E-Tuners / Custom Hardparts
Like Tree5Likes
  • 2 Post By mazdaspeeding
  • 1 Post By mazdaspeeding
  • 1 Post By Lex
  • 1 Post By JP_Playboy
 Old 07-18-2012, 12:07 PM   #1
mazdaspeeding's Avatar
Posts: 260   (View Stats)
mazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the world
Groaned at 8 Times in 4 Posts
Default Satisfied by Stratified
What can I say, it's hands down the best $200 I've spent on this car to date. I don't think you can pick up more power and torque with any bolt-on. Not to mention the ultra smooth and linear power delivery. As with every other Stratified Tune review you've read all comments are positive. Lex was very professional, responsive and effective. The car pulls like a freight train and I would've been happy after the 3rd revision. He did 5 before we called it quits. Apparently my 94 Octane gas combined with my UR FMIC and CPE CAI put me up to E-85 timing levels. I think any fellow Canucks should support a fellow Canuck and check out Stratified. VD's attached.
rfinkle2 and Standsideways like this.
mazdaspeeding is offline   Reply With Quote
The Following 15 Users Say Thank You to mazdaspeeding For This Useful Post:
atvfreek (07-18-2012), AZSPEED3 (07-18-2012), Black Metal (08-10-2012), Dash08 (08-17-2012), Dmurray06 (07-18-2012), helmetface (07-18-2012), LakeSTLMS3 (07-19-2012), Lex (07-18-2012), ms3rick (08-05-2012), Mythyk (07-18-2012), Oliverms3 (07-19-2012), Pointless (08-17-2012), RichieRichness (07-19-2012), skiptowncat (07-18-2012), Vader (07-18-2012)
 Old 07-18-2012, 01:29 PM   #2
skiptowncat's Avatar
Posts: 1,592   (View Stats)
That's a nice power line, just awaiting a few goodies to be fitted before I get the lex treatment.
Tuned with by
The Following User Says Thank You to skiptowncat For This Useful Post:
Lex (07-18-2012)
 Old 07-18-2012, 01:42 PM   #3
Atomic41's Avatar
Posts: 1,174   (View Stats)
Do you have a OTS STAGE before how is the difference ? if yes ...
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
The Following User Says Thank You to Atomic41 For This Useful Post:
Lex (07-19-2012)
 Old 07-18-2012, 02:28 PM   #4
Nice job Alex @Lex
Lex (07-18-2012)
 Old 07-18-2012, 02:42 PM   #5
Atomic...my french Canadian brother - yes I had the Stage 2+ CpCai +TIH +IC +93 ++++ whatever map and this tune is 10 times better than that was. I ran every different map available/applicable map and this tune is still WAY better. More power, smoother, better. Lex will add timing (spark advance) among other tweaks and this is where the power is at. Don't waste your time tuning yourself, spend the $200, I guarantee you won't be disappointed!
stanley0910 likes this.
The Following User Says Thank You to mazdaspeeding For This Useful Post:
Lex (07-18-2012)
 Old 07-18-2012, 04:34 PM   #6
Atomic41's Avatar
OK I WILL GO FOR IT !!!
Right now
Lex (07-19-2012)
 Old 07-18-2012, 06:05 PM   #7
Atomic41's Avatar
What are your modifications ?
Lex (07-19-2012)
 Old 07-18-2012, 07:10 PM   #8
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
yeah, whats your full mod list? Im in line for a tune, and your mods seem to match what I have pretty close. Very promising. Grats
Lex (07-18-2012)
 Old 07-19-2012, 09:43 AM   #9
Same as yours pretty much.
CPE CAI, RMPC TIP, Corksport TP, UR FMIC, Autotech's, 1 step colder NGK's....that's it power wise. (No downpipe, no cat-back, no TIG's).
Lex (07-19-2012)
 Old 07-19-2012, 09:59 AM   #10
mca312's Avatar
Posts: 21   (View Stats)
mca312 is a splendid one to beholdmca312 is a splendid one to beholdmca312 is a splendid one to beholdmca312 is a splendid one to beholdmca312 is a splendid one to beholdmca312 is a splendid one to beholdmca312 is a splendid one to behold
Are you trying to hit 21psi of boost at 4000 rpm or was that overboost?
