E-Tuners / Custom Hardparts
  • 1 Post By
 Old 02-23-2012, 04:39 PM   #1
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
Exactly what sk1nny said. You can put about another quart of oil, more oil gets to the "trouble cylinder" that runs hotter because of the extra air it gets when compared to the other cyls. Not sure if it was a placebo effect, but I noticed the engine rev a bit more eagerly. And to be honest, the extra high freq. vibes feel good on my balls.
2006 Mazdaspeed6 GT BCM
SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors
Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP
HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM
Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate
Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN
psychophyr is offline   Reply With Quote
The Following User Says Thank You to psychophyr For This Useful Post:
h.h.sk1nny (02-24-2012)
Stratified 20% E-85 transformed. 08cosmic3 Stratified Automotive Controls 33 12-29-2013 08:17 PM
Stratified/PERM 298whp/341wtq daafisch Stratified Automotive Controls 55 05-22-2012 09:57 PM
Stratified Tuned also. "Stratituned" 08cosmic3 Stratified Automotive Controls 5 01-16-2012 04:09 PM
Problem. Without meth tune is great. On Meth tune shits the bed. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 16 09-06-2011 06:58 PM
Page generated in 0.24010 seconds with 22 queries
