E-Tuners / Custom Hardparts
  • 1 Post By Lex
 Old 01-18-2016, 08:55 PM   #1
Speedz3's Avatar
Posts: 28   (View Stats)
Speedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond reputeSpeedz3 has a reputation beyond repute
Default SRI+Test Pipe+E85 for 307whp/357wtq?
I was looking through the Stratified dyno results page and found a 2010 MS3 that made 307whp/357wtq with only an SRI+Test Pipe+E85? That seems like very good numbers. Obviously it has internals but I was wondering since I have a very similar set up if I could expect some numbers close to this if I got a custom tune through you guys. Was this a very aggressive tune or was it mild? Thanks in advance for answering my question. Tax return is coming and I want to make sure I have everything lined up before then.
2010 Mica Blue MS3-
Go Fast Stuff-AP V3, CS Internals, CS 3" SRI+TIP, CS BPV, H&R Springs/Koni Oranges, JBR Rear Sway, JBR RMM, CS Race Pipe w/res delete. Stratisfied Pro Tune on 93. Working on E85 now.
Pretty Stuff-CS LED fogs and headlights, CS LED interior lights, JBR shifter knob, Eonon head unit, Alpine 12" Type S, MB Quart Amp
2006 Mazda 3-170k mile beater that runs strong.
Speedz3 is offline   Reply With Quote
 Old 01-19-2016, 09:53 AM   #2
ryguy 3's Avatar
Posts: 353   (View Stats)
Here are my results in V dyno with a stratified flash E-tune, CS SRI/TIP, Test pipe, and front mount. This is for a Gen 1 so Gen 2 might vary but it's just a ball park reference.
File Type: jpg 4 Gallon E85 Flash tune v dyno TPS 100%.jpg (65.9 KB, 182 views)
 Old 01-19-2016, 10:22 AM   #3
Speedz3's Avatar
Good numbers for sure. I wonder how much of your gains are actually from the E85. My other idea was getting a good 93 tune but not if im going to lose 30-40whp.
2010 Mica Blue MS3-
 Old 01-19-2016, 10:30 AM   #4
ryguy 3's Avatar
Remember this is just the 50$ flash E-tune not a full tune. I'd definitely recommend E85 if its near by.
 Old 01-20-2016, 07:00 AM   #5
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
Here's a vdyno comparison I did tracking progress, E definitely makes a difference. All temps we're close within a few degrees of each other and done at the same road same spot.
blue is ots tune before the tmic,green was the same ots with tmic added without proper tune (lost power)
yellow was 93 retune with the new tmic and red is etune after the tmic.
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 06-25-2016, 06:16 AM   #6
DC2
DC2's Avatar
Posts: 26   (View Stats)
DC2 is a jewel in the roughDC2 is a jewel in the roughDC2 is a jewel in the roughDC2 is a jewel in the rough
Nice comparisation !
Question, what is you're E85 mix ? 50/50 ?
2007 Mazda 3 MPS
Cobb accesport v3 Freektuned
Corksport SRI - TIP - HPFP internals - Racepipe
FMIC
Downpipe
Shortshifter
H&R -4cm springs
DC2 is offline   Reply With Quote
 Old 06-25-2016, 07:06 AM   #7
Running a 33-35% mix 2/1 ratio.
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 01-19-2016, 10:39 AM   #8
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
E85 is lyfe
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 01-20-2016, 01:29 PM   #9
E85 definitely allows for more power. Of course it depends from what fuel you are starting from but as a ballpark idea it is worth 20-40whp (again depending on what fuel you start from). E85 can also offset to some degree some cooling inefficiencies such as an OEM TMIC by not being as knock prone and allowing more timing in spite of higher charge temps that would otherwise result in knock.
Have a quick look at this article as well:
Blog : E85 Blends in the Mazda DISI and Ford EcoBoost : Stratified Automotive Controls
RGV_MS3 likes this.
WetzMS3 (01-20-2016)
The Official Downpipe/Test Pipe/Race Pipe Thread MS3-a(sore)ASS-rex Mazdaspeed3/6 General Discussion 415 02-06-2020 08:55 PM
Brand name test pipe vs. custom muffle shop test pipe Huligan MazdaSpeed 3 - Engine, Transmission & Driveline 10 10-05-2009 07:52 AM
Page generated in 0.29270 seconds with 26 queries
