E-Tuners / Custom Hardparts
  • 1 Post By Bob-o
  • 1 Post By turboKart
 Old 04-19-2013, 07:36 PM   #1
BlackBandit's Avatar
Posts: 198   (View Stats)
BlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the worldBlackBandit is the leader of the world
Default Shooting for the Stratophere
I just bought an EBCS from Strat, and I also started an E-tune with Lex.
Currents Mods are in the sig. DP, CBE, and coilovers go on next Wednesday the 24th. EBCS will go in on Thursday. New shoes should be going on the car Friday.
I'm really doubting the 255s will fit, but the guy wants to give it a try anyway. Will switch to 235/40/18 at no charge if they won't work. These Westlakes the dealer put on, when the car was traded in, are pure fucking garbage. Zero first gear traction, with not much in second either. Did the 0-60 and 1/4 mile on the AP and my best 0-60 was 6.0 secs, and the best 1/4 mile was 14.8 at 101, with a 2.6 60'
Goals are 300whp on 93 octane gas. No e85 in Canuckistan (only E10). So that option is out.
2010 Black Mica - Tech Package
Corksport: SRI/TIP - TMIC - RMM - SSP and Bushings - Led Conversions inside and out - DP - Coilovers- Rear Camber Arms
Denso: ITV+22 Plugs
Stratified - EBCS - E-tune.
Cobb: AP
Custom 3" CBE
Autotech: HPFP Internals
Drag: Bronze DR31 18x8 +48
Michelin SS 245/35/18
Awating Install: - CS RSB - Front and Rear adjustable End Links - Stratified GA
BlackBandit is offline   Reply With Quote
The Following 3 Users Say Thank You to BlackBandit For This Useful Post:
Bob-o (05-09-2013), Dmurray06 (05-07-2013), Lex (04-20-2013)
 Old 04-20-2013, 03:29 PM   #2
Alberta has pretty good gas so you should see better power than we do in BC
 Old 04-22-2013, 01:38 PM   #3
First piece of the Puzz. Lex's EBCS.
You can tell right away this is a quality piece. The barbs won't break like the stock EBCS and the clips he provides are the coolest little things ever.
Denso: ITV+22 Plugs
Cobb: AP
Custom 3" CBE
The Following User Says Thank You to BlackBandit For This Useful Post:
Lex (04-22-2013)
 Old 04-22-2013, 08:42 PM   #4
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
I noticed the prices have gone up now? Just before I was about to order my tune... Oh well, still a small price to pay for a quality tuner!
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
The Following 2 Users Say Thank You to JDMJOSH For This Useful Post:
Lex (04-22-2013), v8killer (05-10-2013)
 Old 04-28-2013, 11:20 PM   #5
First tune sent from Strat. Going to install it next week after I get this issue with my front 02 sensor straightened out. I think it got banged around a little during DP install.
Fitted Stratified's EBCS. Easy mod to do. But if you have a CorkSport TIP the barb on their piece is only 1/8" which is too small to get a good seal with the 7/32" hose that Lex recommends to connect to the EBCS. I had to use the CS supplied hose on the intake, then connect through a univeral hose connector to the 7/32" hose. Not hard, but just something I thought I would put up here, in case someone searches this one day.
Denso: ITV+22 Plugs
Cobb: AP
Custom 3" CBE
The Following 2 Users Say Thank You to BlackBandit For This Useful Post:
BruhhWill (07-29-2013), Lex (04-29-2013)
 Old 04-29-2013, 08:39 AM   #6
The TIP is the low pressure side of the system so while the hoses should be snug, they don't hold any boost and don't need to be extremely tight.
The larger barbs were chosen to better match the high pressure ports on the turbo and WG.
 Old 04-29-2013, 10:54 AM   #7
Yeah it was defintiely, audibly leaking before. I could make it worse by rocking the engine, by either accelerating, or breaking hard. After I switched back to their hose it went away.
