E-Tuners / Custom Hardparts
Like Tree38Likes
 Old 03-27-2013, 11:21 PM   #201
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
It will buck about the same and it will be more prone to litlle backfires. At least in my experience.
Boosted Beluga (03-27-2013)
 Old 03-27-2013, 11:25 PM   #202
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Ok thank you.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 04-02-2013, 12:44 PM   #203
Voltwings's Avatar
Posts: 3,713   (View Stats)
So i installed an HTP 4" intake on a 3071 car this weekend and got his base map dialed in last night, and all i can say is the car drives beautifully, it doesnt seem to buck or hesitate during shifts at all.
Changes to the tune include:
Scalaing the MAF (i will do a full MAF cal tomorrow once the car has had a chance to learn some trims)
Upping idle to 1000 rpms
Hardware:
Garrett GT3071r (no surge porting)
HTP 4" intake
Custom intercooler with BPV like 3-4" away from throttle body. Maybe it blows the air off so close to the throttle body / IM it doesnt have time to get turbulent when the throttle closes?
Stock downpipe ... he bought the big turbo on kind of a whim haha
I can try to get some logs for you guys to see but just wanted to check and see what you would like in them / under what conditions.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
Boosted Beluga (04-02-2013), Lex (04-02-2013), SparkySparks (04-08-2013)
 Old 04-02-2013, 07:13 PM   #204
Groans: 50
@Lex; I know this isn't the right thread but im too lazy to search lol
This was my findings between the AEM filter HTP supplies with their intakes and Spectre filter.
The Spectre Flows 9g/s more then the AEM filter there was 2* difference in intake temps. No changes to the tune.
Datalog 12 is with the Spectre filter
Datalog 14 is with the AEM filter
Both 3rd gear logs on the same stretch of road going the same direction.
08 Mazdaspeed 3
The Following User Says Thank You to Boosted Beluga For This Useful Post:
Lex (04-02-2013)
 Old 04-02-2013, 07:21 PM   #205
Even after correcting for the slight AFR difference there seems to be about 7g/s between the 2. Interestingly your throttle also seems to be more open with the AEM filter. Do you have a link to the Spectre filter?
atvfreek (04-09-2013), Boosted Beluga (04-02-2013)
 Old 04-02-2013, 07:38 PM   #206
Groans: 50
I think I was hitting the load limit with the spectre.
Spectre Performance :: The 400 MPH Company
You can get them at pepboys, autozone, ect.
08 Mazdaspeed 3
 Old 04-03-2013, 11:47 AM   #207
Do they publish filtering ability? Flow and filtering ability are often inversely proportional.
Boosted Beluga (04-03-2013)
 Old 04-03-2013, 12:07 PM   #208
Groans: 50
I have no idea. I'll ask my friend that works at O'Reillys. Maybe he can find out?
08 Mazdaspeed 3
 Old 04-09-2013, 10:39 AM   #209
JBR WP 3" MAF calibration added to the OP @jbarone;
JBR likes this.
agentgordon27 (04-09-2013), Dimenus (04-09-2013), Funkster777 (04-11-2013), JBR (04-09-2013)
 Old 04-09-2013, 11:02 AM   #210
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
lex you might want to note the jbr intake as the full aluminum version. I don't know if it will make a difference, but his new 3" wp silicone intakes use a different maf housing with a non honeycomb straightener.
 Old 04-09-2013, 11:05 AM   #211
JBR never had a 3" full aluminum. This calibration is for the new 3" WP which uses that MAF housing and a silicone inlet tube.
I have also added instructions on how to apply the MAF cal and what to look for afterwards to the OP.
zxhoya (05-04-2013)
 Old 04-09-2013, 11:07 AM   #212
doh you are right i was thinking of htp lol. i forgot that jbr only made the 3.5" in full aluminum.
 Old 04-09-2013, 11:13 AM   #213
Groans: 50
@Lex; my friend couldn't find anything out about the spectre filter ether.
08 Mazdaspeed 3
Lex (04-09-2013)
 Old 04-11-2013, 03:41 PM   #214
Voltwings's Avatar
Slightly off Topic @Lex; so feel free to move this elsewhere if it seems fit, but I was playing around and my 4" intake stutters when lifting off the throttle have been smoothed a bit increasing my low load WGDC.
I'm sure some people tried this a long time ago but the other day driving in slow moving traffic I would feel my car basically fall on its face every time I lifted and it got VERY annoying. Looking through my map a bit later I figured the abrupt change from some WGDC to no WGDC may have had something to do with that, adjusted values to the following and its much smoother.
@Tomas; not sure if you ever got your 4" settled, but here you will see the difference between a regular map and mine, hope it helps.
