![]() Join Date: Sep 2013
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score its seem like i have some kr i have drive 60 miles before do this datalog i have datalog with my ap3 i will post my log my mod are jbr stage 2 intake autotech hpfp test pipe can you tell me if all is ok or i need a custum tune |
| The Following User Says Thank You to sebms6 For This Useful Post: | pzr2874 (10-24-2013) |
| Not Ranked : 0 score Looks like the KR you have is very mild. It would help if you logged all the parameters below. However with 91 octane in some areas you might get a touch of knock. It's not serious, so bumping octane a tiny bit or improving cooling (I notice some high BATs) will take care of it completely. As will a custom tune for your car of course. Accel. Pedal Pos. Actual AFR Boost Boosted Air Temp Calculated Load Coolant Temp Engine Speed (RPM) HPFP Actual Pressure Injector Duty Cycle Intake Temp Intake Valve Adv. Knock Retard Long Term FT (LTFT) MAF Voltage Mass Airflow Spark Advance Throttle Position Vehicle Speed Wastegate Duty Cycle
| Enter the 36 Chambers ![]() Join Date: May 2009 Location: Beverly Hills, FL
Rep Power: 1632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,746
| Not Ranked : 0 score sorry to resurect a dead thread. just curious as to what a person must do, driving wise, to make a good datalog. i searched, but must be overlooking the thread that has this information. i have a tune and I'm curious if its good or dangerous for my car. thank you for any info you can provide.
GTX3071r : Tial MV-S 38mm ewg : COBB AP : Stratified ebc : CP-E HPFP : CP-E Safe seals : COBB fmic v2 : HKS bov : HTP 4" intake w/battery tray : DNP turbo mani : ATP catless dp : Mazdaspeed cbe : JBR trilogy : TWM sts : MattDamond occ v2 : NGK6510's : Eibach Prokit : Koni Yellow's : Corksport front endlinks : Corksport RSB : JBR EGR Delete : Kozmic Motorsports Primary EGR Delete : TB coolant bypass : Relentless Customs PnP intake mani : Bosch 3 Bar Map Sensor : Bitwise Motorsports Bosch MAP Sensor Connector : South Bend stg3 endurance clutch : 17x8 Enkei TSP5 : Hankook v12 245/45 SP63 Longblock Head= Mild bowl work as well as mild porting on intake/exhaust. Bottom end= SP63 Weisco 9.5:1 - 87.5mm : Head Studs 10mm L19 : Manley H-Beam : Rod Bolts ARP Custom Age 625 : Coated Clevite Main & Rod Bearings | |
| Not Ranked : 0 score ok, my dumb ass was finally able to find the info i needed. basically, i will have to do a 3rd gear pull from about 3k. and i will also do a 4th gear pull doing the same thing. almost like being on a dyno. i will post them up when i get a chance to do some logs. hopefully everything will be fine, but i have a feeling that this tune might be in the danger zone for my car. if so, looks like i will be hitting you guys up for one of your stratified tunes. i just wanted to give this local shop a try since they've done a couple of other ms3's as well.
| The Following User Says Thank You to NoRegrets For This Useful Post: | pzr2874 (10-24-2013) |
| Not Ranked : 0 score Correct, stomp on it right at 3k RPM and carry it to redline. If you're uncertain about the tune ease into it before doing a full log and keep an eye on vitals such as fuel pressure, overboost, knock. Log the following parameters: Accel. Pedal Pos. Actual AFR Boost Boosted Air Temp Calculated Load Coolant Temp Engine Speed (RPM) HPFP Actual Pressure Injector Duty Cycle Intake Temp Intake Valve Adv. Knock Retard Long Term FT (LTFT) MAF Voltage Mass Airflow Spark Advance Throttle Position Vehicle Speed Wastegate Duty Cycle
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
| Not Ranked : 0 score Ok, I don't have microsoft excell. So I'm using google my drive's spread sheet format. Unfortunately, it will not let me link in the "manage attachements" option in our post configuration. So I'm just going to link it and hope for the best that you can view them. Sorry for any inconvenience. https://docs.google.com/spreadsheet/...rive_web#gid=0 https://docs.google.com/spreadsheet/...rive_web#gid=0 https://docs.google.com/spreadsheet/...rive_web#gid=0
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
| Not Ranked : 0 score i was surprised with how much i gained from it. i was orignally on cobb st2 ots map making 312whp 325wtq. on this map i am making 347whp and 374wtq. but as you stated, i do see consistant kr. i really want to help this guy and his shop out because he is passionate about tuning cars. he has been tuning for 10 years and has tuned some impressive vehicles used for things such as pro drifting and breaking land speed records. he admits he is not savy with our platform be has been learning through his experiences with some of the other locals. is there anything you could suggest he can do to help clean up this tune and make it more safe for everyday use? i myself get totally lost in all of this, so i can not offer any advice to him. i really appreciate you taking the time to look over my datalogs. i am more than likely going to order a tune from you anyways just so i can have a good reliable tune to use. but it would be nice to have a shop to drive to so they can actually feel the way the car drives and listen to how it runs in order to diagnose any issues.
