E-Tuners / Custom Hardparts
Like Tree21Likes
 Old 06-20-2014, 12:10 AM   #241
Originally Posted by TRBLSM View Post
Purchased
Tapatorque steering
Just sent out your map this evening. We're one team member short this week and it took a little longer than expected.
 Old 06-20-2014, 12:50 AM   #242
TRBLSM's Avatar
Posts: 73   (View Stats)
TRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond repute
Yep got it!! Actually thought it'd take a bit longer haha so cheers for that.
Will get the HPFP and test pipe installed this weekend hopefully and flash the new tune.
Will report back and write a review next week.
Much appreciated
Tapatorque steering
2006 True Red 3 MPS - Top Mounted 5858 in progress
TRBLSM is offline   Reply With Quote
The Following User Says Thank You to TRBLSM For This Useful Post:
Lex (06-20-2014)
 Old 06-20-2014, 09:12 AM   #243
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
I love my Stratified OTS+ map, puts the COBB OTS garbage map I was using to shame. Once I get my internals, test pipe and a few other goodies I'm defiantly having Stratified do my custom tune.
Thanks again!
The Following 2 Users Say Thank You to my2k13speed3 For This Useful Post:
Lex (06-20-2014), Mike@Stratified (06-20-2014)
 Old 06-23-2014, 08:50 PM   #244
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Here are the logs and V Dyno I took today to highlight the difference between the OTS2 and the SOTS+ tune. I don't have enough time in the seat with the SOTS+ tune to add anything more, yet. I will definitely be adding more after a week of driving on it so stay tuned for more to come.
It is time to update my time with the OTS+ tune. It is awesome, once the boost comes on it hits like a freight train and feels like the car should have when I rolled off the stealership lot. I'm curious to see what a full tune does and I'll probably be jumping on that soon. Thanks Stratified for making my car awesome.
Lex (06-23-2014)
 Old 07-01-2014, 01:51 AM   #245
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Running an s-ots tune at the moment (htp/sots GB) and really enjoying the car.
Just a quick question, am showing high negative ltft (-10 to -16) up until 50-60g/s. Then it tapers down to -4 before entering open loop. Is this likely due to the fact it's really friggin cold out? It holds boost fine, as AFR's are spot on..
It is pretty much between 0-10C (32-50F) all day at the moment (winter)
Edit: actually, it's probably more that I'm 2000ft up
The Following User Says Thank You to SarcasticOne For This Useful Post:
Lex (07-01-2014)
 Old 07-01-2014, 07:47 AM   #246
You might have a slight leak between the turbo and motor - in the charge piping. Have you done a boost leak test recently?
SarcasticOne (07-01-2014)
 Old 07-01-2014, 10:33 AM   #247
I should also add. I have been seeing some variability with the HTP intakes lately. Things like how far the air filter is pushed on the intake can have big effects in the low regions of the MAF curve where air velocity and volume as low.
 Old 07-01-2014, 11:44 AM   #248
deasuma's Avatar
Posts: 185   (View Stats)
deasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the world
@lex I have purchased an s-ots+ map from you guys and I am now changing a few things up. I was wondering does the ots+ option include calibrating the maf curve of a 3.5" htp intake and tip? I plan on purchasing a full tune from you guys soon but I'm waiting on a few parts prior to pulling the trigger. I just wanted to know if I should wait for everything and do the full tune or go ahead and buy another sots+ to get the intake in before the other parts get ordered/arrive. It will be awhile before I get time to drop the full exhaust in so I'd like something in the mean time and I'm not super familiar with atr and changing things up.
2010 mazdaspeed 3,CS turbo, cobb ap v3, autotech hpfp, htp 3.5" full intake, ISC N1 Coilovers, CS short shift plate, CS 70&80 durometer RMM, CS mudflaps, Stratified e30 tune, Treadstone FMIC w/ TR8 Core, CS Turbo, CS full DP w/ High flow Cat,CPE Triton CBE, Cobb ebcs, Bosch 3 bar map sensor, CS OCC, HKS SSQV IV BPV.
deasuma is offline   Reply With Quote
The Following User Says Thank You to deasuma For This Useful Post:
Lex (07-01-2014)
 Old 07-01-2014, 05:25 PM   #249
Gr33ntumb's Avatar
Posts: 348   (View Stats)
Gr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond repute
That whas hard to understand but do you have the 3.5 intake now? But yeah the ots+ will be calibrated for the larger maf.
