![]() Join Date: Jan 2014 Location: Birmingham, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
__________________ Corksport: Stage 2 SRI w/TIP, Test Pipe, RMM, SSP, Shifter Bushings, Hood Shocks, LED Fogs Autotech: HPFP Internals Cobb: APV3 Other: JDM Vent Visors, Resonator Delete |
| The Following User Says Thank You to ThePatient For This Useful Post: | Lex (04-05-2014) |
![]() Join Date: Nov 2013
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score You almost always see the boost drop like this. The turbo can't hang at 19psi at the higher rpm. Your logs look pretty good. No knock and good A/F's. |
![]() Join Date: Sep 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
| Not Ranked : 0 score I can hang at 19psi in the upper rev range no problem. This heat these last few days have played a role in that as I've noticed recently. I have similar mods as you albeit the test pipe and also see an increased boost level usually after spoolup that settles out. I only see max loads around 2 at that point however. Maybe your 2.1+ is normal with your mods. Everything else looks great. @Lex; ?
__________________ 2009 MS3 GT - JBR SRI/TIP - CS Racepipe - TurboXS CBE - Cobb AP - Stratified E85 Flash Tune Stg. II (294/342) - Stratified Guardian Angel - Autotechs - CP-e S2 RMM - KW V2 - SPC RUCAs |
| Not Ranked : 0 score Yeah good point, I'm down a couple psi going from 40 F to these last two days of 80F weather. That could add to it. Sent from my DROID RAZR HD using Tapatalk |
The maps are not meant to take you to the edge of performance as they are meant to keep a good safety margin with great driveability. The next step is the custom tune to dial in the setup very specifically.
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
| S-OTS Stage 1 Logs | bheath3 | 2010 MS3 - ECU Computer Tuning | 0 | 08-24-2013 10:13 AM |
| Stage II Logs | Awesomesauce | 2010 MS3 - Dyno Sheets/Discussions | 9 | 03-09-2013 04:26 PM |
| Stage 1 First Logs | Tyhackman15 | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 12-15-2012 01:43 AM |
| Stage 2 Logs | iammike | 2010 MS3 - ECU Computer Tuning | 51 | 10-11-2012 03:57 PM |
| New Logs since going stage 2 | bwspeed | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 06-10-2011 11:45 AM |
