E-Tuners / Custom Hardparts
Like Tree38Likes
 Old 01-27-2013, 02:17 PM   #81
I've gotten a good amount of data for the HTP intake now to see that it is fairly close. Of course use at your own risk but the MAF calibration in the OP should be a very good start for the HTP 3" users.
The Following 7 Users Say Thank You to Lex For This Useful Post:
beachshoer (01-27-2013), Deldran (01-27-2013), JDW1 (01-27-2013), KevMS6 (01-27-2013), magicka (01-27-2013), MZRSPEED (09-03-2013), Pointless (05-17-2013)
 Old 01-27-2013, 04:46 PM   #82
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Weather has been crappy here this weekend hopefully I can get u some logs for the 3.5 in the next couple days
Damond Built Speed 6
 Old 01-29-2013, 09:49 AM   #83
Deldran's Avatar
Groans: 118
@Lex;
Here are some logs. It seems i can never get the 3rd and 4th breakpoints to learn anything. its hard for me to spend much time in those areas.
The knock i am seeing in the WOT log is not normal for me, usually i might only see 1 or 2 blips for .35
Also uploaded my map for referance
 Old 01-29-2013, 10:01 AM   #84
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
@Lex; Now that I'm using your MAF Cal. for the HTP 3", I'm having some issues with the car bogging down when coming to a stop. Could this be related to the MAF Cal.? I never noticed it before that.
 Old 01-29-2013, 11:14 AM   #85
mrdouble99's Avatar
Posts: 256   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
Wow Thanks Lex
Mazdaspeed3 - sold
- Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18
- Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 -
- 2010 drag time : 12.737@108.51mph - 259whp@280wtq
- 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq
2014 Black Mazda 6 GT MT
- Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing
- RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19
- 3M Gloss Black Chrome Wrap
- Autoexe Shifter Knob
mrdouble99 is offline   Reply With Quote
 Old 01-29-2013, 11:34 AM   #86
Could be any number of things. Use LTFTs and WOT AFRs as a guide.
BTW this cal is here to help you guys out and get you started. I am not supporting "issues" people have with the calibration.
ASHMS3 (02-04-2013), atvfreek (02-16-2013)
 Old 01-29-2013, 11:49 AM   #87
sidekick's Avatar
Groans: 47
I wasn't looking for support, simply wondering if other people have had similar issues. Thanks.
 Old 01-29-2013, 02:13 PM   #88
I know, I just wanted to make it clear that these are use at your own risk calibrations .
sidekick (01-29-2013)
 Old 01-30-2013, 11:22 PM   #89
Added a BETA 3.5" HTP calibration to the OP. Try it out and give me some feedback.
CamSpeed360 (01-31-2013)
 Old 02-02-2013, 11:44 AM   #90
Deldran's Avatar
Groans: 118
Flashing the Beta cal today.
Its interesting because my maf that i was calibrating had the same little humps in the curve, as your beta does. Those humps where why i decided to try the JBR maf cal. Figured i had messed it all up
 Old 02-03-2013, 10:48 AM   #91
Post up the results.
 Old 02-05-2013, 07:03 AM   #92
Deldran's Avatar
Groans: 118
Here are the results.
seems pretty close. I am targeting 11.8 at WOT its a little lean at first then seems to get pretty close the rest of the way through.
Still cant seem to get it to learn a trim for the 4th breakpoint. i dont think i ever get to it until i do a maf cal log.
Lex (02-05-2013)
 Old 02-05-2013, 11:18 AM   #93
Is this based on the cal I posted or were there any changes made? Also what year is your car?
 Old 02-05-2013, 11:54 AM   #94
Deldran's Avatar
Groans: 118
Its an 07.
no changes made. flashed your htp 3.5 beta cal and ran it for ~80 miles
why strange results?
Lex (02-05-2013)
 Old 02-05-2013, 11:57 AM   #95
Its an 07.
I would like to change the idle region and there is a bit of a bump at around 200 g/s but nothing major.
Can you change your LTFT breakpoints to the following and put some miles on it and get a MAF cal?
A:5.70, B:12, C:20, D:30, E:40 F:150g/s
 Old 02-05-2013, 12:01 PM   #96
Deldran's Avatar
Groans: 118
Will do. By maf cal you mean log. or you want me to get it all calabrated
 Old 02-05-2013, 01:43 PM   #97
MAF cal log once you have 40-60 miles on the flash.
 Old 02-06-2013, 12:13 AM   #98
klafaille's Avatar
Posts: 68   (View Stats)
klafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond repute
@Lex;
Here's an older MAF cal I have for a JBR 3.5" that is +/- 4.5ish using 93 octane. It should be great for getting up and running before fine tuning the cal.