Then within 3 months you can purchase a full tune for - the price of ots+
So get ots+ for your intake, install intake. Then install all your parts within 3 months and save 40$ on your new full tune
Sent by smoke signal
CS 3inch intake, CS FP internals, CS Test pipe, Forge V2, AP v3, JBR 88a RMM and mud flops
Gr33ntumb is offline   Reply With Quote
The Following User Says Thank You to Gr33ntumb For This Useful Post:
Lex (07-01-2014)
 Old 07-01-2014, 05:38 PM   #250
deasuma's Avatar
Sorry for being confusing.
I have the intake but have not installed it due to being wary of messing around with the calibrations.
I already have an ots+ but not for this intake.
I also have a full tbe on order but it will be some time before it arrives. I want to use the new intake before the exhaust arrives. Hence ordering another sots+ map for the new intake then upgrading to a full tune once the exhaust is in. I just wanted to know if the ots+ maps would calibrate the maf or if I would still need to do this on my own.
The website states they will not evaluate logs so I'm confused if the calibration will be off at all with any ots map.
Does that clarify?
Lex (07-01-2014)
 Old 07-01-2014, 08:04 PM   #251
Gr33ntumb's Avatar
Either you get all your parts on within the 3 months from ots+ purchase and get discount on full tune
Or just install intake and get another ots+ with your current mods (3.5 intake) and then you have 3 months to put your exhaust and shit and get your new full tune for a discount
Have fun
The Following 2 Users Say Thank You to Gr33ntumb For This Useful Post:
deasuma (07-02-2014), Lex (07-01-2014)
 Old 07-01-2014, 09:00 PM   #252
We do build the maps for your modifications and that includes the MAF calibration. We have developed calibrations for pretty much any intake out there.
That being said big intake cars really do benefit from a full tune to exploit all the gains from a big intake - especially a 3.5". So we can certainly get you another sots+ or we can get started on a full tune. This depends on your schedule as well. There is a two week grace period in the tune if you want to have a break while installing more parts.
Send me a PM if you like and we can discuss the best route to take for your situation.
 Old 07-02-2014, 08:07 AM   #253
deasuma's Avatar
Thanks guys! Im super new to tuning and im learning alot you guys have all been so helpful. Ill conta t you later lex when im not at work.
Lex (07-02-2014)
 Old 07-11-2014, 09:02 AM   #254
Axela_EN's Avatar
Posts: 498   (View Stats)
Axela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the world
Are these maps set to 900 @ idle?
Custom Tuned, Bolted and on Meth......
Still slower than my dad's Impala
Now featuring: Turblow Smoke Screen Mod
Axela_EN is offline   Reply With Quote
 Old 07-11-2014, 10:39 AM   #255
BigjohnB20's Avatar
Posts: 779   (View Stats)
I think I saw somewhere he sets all his maps to 850 idle
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
The Following 2 Users Say Thank You to BigjohnB20 For This Useful Post:
Axela_EN (07-11-2014), Lex (07-11-2014)
 Old 07-11-2014, 10:41 AM   #256
Axela_EN's Avatar
Thanks!
The Following User Says Thank You to Axela_EN For This Useful Post:
Lex (07-11-2014)
 Old 07-11-2014, 12:01 PM   #257
Indeed the idle setting is 850 which is a nice compromise for comfort as well as preventing turbo smoke.
Axela_EN (07-11-2014), SarcasticOne (07-11-2014)
 Old 07-25-2014, 07:17 PM   #258
razortechrs's Avatar
Posts: 28   (View Stats)
razortechrs is a name known to allrazortechrs is a name known to allrazortechrs is a name known to allrazortechrs is a name known to allrazortechrs is a name known to allrazortechrs is a name known to all
Groaned at 43 Times in 11 Posts
Yea @Axela_EN; it's is 850. Which I did not know until I started the car and it is such a smoother start and idle. Also better leaving first gear. @Lex; knows what he's doing for sure
razortechrs is offline   Reply With Quote
The Following User Says Thank You to razortechrs For This Useful Post:
Lex (07-25-2014)
 Old 07-25-2014, 09:49 PM   #259
Axela_EN's Avatar
No doubt!!!
