E-Tuners / Custom Hardparts
Like Tree4Likes
 Old 04-01-2013, 07:00 AM   #41
mrQQ's Avatar
Posts: 1,164   (View Stats)
Will be buying this.
Question - do you need any additional hoses to install this in 3port mode over the stock one?
mrQQ is offline   Reply With Quote
The Following User Says Thank You to mrQQ For This Useful Post:
Lex (04-01-2013)
 Old 04-01-2013, 11:32 AM   #42
Yes, you will need to reroute hoses and will need additional ones. Easily bought at any local auto shop.
mrQQ (04-02-2013)
 Old 04-01-2013, 02:40 PM   #43
mrQQ's Avatar
Hm, do you think you can list specs for what's needed?
 Old 04-01-2013, 06:50 PM   #44
Take a look at the instructions on the product page. It is all there:
Mazda 3 Port Electronic Boost Control Valve [MAZ 3P EBCV (0100-0005.2)] - $85.00CAD : Stratified Automotive Controls
mrQQ (04-02-2013)
 Old 04-02-2013, 01:02 AM   #45
mrQQ's Avatar
thanks, missed that.
 Old 04-09-2013, 10:40 AM   #46
lyle.thomas's Avatar
Posts: 32   (View Stats)
lyle.thomas has a spectacular aura aboutlyle.thomas has a spectacular aura aboutlyle.thomas has a spectacular aura about
Should I follow the same diagram for your valve in bleed mode, if I plan to run in bleed mode with a Cobb ebcs?
lyle.thomas is offline   Reply With Quote
 Old 04-09-2013, 11:07 AM   #47
Yes the solenoid port numbers are the same on the COBB, GS, and our solenoids.
lyle.thomas (04-09-2013)
 Old 05-13-2013, 02:04 PM   #48
Stratified 3 Ports are back in stock on our site. They had been out of stock for the last 2 weeks and finally the shipment came in!
 Old 05-29-2013, 10:58 PM   #49
IamJamen's Avatar
Posts: 789   (View Stats)
Installed. Let the tuning begin.
The Following User Says Thank You to IamJamen For This Useful Post:
Lex (05-29-2013)
 Old 07-23-2013, 01:01 PM   #50
kentwat's Avatar
Posts: 238   (View Stats)
kentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond reputekentwat has a reputation beyond repute
Can you pm me on a price for an EBCV + tune combo? Thanks. Sent pm to Lex but I believe it is down? Kent
2011 Black Mica with Tech package.
Mods: AP, AT Internals, HTP 3" intake, OBX TP. XP5263 plugs. Tune by Kent
kentwat is offline   Reply With Quote
 Old 07-23-2013, 01:23 PM   #51
PM replied sir.
kentwat (07-23-2013)
 Old 08-26-2013, 10:21 AM   #52
Just so everyone knows - when you purchase a Stratified tune, you get a discount on our 3 Port. So if you're planning on getting a 3 Port for your tune, this is a great opportunity to get the most complete 3 Port package out there.
breakfstincluded (08-26-2013), silvapain (08-27-2013)
 Old 09-09-2013, 01:56 PM   #53
Not a huge fan of bumping threads this way but if you're getting a tune from us and need a 3 port, with the tune discount it's not only the most affordable 3 port, but also the most complete kit.
 Old 10-30-2013, 01:04 PM   #54
These were out of stock for a couple of weeks but a new shipment has come in so they are back in stock:
 Old 01-01-2014, 09:11 AM   #55
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
Kinda old thread bump, is it necessary to buy the ebcv and the boost dial at the same time.
If not when is it necessary?
Sent from my EVO using Tapatalk
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
The Following User Says Thank You to turbo test For This Useful Post:
Lex (01-01-2014)
 Old 01-01-2014, 02:53 PM   #56
You actually choose either one. You don't need both. With boost control if you choose to used a two port bleed method all you need is the boost dial and the OEM solenoid if it's not damaged.
If you choose to run a 3 port boost control method then all you need is the 3 port.
Either method for controlling boost will work fine. The 3 port allows you to drive the turbo harder up top but it also more sensitive for IWG turbos
For EWG turbos I've seen excellent boost control with the boost dial and the OEM 2 port. Very very smooth.
Either method can be used to control boost on both EWG and IWG turbos.
redboat (02-17-2014), turbo test (01-01-2014)
 Old 05-01-2014, 05:36 PM   #57
speed3newb's Avatar
Posts: 233   (View Stats)
speed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond reputespeed3newb has a reputation beyond repute
I want this, but they're sold out. Whats the time frame for the production of these? @Lex;
[/COLOR]2012 MS3 BMCP-e Stage 2 RMMCS SRI/TIPCS SSP/SBJBR Shift KnobRallyArmour MudflapsCOBB AP V3GODSPEED 3PORT EBCS
speed3newb is offline   Reply With Quote
 Old 05-01-2014, 05:43 PM   #58
They are arriving this coming week sir.
