E-Tuners / Custom Hardparts
Like Tree38Likes
 Old 12-05-2012, 01:18 PM   #41
CamSpeed360's Avatar
Posts: 793   (View Stats)
CamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the world
Groaned at 31 Times in 13 Posts
If the readings are turbulent/fluctuate. Look closely at MAF voltage since that's the root of the measurement
Noted. Thank you.
2007 Black Mica MS3
JBR 3.5 Whale Penis Intake = Cobb V2/Treadstone FMIC = PTP HPFP internals
Snow Meth Injection, AIS 5GPH = TurboXS Downpipe/Racepipe = SSP-OCC
Road Magnet Springs = Bilstien B8 shocks = Cobb RSB = SURE RMM
Tuned by the FREEK
CamSpeed360 is offline   Reply With Quote
 Old 01-02-2013, 01:50 PM   #42
Originally Posted by CamSpeed360 View Post
So you're suggesting an air straighter? Everything else is sealed. Or was. My car is stocked out at the moment.
@CamSpeed360; Did you reinstall the intake? Any issues?
CamSpeed360 (01-02-2013)
 Old 01-02-2013, 02:06 PM   #43
Yes sir, just the other day. Everything is running great. I need to do a maf cal but my LTFTs are within 4 while driving. At idle my LTFT is +20 so I need to adjust it there. It may have something to do with my catch can. But its running well for the most part. Maf cal, downpipe and then its toonin time!
2007 Black Mica MS3
Tuned by the FREEK
 Old 01-10-2013, 12:12 PM   #44
Awesome glad to hear it's resolved and it sounds like the MAF cal won't be too difficult.
CamSpeed360 (01-10-2013)
 Old 01-11-2013, 12:59 PM   #45
kentwat's Avatar
Posts: 238   (View Stats)
kentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond repute
Default HTP 3" values.
Lex I was thinking of getting the 3" HTP intake would I use the same values as the Sure 3"? Thanks for your support on the calculations. Kent
2011 Black Mica with Tech package.
Mods: AP, AT Internals, HTP 3" intake, OBX TP. XP5263 plugs. Tune by Kent
kentwat is offline   Reply With Quote
 Old 01-11-2013, 01:15 PM   #46
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Just ordered mine as well today. Anyone care to provide info on this?
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
 Old 01-11-2013, 01:17 PM   #47
LOL. I'll send you a map with a 3" maf curve.
 Old 01-12-2013, 12:46 PM   #48
Remember that the MAF calibration is mostly affected of the inner diameter of the MAF housing. SURE's housing is pretty darn close to 3". If the HTP is pretty close the MAF curve will work just fine. Things like the air filter will play a role but that is relatively minor and mostly seen at idle.
Also, don't be afraid of LTFTs. As long as they are less than +/-10% you're fine, especially if those larger numbers are at idle and low throttle. The LTFTs are the car's way of adapting to the environment and that's why they are there. Once the LTFTs are learned they are applied immediately to the MAF calculation. In other words, the car calibrates the MAF for you (within reason) using the LTFTs.
 Old 01-15-2013, 12:26 PM   #49
So are you saying that you can hit your targeted AFR after your car has learned its LTFT? I understand LTFT is for closed loop and when you're wide open you are in open loop. That's why the importance of a maf cal kinda confuses me. Do we calibrate our maf so that we don't have to worry fuel trims right after a new map flash?
I mean, my shit's pretty well calibrated now but I still don't have 100% understanding.
2007 Black Mica MS3
Tuned by the FREEK
 Old 01-15-2013, 01:09 PM   #50
Long term fuel trims are the ECUs way of scaling the MAF. So if your MAF is off 10% in a certain region and the ECU uses STFTs to adjust for this, eventually the LTFT will be set to 10%. That is equivalent to the MAF being scaled correctly in that area now since the final fueling calculation automatically includes the LTFT value.