Lex (07-26-2014)
 Old 07-25-2014, 10:48 PM   #260
socaltouch13's Avatar
Posts: 235   (View Stats)
socaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond reputesocaltouch13 has a reputation beyond repute
Groaned at 14 Times in 6 Posts
So i got 1 of these the other day and im really satisfied. I jave a feeling that the answer is yes, but is there a world of a difference from a s+ots map, to a custome tune? The only thing holding me back is purchasing a downpipe or testpipe
IG:Warwickspeed_3
socaltouch13 is offline   Reply With Quote
The Following User Says Thank You to socaltouch13 For This Useful Post:
Lex (07-26-2014)
 Old 07-26-2014, 07:12 AM   #261
darthxar's Avatar
Posts: 560   (View Stats)
I noticed a significant difference going from the ots+ to the full tune, but the biggest difference is the piece of mind that your car is tuned for your exact set up and conditions. You will learn a lot about your car, collect a lot of data, and be able to have your tuner tweak aspects of the tune to your taste and driving style.
My favorite part is that instead of assuming my car is safe, I know it's safe. Since I was involved in finding my cars limits and I made the decisions about how much margin I wanted to those limits, I feel completely comfortable pushing my car as hard as I want whenever I want. I now have a confidence in the car that I didn't have with ots maps or even when the car was bone stock, as the factory tune caused some questionable behavior in my opinion.
2013 VRM MS3
The Following 2 Users Say Thank You to darthxar For This Useful Post:
Lex (07-26-2014), socaltouch13 (07-26-2014)
 Old 07-26-2014, 10:18 AM   #262
From what I have read there is a major difference between the 2. I myself am not trying to break records since it's is my DD but I have the sots+ and it is great. And now seeing the difference that made I'm almost ready to buy a DP or RP catless and then due the full tune. I've had a custom tune before from another performance shop but the sots+ makes it a whole new experience. Plus you'll be getting added gains from installing the dp
The Following 2 Users Say Thank You to razortechrs For This Useful Post:
 Old 07-28-2014, 12:35 PM   #263
We do get this question a lot. The custom tune goes through the refining one on one process with a tuner where datalogs and maps are sent back and forth. The SOTS+ is a tune that has built into it our know how and strategies developed over the last 6 years but the full tune really caters the tune to your particular car, modifications, fuel, and driving preferences. Since you are working one on one with a tuner you also get to discuss any concerns or future plans for the car during the process.
razortechrs likes this.
razortechrs (07-28-2014)
 Old 07-28-2014, 07:15 PM   #264
DaUberSchwebel's Avatar
Posts: 233   (View Stats)
DaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the world
I got my OTS tune today and all I can say is WOW. What a difference between the Cobb OTS map I was running. My car runs smooth as silk, pulls hard and actually gets better mileage. I ran through a half tank today and got an average of 2mpg better, even with getting on the car a lot. After I decide on an exhaust and IC setup, I will be contacting you for a custom full tune. Thanks Lex, best $40 my car has seen (except for the donation to the forum..lol)
Anyone limping by on the Cobb OTS maps, really needs to get a hold of Lex. You won't be sorry.
2013 VRM with Cobb AP V3/ CS SRI/TIP/SS/TP/ CP-E RMM CP-E TMIC Autotechs JBR TIG/IMG/EGR delete Stratified OTS tune
DaUberSchwebel is offline   Reply With Quote
The Following 6 Users Say Thank You to DaUberSchwebel For This Useful Post:
deasuma (07-28-2014), Lex (07-29-2014), Mike@Stratified (07-29-2014), Ozynigma (07-28-2014), SarcasticOne (07-29-2014), tbcota25 (07-29-2014)
 Old 08-07-2014, 01:51 PM   #265
There are a lot of happy campers MazdaSpeed owners running our SOTS+ maps. We now include the SOTS+ tune of your choice (pump or E85) with every AP purchase for just the price of the AP:
MazdaSpeed 3/6 COBB AP With S-OTS+ [MS_AP_Package_2] : Stratified Automotive Controls
Axela_EN (08-07-2014), monkey.bones.007 (08-07-2014), my2k13speed3 (08-07-2014), SarcasticOne (08-07-2014), socaltouch13 (08-07-2014)
 Old 08-07-2014, 02:35 PM   #266
I was so happy with my ots+ tune I jumped to a full time from Stratified. Can't beat the ots+ tunes.