Denso: ITV+22 Plugs
Cobb: AP
Custom 3" CBE
Lex (04-29-2013)
 Old 05-07-2013, 11:22 AM   #8
Ok I got the front o2 sensor replaced. I know for sure the guy who did my exhaust broke it as I saw no evidence he disconnected the wire harness and cut all the stock ties so that you don't twist the wiring when swapping it between DPs. SAYS SO RIGHT IN THE INSTRUTCTIONS! I If it was more than $130 for the part I would have made him pay for it, but I won't make a stink over that much money, since he did a good job on the custom piping.
Anyway I have Lex's 1.00 tune in. The car runs GREAT. The closed loop mode is so efficient I'm barely touching boost in everyday driving now. Even thou this is a power tune I imagine I will get better mileage anyway.
Logs are attached for anybodies curiousity. Barely any knock, and boost is not spiking bad and appears to be holding well. Can't wait for the VD results.
Denso: ITV+22 Plugs
Cobb: AP
Custom 3" CBE
Lex (05-07-2013)
 Old 05-07-2013, 10:39 PM   #9
JDMJOSH's Avatar
Nice! I'm currently on my 1.0 map as well. Sent new logs nearly 5 days ago, patiently awaiting for the next revision. @Lex ? Hope your OK over there! I know your a busy man
The Following User Says Thank You to JDMJOSH For This Useful Post:
Lex (05-07-2013)
 Old 05-07-2013, 10:47 PM   #10
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
Alex won't disappoint. Ask me how I know.
The Following 2 Users Say Thank You to Dmurray06 For This Useful Post:
Lex (05-07-2013), v8killer (05-10-2013)
 Old 05-07-2013, 10:53 PM   #11
Working day and night guys
Bob-o (05-09-2013), JDMJOSH (05-08-2013), keridil (05-08-2013), Mike@Stratified (05-08-2013)
 Old 05-08-2013, 06:05 AM   #12
keridil's Avatar
Posts: 84   (View Stats)
keridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond repute
We know, it's just that we are quite eager to finish. ;-) Every iteration is a bit better than the former one. BTW, I'll change my tires tomorrow to a new size, I hope it doesn't bother much.
Cheers,
Berto.
Mazda 6 MPS / BPV GFB / RX-8 8x18" Wheels / EBC RedStuff pads / 235x40 Michelin PS4 / Bilstein B8 & Eibach Pro-Kit / Stainless Steel Brake Lines / Autoexe Front Strut Bar / SU Rear Floor Cross Bar / SURE Anchors, CounterShift, Dreadnaught, Torq R6 70a, 621g AGS Shift Knob / CorkSport 3" SRI / Ralco RZ SS Stage 2 / GrimmSpeed EBCS (interrupt) / CorkSport TMIC / CorkSport DP / AutoTech HPFP internals / BNR stage 3 v2 <-Stratified tuned
'07 BMW 335xi / Koni Yellow & HR / UUC SSK / M193 225/40 8"x18" 255/40 8.5"x18" Michelin PS4 / ER chargepipe / 335is clutch / MHD E30 mapped
keridil is offline   Reply With Quote
The Following User Says Thank You to keridil For This Useful Post:
Lex (05-08-2013)
 Old 05-08-2013, 05:05 PM   #13
This week has had a lot of unexpected issues come up. Expect a lot of updates today and tomorrow.
JDMJOSH (05-08-2013), keridil (05-08-2013), Mortose (05-09-2013)
 Old 05-09-2013, 11:55 AM   #14
Bob-o's Avatar
Posts: 1,312   (View Stats)
@Lex; is the man, be patient and everyone'll get tuned soon enough!
Dmurray06 likes this.
The Following 2 Users Say Thank You to Bob-o For This Useful Post:
Dmurray06 (05-09-2013), Lex (05-09-2013)
 Old 05-09-2013, 02:19 PM   #15
Got my 1.10 map loaded up.
