E-Tuners / Custom Hardparts
View Poll Results: Mounting for EBCS, traditional bracket with bolts for more $$, or an adhesive mounting solution?
Bracket, more $ 23 58.97%
Adhesive 16 41.03%
Voters: 39. You may not vote on this poll
  • 1 Post By Lex
  • 1 Post By Lex
 Old 10-10-2012, 09:06 PM   #1
Default Stratified Electronic Boost Control Solenoid (EBCS)
A lot of people break the stock 2 port solenoid or need a 3 port when installing a big turbo.
Boost control falls right into the Stratified area of expertise so I've been designing a solution that is plug and play and less expensive than the competition but works very well and that is key.
With the idea of saving the customer money I have been looking at mounting solutions:
1. One is the traditional bracket and bolts. This is done by everyone else and it adds cost, complexity, and the need to drill holes.
2. Another method for mounting is using an adhesive. The adhesive is strong and withstands engine bay heat and it is easily removed without residue. There is no need to drill any holes so things are kept clean.
However the solenoid must be placed on a flat plastic piece in the engine bay (vertically or horizontally). Lots of spaces to do this like the side of the battery tray. The downside is that when removed, the adhesive needs to be replaced/reapplied.
So the question is:
Do you prefer the traditional mounting bracket with bolts or is a much less expensive one time adhesive acceptable?
Vote away!
Hamilton69 likes this.
The Following 12 Users Say Thank You to Lex For This Useful Post:
BlueStreak (10-10-2012), breakfstincluded (10-11-2012), Dmurray06 (10-10-2012), easy (10-10-2012), exentix (10-11-2012), lilred (10-10-2012), Micha (10-29-2012), Monotonous ONE (10-11-2012), smoogs12 (10-11-2012), TiGraySpeed6 (10-11-2012), Todd98SE (11-14-2012), uncorked11 (11-14-2012)
 Old 10-10-2012, 09:17 PM   #2
lilred's Avatar
Posts: 5,792   (View Stats)
Not having an previous knowledge but given a lower priced quality option mounting with adhesive seems fine.
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
Lex (10-10-2012)
 Old 10-10-2012, 09:25 PM   #3
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
Hell yea. Will buy.
Lex (10-10-2012)
 Old 10-10-2012, 10:13 PM   #4
Thanks for the input so far. Keep it coming!
 Old 10-10-2012, 11:23 PM   #5
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
@Lex
Could use this too.
3M Dual Lock, Dual Lock Fastener in Stock - ULINE
Nator is what it does.
Lex (10-11-2012)
 Old 10-10-2012, 11:29 PM   #6
NCZ13's Avatar
Posts: 1,268   (View Stats)
I voted for a bracket, but realistically an adhesive would probably be better. especially for those when they sell the car, and want to stock out to a completely unmolested status.
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
The Following User Says Thank You to NCZ13 For This Useful Post:
Lex (10-11-2012)
 Old 10-11-2012, 12:24 AM   #7
I'm with kritz.. Hoop/Loop fastener via super Velcro.
Lex (10-11-2012)
 Old 10-11-2012, 12:38 AM   #8
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
I wish my grimmspeed was adhesive of some sort. And cheapers always better
Lex (10-11-2012)
 Old 10-11-2012, 01:03 AM   #9
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
crap dont make one! ill regret the one i bought from cobb :C although it was because of the nice discount from coming 12 months in a row (:
this interests me since BNRS3 deletes the EBCS mount point, that i wouldve liked to use.
does velcro have to worry about catching on fire in engine heat lol
Lex (10-11-2012)
 Old 10-11-2012, 06:13 AM   #10
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I found mounting in the stock location to be easy, fast and reliable. The bracket itself was simple in design, quick to create/manufacture, and has room for profit while adding only minimally to overall cost.
An adhesive based mounting solution leaves me wondering how it would fare after 2-3 years worth of temp variations- countless heat cycles and freezing or sub-freezing nights would take their toll on any sticky substance.
I voted for mount.
340hp / 371tq
Lex (10-11-2012)
 Old 10-11-2012, 08:42 AM   #11
Good points everyone and thanks for the input.
It will not have an L shaped bracket for the stock mount location. Most people will be purchasing these for big turbo setups so the bracket will have to be more generic.
The velcro idea is good - I have had mixed results with it and I will be looking at the specs of what 3M has to offer. The adhesive I have been using (also 3M) is really excellent. It offers a vibration cushion, it is automotive spec, and all electronics in my engine bay including the GA and Meth controller are fastened this way. They haven't come loose over several years and are easy to take off if need be. Only catch is that the surface has to be clean and free of that black polish stuff.
TiGraySpeed6 likes this.
 Old 10-11-2012, 08:57 AM   #12
Vader's Avatar
Posts: 1,651   (View Stats)
Vader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the world
Groans: 45
3M VHB
/thread
I use that shit to hold stuff all over, in my engine bay.
It's tough stuff, and, the adhesive doesn't degrade from the heat over time like the Velcro/Dual Lock does.
Originally Posted by mikelevi View Post
...When you have 600 lbs of faggot in your car, you are much slower than someone with 10 lbs of dick.
Vader is offline   Reply With Quote
The Following User Says Thank You to Vader For This Useful Post:
Lex (10-11-2012)
 Old 10-11-2012, 10:27 AM   #13
Evaluating all mounting solutions. I think you will all be very pleased with the final outcome. Been running this solenoid in 2 port (OEM mode) on the K04 and it has improved boost characteristics due to the higher flow of the valve versus OEM.
 Old 11-14-2012, 04:39 PM   #14
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Maybe offer both, and just charge more for the bracket option.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following User Says Thank You to Todd98SE For This Useful Post:
Lex (11-14-2012)
 Old 11-14-2012, 04:45 PM   #15
These are getting built as we speak ... so you guys will see what was chosen soon enough.
BigjohnB20 (11-14-2012), breakfstincluded (12-01-2012)
 Old 11-14-2012, 04:47 PM   #16
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
Mount
Sent from my balls via my penis
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline   Reply With Quote
 Old 11-14-2012, 04:51 PM   #17
moomooz12's Avatar
Posts: 378   (View Stats)
moomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the world
::Crosses fingers for bracket::
moomooz12 is offline   Reply With Quote
 Old 11-14-2012, 05:11 PM   #18
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Bracket. I'm not sure you'll find an adhesive that can handle the heat and movement in the engine bay.
Sent from my your mom's face on my junk
07 MS3
The original Genpoo Hater
G26 (11-14-2012)
 Old 11-14-2012, 05:34 PM   #19
I don't put stuff out there that has not been tested.
Todd98SE (11-17-2012), Vader (11-15-2012)
 Old 11-14-2012, 06:01 PM   #20
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
Subbed for future reference.
Give it a little tap, a tap tap tap-a-roo
99 miata: sold
 Old 12-07-2012, 02:12 PM   #21
Cat's out of the bag!
Product Release: Mazda 3 Port EBCV/EBCS
Sig_Nasty (12-07-2012), Todd98SE (12-07-2012), Vader (12-07-2012)
Help-OEM Boost Control Solenoid TRSpeed MazdaSpeed 3/6 - Turbo Induction 23 02-16-2016 07:09 AM
Cobb releasing electronic boost control solenoid for Genpu bertrand_CX_7 2010 MS3 - ECU Computer Tuning 9 05-04-2012 04:34 PM
Page generated in 0.41341 seconds with 35 queries