STFTs are always active in closed loop and they help bring AFRs on target based on feedback from the O2 sensor. Eventually LTFTs are learned making the deviations from target AFR smaller and STFTs which rely on the O2 feedback become smaller. This means the car reaches target AFRs even faster.
In open loop STFTs and LTFTs are not active.
On the gen2 there are open loop WOT trims similar to STFTs that help the car target AFRs. We can't log these but the MAF can be 10% off and the car will track AFR targets perfectly fine. These WOT trims have a range of +/- 10-12% from what I've seen.
On gen1 cars there are some WOT trims but they take a lot longer to learn so in gen1 cars it is more important for the MAF cal to be closer to actual than in gen2 cars and fuel variations affect it more. However in gen1 cars there are also some trims that act at WOT and after enough WOT runs the car starts to track AFRs even better.
So what is the lesson here?
The MAF cal should be within +/- 10% in closed loop and I would say +/-5% in open loop. I would not strive for a perfect calibration because the weather, motor aging, gas used, A/C being on will change STFTs and LTFTs. The car does not run any "better" if the LTFTs are 1% versus 7%.
The learning mechanisms of the ECU are in place to allow for these variances in he MAF cal and adjust all the time. It's a smart machine
The Following 10 Users Say Thank You to Lex For This Useful Post:
ASHMS3 (01-18-2013), atvfreek (01-15-2013), CamSpeed360 (01-15-2013), Dahouse702 (01-23-2013), FistPump20fo7 (02-05-2013), Hush (01-24-2013), moomooz12 (01-16-2013), Pointless (05-17-2013), RichieRichness (01-16-2013), zxhoya (04-25-2013)
 Old 01-15-2013, 03:37 PM   #51
Well that makes it easier to wrap my head around. That was kinda what I was thinking but your explanation makes it much more simple. Thanks!
2007 Black Mica MS3
Tuned by the FREEK
The Following User Says Thank You to CamSpeed360 For This Useful Post:
Lex (01-15-2013)
 Old 01-16-2013, 05:56 PM   #52
JDW1's Avatar
Posts: 486   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
Just to be clear, these calibrations should be a good starting point for bigger turbo's also? Would it be prudent to decrease boost while dialing in wot afr's?
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out.
11 Mustang GT current.
JDW1 is offline   Reply With Quote
 Old 01-16-2013, 05:59 PM   #53
The MAF will read the same regardless of what turbo sits behind it. Also when making any map changes you should ease into the throttle and watch the vitals: Boost, AFR, Fuel Pressure, KR before stomping through a full high gear pull.
Also be aware that a larger turbo will flow more air so it will place the sensor reading into an area of the MAF curve that was not used previously. What I find is that if the curve is reasonable (not hacked up) a curve that matches the intake at low airflow levels will also match it at higher airflow levels.
JDW1 (01-16-2013), Voltwings (01-16-2013)
 Old 01-16-2013, 11:29 PM   #54
Voltwings's Avatar
Posts: 3,713   (View Stats)
^^ this. Going from my 3" intake, after scaling my MAF and then just 2 maf cals (was trying to be safe and rich but wwaayy over shot it) i was running just as close to target AFR with my 4". Granted going from a 3" to 4" i dropped a ton of MAF voltage so that was already a frequently traveled area that was well dialed in. Hell even now im barely touching 4.0v at 25 psi haha.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 01-22-2013, 09:50 AM   #55
JDW1's Avatar
For me the HTP values are pretty close, I was pretty rich at WOT in the upper RMP but I was ok with that. I know there's a lot of factors in place to get it dialed in for each car but it was a great starting point, thanks @Lex;
The Following User Says Thank You to JDW1 For This Useful Post:
Lex (01-22-2013)
 Old 01-22-2013, 09:55 AM   #56
From what I've read the HTP has a smaller ID than 3." Can someone measure the MAF ID and post it here for the HTP and I can make a better MAF cal.
