E-Tuners / Custom Hardparts
Like Tree10Likes
 Old 02-04-2013, 01:49 PM   #81
Originally Posted by Rayd View Post
You have a new boost dial order to AUS! And an email re: boost dial
Thanks again lex!
All Boost Dial orders shipped out!
amoosenamedhank (02-04-2013), Zbrit00x (02-04-2013)
 Old 02-04-2013, 05:20 PM   #82
Rayd's Avatar
Posts: 171   (View Stats)
Rayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond reputeRayd has a reputation beyond repute
Legend!
Just got the shipment email
05 MPS 6 - Self Tuned
Borg Warner EFR T4 Twin Scrolled, Forged Block, Snow Performance S3 WMI, 5th/6th Port Injection, CPe: Ex Mani, Custom intake 3.75" MAF, CPe HPFP, Injector Seals, REM, SURE: Rear Diff Front mount & Brace, TIG's; Tial EWG, HDI FMIC, Custom 3" TBE, 3.5-Bar MAP sensor, AWR SEM, SouthBend S4 Clutch, Custom Head Unit, Car-LED Tails, 6000K HIDs, Auto Head-light Kit, Mugen Visors, LED conv., BC Coilovers, SPC Ball Joints, Brembo BBK
Rayd is offline   Reply With Quote
The Following User Says Thank You to Rayd For This Useful Post:
Lex (02-12-2013)
 Old 02-12-2013, 12:57 PM   #83
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Just wanted to double check I've done this right....
Ms paint ftw
Is port 3 supposed to be vta? Couldn't find anything on GS instructions about blocking it off...
@Rayd; has reported great success, but mine seems much less so...
Also, should the boost source house be 4 or 6mm? Had all sorts of issues getting the 4 mm on there...
The Following User Says Thank You to SarcasticOne For This Useful Post:
Lex (02-12-2013)
 Old 02-12-2013, 01:20 PM   #84
Cap off the 3rd port on the GS solenoid.
Use hoses that fit snugly and don't leak - the diameter doesn't matter in terms of response as long as they don't slip off or leak.
For initial setting (not sure how your setup is) but I would try a Blue 9 or there abouts (almost in the orange zone) and work your way towards the + if needed. Remember that the tune has to be calling for the correct values and I recommend having stock or very close to stock LEC and BEC values with correct boost and load targets (depending on if it's a boost targeting or load targeting tune).
Post up a log.
SarcasticOne (02-12-2013), TiGraySpeed6 (02-12-2013)
 Old 02-12-2013, 01:37 PM   #85
Took till nearly 4k rpm for full spool on a 3071
@atvfreek; has logs, I'm on phone, but am sure he'll look after me Just wanted to check to see if install fail on my part :p
 Old 02-12-2013, 01:42 PM   #86
Not sure how he's tuning you - he can chime in here - but if you are having slow spool AND HIGH WGDC then you need to turn it more towards +. If you are having slow spool and LOW WGDC then the tune has to call for more boost/load.
 Old 02-12-2013, 01:52 PM   #87
Definitely high wgdc, 24psi on 10psi spring... Have left to go to work for the day, but I went out last night, did logs and adjusted knob until hitting desired boost at redline... From memory, was 7 on the colour before white...
But guessing I should cap off port 3 before commenting too much further...
 Old 02-12-2013, 01:58 PM   #88
Post your results but also note that 24psi is asking a lot from a 10psi spring when it comes to boost control. Looking forward to seeing some logs.
 Old 02-12-2013, 03:40 PM   #89
Rayd's Avatar
@SarcasticOne, i think i hooked mine up abit differently... not sure how the GS EBCS is compared to my perrin, but what i did was, the line that originally came from the turbo compressor housing to the EBCS i took out and put the boost dial vacuum line into that port, i then removed the vacuum line that use to come from the EBCS the WG actuator and capped it off, and i left the line that originally went from the EBCS to the intake as it was.
have huge oscillations though so maybe i did it wrong aswell! lol @Lex might be able to confirm?
 Old 02-12-2013, 04:07 PM   #90
Ray, I need to send you a proper map Give me a bit of time.