Lex (08-07-2014)
 Old 08-07-2014, 02:47 PM   #267
darthxar's Avatar
Glad to see I'm not the only canuk tuned speed in Illinois.
2013 VRM MS3
Lex (08-07-2014), monkey.bones.007 (08-07-2014)
 Old 08-07-2014, 03:38 PM   #268
I've got a thing for bacon and maple syrup speed.
darthxar (08-07-2014), Lex (08-07-2014)
 Old 08-07-2014, 06:35 PM   #269
You're not the only one mentioning these Canadian delicacies . Maple syrup might be the special sauce.
monkey.bones.007 likes this.
 Old 08-12-2014, 12:06 PM   #270
fretburnr's Avatar
Posts: 226   (View Stats)
fretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the worldfretburnr is the leader of the world
Not even close
I'm still loving the S-OTS+ tune, 6500mi later! Thanks again, Lex!
Jay
'14 focusST
'03 330i
fretburnr is offline   Reply With Quote
The Following 2 Users Say Thank You to fretburnr For This Useful Post:
Lex (08-12-2014), monkey.bones.007 (08-12-2014)
 Old 08-12-2014, 01:53 PM   #271
Originally Posted by fretburnr View Post
Not even close
We have had really positive feedback for these and I'm very happy you're enjoying the tunes. Can't thank you guys enough because your support allows us to develop better tunes/products and have some more goodies on the way .
fretburnr (08-13-2014), speedaholic (08-12-2014)
 Old 08-14-2014, 08:31 PM   #272
evilmonkey187's Avatar
Posts: 294   (View Stats)
evilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the worldevilmonkey187 is the leader of the world
Hey Lex, what are the pros and cons of doing a full tune in dead of summer? Here in the U.S.A.'s penis state (floriduh) I am regularly seeing temps in the high 90's. The hotter it is usually means less O2 volume. If tuned for hotter temps,when it gets cooler O2 volume goes up which mean leaner mix, will the ecu compensate properly?
I guess what I'm asking is, would it be better to have a summer tune AND a winter tune? Or would the single tune be safe and effective?
Thanks in advance, your friendly neighborhood shit thrower
Bosch 3bar/$/Perm Plate/$/BNR s3 v2/$/Corksport "Power Series" ram air intake/$/Corksport FMIC/$/HKS BOV/$/TIP/$/Autotech's/$/Cobb DP/$/Test Pipe/$/Corksport Exhaust/$/Cobb SS/$/Greddy OCC/$/NGK/$/AEM Wideband/$/Hotchkis F&R Sway Bars/$/JBR Camber Arms/$/Brembo BBK/$/RMM/$/ACT 6 Puck/$/Prolight/$/AutoEXE Bumper/$/Rear Tow Bar/$/
evilmonkey187 is offline   Reply With Quote
The Following User Says Thank You to evilmonkey187 For This Useful Post:
Lex (08-15-2014)
 Old 08-14-2014, 08:37 PM   #273
I'm glad this was asked as i was going to ask when my full tune was getting started. I'm in Illinois and I'll see an even bigger swing in temps between summer and winter.
Lex (08-15-2014)
 Old 08-14-2014, 10:03 PM   #274
axiom's Avatar
Posts: 36   (View Stats)
axiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to behold
Purchased, received, and flashed the S-OTS+ Stage 2 on 91 today. Like everyone else has mentioned it's an amazing change for $40. I haven't had a chance to drive it around that much but did notice the following:
-Extremely smooth power delivery, all the way to redline
-Throttle response is smoother, not as 'jerky' as before
-Shifting feels much smoother, not as 'jerky' (due to the throttle response I'm sure)
Overall drivability has improved quite a bit. I was using the free Stratified S-OTS Stage 2 map before and thought that was pretty awesome already but for the price, the OTS+ is a no brainer and was worth every penny and then some.
axiom is offline   Reply With Quote
The Following User Says Thank You to axiom For This Useful Post:
Lex (08-15-2014)
 Old 08-15-2014, 11:52 AM   #275
The tunes are designed to work year-round and be safe year-round. The fueling will definitely keep up. For mediocre fuel quality I choose load tuning since it really lets me hone in on the timing and load curves and they stay consistent year round without fear of knock.