 Old 01-22-2013, 03:42 PM   #57
JDW1's Avatar
Inside diameter looks like 2.75"
 Old 01-22-2013, 03:57 PM   #58
DamagedGoods's Avatar
Posts: 304   (View Stats)
DamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the world
Sigh I was hoping it was an honest 3"
Tappin
2007 Mazdaspeed 6 - Bolted, Methed, Tuned
DamagedGoods is offline   Reply With Quote
 Old 01-22-2013, 03:58 PM   #59
I heard 2.8" from someone else. Did you verify this with calipers?
 Old 01-22-2013, 04:27 PM   #60
JDW1's Avatar
All I had was a tape measure. 2.8 may be more exact
 Old 01-23-2013, 12:54 PM   #61
GODspeed7's Avatar
@Lex; would having the HTP 3" intake actually being 2.8" but scaling for 3" explain my rich condition at WOT?
 Old 01-23-2013, 12:58 PM   #62
Yes sir.
 Old 01-23-2013, 01:13 PM   #63
GODspeed7's Avatar
Yes sir.
Spoke with Matt at HTP and the inner diameter of the intake is 2.87" so take that for what it's worth!
The Following 2 Users Say Thank You to GODspeed7 For This Useful Post:
atvfreek (01-25-2013), Lex (01-23-2013)
 Old 01-23-2013, 09:00 PM   #64
I am getting a quite a few customers here that have issues with the MAF cals fpr the HTP intakes and I posted in their section. From my calculations the ID of these intakes is somewhere around 2.75." The ID should be measured right where the MAF sensor sits, not where the pipe is bead rolled - so measure further in than the bead rolled section.
For you guys that have them can you please measure the ID with some calipers? I want to settle this and get some MAF cals out for people to use and stop the confusion. A MAF cal for a 3" ID MAF won't work well at all for a 2.75" ID MAF.
Jakeypoo likes this.
 Old 01-24-2013, 05:19 AM   #65
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I have the 3.5 inch HTP. I was just doing my own maf cal but I think I messed it up again so was going to use ur jbr 3.5 cal and see where it got me.
As far as measuring the ID because of the honeycomb straightner it will be hard to get it.
@HTP; what the ID of the 3.5" intake
Damond Built Speed 6
 Old 01-24-2013, 07:23 AM   #66
alfre127's Avatar
Posts: 291   (View Stats)
alfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond repute
Gotta say thanks, used CPE 3.25 MAF Cal for My Sure 3.25, Wow AFR almost spot on barley have to do any MAF Cal, Thanks LEX.
GTX3076 EWG // Tial Waste Gate // Sure 3.25 Big Mouth // // JBR Side Motor Mounts // JBR, SS Kit, Corksport RMM Inserts // Cobb Pipping with TRL8 // CNT DP // CNT Cat back // DNP Mani // Autotech HPFP // Rota G-force 18x8.5 // Eibach Pro Kit Springs // Cobb AP, // Auto meter boost and vacuum gauges // AEM A/F gauge // AEM Meth Stage 2 kit // Hella Horns // PTP injector seals // PNP IM // TIGS // EGR Delete // ACT 6 Puck Sprung/Streetlite // Superskaterex 74MM TB //
alfre127 is offline   Reply With Quote
 Old 01-24-2013, 08:01 AM   #67
JDW1's Avatar
It's looking like for me and the HTP, around a .9 multiplier for the cruising breakpoints, up to 70 and .6 for WOT to get me to my comanded 11.8.
Still in the process of getting it within my tolerancees but that should have it very close.
 Old 01-24-2013, 08:17 AM   #68
So you're noticing that it is very rich in the WOT regions correct? I am running into this as well. The MAF curve for these intakes doesn't seem to follow curves for other MAFs which is a little troublesome. The shape of the curves should not change.
JDW1 (01-24-2013), Pointless (05-17-2013), rfinkle2 (01-24-2013)
 Old 01-24-2013, 08:42 AM   #69
GODspeed7's Avatar
@rfinkle2; this is a good thread too. This intake is proving to be a pain in the ass!