Past:
-Sold-
-Sold-
Current:
Boosted Beluga (04-11-2013), djuosnteisn (04-12-2013), Tomas (07-29-2013)
 Old 04-11-2013, 04:40 PM   #215
Groans: 50
I'm going to have to try that. Thank you.
08 Mazdaspeed 3
 Old 04-12-2013, 12:48 PM   #216
ry1g2uy3's Avatar
Posts: 49   (View Stats)
ry1g2uy3 is a glorious beacon of lightry1g2uy3 is a glorious beacon of lightry1g2uy3 is a glorious beacon of lightry1g2uy3 is a glorious beacon of lightry1g2uy3 is a glorious beacon of light
Lex, I noticed that about two weeks ago when I copied the values for the htp 3.5 You mentioned it was a beta . Now the (beta) has been removed. Did you make new revisions that I should re flash or were those values adequate? Thanks
ry1g2uy3 is offline   Reply With Quote
 Old 04-12-2013, 01:30 PM   #217
Nope, just saw it on enough cars to feel comfortable with it. Remember that with these big intakes it's always good to do a MAF cal log on your particular car.
Boosted Beluga (04-12-2013), ry1g2uy3 (04-12-2013), Speed3eak (04-16-2013)
 Old 04-12-2013, 01:43 PM   #218
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Interesting observation. My only $.02 on it is be careful with 100's down there. Having 100's throughout the entire light load and idle range could result in a very hot solenoid, and may lead to premature failure.
It's robust... and can handle 100's for short stints while wot... but i wouldn't want to leave 100's on it for a 20 minute period while you cruise down the highway at light load:
FEAR NOT........... the 100% WGDC
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Boosted Beluga (04-12-2013), Speed3eak (04-16-2013), Voltwings (04-12-2013)
 Old 04-12-2013, 01:55 PM   #219
Groans: 50
What about say 50%?
08 Mazdaspeed 3
 Old 04-12-2013, 03:45 PM   #220
Voltwings's Avatar
Noted! I am on a grimmspeed but still in no hurry to piss away $100, ill gradually start lowering it and see where the happy median is, thanks for the heads up.
What about say 50%?
See above ^^ ill either pm you or start a new thread to keep from crapping this thread up. The 4" intake stutter seems to have been moved here so I guess if its "relevant" enough we'll leave it here.
Past:
-Sold-
-Sold-
Current:
 Old 04-12-2013, 04:06 PM   #221
Groans: 50
Sounds good. I've learned to live with it so I'm not in a hurry.
08 Mazdaspeed 3
 Old 04-13-2013, 01:10 AM   #222
Voltwings's Avatar
New WGDC table, may bump them up to 60% just to see but 50% still seems very effective. Basically to test this what I would do is leave it in first and get to about 2700-3000 rpms, cruise for a second then lift off the throttle to simulate stop and go traffic. Basically doing this there was a slight hesitation as soon as I lifted, but then a smooth gradual deceleration, Seems to have smoothed things out quite a bit.
Past:
-Sold-
-Sold-
Current:
Boosted Beluga (04-13-2013)
 Old 04-13-2013, 10:51 AM   #223
Groans: 50
Thank you. I sit in stop and go traffic almost every day. Lol
08 Mazdaspeed 3
 Old 04-19-2013, 08:09 PM   #224
mrdouble99's Avatar
Posts: 256   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
My Full3 Aeros ID300 Intake is installed.
MAF cal is done using @Lex Cal.
Long ride tomorow, so i'll update how it goes
Mazdaspeed3 - sold
- Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18
- Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 -
- 2010 drag time : 12.737@108.51mph - 259whp@280wtq
- 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq
2014 Black Mazda 6 GT MT
- Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing
- RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19
- 3M Gloss Black Chrome Wrap
- Autoexe Shifter Knob
mrdouble99 is offline   Reply With Quote
The Following User Says Thank You to mrdouble99 For This Useful Post:
Lex (04-20-2013)
 Old 05-01-2013, 08:41 PM   #225
bstover17's Avatar
Posts: 586   (View Stats)
Groans: 228
I got my maf cal down to -2.34 so I think I am done with my cal thanks to this thread. I used Lex's figures for the HTP 3" intake and tweaked them somewhat. Now to learn how to tune until I can get a stratified tune!
2010 MAZDASPEED 3
The Following 2 Users Say Thank You to bstover17 For This Useful Post:
jmhinkle (05-01-2013), Lex (05-01-2013)
 Old 05-04-2013, 01:06 PM   #226
Redline143's Avatar
Posts: 930   (View Stats)
Redline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the world
Has anyone else noticed that if your MAF is dialed-in with a 93 tune and you switch to an ethanol tune that your ECU is consistenly needing to add ~5-8% more fuel, everything else being equal? I know it's not a hardware issue. The only variable is the fuel (FSG and injector scalar changed for the proper ratio too, of course).