 Old 02-12-2013, 04:24 PM   #91
Rayd's Avatar
lol thanks mate
I've been checking my emails with constant refreshing! im just worried that me or sam have "swapped" our EBCS from 3 port interrupt to bleed type incorrectly
 Old 02-12-2013, 06:23 PM   #92
lol thanks mate
Did the diagrams on my site help? Let me know if anything is unclear. I will be getting to your e-mail this evening.
 Old 02-12-2013, 07:07 PM   #93
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
GA and BD shipping email recieved
ETA: Feb 19
Thanks Lex
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
Dmurray06 (02-12-2013), Lex (02-12-2013)
 Old 02-12-2013, 10:48 PM   #94
Rayd's Avatar
Thanks lex
The diagrams did indeed help a lot, but since they were for a two port EBCS (stock looking) and I have a 3 port Perrin EBCS, it was abit difficult to correspond the appropriate vacuum lines.
to explain further: I wasn't sure about how to convert the 3 port EBCS to the bleed style 2 port correctly. Unsure which port had to be routed to where And wasn't 100% certain of which one to cap.
As I mentioned in the earlier post, I ended up capping off the port that previously went to the WG, and put the vacuum line that is coming from the boost dial to the port on the EBCS that was previously tapped to directly to the boost source (turbo compressor housing)
Oh and I let the 3rd port from the EBCS to the intake as it was.
Is that correct?
The Following 2 Users Say Thank You to Rayd For This Useful Post:
Lex (02-13-2013), SarcasticOne (02-13-2013)
 Old 02-13-2013, 07:01 AM   #95
Redline143's Avatar
Posts: 930   (View Stats)
Redline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the world
If you move the window in a very high region (turn the dial in the + direction lots) you will get extremely quick spool and it will allow the system overall to reach more boost. However this may or may not be a good thing on a K04.
You can definitely switch to load tuning whether using the Boost Dial or not. The OEM turbo has an inline restrictor so it is like a Boost Dial that is not adjustable.
So, carrying 20 or 21psi to redline on a K04 is ill-advised due to efficiency issues?
Redline143 is offline   Reply With Quote
The Following 2 Users Say Thank You to Redline143 For This Useful Post:
Lex (02-13-2013), rfinkle2 (02-13-2013)
 Old 02-13-2013, 08:26 AM   #96
atvfreek's Avatar
Posts: 7,787   (View Stats)
The comp tables are still very conservative due to the boost control before. Once I take a look at the logs I will give the map some more authority and we will see how it performs. If you are hitting your target boost up top, I would say the dial is in the right position and we just need to work on the wgdc and comp tables
Sent from your couch
You're blowing fire at that point. I usually have boost taper to 17-18 at redline on any k04 setup. Even that is over spinning the compressor.
I would study some compressor maps. Keeping the compressor efficient will keep the turbo happy for lots of miles and also make the best power.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Last edited by atvfreek; 02-13-2013 at 08:26 AM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
Lex (02-13-2013), Redline143 (02-13-2013), rfinkle2 (02-13-2013), SarcasticOne (02-13-2013)
 Old 02-13-2013, 08:53 AM   #97
Lex and atvfreek have studied this stuff in depth, and I tried to make a good visual representation here:
(theoretical, but should get the job done to illustrate)...
Notice how many lbs per minute a 2.3 liter engine consumes @ 6500 rpm per each boost level (on the right of the chart).
To run 20 psi on a 2.3 liter engine @ 6500 rpm efficiently, you need somewhere in the neighborhood of 45 lbs per min...
A strong k04 may be capable of ~ 36 lb min while overspinning.
http://www.mazdaspeedforum.org/forum/foru...-101-a-110475/
The Following 9 Users Say Thank You to rfinkle2 For This Useful Post:
amoosenamedhank (02-13-2013), atvfreek (02-13-2013), Dano (02-13-2013), Dmurray06 (02-14-2013), Lex (02-13-2013), Mike@Stratified (02-13-2013), Nliiitend1 (02-13-2013), SarcasticOne (02-13-2013), TiGraySpeed6 (02-13-2013)
 Old 02-13-2013, 11:00 AM   #98
@atvfreek; take a look at my OP in this thread. I recommend starting with OEM LEC and BEC tables and even the WGDC table I posted. Then look at his WGDC and boost. Usually very minor changes are needed to the LEC and BEC tables.