'08 MS3 - CS SRI/TIP, CNT DP, AP, AT Internals, JBR Mounts
mca312 is offline   Reply With Quote
The Following User Says Thank You to mca312 For This Useful Post:
Lex (07-19-2012)
 Old 07-19-2012, 10:21 AM   #11
maisonvi's Avatar
Groans: 75
Good to know.
I noticed you used the Dynojet correction factor. Do you know what you end up with with a 1.01 CF? (I believe it is the more common one to use)
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
Lex (07-19-2012), Tokay444 (08-10-2012)
 Old 07-19-2012, 10:40 AM   #12
Talking
I only hit 21 psi because it was a 4th gear pull from way down low. Under normal driving I would never be flooring it at 2800 rpm in 4th gear. This was just for tuning/logging purposes.
Under normal driving or hard driving going through the gears at optimal shift points I usually spike about 19 psi, higher in the higher gears as you can really load up the car in 5th and 6th. See attached for a 2-3-4 pull.
Lex (07-19-2012)
 Old 07-19-2012, 11:02 AM   #13
Good to know.
I think you're referring to the VD correction factor which is 1.0. See attached. Still not bad considering I have the Stock downpipe and this was taken during a heatwave with 100% humidity. It was 30 degree's Celsius (86F), 36/37 Celsius (97+F) with the humidex.
On a cool summer night when temps drop down into the 60's and 70's the car will absolutely haul even more ass and another 10-15 whp will be no problem.
We all know our cars run much faster when cold/cool and as they heatsoak they slow down significantly. We'll my car on the hottest days of July during a heatwave pulls harder than it did this spring in cool 65F temps on the Stage 2++++ tune.
The Following 2 Users Say Thank You to mazdaspeeding For This Useful Post:
Lex (07-19-2012), Pointless (08-17-2012)
 Old 07-19-2012, 11:21 AM   #14
maisonvi's Avatar
Groans: 75
Still looks real good, and is super promising for when I finally get my tune. No question when you get some cold air you will gain some power.
And I believe you can put in a "custom correction factor". Ive been using 1.01 becuase somewhere a while ago I read that people were getting the closest results between that and a real dyno numbers.
Lex (07-19-2012)
 Old 07-19-2012, 11:29 AM   #15
galens47's Avatar
Posts: 1,616   (View Stats)
galens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the world
Hey All,
I totally vouch for Lex! We are tuning mine right now and the results are amazing. Lots of logs and driving, I'm really getting to know my car in a new way, plus actually learning some shit.
Cheers,
Galens47
2008 Toyota Prius Grand Touring. Slow, no mods. Saving $600/month - Fuck off you judgmental Assholes. I miss the fuck out of my speed3 way more than the mustang. Alas I'm waiting for the next one.
2014 Mustang GT Premium, Deep Impact Blue. Boss 302 Steering wheel (Alcantara), SR Shift bracket, Roush Axelback -sold
2010 ms3 Black Mica Tech Package -sold
Internals are easy. Who the fuck thought it would be a good idea to point the genjuan's valve cover recirc tube at the EGR?
“It is the mark of an educated mind to be able to entertain a thought without accepting it.” --Aristotle
galens47 is offline   Reply With Quote
The Following User Says Thank You to galens47 For This Useful Post:
Lex (07-19-2012)
 Old 07-19-2012, 11:30 AM   #16
Thank you for the very kind words
Correction factors don't matter too much simply because even dyno operators apply varying correction factors. I leave it at the DJ correction factor for everyone I work with since this is what I've been using and it gives me a personal frame of reference between all the cars I'm working with. After all, a dyno is just a frame of reference.
This car performed extremely well even under very hot conditions. It took timing like a champ on the 94 pump gas and when temperatures drop there's another 20whp or so left on the table simply because the turbo will be able to naturally flow more.