Denso: ITV+22 Plugs
Cobb: AP
Custom 3" CBE
Bob-o (05-09-2013), Dmurray06 (05-09-2013), Lex (05-09-2013)
 Old 05-10-2013, 07:45 AM   #16
agentgordon27's Avatar
Posts: 560   (View Stats)
Thanks for this, now there should never be a brownie asking this question, HA!
Stock as fook.
The Following User Says Thank You to agentgordon27 For This Useful Post:
Lex (05-10-2013)
 Old 05-18-2013, 07:37 PM   #17
Here's my first VD. Remember I'm not looking for max HP. But drivability and power across the band. Tune is still in progress.
+32 HP, +51 TQ. Needless to say I'm pretty happy with Stratified's work so far.
Denso: ITV+22 Plugs
Cobb: AP
Custom 3" CBE
Dmurray06 (05-18-2013), Lex (05-18-2013), MS309 (05-23-2013)
 Old 05-19-2013, 07:41 AM   #18
JDMJOSH's Avatar
Awesome numbers! I've gained around 20whp already just from adjusting timing/load/fueling and Lex hasn't even touched the boost tables yet... really nice results so far
Is CF 1.01 and smoothing 3 still the most accuate VD setting when it comes to the Speed 3?
Lex (05-19-2013)
 Old 07-26-2013, 11:15 PM   #19
turboKart's Avatar
Posts: 321   (View Stats)
turboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the worldturboKart is the leader of the world
Groaned at 8 Times in 4 Posts
Default Just got in line!
I just got done asking paypal to send stratified some $$$ soas I can get tuned - Finally!
I feel like a kid in line for the roller coaster...
memin likes this.
'09 MGM MS3 - 'MaZcedes'
* Cobb A/P * CP/e S2 RMM * Autotech/6oost3d/McMaster-Carr HPFP Internals * JBR PowerPath SRI/TIP * ATP Catless DP * Cobb XLE BPV * Bilstein B8 Sprint Shocks * JBR 32mm Rear Sway Bar *
STRATIFIED...proper - ZFZMF!
turboKart is offline   Reply With Quote
The Following User Says Thank You to turboKart For This Useful Post:
Lex (07-27-2013)
 Old 07-29-2013, 09:06 AM   #20
BruhhWill's Avatar
Posts: 104   (View Stats)
BruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond repute
This is great to hear. I just received my Stratified Auto EBCS and am waiting to install it. I was wondering how the CorkSport Barb on the inlet pipe was supposed to fit over the fittings on the EBCS. Glad a 1/8 to 7/32 connector and hose solves the problem.
2008.5 MGM Mazdaspeed3
Engine
Cobb Accessport // Autotech HPFP Internals // Stratified Auto 3 Port Boost Control Solenoid (2-Port Mode) // Injen Cold Air Intake // CorkSport TIP // NGK Spark Plugs // Ultimate Racing Resonated Test Pipe // Stratified Auto S-OTS Stage 2+ Tune //
Transmission
JBR V2 Rear Motor Mount 80a // JBR Heavy Shift Knob // Corksport Shifter Bushings // Corksport Short Shift Plate //
Suspension
Koni Yellow Struts and Shocks with H&R Sport Springs // JBR Rear Sway Bar // 18x8 +45 Enkei Raijins in Black wrapped in Kumho Ecsta 4X All Seasons 235/40/18
Aesthetics
JDM Axela Window Visors // Corksport LED Fog Lights // Corksport LED Interior Lights //
Past:
1999 Crystal Blue Honda Prelude SH
2006 Titanium Grey Mazda 3 Hatchback (R.I.P.)
1995 Hyundai Elantra
BruhhWill is offline   Reply With Quote
The Following User Says Thank You to BruhhWill For This Useful Post:
Lex (07-29-2013)
Shooting Wisdom.... Alpha Wolf CX-7 > General Lounge + New Member Welcome 2 06-06-2011 02:31 AM
Shooting Fake: Porsche Cayman Shooting Brake a Top Gear hoax Haltech Automotive News 0 08-13-2009 11:00 AM
Page generated in 0.41101 seconds with 29 queries
