E-Tuners / Custom Hardparts
Like Tree10Likes
 Old 07-27-2013, 10:23 AM   #161
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
This afternoon I've made some more test runs and the results weren't as impressive as before, probably because of the extreme high ambient temps (iat > 45°C - I didn't get much higher load values than 2.1!). Under these abnormal weather conditions you cannot expect anything, but the results were still better than in 3-port mode...This time the maximum wgdc at high revs was around 90, so it really seems that the current boost dial setup is ok.
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 07-27-2013, 10:29 AM   #162
This may also have to do with the tune. At high temperatures loads will be lower - are you targeting load or boost?
 Old 07-27-2013, 11:02 AM   #163
EmPeEs6's Avatar
I'm targeting boost, all correction tables are stock (except for the load comp tables, which are zero'd out) and wgdc is chosen a little bit lower (max 80) than observed. I know that the tune is not yet perfect, since I use much more oem (correction/adjustment) tables than before.
Concerning the low load values, I just wanted to demonstrate how hot it was ;-)
BTW: I guess one reason for the quite stable boost curve is that in 2-port mode the boost system is not so sensitive to little changes in wgdc, which is why boost fluctuations during the correction process are also smaller.
 Old 07-27-2013, 03:18 PM   #164
Exactly correct and why it is used by the oems.
 Old 08-09-2013, 12:04 PM   #165
m4tic's Avatar
Posts: 4,928   (View Stats)
Wow, why did I not know this existed? I'm going to order one for my BNR install.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
Lex (08-10-2013)
 Old 04-03-2014, 02:01 AM   #166
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
Lex I recently installed a Cobb FMIC and ported my intake which has made dialing in boost a bit tricky. So I just purchased a boost dial which hopefully will help, I was just wondering when its comes to switching maps from say a 20psi map to a RT 26psi map am i going to have to adjust the boost dial or do you think i'll be able to find a happy medium which will work in both scenarios?
2012 Black Mazda 3 MPS
CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC
2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate
OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors
Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks
Versus Eurolace 19 x 8 +45 - Hankook RS3
Built & Tuned by Rob
Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18
DBA T3 Rotors - Carbotech XP10 Brake Pads
ledfootrob is offline   Reply With Quote
 Old 04-03-2014, 12:36 PM   #167
This all depends on the other hardware installed. Generally speaking you should find a happy medium within that window.
On a related note I haven't seen an order for a dial come in. Make sure it was submitted.
ledfootrob (04-04-2014)
 Old 04-03-2014, 03:46 PM   #168
ledfootrob's Avatar
Awesome thanks
Sent from my GT-I9300 using Tapatalk
 Old 05-06-2014, 09:55 AM   #169
It's hard to beat the smoothness of 2 port boost control using the Boost Dial.
This is a GTX3076 internally gated turbo. EWG setups work even better with the boost dial.
SpeedRebirth (05-13-2014)
 Old 08-31-2014, 09:18 PM   #170
The killer combo with the boost dial is an external wastegate setup. It is just so easy to get picture perfect boost control.
SpeedRebirth (08-31-2014)
 Old 08-31-2014, 11:26 PM   #171
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
So you recommend ditching 3 port gs, and use the boost dial with the gs in 2 port/ewg on the 3076?
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
Lex (09-01-2014)
 Old 09-01-2014, 12:24 PM   #172
You can achieve good boost control with the 3 port as well. The boost dial allows you to build a tune that is very flexible however when coupled with an ewg. The shortcoming of the boost dial is being able to drive the last pound of boost from a turbo and that is inherent to two port control. However with an ewg this is not an issue and you get to keep the flexibility and higher resolution of the two port/boost dial setup.
 Old 09-01-2014, 08:59 PM   #173
mrmonk7663's Avatar
Hmmm. I have your boost dial sitting in a box. I have a GS in 3 port currently. I have a GTX3076 with a tial hotside on the car. Current boost control is great...but im only running 16psi. Game plan is to NOT run over 23-24psi...and this turbo can go at least 30 psi....so I won't be at the point where I need to extract the last pound of boost, I'm well below that threshold. Perhaps I should give this at try. I'm just not fully understanding why I would want to do this vs my current 3 port.
 Old 09-01-2014, 11:48 PM   #174
The advantage is the tuning resolution. Let's say that for a 3 port 5% WGDC change results in 1 psi boost change. For the boost dial 10% WGDC change results in 1 psi boost change. This is just an example. What this means is that you have finer control over boost and are less likely to oscillate or spike.
Try both methods!
mrmonk7663 (09-01-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/product-release-stratified-boost-dial-136768/
Limestone Street Scene - View topic - My Speed3 is faster than yours....lol This thread Refback 02-08-2013 12:10 PM
Instead of a 3 port boost solenoid.... ? Mazda MPS Owners Club This thread Refback 02-01-2013 03:19 AM
Product Release! CorkSport Oil Catch Can Development and Release Notes CorkSport CorkSport 118 03-25-2014 05:20 PM
Product Release! CorkSport LED Underhood Lighting Kit CorkSport CorkSport 12 11-30-2013 04:29 AM
New Product release. Speed 6 rear mount medieval MazdaSpeed 6 - Engine, Transmission & Driveline 22 04-24-2009 09:12 PM
Page generated in 0.35418 seconds with 25 queries