atvfreek (02-13-2013), rfinkle2 (02-13-2013), SarcasticOne (02-13-2013)
 Old 02-13-2013, 12:29 PM   #99
Lots of people are confused about vacuum routing for the Boost Dial if they have a 3 port solenoid installed. I updated the OP with a diagram on how to do this.
amoosenamedhank (02-13-2013), atvfreek (02-13-2013), magicka (02-13-2013), Rayd (02-13-2013), TiGraySpeed6 (02-13-2013)
 Old 02-13-2013, 08:32 PM   #100
Redline143's Avatar
That's what I already was thinking. I have a friend who wanted the boost dial to try and run a little higher boost on his K04, in addition to smoothing out boost oscillations beyond what hybridizing his tune with the TRL and LEC tables availed. As I've been practicing tuning a lot, I've come across numerous mentions of K04s not doing well past 17 or 18 at redline. I've experimented on my on Speed, and it won't even make past 18 at 6500 regardless of the WGDC or Boost targets I command... Almost like it knows its own limits, LOL!
Thanks for reaffirming what I was pretty sure of...
 Old 02-14-2013, 01:00 PM   #101
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
^ at 5500 ft of altitude, it self limits itself to max 15 psi anywhere after 5500 rpm :/
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 02-14-2013, 08:14 PM   #102
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
lil turbo can't be expected to pump air that isn't there...lol
Dmurray06 (02-14-2013), phate (02-14-2013), Zbrit00x (02-14-2013)
 Old 02-14-2013, 09:04 PM   #103
Zbrit00x's Avatar
Posts: 541   (View Stats)
My boost dial is working amazingly, getting 19/20 psi by 32/3400 rpm, and the car is so much more responsive on the load based tune.
2010 ms3-sold
ww evo x -385/360
Zbrit00x is offline   Reply With Quote
The Following User Says Thank You to Zbrit00x For This Useful Post:
Lex (02-14-2013)
 Old 02-15-2013, 12:10 AM   #104
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
How so fast!??! Full boost for me isnt till 3700-3800
Sent from my EVO using Tapatalk 2
2009 CWP Speed3
Lex (02-15-2013)
 Old 02-15-2013, 12:19 AM   #105
Zbrit00x's Avatar
It varies on temp, additional load In the car etc. soonest ive seen is 3200, average is about 34/3500 I'd say
2010 ms3-sold
ww evo x -385/360
Lex (02-15-2013)
 Old 02-15-2013, 01:49 AM   #106
Rayd's Avatar
Boost dial is working great for me too! Improved spool and responsiveness and only on my 1st stratified revision!
20/21PSI by 3250-3350
And that's with the dial set to orange 4.5 (about midway)
Lex (02-15-2013)
 Old 02-15-2013, 08:43 AM   #107
Cale don't you have a bigger turbo? I know your setup is flowing more g/s than Zayn. Targeting load means that you may need less boost to get to the same load if your setup flows very well.
 Old 02-15-2013, 12:42 PM   #108
I dont think so? I believe he has the gt3071 and I have the gtx.
2009 CWP Speed3
 Old 02-15-2013, 01:16 PM   #109
Zbrit00x's Avatar
Correct, the gtx is supposed to flow better mid to up top I thought so you should be good
2010 ms3-sold
ww evo x -385/360
 Old 02-19-2013, 09:54 PM   #110
Groans: 33
Thank you @Lex;!!
Recieved my Guardian Angel and Boost Dial today, looks awesome
GA will be installed as soon as possible
Mazdaspeed6 -06
290 AWHP / K04
Lex (02-19-2013), Mike@Stratified (02-20-2013)
 Old 02-19-2013, 09:57 PM   #111
Glad it made it safely! Thanks for posting sir!
