E-Tuners / Custom Hardparts
Like Tree5Likes
  • 4 Post By Lex
  • 1 Post By Lex
 Old 08-14-2015, 03:27 PM   #1
Default MAP sensor upgrade now included in the GA
We've just added even more functionality to the Guardian Angel. Now it not only controls the BOV/BPV but it is also your MAP sensor upgrade.
Anyone who is upgrading the turbo upgrades their MAP sensor to 3 bar, 3.5 bar or 4 bar. This ranges in cost from $100 to over $250.
The Guardian Angel internally already contains a 4bar MAP sensor (good for reading up to 44psi of boost if need be). We are now offering the output from this MAP sensor to act as the MAP sensor for the main ECU with a very simple wiring modification. The OEM 2.5 bar MAP sensor will still be used for temperature (Boosted Air Temps). The GA MAP sensor will accurately send the manifold pressure to the OEM ECU.
We have been testing this feature and there have been no issues - this upgrade will perform the same as installing a replacement Bosch MAP sensor.
That means that with a GA you never have to upgrade your MAP sensor again (unless you run more than 44psi of boost). Whether you need a 3bar, 3.5bar, or 4bar this has you covered.
We are now offering a no cost addition to the GA V2 to have this MAP sensor output available.
All the other GA features are still there (Failsafe, BPV/BOV control) which are huge pluses especially on a big turbo build.
Have a look at the details here.
The Following 16 Users Say Thank You to Lex For This Useful Post:
Amnesiac (08-14-2015), aromig (08-16-2015), btstarcher (08-15-2015), Castillo817 (09-25-2015), cshunter (08-15-2015), Etipp98 (09-25-2015), Finchee (09-27-2015), Hammology (09-29-2015), lnumbp (09-29-2015), magicka (10-02-2015), Mauro_Penguin (08-16-2015), monkey.bones.007 (08-14-2015), MS3Shadow (08-14-2015), Pointless (08-15-2015), redboat (03-29-2016), speed_freak91 (09-29-2015)
 Old 08-15-2015, 07:10 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
You're making this more and more desirable. Buy this and sell my 3 bar here?.....
 Old 08-16-2015, 12:20 AM   #3
You can definitely do this. No need for another map sensor or an adapter harness.
 Old 09-25-2015, 10:32 AM   #4
SNOW_QN's Avatar
Posts: 384   (View Stats)
Does this require any unique tuning if the map signal comes from this device if the stock sensor is still installed?
Sent from my SCH-I545 using Tapatalk
 Old 09-29-2015, 12:23 AM   #5
The only tuning is setting the correct MAP sensor scalar and offset as you would with any upgraded MAP sensor.
The scalars and offset for any MazdaSpeed are:
Scalar A: 82.60, Scalar B: 1.00, Offset: -3.48 (kpa)
SNOW_QN likes this.
 Old 09-29-2015, 03:47 AM   #6
SNOW_QN's Avatar
Sounds good. Appreciate the answer. I'll be picking one up in a few weeks.
 Old 09-29-2015, 05:46 AM   #7
ricardo_yen's Avatar
Posts: 27   (View Stats)
ricardo_yen will become famous soon enough
Hi Alex,
Can anything be done on a V1 Unit ?
2007 Mazda 6 MPS
Full House
Fully Loaded
ricardo_yen is offline   Reply With Quote
 Old 10-04-2015, 01:55 PM   #8
Originally Posted by ricardo_yen View Post
Hi Alex,
We can retrofit it as well for the 4 bar MAP sensor. It is $50 and you have to cover shipping.
How-To: Painless 3 BAR MAP Sensor upgrade TiGraySpeed6 MazdaSpeed 6 - How-To's 118 07-16-2018 07:38 AM
Stock Fitment 3 Bar Map Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - ECU Computer Tuning 529 02-23-2017 05:15 PM
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 234 10-25-2014 01:54 AM
3.5 Bar Map Sensor Upgrade help Nitr0EngiE MazdaSpeed 3/6 - ECU Computer Tuning 9 12-05-2012 11:11 AM
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MSF KB - Mazdaspeed 3/6 - Fuel 234 09-19-2012 01:53 PM
Page generated in 0.28887 seconds with 23 queries