If fuel octane is very high (E85) targeting boost allows you to have more power in the winter when temperatures drop and gives you the knock resistance in the summer due to the fuel.
Having been doing this through the seasons for several years I know what to expect from the car year-round regardless of when we actually tune. In cold climates it gets unsafe to log when there is snow on the ground but otherwise it is really up to you when you'd like to do the tune.
Axela_EN (08-15-2014), evilmonkey187 (08-16-2014), monkey.bones.007 (08-15-2014)
 Old 08-16-2014, 06:04 AM   #276
cciepunk's Avatar
Posts: 181   (View Stats)
cciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the world
Groaned at 43 Times in 42 Posts
I got one of the sots+ maps for my setup with the catted DP, but was not able to stop the car from over boosting with it. I ended up having to go full tune and car runs great now.
cciepunk is offline   Reply With Quote
The Following User Says Thank You to cciepunk For This Useful Post:
Lex (08-19-2014)
 Old 08-19-2014, 11:40 AM   #277
Zep
Zep's Avatar
Posts: 17   (View Stats)
Zep will become famous soon enoughZep will become famous soon enough
Default OTS S+ Map -- huge improvement in power delivery
Another Stratified OTS S+ success. My 2008 MS3, running a COBB stage 2 map, was driving me batty, on the serpentine back roads in my area...the abrupt power delivery made for no-fun driving. My attempts to tune the COBB map did not provide enough improvement.
The OTS S+ map improves the power delivery by a remarkable amount...it now drives smooth, with no schizophrenic boost building.
I figure that Stratified saved me a bunch of money, since I now don't feel the need to shop for a new car. A full custom etune is in my future.
Thanks, Stratified...you made a believer out of me.
2008.5 Metro Grey GT
AP running Stratified OTS S+ stage2 tune/Cobb SRI & TIP/Corksport DP & RP/Stock Catback/ETS TMIC/Forge BPV/Denso ITV-22/PTP CDFP internals/OCC/BNoon Bolt/Corksport SS/AWR RMM/Cobb RSB/Koni FSD/Goodrich G-Force
SOLD: 11/25/2014
Zep is offline   Reply With Quote
The Following User Says Thank You to Zep For This Useful Post:
Lex (08-19-2014)
 Old 10-02-2014, 02:05 PM   #278
vtdone's Avatar
Posts: 10   (View Stats)
vtdone has a spectacular aura aboutvtdone has a spectacular aura about
I agree. The combo of Stratified S-OTS map and the JBR Power Path Stage 2 is an addictive bolt-on mod for the car and literally breathes new life into a nearly 7 year old car!
Last edited by vtdone; 10-02-2014 at 06:03 PM. Reason: Found the anser to my question
vtdone is offline   Reply With Quote
The Following User Says Thank You to vtdone For This Useful Post:
Lex (10-02-2014)
 Old 10-02-2014, 11:18 PM   #279
Happy you're enjoying these and thanks for the review! We have a lot of customers enjoying the driveability and performance of these tunes.
 Old 10-08-2014, 01:41 AM   #280
TRBLSM's Avatar
Finally installed some parts i had sitting around and flashed my s-ots plus tune.
As many others have said before, this blows the cobb ots tunes out of the water. Response, smoothness in both part throttle cruising/shifting and flooring the gas pedal is amazing.
Am slowly acquiring parts for my bt build but will be more than happy running this for a while
Tapatorque steering
The Following 3 Users Say Thank You to TRBLSM For This Useful Post:
Lex (10-08-2014), Mike@Stratified (10-08-2014), SarcasticOne (10-08-2014)
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
How To: Stratified Tune Lex Stratified Automotive Controls 1 07-24-2014 12:22 PM
First Stratified S-OTS+ Tune Jadcock 2010 MS3 - ECU Computer Tuning 45 07-09-2014 08:57 AM
Stratified Tune phahengpro MazdaSpeed 3/6 - ECU Computer Tuning 42 03-07-2014 03:29 PM
Stratified Tune? ape_ck Stratified Automotive Controls 7 08-04-2013 08:21 AM
Stratified tune done. MS309 Stratified Automotive Controls 57 08-04-2012 05:39 PM
Page generated in 0.59739 seconds with 39 queries