The Following User Says Thank You to GODspeed7 For This Useful Post:
 Old 01-24-2013, 08:45 AM   #70
No worries. As long as it is consistent, it is just a matter of making some changes to the curve.
 Old 01-24-2013, 08:46 AM   #71
GODspeed7's Avatar
You have an email man!
 Old 01-24-2013, 08:47 AM   #72
So you're noticing that it is very rich in the WOT regions correct? I am running into this as well. The MAF curve for these intakes don't seem to follow curves for other MAFs which is a little troublesome. The shape of the curves should not change.
Yes. I do see the 3" version especially rich @ wot.
I agree in theory. If we can get some sort of consistency, we will post our findings.
 Old 01-24-2013, 08:53 AM   #73
JDW1's Avatar
I mis typed, it's .96 at WOT not .6 but apparently I'm flowing more air than most at WOT, logged over 380g/s last night(curiously I know). My AFR's in that log were 11.7-11.6 mainly, I scaled back another 1% to get me ~11.8. In my first log with your Sure cal i was at 10.9 AFR by redline, maybe low 11's prior, I've just made my 3rd revision. I've seen LTFT's cruising ~-9 so those break points are definitely spot on for pulling that much.
 Old 01-24-2013, 09:51 AM   #74
Deldran's Avatar
Groans: 118
@Lex;
I am going to flash your 3.5" curve at lunch today.
Hopefully I can get some miles on and post some initial results of the difference.
I always seem to have trouble calibrating the area of the curve between a 2nd gear maf log and wot. That is where I screwed up last time and the curve had a bump in it so I figured I would start fresh I hope I can help out with this. I do love the 3.5" htp the fitment it great.
What could make it so much different than the jbr other than the built in honeycomb
Lex (01-24-2013)
 Old 01-24-2013, 11:09 AM   #75
Added the HTP 3" BETA calibration to OP. At least it's closer to the truth but not fully developed.
ASHMS3 (01-24-2013), FistPump20fo7 (02-05-2013), JDW1 (01-24-2013), ledfootrob (01-24-2013), magicka (01-24-2013)
 Old 01-24-2013, 10:11 PM   #76
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
Cheers for this, works well on my car. Idle is fine, C/L is only 3-5% off just gotta do some WOT logs but so far so good. Even managed to fit intake inside the Corksport Airbox, just had to make the hole slightly larger.
Im using the HTP 3" TIP 3" Maf housing and AEM Dry filter.
2012 Black Mazda 3 MPS
CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC
2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate
OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors
Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks
Versus Eurolace 19 x 8 +45 - Hankook RS3
Built & Tuned by Rob
Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18
DBA T3 Rotors - Carbotech XP10 Brake Pads
ledfootrob is offline   Reply With Quote
The Following User Says Thank You to ledfootrob For This Useful Post:
Lex (01-24-2013)
 Old 01-25-2013, 07:04 AM   #77
Deldran's Avatar
Groans: 118
@Lex;
So here is some initial stuff, no logs yet waiting to get some more miles.
It appears to be a bit rich at idle. LTFT at idle is -3
Then it appears to be lean at city cruisng aka 40 mph in 5th. LTFT there is 10
Then the couple times i went woot it was also a bit rich. I target 11.8 was getting 11.5-11.7.
Also this call does not like cold starts. Previously on an OTS cal the i modified for this intake i didnt have any issues. This morning i went out to start my car, it started then died a couple seconds after. It did this twice. It threw a CEL but it started on the third try and the CEL was no longer there. I was a bit late for work so i didnt try and check it before I started it for the 3rd time. I gave it a bit of gas and it stayed running.