I don't doubt in the least that zero'ing everything to 0.9 is useful, but I don't have any CEL or bouncing idle and it idles fine at 14.7/14.8 AFR.
Dunno if this is useful at all, but I figured I'd post it up.
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.04	0.05	0.11	0.16	0.24	0.32	0.43	0.56	0.72	0.86	1.04	1.24	1.45	1.69	1.96	2.23	2.53	2.88	3.25	3.65	4.34	5.08	6.83	6.34	6.98	7.75	8.63	9.30	10.32	11.28	12.13	13.10	14.14	15.33	16.54	17.67	20.06	21.36	23.03	24.78	26.57	28.40	28.97	30.87	32.77	34.68	36.58	38.98	41.52	44.17	46.96	50.23	53.23	56.35	59.57	62.93	66.42	70.02	72.86	75.69	77.86	83.53	88.04	92.54	100.67	106.94	113.22	114.90	118.21	121.53	124.24	133.29	140.25	143.63	147.01	151.48	158.90	165.00	171.17	175.88	183.99	190.64	195.61	202.53	211.59	216.93	226.60	232.35	242.63	250.95	258.62	267.33	276.24	285.35	294.68	304.21	313.91	323.79	333.88	344.22	354.76	365.51	376.50	387.73	399.22	410.94	422.90	435.10	447.55	460.24	473.21	486.43	499.90	513.64	527.64	541.92	556.47	571.30	586.40	601.79
2011 LSM
JBR 88 Duro RMM, JBR EGR Delete, JBR 3.5" WP Full Intake, COBB AccessPort, Autotech HPFP Internals, cp-e TMIC, Denso IVT22 Plugs, OBX Test Pipe from teh eBays
klafaille is offline   Reply With Quote
The Following User Says Thank You to klafaille For This Useful Post:
Lex (02-06-2013)
 Old 02-06-2013, 08:11 PM   #99
JDW1's Avatar
Posts: 486   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
Did some testing, log attached. The beta cal on the 3" is close, from what I can tell maybe a tad rich at idle and a hair lean at the beginning of WOT, an adjustment or two should have it about perfect.
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out.
11 Mustang GT current.
JDW1 is offline   Reply With Quote
The Following User Says Thank You to JDW1 For This Useful Post:
Lex (02-06-2013)
 Old 02-10-2013, 08:53 AM   #100
Deldran's Avatar
Groans: 118
@Lex;
Here is the results from what you asked.
Breakpoints changed to you suggestion. I did not get a log of the first break point. at 2k in second i am doing 10grams of flow.
If you need me to do something else to help let me know
Log 105 is 4th gear wot pull.
 Old 02-15-2013, 10:41 PM   #101
Redline143's Avatar
Posts: 930   (View Stats)
Redline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the world
I'll give the HTP 3.5" beta a shot too. I'm also inputting the breakpoints you suggested to Deldran, @Lex.
As I'm a student of the tune, do you mind explaining those breakpoints? Are they merely temporary as you're refining the 3.5 HTP sensor table more? It seems like placing them close like that near the beginning can help you gather helpful data. Why jump from 40 to 150? That seems like a really big jump with all of the other breakpoints so close...
Redline143 is offline   Reply With Quote
 Old 02-16-2013, 12:23 AM   #102
Voltwings's Avatar
Posts: 3,713   (View Stats)
you have to think about spool, once the turbo gets going it starts pulling in substantially more air. Do a data log of daily driving, then get on it a bit part throttle and take a look at what your G/s do and those break points will make a lot more sense.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 02-16-2013, 09:32 AM   #103
Redline143's Avatar
I realize that it would also help one to dial-in the lower region of the MAF sensor table a lot better too. Wouldn't it avail more resolution in the 0 to 40 range by having so many breakpoints? My logic may be flawed, but that's what I would think.
Then, to dial in the high side of the MAF cal table, maybe using breakpoints that are far spaced down low (in terms of grams/sec) and closer together up top (also in terms of grams/sec) could help?
Are you saying, @Voltwings, that these suggested breakpoints aren't temporary? That they're for more than just getting the 3.5 BETA table dialed in? If these breakpoints work well and are meant for continual (rather than temporary) use, I'd happily do so. I'm just really used to 5.7/18/50/75/120/150 (Bucker's suggested) which seems to be a more balanced, evenly-distributed scheme.
 Old 02-16-2013, 01:01 PM   #104
Voltwings's Avatar
Originally Posted by Redline143;1898446
Are you saying, [MENTION=9219
I'm using buckers breakpoints on my 4" and they work just fine. However, your maf cal is based off whatever breakpoints you are using, if you do a Maf cal and then change your breakpoints, you will more than likely need a new calibration so its a bit of a step in the wrong direction.