SpeedRebirth (02-19-2013)
 Old 02-21-2013, 04:41 PM   #112
mps6dave's Avatar
Posts: 45   (View Stats)
mps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud of
hi alex,ive just ordered one of these from you due to pesky ossilations,correction table is well chopped down and its still a pain,im hoping this cures the problem,mods are in my sig,and log for you to see whats happening ,any tips on what setting to put in will be great,ill also be fitting the stock ebcs and not the gs
thanks lex
mps6,cs tmic,versatuner,one step cooler plugs ngk,jetex 3"cbe,3" catless long pipe,kmd hpfp internals.coolant bypass.bnr3 turbo.3.25 sure maf.egr delete,mani flap delete.injector seals.devils own meth,htp 3" tip,stratified boost dial,cs cab,ported intake,h&r springs,floor braces all round,soon to be forged to get the most out of the turbo
mps6dave is offline   Reply With Quote
The Following User Says Thank You to mps6dave For This Useful Post:
Lex (02-21-2013)
 Old 02-21-2013, 10:27 PM   #113
thanks lex
I would start with blue 8 - they are preset at those values and set the boost control logic to OEM.
mps6dave (02-22-2013)
 Old 02-23-2013, 05:47 AM   #114
mps6dave's Avatar
hi lex,i had a boost dial delivered for a customers car thats coming for work next month so i fitted it to mine,couldnt wait for mine to arrive.
anyway we set the correction tables 75% of the stock values,reflashed the car and this was the outcome,not reached the load targets and the wgdc is high so adjust the valve untill the load is reached . much much smoother
Lex (02-23-2013)
 Old 02-23-2013, 12:05 PM   #115
@mps6dave; post the log in csv format (not sure what the axes are there) here and the setting on the boost dial. What turbo is the car running?
Also I would set the correction table to stock values (this can change from turbo to turbo slightly) and perhaps adjust the WGDC base table a bit and the boost dial. The curve looks much smoother and you guys are getting a lot of these in the UK - thanks for that
 Old 02-23-2013, 12:41 PM   #116
mps6dave's Avatar
its running the bnr3 turbo,the valve is preety damn good,wish it was out 21 map revisions earlier.
Lex (02-23-2013)
 Old 02-23-2013, 12:56 PM   #117
mps6dave's Avatar
i did some messing today and think i need to raise the correction factors back to stock in the load tables as in crease the wgdc a little,i run 50% from 3-7k
also my idc is running 99%,so need to run meth or increase the fuel pressure with a better valve
Lex (02-23-2013)
 Old 02-23-2013, 12:59 PM   #118
Beautiful boost curve. Smooth, tapers towards redline, and you have 20psi by 3000 RPM Nice to see the Boost Dial is working as it should. It is a game changer once people use it and realize how easy it is to have smooth and responsive boost control with no oscillations or hassle.
A tip on the tune if I may. Try and target no less than 10* advance at redline even if you have to lower the load/boost. Dropping timing that low is costing more than dropping some load.
mps6dave (02-23-2013)
 Old 02-23-2013, 01:00 PM   #119
Also don't use an aftermarket relief valve for the fuel rail. You will hit a cut as the sensor maxes out at around 2100psi and it's annoying. It's fine to have IDC even a bit above 100 but adding meth always helps and it will help with your timing.
mps6dave (02-23-2013), phate (02-23-2013)
 Old 02-23-2013, 01:06 PM   #120
mps6dave's Avatar
its becoming hesitant/juddery up top when fueling gets to about 95%idc,im usually running 265kpa,9.5-10* up top , i can can run 2.38load up to 5k then tapers down to 2.15at 6900rpm if fueling allows it.
i may get a better in tank pump to help with fuel demand
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/product-release-stratified-boost-dial-136768/
Limestone Street Scene - View topic - My Speed3 is faster than yours....lol This thread Refback 02-08-2013 12:10 PM
Instead of a 3 port boost solenoid.... ? Mazda MPS Owners Club This thread Refback 02-01-2013 03:19 AM
Product Release! CorkSport Oil Catch Can Development and Release Notes CorkSport CorkSport 118 03-25-2014 05:20 PM
Product Release! CorkSport LED Underhood Lighting Kit CorkSport CorkSport 12 11-30-2013 04:29 AM
New Product release. Speed 6 rear mount medieval MazdaSpeed 6 - Engine, Transmission & Driveline 22 04-24-2009 09:12 PM
Page generated in 0.59058 seconds with 32 queries
