E-Tuners / Custom Hardparts
 Old 02-20-2014, 03:10 PM   #1
untitledav's Avatar
Posts: 189   (View Stats)
untitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond repute
Default Stage1 S-OTS map WOT
Hello all,
Sorry for reposting this (my original post was in Sticky section) but wanted to put it in the place that is visible.
So just recently i installed JBR SRI+TIP on my 13 PU and flashed with Stage1 S-OTS 93 and now i love this car even more!!!!!! It drives very smooth in 1st and 2nd, also shifts from 1st to 2nd are much nicer now. Great Accel pedal response! My fuel economy improved before it showed 19 avarage now im in 24!
I wanted to post 2 runs in 3rd gear @ WOT, Lex please take a look and let me know if everything looks good.
untitledav is offline   Reply With Quote
 Old 02-20-2014, 09:00 PM   #2
Originally Posted by untitledav View Post
Hello all,
Everything looks good in the logs for the map you are running. Glad you're enjoying the drive! Wait until you get a full custom tune .
 Old 02-21-2014, 03:51 AM   #3
scapone4's Avatar
Posts: 179   (View Stats)
scapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud of
You have internals or no?
scapone4 is offline   Reply With Quote
 Old 02-21-2014, 08:39 AM   #4
untitledav's Avatar
Thank you very much for your input!
Now i need to install HPFP this week and ill have happy car!
 Old 02-21-2014, 10:17 AM   #5
With an HPFP you can try the stg2 maps.
 Old 02-21-2014, 10:54 AM   #6
untitledav's Avatar
That was my goal
But seriously i could not believe how awesome my car drives now!
Again Thank you Lex!
The Following User Says Thank You to untitledav For This Useful Post:
Lex (02-21-2014)
 Old 03-31-2014, 10:33 AM   #7
untitledav's Avatar
Hello Lex,
I have a issue with my car it seams like it lost responsiveness and it does not accelerate as hard as it used to. This is second time it happened, first time car was stock and after reseting battery everything came back to normal. Then i flashed with S-OTS and car ran great until one time i drove it and it seams like it had lost some power.
Are you able to help me out?
Kind Regards,
 Old 03-31-2014, 03:47 PM   #8
Hello Lex,
Kind Regards,
PM sent. I will need to see a few logs.
..stage1 93 Normal ? SS_27 MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 05-20-2012 02:11 AM
map for BNR stage1 on a stage2+ ms3? numbnuts22715 MazdaSpeed 3/6 - ECU Computer Tuning 2 02-01-2012 10:31 AM
WOT run - Stage1+KNSRI 91 BT WillyH 2010 MS3 - ECU Computer Tuning 19 06-06-2011 01:39 PM
20.3 psi on Stage1+9CF 93 LandonElf 2010 MS3 - ECU Computer Tuning 59 04-01-2011 08:02 AM
Stage1+cpN+TIH 93 @ -18 C bcmountainspeed 2010 MS3 - ECU Computer Tuning 9 02-25-2011 04:52 PM
Page generated in 0.28637 seconds with 23 queries
