E-Tuners / Custom Hardparts
 Old 06-18-2013, 02:17 PM   #1
speeding3's Avatar
Posts: 118   (View Stats)
speeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond repute
Groaned at 17 Times in 8 Posts
Default JBR S-OTS vs Stratified Custom e85 tune
Hey guys maybe you can shed some light on this for me. I currently am running the S-OTS map for the jbr intake, but I am running a CS TIH and SRI, only because with my setup the cobb ots maps suck dick and my car runs like shit, but it kicks ass with the S-OTS tune.
My car is fully bolted minus a intercooler, I'm wondering will ther be a noticeable difference from the S-OTS to a custom 3-5 gallon e85 tune, or should I buy an intercooler and then tune a couple of months from now. I'm looking for the best bang for the buck rite now, I know that both would be optimal but I only have money for one or the other. I was hoping that the use of e85 would help negate the hotter BAT's due to being higher octane.
Any help would be great thanks.
speeding3 is offline   Reply With Quote
The Following User Says Thank You to speeding3 For This Useful Post:
Lex (06-18-2013)
 Old 06-18-2013, 03:34 PM   #2
There will absolutely be a difference with an E85 custom tune. The S-OTS maps are setup to be quite mild and for pump gas. They are not setup to run each car at its utmost potential for safety reasons and they are not setup to take full advantage of E85 fuel.
speeding3 (06-18-2013)
 Old 06-18-2013, 04:38 PM   #3
speeding3's Avatar
That's exactly the Info I was looking for. Im not running e85 rite now, but will be as soon as I get a stratified custom tune. What about the upgraded intercooler? will I still see good gains with just the e85 tune on a stock tmic and otherwise fully bolted?.
Lex (06-18-2013)
 Old 06-18-2013, 04:42 PM   #4
That's exactly the Info I was looking for. Im not running e85 rite now but will be as soon as i get a stratified custom tune. What about the upgraded intercooler will I still see good gains with just the e85 tune on a stock tmic.
Yes, no matter what parts you have installed, you will see gains with E85 (only exception is a meth kit with a large nozzle and good fuel that can get you to the same timing values as E85).
 Old 06-18-2013, 04:47 PM   #5
Speed3_BigV's Avatar
Posts: 23   (View Stats)
Speed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to behold
Speaking of intercoolers, I'm getting a custom front mount done soon. Are the OTS maps good to run with a front mount or will I need to switch to a Cobb map that supports FMIC... I hope to god I don't have to, the Cobb OTS maps suck balls! lol
Thanks
| 2010 Mazdaspeed with Tech Pkg / 18x8.5" Enkei T6S w/ Nitto NT05 245/40
| Cobb AccessPORT / Self Tuned
| Ultimate Racing Turboback Exhaust (Catted, Non-resonated) / Ultimate Racing FMIC
| Grimmspeed EBCS / Turbosmart Dual Port BPV / Denso ITV22 / Autotech Internals / JBR EGR Delete / Corksport OCC
| JBR Chrome-Moly 88A RMM / Corksport TMM Insert / Corksport Shifter Bushings
| Prosport Halo Boost Gauge / Corksport LED DRL and Foglight Bulbs / Rally Armor Mudflaps
Speed3_BigV is offline   Reply With Quote
The Following 2 Users Say Thank You to Speed3_BigV For This Useful Post:
Lex (06-18-2013), speeding3 (06-18-2013)
 Old 06-18-2013, 04:56 PM   #6
Thanks
The front mount should work well with the S-OTS.
Speed3_BigV (06-18-2013), speeding3 (06-18-2013)
 Old 06-18-2013, 05:14 PM   #7
speeding3's Avatar
Hey lex what about for logging for the custom tune can I keep the S-OTS map flashed even thow I'm running the Corksport Sri and TIH. I know u can't acess them in ATR i don't know if that will be an issue, but I feel like the S-OTS is a far better baseline than the POS cobb ots maps.
 Old 06-18-2013, 08:02 PM   #8
The MAF calibration may be off since the maps were designed for the JBR intakes.
 Old 06-18-2013, 08:58 PM   #9
speeding3's Avatar
Ok so should I just go back to the cobb ots maps for logging purposes
 Old 06-18-2013, 09:01 PM   #10
No, you can log with what you have. If you are getting a custom tune we will make the needed adjustments. If you see LTFTs greater than +/-10 then I would switch maps if you are planning to run the map for an extended period of time.
How To: Stratified Tune Lex Stratified Automotive Controls 1 07-24-2014 12:22 PM
Stratified Tune List Lex Stratified Automotive Controls 46 04-22-2014 10:26 AM
Stratified tune done. MS309 Stratified Automotive Controls 57 08-04-2012 05:39 PM
Just finished my Stratified tune zedekias Stratified Automotive Controls 11 07-18-2012 12:31 PM
Stratified (Lex) Tune! (330/393 VD) psychophyr Stratified Automotive Controls 11 02-23-2012 04:39 PM
Page generated in 0.32019 seconds with 22 queries
