E-Tuners / Custom Hardparts
  • 1 Post By
 Old 09-24-2016, 08:56 PM   #1
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Originally Posted by Bob-o View Post
If you just reflashed, you probably need to drive around a bit for the car to learn the LTFT's, no? Also, STFT's come secondary to LTFT's i thought? I understand the LTFT's are build from STFT's, but they are much more subject to change and can swing up and down from moment to moment?
I am very curious to see if addressing the MAF harness will fix the issue; problem is I'm working out of town, and not at my car
Reading the TSB's for this issue, they indicated it was the black ground wire that caused all these issues. Should this be the only wire I do? Or would all the wires need to be cut, stripped, and repinned?
You are right about the trims but what i noticed with my car is that ir learns the trims within 2 miles of driving. And they will slightly level out within the next 10 but its basically spot on within 2 mile. I tried disconnecting the battery and re flashes and it still learns it that fast.
Yes ltft are based off stft but when my ltft are -.94 with stft -17 the car should pick that up pretty quick. 2 day it learned some and went to -10 ltft and then out of no where it went to -.16 ltft like if some how it got reset? Idk whats going on there. Going to check for leaks again and if nothing try adjusting the maf cal a bit.
And yes i read it was the black wire also. I ended up with a new pig tail so i cut and spliced all new wires. Now when i wiggle the wires i get nothing to happen on the ap which is good. I also have a 2nd maf sensor i may try out and see what happens.
Mysterious scratches 20boxer Gen2 MS3 General Discussion 2 05-30-2016 05:59 PM
AFR Very Rich @ WOT - LTFT High Negatives Axela_EN 2010 MS3 - Fuel, Nitrous & Water Injection 2 02-25-2014 07:36 PM
Somewhat rich LTFT after SRI+TIP install MarcoAntonio MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 02-23-2013 08:43 AM
Rich idle, Rich on throttle tip in MSP6 MazdaSpeed 6 - Engine, Transmission & Driveline 39 02-17-2013 06:49 PM
Mysterious Cut senor blanco ms3
Cobb ATR Support
14 08-01-2009 08:30 AM
Page generated in 0.23958 seconds with 22 queries