Past:
-Sold-
-Sold-
Current:
 Old 02-16-2013, 02:22 PM   #105
Redline143's Avatar
Yeah, that's what I was thinking. I'll gladly use new breakpoints to gather data and help the community, in general, and Lex's MAF chart for the HTP 3.5, specifically.
I was just trying to figure out if the breakpoints that Deldran and I are using are meant solely for data gathering, and that we'd change them later for more precise AFRs, or if the breakpoints will basically be the new ones that Lex is suggesting we use from now on.
Honestly, I find a lot a variation on suggested breakpoints. I'm not quite sure which work best and why. Also, I realize that "best" is often highly relative and goal-specific. I'm running E40, so that factor may alter "most accurate AFR breakpoints" (probably a better term than "best") even more. I've already noticed positive LTFT values across the board (in the +3 to +8 range, except a -3 or so at idle) in the 40 or so miles I've driven. I primarily attribute this to my ethanol blend.
Care to chime in, @Lex?
 Old 02-16-2013, 04:14 PM   #106
I will chime in to the breakpoints. The MAF curve is exponential. The higher you go in the curve the fewer points for resolution you have.
Further, take a log when normally driving. You almost never find yourself at 70 or even 120 g/s. Since the car spends very little time in that area of the curve it will take a LONG time for the ECU to learn the LTFTs. LTFTs are important to learn quickly because this is the ECU's way of calibrating your MAF. So if you have a point between 70 and 125 the car will almost never be in that area and the ECU won't apply the calibrations it learns before this to that area meaning it has to wait for STFTs to respond.
So there is logic behind the placement of my LTFT breakpoints and it is related to the way the vehicle is driven, increasing the speed at which LTFTs are learned, and finally taking into account the exponential like rise in mass airflow with respect to sensor voltage. Even distribution of the separation points in this case is not the correct way to approach this.
breakfstincluded (10-09-2013), Pointless (05-17-2013), Redline143 (02-16-2013), Voltwings (02-16-2013)
 Old 02-16-2013, 05:35 PM   #107
Deldran's Avatar
Groans: 118
Most of the time if you are in the 70+ range won't you also be in open loop where ltft doesn't matter?
At least that seems to be my experiance
Sent from my Nexus 4 using Tapatalk 2
 Old 02-16-2013, 06:21 PM   #108
Redline143's Avatar
As you explain this, it makes perfect sense. Looking at the plot of the MAF curve itself shows quite clearly that an exponential equation is used. Therefore, having breakpoints that are very close together at first and get progressively wider-spaced makes a lot of sense. I didn't know that having the ECU learn trims very quickly has benefits. I'll take your word for it, as I know you're very well-informed about our ECUs. That provides even more support to have lots of closely-spaced breakpoints down low, then moving to more widely-spaced up top.
Thanks, @Lex. So, just to be clear, you recommend these breakpoints for long-term use? Based on what you said, that would make sense. It's not about getting your HTP 3.5 dialed in at all. They're great points to use always, right?
 Old 02-16-2013, 06:33 PM   #109
Correct, these breakpoints is what I would use all the time unless there are specific reasons not to.
 Old 02-16-2013, 09:21 PM   #110
Redline143's Avatar
Okay, so here are my initial results and logs. I've included 4 MAF cal logs and 1 driving around log. These logs were taken with ~60 miles since flashing:
0.88-1.14 volts: -2.34 LTFT (will multiply voltage range by 0.9766 to adjust)
1.16-1.51 volts: +3.91 LTFT (will multiply voltage range by 1.0391 to adjust)
1.54-1.73 volts: +7.03 LTFT (will multiply voltage range by 1.0703 to adjust)
1.74-1.94 volts: +1.56 LTFT (will multiply voltage range by 1.0156 to adjust)
1.96-2.15 volts: +7.81 LTFT (will multiply voltage range by 1.0781 to adjust)
2.16-3.15 volts: +8.59 LTFT (will multiply voltage range by 1.0859 to adjust)
Hope these data help, @Lex
I'm calibrating, reflashing, and I'll repost the new results after another ~60 miles or so.