| The Following User Says Thank You to NoRegrets For This Useful Post: | phahengpro (10-27-2013) |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | Mike@Stratified (10-27-2013), turbo test (11-30-2013) |
![]() Join Date: May 2012 Location: West Hempstead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 572
in fact i KNOW youre not making 347 lol
__________________ //2012 Black Mica Mazdaspeed 3// //Sure Torq R3//Cobb AccessPort//Autotech Internals//Ultimate Racing Axelback//Resonator Delete//Ebay Catless DownPipe //TR8L & Protege Garage piping//Devils Own Stage 1//NGK One Step Colder(failed) Denso ITV22//GoFastBits Blow Off Valve//Ksport Coilovers //GTX 2867r//Protege Garage Externally Gated Manifold//Precision Turbo Wastegate//Bosh 3 Bar Map//HTP 3.5" Full Intake //Grimmspeed 3 Port//Cobb Wastegate Lockout//Selfmade Screamer Pipe//ACT 6 puck w/ streetlite flywheel // R3X Tune in Progress (self tune) 310whp 354wtq (CF 1.01) w. DO7 KO4 ......GTX2867r 22psi: 357whp 353wtq (CF1.01) Needs installing: JBR BSD kit, OCC | |
![]() Join Date: Nov 2010 Location: Moore, Oklahoma
Rep Power: 234 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 339
| Not Ranked : 0 score I can understand wanting to help the local guy out, but do yourself a favor and let Lex tune yours. Your car will perform better while giving you piece of mind.
Are you using virtual dyno or something else to get your numbers?
__________________ MS3 traded in after VVT eruption 2013 WRX - no mods and slower Last edited by phahengpro; 10-27-2013 at 12:44 PM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score i did not mean to insult anybody and i apologize if i have. i just wanted to help the guy out in case his tune is in danger of damaging, or even worse, causing engine failure. it is one thing if his tunes are not giving the full performance potential, but it is another thing if he is handing out ticking time bombs because he is still learning about our fickle platform. it was not the ots map that made those numbers. my ots map gave me 312whp 325 wtq. his tune gave me 347whp 374wtq. it was dyno tuned as i sat there and watched him. btw, please fully read my post, as i have previously stated this, before you groan me. even though i am on a tune from a different person, i still wanted lex's input on it. because i know he knows his stuff when providing a safe reliable tune that also gives good performance. i would like for lex or one of his associates to etune my car as well. 1. so i know i have a good, safe, reliable tune. 2. it would be nice to compare ots cobb vs the tune i am running now vs stratisfied. and now that i know i can datalog on my way to the gym, i feel more confident with getting an etune without worring about having the time to provide the information needed to get my tune right. once again, thank you for spending the time to look this over and answer my questions.
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (10-27-2013) |
| Not Ranked : 0 score sorry, just one more question. i'm obviously still running my stock k04. would it be necessary to buy the 3 port ebc, or can that wait till i go big turbo down the road. i know you have a package deal that if i get a tune and the ebc, it knocks $10 off. thanks again
| The Following User Says Thank You to alexryan For This Useful Post: | NoRegrets (10-27-2013) |
However the 3 port (or boost dial) are an important piece of a successful BT install as you know so it is entirely up to you and your goals on the K04 if you get it now or later.
| The Following User Says Thank You to Lex For This Useful Post: | NoRegrets (10-27-2013) |
![]() Join Date: Aug 2012 Location: San Mateo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,022
| Not Ranked : 0 score Still, 312/325 is not believable from an OTS tune. It would be a record... or am I reading this wrong. This tuner stuck your car on the dyno before he started tuning it... you had a Cobb OTS stage 2 map, and the dyno spat out 312whp/325wtq? edited: because I think I must have missed something, lol
__________________ CRMetallic 2019 Mercedes C43 AMG SOLD MNBlue 2012 S4 Prestige... a few mods SOLD IB 2015 3.8 Gencoupe Ultimate BLOWED UP DIB 2014 Mustang 5.0... a few mods SOLD - LS 2012 MS3 Cobb AP//SF//CAB Autotech HPFP Corksport TMIC//BPV//TIP//BTbs JBR 88a RMM Sure M3 TP OBX CBE Tanabe NF210's ADVAN RG-D 18x8 +38 Freektuned 50/50 E85 Last edited by jseams; 10-27-2013 at 07:36 PM. |
| Not Ranked : 0 score thank you lex. i will just go ahead and grab that with the tune when i order. since i know i am eventually going bt when my stocker finally gives out. and what my tuner did was put the car on the dyno. then dynoed and datalogged the car with the cobb stg2 ots map to get a baseline and see where my car was at. after that, he made some adjustments and dynoed again. repeat and rinse till i got the final tune that i am currently running. maybe his dyno was feeling a little nice and inflated my numbers, or maybe that is what i am putting down. for all i know i could be only putting down 320whp. all i know is my car feels a lot stronger now. unfortunately, as pointed out, it is not entirely a safe tune. so that is why i will be going to way of lex and his crew.
| The Following User Says Thank You to NoRegrets For This Useful Post: | Lex (10-28-2013) |
| First ever Datalog! | MS3Cody | 2010 MS3 - ECU Computer Tuning | 4 | 10-05-2012 09:29 PM |
| First datalog | razorscs | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 03-24-2012 03:51 PM |
| My first Datalog on my AP | alien_sporez | 2010 MS3 - ECU Computer Tuning | 12 | 12-31-2011 05:20 PM |
| First Datalog | iggy097 | 2010 MS3 - ECU Computer Tuning | 4 | 09-08-2011 09:09 AM |
| First Datalog... Does it look ok? | jlink38 | Mazdaspeed3/6 General Discussion | 22 | 08-12-2011 09:36 PM |
