | 2010 MS3 - Suspension & Brakes | 11 | 02-21-2013 12:15 PM |
| Report: The importance of luxury SUV and crossover sales explained | Haltech | Automotive News | 0 | 10-11-2012 04:40 PM |
| Report: Moscow Auto Show gaining importance | Haltech | Automotive News | 0 | 09-07-2012 07:10 AM |
| Re-enforcing the importance of matching tires on AWD | quad4svtspeed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 12-19-2011 09:38 AM |
| Christian Bale: The Importance of Being Ernest | Haltech | Celeberty Smut | 0 | 07-29-2009 11:50 AM |