 Old 02-18-2013, 01:25 PM   #111
0.88–1.14 volts: -2.34 LTFT (will multiply voltage range by 0.9766 to adjust)
1.16–1.51 volts: +3.91 LTFT (will multiply voltage range by 1.0391 to adjust)
1.54–1.73 volts: +7.03 LTFT (will multiply voltage range by 1.0703 to adjust)
1.74–1.94 volts: +1.56 LTFT (will multiply voltage range by 1.0156 to adjust)
1.96–2.15 volts: +7.81 LTFT (will multiply voltage range by 1.0781 to adjust)
2.16–3.15 volts: +8.59 LTFT (will multiply voltage range by 1.0859 to adjust)
Thanks for the data. How are the WOT AFRs?
 Old 02-18-2013, 04:48 PM   #112
Redline143's Avatar
@Lex,
I haven't pulled any WOT logs yet. I was planning on doing so after the second calibration.
Would you like some pre-second calibration WOT logs? So far, my LTFTs have settled down pretty well. I'm now in the -3.7 to +5.5 range across the voltage/airflow spectrum. Several of the breakpoint ranges are actually within +/- 0.8 after my first revision, so they seem pretty much perfect.
Update: I just did the second recalibration:
1.06–1.11 volts: -3.12 LTFT (will multiply voltage range by 0.9688 to adjust)
1.12–1.42 volts: +3.91 LTFT (will multiply voltage range by 1.0391 to adjust)
1.68–2.10 volts: +0.78 LTFT (will multiply voltage range by 1.0078 to adjust)
2.12–3.16 volts: -0.78 LTFT (will multiply voltage range by 0.9922 to adjust)
The gaps in voltages represent regions that had an LTFT of 0.
These LTFTs were ~80 miles after flashing. I'll reflash the new map and do WOT logs for you. Do I need to wait a certain amount of time for the LTFTs to settle in for the purposes of gathering useful data on the WOT logs? I wasn't sure if the ECU needed some time to adjust to extrapolate the trims for WOT runs more accurately. If I don't hear back from you soon, I'll just wait ~50 miles before WOT logging.
 Old 02-19-2013, 11:14 AM   #113
@Lex,
LTFTs are not going to affect WOT so no you don't need to wait to take WOT logs.
So are you on the 2nd cal right now or the 3rd? You supplied 2 sets of adjustments. Did you apply both or did you let the trims settle more and then just applies the 2nd set quoted here to the MAF calibration in the OP?
 Old 02-19-2013, 06:25 PM   #114
Redline143's Avatar
I wasn't sure about LTFTs affecting WOT AFR--thanks for clarifying, @Lex
I applied each set of adjustments when I posted the data. I didn't wait for the trims to settle any more before doing so.
So, first I applied your 3.5 HTP MAF table and flashed the map. I ran about ~60 miles and adjusted the MAF sensor table with the values I first posted. Then, I reflashed.
After reflashing, I ran about ~80 miles and did another MAF sensor table calibration with the values I second posted. Then, I reflashed.
So, I'm on the 3rd map. The first was what you gave me. The second was after the first ~60 miles. The third (which I'm on right now) was after ~80 miles. The two sets of logs and data I posted were from between the 1st and 2nd flash, and the 2nd and 3rd flash.
So far, I have 0 miles on the newest (the 3rd) flash. I commuted with my wife to work today. Since today's my birthday, so I'm not sure if I'll be able to pull WOTs tonight, but I'll try to do so soon.
Let me know if this response clarified things for you, or if you have further questions.
The Following User Says Thank You to Redline143 For This Useful Post:
Lex (02-19-2013)
 Old 02-19-2013, 08:54 PM   #115
Seems like you're on the right track! Happy Birthday and post up the results from the 3rd calibration. Also FIY there are WOT trims that can go +/- 12% on gen2 cars. We can't log these trims. So we won't know how far the MAF is off at WOT in the gen2 cars unless it's more than +/- 12%
 Old 02-19-2013, 09:58 PM   #116
Redline143's Avatar
Thanks!
Wow, +/- 12% is definitely significant--I had no idea!
FWIW, I started with the JBR 3.5 curve you originally had posted on this thread on the previous calibration I was running. After getting things dialed-in, I was virtually always within 11.8 to 12.2 when targeting 12.0 AFR on my E40 mix. That means I was withing +/- 1.67%. I did virtually no WOT calibration too--there was no need.
If I can be within that range with this new calibration, I'll be happy. I notice the max JBR voltage shows over 600 grams/sec. This new calibration I'm using maxes out at about ~586. In other words, a 2.3% difference in flow at max voltage. The results should be interesting.
 Old 02-19-2013, 10:11 PM   #117
Thanks!
At WOT your ECU was adjusting your AFRs so you may have been further off. The JBR calibration is pretty good though and yes, his 3.5" has more flow headroom.
