E-Tuners / Custom Hardparts
Like Tree3Likes
 Old 12-04-2014, 04:08 PM   #41
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
@Lex; I know if you purchase a custom e-tune within 3 months of purchasing the flash tune you will get full credit on the amount paid on the flash tune.
What if I purchased a flash tune upgrade will I get any type of credit if I do a full custom tune?
 Old 12-04-2014, 11:32 PM   #42
You get the flash tune amount until that expires. And you get the upgrade amount for the remaining amount of time.
 Old 12-04-2014, 11:36 PM   #43
So I bought the flash tune originally in June so obviously that expired. I bought the upgrade a little over a week ago, so I would get $25 towards my custom e-tune?
 Old 12-05-2014, 09:58 AM   #44
Yes sir!
 Old 12-05-2014, 10:08 AM   #45
Yes sir!
Sounds good to me, so when I make my purchase how do I get the $25 credit?
 Old 12-05-2014, 01:18 PM   #46
I send it as a refund. It's the easiest way to process through. Let me know if this is an issue at all.
 Old 12-05-2014, 01:31 PM   #47
Nope not an issue at all, I will have the custom e-tune purchased within the next week or so, thanks Lex can't wait!
The Following User Says Thank You to my2k13speed3 For This Useful Post:
Lex (12-05-2014)
 Old 12-27-2014, 12:47 AM   #48
Jeremy M's Avatar
Posts: 345   (View Stats)
Jeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond reputeJeremy M has a reputation beyond repute
Groaned at 11 Times in 3 Posts
i ordered this v2 ots e85 tune today and recieved a form for a focus st, i emailed you about it today (26th)
2010 Celestial Mica Blue
APv2, CS RMM, JBR ALUM 3" INTAKE, CS CBE, CS DPcatted,CS HPFP, H&R Springs (BNR S4 to be installed)
Stratified OTS+ E85 tune
Jeremy M is offline   Reply With Quote
 Old 12-27-2014, 01:36 AM   #49
My mistake, the wrong email was sent out. I will have this fixed in the morning.
 Old 12-27-2014, 03:29 PM   #50
Resent sir!
Jeremy M (12-27-2014)
 Old 12-27-2014, 03:55 PM   #51
Jeremy M's Avatar
Grassy ass
 Old 03-04-2015, 04:54 PM   #52
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
So today I upgraded my mid pipe on my car from stock to 3" and I now have a full 3" Ultimate Racing TBE. I was wondering if you would recommend getting a flash tune for my V2.0 tune or would it be ok to just run the one I have with the stock mid pipe?
2012 Mazdaspeed3 Black Mica
 Old 03-04-2015, 10:04 PM   #53
If you already have the stg2 this is the highest performance flash tune we currently offer before going to a custom tune.
The efficiency gained from a freer flowing exhaust will benefit the performance of the car.
 Old 03-16-2015, 06:19 AM   #54
TORQUERULES's Avatar
Posts: 283   (View Stats)
TORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond repute
In the flash tune you can also go ahead and take care of EGR delete codes and Downpipe codes as well, correct?
Do launch control and flat foot shifting options cost extra on the tune?
Another question, I also have E85 available. Is the power and safety advantage worth it considering the issues with pump deposits? Or with your recommended mixture are pump deposits not an issue?
Thanks for yourself. Looking to go AP with a flash tune from Stratified.
(SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc.
2017 Mazda CX-3 Meteor Gray
Last edited by TORQUERULES; 03-16-2015 at 06:19 AM. Reason: MSF Database - Automerged Doublepost
TORQUERULES is offline   Reply With Quote
 Old 03-16-2015, 07:13 PM   #55
Yes codes are taken care of.
LC and FFS we can set at no extra charge and for people with the V3 AP you can also set this with our latest tunes as you wish.
With a 4 gallons of E85 and rest pump gas mix there are no issues and yes the gains and safety are worth it .
TORQUERULES likes this.
TORQUERULES (03-17-2015)
 Old 03-17-2015, 05:14 AM   #56
Thanks. Yes, I will be purchasing a V3 AP, so that is nice to have the option to turn LC and FFS on or off.
I will be purchasing a pure pump gas flash first and then an E85 later on. Can both be loaded onto the AP at the same time and switched when needed?
Thanks.
One more question: I will be getting a catless DP next. Would it be good to request the O2 code be taken care of already, or just wait to do a revision on the whole tune to take care of the DP addition and do it then?
Last edited by TORQUERULES; 03-17-2015 at 05:14 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-17-2015, 10:57 AM   #57
Thanks.
If you purchase the AP V3 through us, one of your flash tunes is already included in that price.
MazdaSpeed 3/6 COBB AP With Stratified Flash Tune [MS_AP_Package_2] - $650.00USD : Stratified Automotive Controls
Yes you can have both the E85 and pump tunes on the AP at the same time and flash between them.