The K04 MS3s are flow limited in almost all conditions so temperature plays a huge role.
EDIT: I know I am a couple days behind my tunes and e-mails but I will be catching up today and tomorrow with everyone! Been working hard on boost control for the big turbo guys and it sucked up my time
atvfreek (07-19-2012), Boost_creep (07-19-2012), Dash08 (08-17-2012), JP_Playboy (07-19-2012), mazdaspeeding (07-19-2012), rfinkle2 (08-10-2012)
 Old 07-19-2012, 11:46 AM   #17
secondchance's Avatar
Posts: 421   (View Stats)
secondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the world
Groaned at 114 Times in 37 Posts
Add some more tunes next week so i may purchase one please
2009 Subaru WRX 265 Sedan || Cobb AP || Cobb SF intake w/ air box || Process West TMIC || Tein Springs || Grimspeed 3 port || Forge BPV || Invidia Catback || UR Downpipe || Kartboy short throw w/ cobb knob and bushings || Cobb Heatshield || DW65c fuel pump || NGK 1 steps
In Garage for Spring || HSD Coilovers || Eibach f+r sway bars || Whiteline positraction bushing kit || Kartboy Endlinks || Whitelink endlink reinforcements || GTSpec front + rear sway bars || Stoptech front and rear rotors,pads,lines
Sold
2007 MS3 295 whp 350 Torque
2010 Evo X 440AWHP 11.7 @ 113
2009 Ralliart w/ xswap 320AWHP (first in canadia to break 300whp in gen2 RA) 12.4@ 108
2004 srt-4 s2
2006 ms6
2005 srt-4 s3 w/toys 12.16 @ 117
secondchance is offline   Reply With Quote
The Following User Says Thank You to secondchance For This Useful Post:
Lex (07-19-2012)
 Old 07-19-2012, 12:53 PM   #18
mrdouble99's Avatar
Posts: 256   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
Next year i'm gonna be Stratified to
Mazdaspeed3 - sold
- Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18
- Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 -
- 2010 drag time : 12.737@108.51mph - 259whp@280wtq
- 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq
2014 Black Mazda 6 GT MT
- Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing
- RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19
- 3M Gloss Black Chrome Wrap
- Autoexe Shifter Knob
mrdouble99 is offline   Reply With Quote
The Following User Says Thank You to mrdouble99 For This Useful Post:
Lex (07-19-2012)
 Old 08-10-2012, 03:46 PM   #19
Standsideways's Avatar
Posts: 363   (View Stats)
Standsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the world
Are you using petro ultra 94? Or do you guys have something different in quebec?
I didnt realize the ethanol content was that much, but hey the #'s on u94 is
101.5 Ron
80Mon
94 AKI
Where e85 #'s are
102-105Ron
85-87Mon
94-96 AKI
Aki is (r+m)/2
Looks like the ultra 94 we get is very close to e85
Standsideways is offline   Reply With Quote
 Old 08-10-2012, 03:58 PM   #20
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
Very nice numbers for the stock DP!
101.5 Ron
80Mon
94 AKI
Where e85 #'s are
102-105Ron
85-87Mon
94-96 AKI
Aki is (r+m)/2
However MON is far more important for FI cars so the 85-87 MON is quite a bit higher than the 80 that your 94 has.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
The Following 2 Users Say Thank You to Black Metal For This Useful Post:
mazdaspeeding (08-20-2012), Standsideways (08-10-2012)
 Old 08-10-2012, 04:18 PM   #21
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
I knew there was a reason why I am refraining from emailing you more often.