Any tuners care to speak to this? @rfinkle2? @atvfreek? @Lex? @Bucker? @phate? Any of the numerous other highly competent folks I didn't mention?
I don't know the technical terms, but doesn't ethanol create sort of a vacuum effect in the combustion chamber and therefore mean that at a given MAF voltage, you actually should be seeing more grams/second when properly calibrated? I was thinking of multiplying all of my open-loop ranges (150 grams+) by a conservative 1.02 and seeing what my WOT logs show. The open loop fuel trims which we know exist on Genpus (but don't have access to) means there's a lot of guess work. Ideally, I'd want to be in the center of the ECU's range of O/L fuel trim adjustability, but since I'm tuning blind up there (not seeing those O/L trims) I'm trying to get a good idea where to start.
TLDR version: when running ethanol, should we scale the O/L MAF table ranges (~150 grams+) by a certain amount to account for the additional grams/second we see when running ethanol, everything else being equal?
Redline143 is offline   Reply With Quote
The Following User Says Thank You to Redline143 For This Useful Post:
phate (05-04-2013)
 Old 05-04-2013, 01:09 PM   #227
Ethanol is an oxygenated fuel. That means it carries more oxygen in the fuel itself and this is why you will run "leaner" if you add E85 without scaling anything to add extra fuel volume.
Redline143 (05-04-2013)
 Old 05-04-2013, 01:10 PM   #228
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I've always chalked it up to 1 of 2 things: the scalars aren't perfect, or the mix isn't perfect. If I'm close on trims when I switch and I'm hitting OL fueling targets, I don't worry about it. I do MAF cals on my own car when LTFT's are >|10%|.
-06 MS6
-Corn fed 07 MS3 - Sold
bob^3 (08-26-2013), Bucker (05-04-2013), Lex (05-04-2013), Redline143 (05-04-2013)
 Old 07-09-2013, 08:28 AM   #229
bhamitgeek's Avatar
Posts: 362   (View Stats)
bhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the world
just fyi with the JBR intake, you should probably just zero out anything below 0.9v. @Ziggo figured out that this will trip the Crank Position Sensor circut malfunction CEL because the KOEO voltage is around .9 when its scaled so much. The ECU sees no airflow and thinks there should be at that voltage, or something like that ha. I used to get the CEL occasionally, and since I've zero'd out everything below 0.9v, the CEL has not returned.
Would this be the case for the regular St2 PowerPath too? @Lex
bhamitgeek is offline   Reply With Quote
 Old 07-09-2013, 09:20 AM   #230
No the powerpath is a stock sized maf intake. This applies to the much larger intakes.
bhamitgeek likes this.
bhamitgeek (07-09-2013)
 Old 07-09-2013, 03:43 PM   #231
elroes's Avatar
Posts: 52   (View Stats)
elroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud of
Installed the HTP 3.5" last week and used the MAF cal here (also bumped the idle to 850 rpm for good measure). First start had a slight stumble, after that all is good. LTFTs are within +/- 5% after 5 days of driving with one longish trip thrown in (about 1 tank of gas). Sadly the one log I took showed almost no change in g/s at redline However, car was holding slightly more boost on the Cobb Stage 2 map (a little over 18 psi) and Vdyno showed about a 10 hp gain. None of that means a whole lot though, just know that the cal works! Now I need an e-tune...
2009 True Red Mazdaspeed3
HTP 3.5" Intake -- JBR RMM -- AccessPort -- Autotech HPFP Internals
CP-E Catted DP -- GFB Respons -- Denso ITV22s -- Cobb Catback
elroes is offline   Reply With Quote
The Following User Says Thank You to elroes For This Useful Post:
Lex (07-09-2013)
 Old 07-29-2013, 11:57 AM   #232
Added the JBR 3.5" WP silicone intake MAF calibration.
Also added MAF cal for 4" HTP Beta.
Last edited by Lex; 07-29-2013 at 11:58 AM. Reason: MSF Database - Automerged Doublepost
Code Monkey (07-29-2013), Tomas (07-29-2013)
 Old 08-24-2013, 05:47 AM   #233
Mistersix's Avatar
Posts: 2,585   (View Stats)
Installed and calibrated a JBR 3.5" and everything is fine except for some issues during cold start up. When the car is full cold it struggles to find idle and either stalls a few times and needs re started or nearly stalls. Which throws a code, p0300 i think which is random misfire due to the stumbling i assume.
Any advice? Was wondering if an air straightener would help.
 Old 08-24-2013, 09:27 AM   #234
Groans: 50
You don't have a honeycomb air straightener? Could be your problem.
08 Mazdaspeed 3
 Old 08-24-2013, 12:28 PM   #235
Mistersix's Avatar
No. The all aluminum JBR intakes didn't come with one. And i don't think he's stocking them any more so i'll have to look else where. Car runs great other wise. Just stumbles when i start it after sitting all nite.