If you are planning on the catless DP, then do specify the O2 codes to be removed.
 Old 04-15-2015, 03:56 PM   #58
stoickiwi's Avatar
Posts: 235   (View Stats)
stoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the worldstoickiwi is the leader of the world
Just got my Flash Tune last night at like 4am. I loaded it on to the AP before work and flash it.
Holy crap am I impressed!
I attached a log from my first pull on my way home and I am boosting like a boss with AFRs, KR, and LTFTs looking great.
The car pulls SO much harder than with the Cobb OTS.
Not only that, but I averaged 1.5MPG better on the way to and from work with many more foot stomps to enjoy the new tune.
Keep up the good work guys and gals!
2012 MazdaSpeed3 with Tech
Stock AF
stoickiwi is offline   Reply With Quote
The Following 2 Users Say Thank You to stoickiwi For This Useful Post:
kgb (04-15-2015), Lex (04-15-2015)
 Old 04-15-2015, 10:20 PM   #59
Happy you're enjoying the tune!
stoickiwi (04-16-2015)
 Old 04-24-2015, 03:25 PM   #60
portetra000's Avatar
Posts: 85   (View Stats)
portetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond repute
Just ordered my e85 tune!!! Cant wait to see the results with the 3.5 intake coupled together. I usually write my own tunes but I haven't ventured into corn yet so in the meantime I've always wanted to try a stratafied tune while I develop my own. Super excited to see what comes out of it. Very fast turnaround already it took only an hour to get the mod form from the time of ordering.
2007 MS3/Black Mica/JBR 3.5 Aluminum Whale Penis/CP-E catted downpipe/JBR EBC/JBR EGR Blockoff/CX Racing BOV/Corksport cat back exhaust/Cobb lowering springs/AP Tuner/ Stage 2 -self tooned (E85 Stratafied Stage 2 tune for fun days)/JBR 88a RMM/shaved hatch/corksport mudflaps/Dip'd rims/aftermarket boom boom box
portetra000 is offline   Reply With Quote
 Old 04-27-2015, 11:06 PM   #61
EvoFire's Avatar
Posts: 389   (View Stats)
Do you tweak the flash tunes depending on the parts installed? Right now I have a stg2 flash tune for 3" intake and ETS TMIC. I scored a good deal on a CS downpipe, a catted testpipe, and Cobb exhaust. I was wondering if I need to get an upgrade flash if I install any of the parts?
 Old 04-28-2015, 10:24 PM   #62
If you have the latest stg2 tune and none of the parts are going to trigger CELs and fuel quality remains the same then you are good to go. Otherwise you can purchase a flash tune upgrade.
EvoFire (04-29-2015)
 Old 04-30-2015, 11:12 AM   #63
THE E85 tune kicks ass with the new intake! Its been lightly raining and I cant even log a run because I cant keep traction at WOT. As soon as it drys out I will make a run and post a vdyno. Need moar rubber on the road
The Following User Says Thank You to portetra000 For This Useful Post:
Lex (04-30-2015)
 Old 05-19-2015, 05:52 PM   #64
speedboost's Avatar
Posts: 13   (View Stats)
speedboost is a glorious beacon of lightspeedboost is a glorious beacon of lightspeedboost is a glorious beacon of lightspeedboost is a glorious beacon of lightspeedboost is a glorious beacon of light
I heard the 90 day upgrade discount from ots+ to custom tune has ended now?
can you please confirm this discount has now ended?
Cobb SRI, TIP, DP // AT internals // Denzo itv22 // AP V3 // Stratified
speedboost is offline   Reply With Quote
 Old 05-19-2015, 10:09 PM   #65
This is correct the discount has indeed expired.
 Old 05-28-2015, 03:36 PM   #66
Quick question on this. is there enough correction in this tune that i will be semi safe installing a mac valve ebc on the tune i bought for the stock ebc or should i steer clear of using it till i get a retune on the e85 with it?.
 Old 05-28-2015, 04:21 PM   #67
It will be safe as long as the EBCS is installed in the OEM 2 port mode with port 3 capped, port 2 going to the TIP and port 1 going to the OEM WG actuator top port.
If you want a 3 port interrupt setup then a custom tune is needed to dial in the boost control.
portetra000 (05-28-2015)
The Stratified Flash Tune (Formerly S-OTS PLUS) Lex Stratified Automotive Controls 312 02-26-2016 12:55 PM
How To: Stratified Tune Lex Stratified Automotive Controls 1 07-24-2014 12:22 PM
First Stratified S-OTS+ Tune Jadcock 2010 MS3 - ECU Computer Tuning 45 07-09-2014 08:57 AM
Stratified Tune phahengpro MazdaSpeed 3/6 - ECU Computer Tuning 42 03-07-2014 03:29 PM
Stratified tune done. MS309 Stratified Automotive Controls 57 08-04-2012 05:39 PM
Page generated in 0.47712 seconds with 29 queries
