E-Tuners / Custom Hardparts
 Old 01-16-2014, 12:52 PM   #1
Default More intake and turbo discussion!
Just wrote another article - this time with more detail - regarding the effects of intakes and pressure drops for turbochargers. It's an easy read - have a look and discuss!
Blog : A Technical Discussion of Intakes and Turbocharging : Stratified Automotive Controls
On a similar theme, older blog posts:
Blog : Does a downpipe make a difference on a stock turbo MazdaSpeed3? : Stratified Automotive Controls
Blog : The effects of intake air temperatures on turbocharged vehicles : Stratified Automotive Controls
The Following 26 Users Say Thank You to Lex For This Useful Post:
Agent_Orange (01-16-2014), beachshoer (01-18-2014), bioevolve (01-20-2014), Bolted6 (01-20-2014), breakfstincluded (01-17-2014), Chron (01-16-2014), Code Monkey (01-20-2014), cymen (01-20-2014), Hammology (01-17-2014), Hush (01-18-2014), ibcrusn (01-21-2014), KCi (01-16-2014), Mauro_Penguin (01-17-2014), mazda_speed_6 (01-17-2014), mike w (01-18-2014), Mortose (01-16-2014), Pu Manchu (01-18-2014), pzr2874 (01-17-2014), rymanmazda (01-18-2014), SarcasticOne (01-17-2014), sidekick (01-16-2014), snailD (01-20-2014), SparkySparks (01-16-2014), TWENTY1 (01-17-2014), WetzMS3 (01-17-2014), YABBAMZR (01-20-2014)
 Old 01-16-2014, 12:56 PM   #2
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
Lex, thanks to you and all your blogs, i had to make room, and now i don't know math, or remeber my childhood.
99 miata: sold
The Following 3 Users Say Thank You to Mortose For This Useful Post:
derek13p (01-17-2014), Lex (01-16-2014), Mauro_Penguin (01-17-2014)
 Old 01-17-2014, 02:05 PM   #3
mazda_speed_6's Avatar
Posts: 84   (View Stats)
mazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nice
dam good blog,lots of information. on a bnr stg 3 would there be a big gain in power with a 3 inch intake over stock size?. i see most people run the stock size intake on this turbo, i was planing on keeping my sure aeros and buying a jbr tip when i go bnr stg3 but now im leaning more towards getting a 3 inch intake, more power and safer for the turbo itll be worth the extra money..
2006 MS6 sri/tbe/cpe diff mount/TS bpv/AT internals/jbr motor mounts/COBB acessport/stratified ots map/act 6 puck
mazda_speed_6 is offline   Reply With Quote
The Following User Says Thank You to mazda_speed_6 For This Useful Post:
Lex (01-17-2014)
 Old 01-17-2014, 02:08 PM   #4
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Love seeing this stuff compiled in your articles...
MSF has so much info, but it's not always easy to draw a conclusion even after forum crawling a dozen threads.
The Following 5 Users Say Thank You to breakfstincluded For This Useful Post:
Cheapspeed (01-20-2014), Lex (01-17-2014), Mauro_Penguin (01-18-2014), mazda_speed_6 (01-17-2014), pzr2874 (01-17-2014)
 Old 01-17-2014, 03:05 PM   #5
Yes absolutely. A lot of the OEM sized intakes are maxed out and can cause MAF related fuel cut when you really push the BNR. A 3"+ intake on a big turbo is a almost a must.
Thank you! Glad it's useful!
Last edited by Lex; 01-17-2014 at 03:05 PM. Reason: MSF Database - Automerged Doublepost
breakfstincluded (01-17-2014), mazda_speed_6 (01-17-2014)
 Old 01-17-2014, 11:11 PM   #6
@Lex what 3 inch intake would you recommend? ill more than likely grab a jbr 3" intake because he use a k&n filter, high quality filter better flow. i would assume it would flow better than a sure intake, i love my sure sri, i bought it way back when sure was still part of this forum but the filter on it looks kinda cheap well compared to a k&n filter.
 Old 01-17-2014, 11:18 PM   #7
I'm no Lex, but on 3" I personally like the metal intakes like the HTP because you can just switch couplers if you go big turbo, instead of getting a whole new intake.
The Following 3 Users Say Thank You to breakfstincluded For This Useful Post:
mazda_speed_6 (01-17-2014), Mortose (01-17-2014), snailD (01-17-2014)
 Old 01-17-2014, 11:34 PM   #8
That's a good point it's a pain having to replace the intake for every turbo upgrade.. I'm gonna have to look in to metal intakes I like silicone but in the long run a metal intake will save me some money if I go bigger.
 Old 01-18-2014, 02:18 PM   #9
The SURE filters were super restrictive. I did testing with them and you can definitely gain from just swapping filters.
mazda_speed_6 (01-19-2014), snailD (01-20-2014)
 Old 01-20-2014, 06:28 PM   #10
i kinda figured it was a restrictive intake, kinda a weird the silicone and maf housing are made of good quality and looks good but the filter looks like its a $5 filter. what brand of filter did you use when you did the test, if you dont mind me asking?? i might swap my filter for a aem dry flow i got laying around maybe ill be able to get past 12 psi from 5000rpm- redline..
 Old 01-20-2014, 06:48 PM   #11
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Think he rates the AEM filters as some of the best...
The Following User Says Thank You to SarcasticOne For This Useful Post:
mazda_speed_6 (01-20-2014)
 Old 01-20-2014, 07:50 PM   #12
I've been using the AEM dryflows for a while now with great results. The flow similarly to a K&N without the oil or mess.
 Old 01-20-2014, 08:06 PM   #13
MechEnix's Avatar
Posts: 186   (View Stats)
MechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond repute
I think you need this one instead of Bernoulli's Eq, Darcy?Weisbach equation - Wikipedia, the free encyclopedia
Isn't the flow in the intake turbulent?
% Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe
% Next up = Custom Tune
MechEnix is offline   Reply With Quote
The Following User Says Thank You to MechEnix For This Useful Post:
Lex (01-20-2014)
 Old 01-20-2014, 11:02 PM   #14
Yes it is turbulent. The head loss can be approximated by this equation plus head loss due to junctions in the intake piping.
Bernoulli states there is conservation of energy meaning that any time you increase velocity you drop pressure and velocity increase is proportional to the diameter of the tubing. Due to the flow being turbulent friction, and thus the material of the tubing do play a role in pressure loss.
 Old 01-21-2014, 01:26 PM   #15
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
Great article, thanks. All three should be a must read for folks new to turbo'd engines.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
The Following User Says Thank You to ibcrusn For This Useful Post:
Lex (01-21-2014)
2010+ Mazdaspeed 3 performance air intake discussion Nataphen 2010 MS3 - Turbo Induction 467 12-30-2017 11:09 AM
2010+ Mazdaspeed 3 performance air intake discussion Nataphen MSF KB - Mazdaspeed 3/6 - Turbo Induction 442 09-19-2012 06:10 PM
Intake air temp discussion Lex Stratified Automotive Controls 70 08-31-2012 01:26 PM
Page generated in 0.34565 seconds with 26 queries