 Old 02-19-2013, 10:45 PM   #118
Redline143's Avatar
Makes sense... I kinda wish the HTP flowed more than the JBR, but it would only be bragging rights. There's no way I'll be maxing out my setup. I'm thinking of a BNR S3 one day, and I know that won't be a flow issue.
Gosh, even with a GTX3076 or larger, it probably wouldn't be an issue. I don't think I've ever seen a single log with 500+ grams/second, let alone almost 600, LOL!
 Old 02-21-2013, 09:25 PM   #119
Redline143's Avatar
Default 3rd flash results...
Alright, @Lex, here are the results from the 3rd flash. So, to recap: I did your initial Beta calibration table, drove ~60 miles, pulled logs, then recalibrated and flashed again. After running ~80 miles, I pulled more logs and then flashed again. I'm now on this 3rd calibration. I have driven ~60 miles before pulling these most recent (attached) logs. I have 2 WOT runs, 1 MAF cal run, and then a final run where I was sitting at a stop light, casually getting on an onramp, then coming to cruising speed on the highway.
The MAF cal shows I'm within +/- 1.56 for all ranges but one, which shows 3.12. One final calibration should lock my closed loop in nicely.
Regarding the WOT runs, you tell me. I'm targeting 12.0AFR. These logs look good to me; what say you? Since you're looking at them, can you offer me any insight or advice at all on how they look? My initial boost spike is brief and ~1.5 higher than my 21.0 target. I wonder if there's anyway to eliminate the initial WOT 10.x AFR I seem to always see.
Anyways, I hope these data help
 Old 02-21-2013, 10:29 PM   #120
I would not try and chase your tail with a 3.x LTFT. That is more than within spec - leave it as you will see more fluctuations from changes in weather.
As for the WOT regions, did you modify the WOT region at all from the original MAF cal you started from?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/maf-calibrations-bigger-intakes-124734/
VersaTune - View topic - DTC P2178, P2188 This thread Refback 12-19-2015 07:06 PM
VersaTune - View topic - Share your MAF Calibration This thread Refback 11-23-2015 12:53 AM
VersaTune - View topic - Hello This thread Refback 11-17-2015 02:20 AM
VersaTune - View topic - New to Versatuner/Tuning This thread Refback 06-29-2015 07:49 PM
Sorry gents, MAF CAL ? Mazda MPS Owners Club This thread Refback 12-24-2014 06:37 AM
For Sale: JBR 3" Intake, JBR Heavy Knob, Other assorted parts This thread Refback 07-26-2014 07:51 PM
4th Gear WOT log This thread Pingback 07-05-2014 04:12 AM
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune This thread Pingback 06-04-2014 11:50 PM
Cobb ap logs help This thread Refback 05-21-2014 04:56 PM
Emew's Tune - Page 23 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-18-2014 08:40 AM
Newbie COBB User This thread Refback 01-17-2014 01:58 PM
New custom made 3.75" Aluminum MAF Housings - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2013 07:09 PM
cobb sure map thats been maf corrected ? Mazda MPS Owners Club This thread Refback 12-08-2013 02:17 PM
Intake Tuning Question? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-03-2013 10:37 AM
Cobb Ap and dash hawk ? Mazda MPS Owners Club This thread Refback 10-04-2013 08:24 AM
Sure Full3 Aeros ID300 Mazdaspeed3 - Mazda 3 Quebec This thread Refback 09-15-2013 08:06 PM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 09-09-2013 10:10 AM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 08-29-2013 05:03 AM
Mrdouble99 Part out :( - Mazda 3 Quebec This thread Refback 07-28-2013 03:27 AM
Mrdouble99 Part out :( This thread Refback 07-27-2013 05:52 PM
HELP! Advice requested please on SRI and TIP with CobbAP - Page 2 This thread Pingback 05-16-2013 07:07 PM
Solid 14.2 AFR killing my vibe man! - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-22-2013 09:45 AM
Nouveauté : HTP 3" Intake Kit - Mazda 3 Quebec This thread Refback 01-28-2013 05:37 PM
HTP 3" full intake - top quality ? Mazda MPS Owners Club This thread Refback 01-27-2013 02:22 PM
HTP 3" Intake - Page 2 This thread Refback 01-24-2013 11:19 PM
AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3! Travis@Cobb 2010 MS3 - ECU Computer Tuning 173 03-25-2011 08:31 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Copying MAF calibrations between maps smakdown61
Cobb ATR Support
3 04-21-2009 02:52 PM
V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 5 01-09-2009 05:54 PM
Spy Shots: Next Pagani Zonda packing big engine, bigger intakes Haltech Automotive News 1 05-14-2008 05:02 PM
Page generated in 0.63825 seconds with 28 queries