 Old 08-24-2013, 01:08 PM   #236
You don't need a straightener and I doubt it will help with a momentary cold start stumble.
Mistersix (08-24-2013)
 Old 08-24-2013, 03:51 PM   #237
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Do a cold start log & see what's what-
key on, start log, start car
340hp / 371tq
 Old 08-24-2013, 08:16 PM   #238
Mistersix's Avatar
I'll get one tomorrow morning. I've been monitoring things when it happens but all the figures go wonky because of the stumbling.
The maf cal is zero'd at .9v and down. But the voltage is higher than that during warm up so i don't think thats it. I'm puzzled atm.
 Old 08-24-2013, 11:40 PM   #239
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
@Lex:
Could you please explain why you're using the same maf curve for MS3 and MS6 models, which have totally different oem curves (or are the factory differences just because of the different airbox constructions)?
After upgrading from a CS sri to a 3.5" JBR wp I get extremely low maf voltage values (max around 4V) and thus very low load and maf g/s values.
I'm still using a rough maf calibration resulting from a constant, commonly recommended multiplication factor of 1.65 (which is d^2/d_oem^2), but in your suggested maf curve for the JBR 3.5" you are using a varying correction factor up to ~1.75.
Why do you use such a large factor - and doesn't the size of the tip connection (2.25"/4") matter at all?
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 08-25-2013, 07:03 PM   #240
Originally Posted by EmPeEs6 View Post
@Lex:
Generally speaking only the inner diameter of the MAF housing (where the sensor sits) matters for the MAF calibration. The MAF calibration is simply dependent on that piece of pipe and the sensor itself which is the same for the MS3 and MS6. What is in front and behind the MAF housing (TIP, filter, etc.) can skew the MAF curve slightly but generally should not have a large effect. Air straighteners also affect the curve and you will see this in intake that have them (HTP) versus ones that don't.
EmPeEs6 (08-26-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/maf-calibrations-bigger-intakes-124734/
VersaTune - View topic - DTC P2178, P2188 This thread Refback 12-19-2015 07:06 PM
VersaTune - View topic - Share your MAF Calibration This thread Refback 11-23-2015 12:53 AM
VersaTune - View topic - Hello This thread Refback 11-17-2015 02:20 AM
VersaTune - View topic - New to Versatuner/Tuning This thread Refback 06-29-2015 07:49 PM
Sorry gents, MAF CAL ? Mazda MPS Owners Club This thread Refback 12-24-2014 06:37 AM
For Sale: JBR 3" Intake, JBR Heavy Knob, Other assorted parts This thread Refback 07-26-2014 07:51 PM
4th Gear WOT log This thread Pingback 07-05-2014 04:12 AM
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune This thread Pingback 06-04-2014 11:50 PM
Cobb ap logs help This thread Refback 05-21-2014 04:56 PM
Emew's Tune - Page 23 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-18-2014 08:40 AM
Newbie COBB User This thread Refback 01-17-2014 01:58 PM
New custom made 3.75" Aluminum MAF Housings - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2013 07:09 PM
cobb sure map thats been maf corrected ? Mazda MPS Owners Club This thread Refback 12-08-2013 02:17 PM
Intake Tuning Question? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-03-2013 10:37 AM
Cobb Ap and dash hawk ? Mazda MPS Owners Club This thread Refback 10-04-2013 08:24 AM
Sure Full3 Aeros ID300 Mazdaspeed3 - Mazda 3 Quebec This thread Refback 09-15-2013 08:06 PM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 09-09-2013 10:10 AM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 08-29-2013 05:03 AM
Mrdouble99 Part out :( - Mazda 3 Quebec This thread Refback 07-28-2013 03:27 AM
Mrdouble99 Part out :( This thread Refback 07-27-2013 05:52 PM
HELP! Advice requested please on SRI and TIP with CobbAP - Page 2 This thread Pingback 05-16-2013 07:07 PM
Solid 14.2 AFR killing my vibe man! - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-22-2013 09:45 AM
Nouveauté : HTP 3" Intake Kit - Mazda 3 Quebec This thread Refback 01-28-2013 05:37 PM
HTP 3" full intake - top quality ? Mazda MPS Owners Club This thread Refback 01-27-2013 02:22 PM
HTP 3" Intake - Page 2 This thread Refback 01-24-2013 11:19 PM
AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3! Travis@Cobb 2010 MS3 - ECU Computer Tuning 173 03-25-2011 08:31 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Copying MAF calibrations between maps smakdown61
Cobb ATR Support
3 04-21-2009 02:52 PM
V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 5 01-09-2009 05:54 PM
Spy Shots: Next Pagani Zonda packing big engine, bigger intakes Haltech Automotive News 1 05-14-2008 05:02 PM
Page generated in 0.62712 seconds with 37 queries