 Old 05-01-2014, 05:51 PM   #59
speed3newb's Avatar
Thanks for the quick reply I shall be placing an order. Do I need to be on a waiting list?
Sent from my HTCONE using Tapatalk
 Old 05-02-2014, 12:51 AM   #60
I do have a waiting list. PM me your e-mail and I will send you a message as soon as they are in.
 Old 05-06-2014, 11:40 AM   #61
We just got these back in stock everyone!
 Old 06-16-2014, 04:15 PM   #62
thepatient77's Avatar
Posts: 162   (View Stats)
thepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond repute
@Lex; how big is the waiting list? I ordered one back on June 8th (order #1230 ). Was wondering if i have to wait for the next batch?? Thanks!
thepatient77 is offline   Reply With Quote
 Old 06-16-2014, 05:21 PM   #63
It is on its way. Sometimes the tracking takes a little while to update but it was dropped off in the mail box last week. Let me know if you haven't received the tracking information.
thepatient77 (06-16-2014)
 Old 06-16-2014, 06:17 PM   #64
I have the tracking info but, it hasn't updated. That's why i was asking. Thanks for checking it for me. Can't wait to receive this product!!!! Will probably be getting a tune from y'all real soon!!
The Following User Says Thank You to thepatient77 For This Useful Post:
Lex (06-16-2014)
 Old 06-16-2014, 06:22 PM   #65
Sounds great! If it still hasn't updated in 2 days send me a PM.
 Old 10-24-2015, 10:10 PM   #66
SPEEDO90's Avatar
Posts: 79   (View Stats)
SPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the rough
Hey guys i am so confused about the install for this product can someone please shed me some light I had touch to images of what's confusing me I'm not sure if the restrictor and the T connector is already installed oem in my turbo or do i need to but this i want to run it in 2 port mode sorry for reposting here.
SPEEDO90 is offline   Reply With Quote
 Old 10-25-2015, 08:23 PM   #67
If you have an OEM K04 it will have the restrictor already installed in the compressor housing barb. So if you were to run it in 2 port on the OEM turbo, simply plug port 3 with the included thread-in plug and connect ports 1 and 2 as shows in the diagram.
 Old 10-26-2015, 08:26 PM   #68
SPEEDO90's Avatar
Thanks for the replay. If i run it in 3 port mode on the stock k04 do i have to plug or cap the bottom nipple on wastegate? So for instance I run my hose as followed one to the intake one to the turbo and one to the waste gate then plug the bottom nipple/line with a vacuum cap right? Am i missing anything for 3port mode?
 Old 10-26-2015, 10:08 PM   #69
SPEEDO90's Avatar
I'm such a freaking noob sorry guys I get everything else but the turbo part for 3 port mode. I decided to go that rout does this look right to you?
 Old 10-28-2015, 01:23 PM   #70
That top line is a water line, definitely leave that alone.
For 3 port:
1. Cap the bottom port of the WG actuator.
2. Cap the compressor barb on the leftof the picture.
3. T into your BPV source line from the manifold (port 3)
4. TIP to port 1
5. The remaining barb on the WG actuator goes to port 2
Remember that the car has to be tuned to not overboost in 3 port interrupt mode.
 Old 03-21-2016, 07:31 PM   #71
rotarican21's Avatar
Posts: 30   (View Stats)
rotarican21 has a spectacular aura aboutrotarican21 has a spectacular aura aboutrotarican21 has a spectacular aura about
I'm not quite ready to order one yet but will be soon. How would i go about ordering it? when i go to the link from earlier posts, it says that the product can't be found. Also would like to know about the ebcs+tune discount. Thanks in advance!
rotarican21 is offline   Reply With Quote
 Old 03-21-2016, 10:07 PM   #72
We actually carry the JBR EBCS right now. Will be happy to get you one of these as well as tune your car of course:
JBR 3-Port EBCS MS3 Gen1/MS6 [JBR_MS3_3Port_MAZ-JBRMAC-EBCS] - $79.50USD : Stratified Automotive Controls
Product Release! CorkSport Mazda 2 Cold Air Duct CorkSport CorkSport 4 09-17-2012 11:53 AM
Product Release! CorkSport Mazda CX-7 Airbox CorkSport CorkSport 0 08-28-2012 11:00 AM
Product Release! CorkSport Coilovers for Mazdaspeed 3 and Mazda 3 CorkSport CorkSport 35 08-04-2012 02:14 PM
Product Release! CorkSport Mazda CX-5 LED Lighting Kit CorkSport CorkSport 0 05-23-2012 12:00 PM
Product Release! CorkSport Mazda 2 Skid Tray CorkSport CorkSport 7 05-19-2012 07:08 PM
Page generated in 0.53873 seconds with 30 queries