Pickles Tune in progress
 Old 08-10-2012, 05:30 PM   #22
JP_Playboy's Avatar
Posts: 228   (View Stats)
JP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the world
I must also post my experience with @Lex for a second and probably won't be my last as he is not done yet. I sent him a message explaining that my COBB AP was damaged in an experience I had to deal with to where I could no longer use the main unit. I was assured by Lex that it would not be a problem and that he would suspend my time allotted until COBB could repair the unit and send it back to me. He also sent me my new map and said "this is for when you get your AP back, have fun with this one". Not exact words but as close as I can remember it at this very second. I'm so impressed with him and his service that I have been bragging about how awesome he is to my wife and the other local mazdaspeed guys and now I felt it was time to let everyone else know how great of a person and tuner he is. Lex, my offer still stands if you are ever in my neck of the woods, I will buy you countless amount of alcoholic beverages and you can crash here afterwards. You are doing a superb job and know this will not be my last review of how great you are doing. Cheers.
Standsideways likes this.
09 Mazdaspeed 3 - Mazdaspeed CAI V2, COBB TIP, COBB DP, COBB CBE, Corksport TMIC, CP-E HPFP, COBB RMM, COBB AP, Stoptech slotted rotors, HAWK break pads, tuned by LEX (Stratafied).
Semper Fi
JP_Playboy is offline   Reply With Quote
The Following 3 Users Say Thank You to JP_Playboy For This Useful Post:
Black Metal (08-10-2012), Lex (08-11-2012), Standsideways (08-10-2012)
 Old 08-17-2012, 02:01 PM   #23
101.5 Ron
80Mon
94 AKI
Where e85 #'s are
102-105Ron
85-87Mon
94-96 AKI
Aki is (r+m)/2
Yes, I am using the Petro Canada Ultra 94 but I'm not in Quebec, I live in Kingston, Ont. (Where are you? You going to MOM on Sunday in Caledon?)
Only 2-3 cents more than 91 and what a difference!
I wish I knew more about those numbers above but either way this is awesome. I no longer live in a constant state of sadness and jealousy over our American neighbours and they're E-85.
Americans, how much more or less is E-85 over premium?
 Old 08-17-2012, 04:13 PM   #24
E85 is less $ per gallon, but you use like 2X the fuel when using ethanol.
U.S guys will have to chyme in
 Old 08-17-2012, 04:15 PM   #25
Kitchener-waterloo, no im likely not going to MOM, if anything ill be going up to cscs
 Old 08-17-2012, 06:13 PM   #26
Groans: 78
I lose 1.5-2 mpg on a 25% mix and e85 is around .75 cheaper per gallon in my area
- 6MT - Stock -
 Old 08-18-2012, 04:06 PM   #27
I'm seeing some very nice numbers from the 94 octane on the east coast. Some people are able to run almost as much as 25% E85 mixes.
Standsideways (08-18-2012)
 Old 08-18-2012, 04:26 PM   #28
ms3rick's Avatar
Posts: 2,959   (View Stats)
Wish I had some of that 94 out in cali! owell, havnt gotten any recent KR even with these 108+ Temp days!
another great job by @Lex!
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
The Following User Says Thank You to ms3rick For This Useful Post:
Lex (08-19-2012)
 Old 08-21-2012, 03:07 PM   #29
DJBY's Avatar
Posts: 66   (View Stats)
DJBY is a name known to allDJBY is a name known to allDJBY is a name known to allDJBY is a name known to allDJBY is a name known to allDJBY is a name known to all
Groaned at 10 Times in 2 Posts
Waiting for my parts and ill be next @Lex
Hehe
DJBY is offline   Reply With Quote
The Following User Says Thank You to DJBY For This Useful Post:
Lex (08-21-2012)
another satisfied STRATIFIED customer ruthless013 Stratified Automotive Controls 0 04-26-2012 09:05 AM
Yet another more than satisfied customer... CCC JAMES BARONE RACING 6 11-12-2010 12:33 PM
Another satisfied JBR SSP Customer mazdaspeeding MazdaSpeed 3 - Engine, Transmission & Driveline 7 07-14-2010 10:51 AM
Another satisfied customer. MS6 SSP fhaze JAMES BARONE RACING 1 05-03-2010 10:04 AM
Another satisfied Forge BOV owner... zoom1&zoom2 MazdaSpeed 6 - Engine, Transmission & Driveline 13 03-30-2009 11:41 AM
Page generated in 0.49941 seconds with 36 queries