This is odd to me because I took my previous stock intake cal i had did and just multiplied it by 1.66. This got me started, it spat and sputtered for a bit on first startup but after that never had a cold start issue and it was added almost 20% ad idle.
temps here today are 23 degrees so if it does it again when i go to leave work i will be sure to check the CEL
 Old 01-25-2013, 09:03 AM   #78
The 3.5" JBR calibration zeroes out the MAF curve up to 0.9V to avoid a CEL. If the HTP MAF is smaller that section might get into the idle regions and this may be causing the stalling. Take a MAF cal log including idle and a WOT log and I will see if I can come up with an HTP 3.5" cal that works better.
Does your intake have the honeycomb?
 Old 01-25-2013, 09:11 AM   #79
Deldran's Avatar
Groans: 118
Yes all of the HTP intakes have a built in honey comb. I will look and see how far up I zero out my old maf. I think it wasn't up to .9
 Old 01-25-2013, 09:25 AM   #80
sleepyspeed6's Avatar
Posts: 288   (View Stats)
sleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the world
I have a 3.5" intake and if it is under 15°ish it will start and die once then starts fine.
Hx35 sold
New sc6266
sleepyspeed6 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/maf-calibrations-bigger-intakes-124734/
VersaTune - View topic - DTC P2178, P2188 This thread Refback 12-19-2015 07:06 PM
VersaTune - View topic - Share your MAF Calibration This thread Refback 11-23-2015 12:53 AM
VersaTune - View topic - Hello This thread Refback 11-17-2015 02:20 AM
VersaTune - View topic - New to Versatuner/Tuning This thread Refback 06-29-2015 07:49 PM
Sorry gents, MAF CAL ? Mazda MPS Owners Club This thread Refback 12-24-2014 06:37 AM
For Sale: JBR 3" Intake, JBR Heavy Knob, Other assorted parts This thread Refback 07-26-2014 07:51 PM
4th Gear WOT log This thread Pingback 07-05-2014 04:12 AM
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune This thread Pingback 06-04-2014 11:50 PM
Cobb ap logs help This thread Refback 05-21-2014 04:56 PM
Emew's Tune - Page 23 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-18-2014 08:40 AM
Newbie COBB User This thread Refback 01-17-2014 01:58 PM
New custom made 3.75" Aluminum MAF Housings - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2013 07:09 PM
cobb sure map thats been maf corrected ? Mazda MPS Owners Club This thread Refback 12-08-2013 02:17 PM
Intake Tuning Question? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-03-2013 10:37 AM
Cobb Ap and dash hawk ? Mazda MPS Owners Club This thread Refback 10-04-2013 08:24 AM
Sure Full3 Aeros ID300 Mazdaspeed3 - Mazda 3 Quebec This thread Refback 09-15-2013 08:06 PM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 09-09-2013 10:10 AM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 08-29-2013 05:03 AM
Mrdouble99 Part out :( - Mazda 3 Quebec This thread Refback 07-28-2013 03:27 AM
Mrdouble99 Part out :( This thread Refback 07-27-2013 05:52 PM
HELP! Advice requested please on SRI and TIP with CobbAP - Page 2 This thread Pingback 05-16-2013 07:07 PM
Solid 14.2 AFR killing my vibe man! - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-22-2013 09:45 AM
Nouveauté : HTP 3" Intake Kit - Mazda 3 Quebec This thread Refback 01-28-2013 05:37 PM
HTP 3" full intake - top quality ? Mazda MPS Owners Club This thread Refback 01-27-2013 02:22 PM
HTP 3" Intake - Page 2 This thread Refback 01-24-2013 11:19 PM
AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3! Travis@Cobb 2010 MS3 - ECU Computer Tuning 173 03-25-2011 08:31 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Copying MAF calibrations between maps smakdown61
Cobb ATR Support
3 04-21-2009 02:52 PM
V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 5 01-09-2009 05:54 PM
Spy Shots: Next Pagani Zonda packing big engine, bigger intakes Haltech Automotive News 1 05-14-2008 05:02 PM
Page generated in 0.60099 seconds with 32 queries
