E-Tuners / Custom Hardparts
Like Tree12Likes
 Old 01-22-2013, 09:49 AM   #81
Originally Posted by DSIT995 View Post
Just want to clarify something in this setup...
So for the mounting in the TB silicone your using just the washer on the inside and attaching the nozzle threw the silicone to the 90* fitting?
The reason I asked is I used the DO silicone adapter when I ran my TMIC setup and it always scared the shit out me the inner adapter was going to end up in my engine.(even with loctite on it) One of the reasons I didnt re-install my meth in the same manner on my fmic.. I want to get it hooked back up w/ my current setup and just trying to find the best nozzle mounting point
If this is the case are you using loctite or something to make sure it doesnt loosen? And how would you go about cleaning the filter using this method..
btw my setup is the original DO stage 2 progressive controller and I ran a DO3 nozzle w/ 25/75% mix.. kinda weak but kept BATs at bay in the summer months
Edit: Also would you reccomend using the "newer style" nozzles from DO which seem similar to the CoolingMist nozzles?
I've ran this setup for a long time (years) with no issues. Yes, I use blue loctite on the nozzle but the NPT fitting and sticky nature of the silicone has worked great at keeping everything together with no leaks. The coupler I am using is the COBB one to the throttle body and it is quite thick. I don't like the adapters that DO makes and won't use them. Having a nut inside the charge pipe scares me as well - this is safer as the threading happens outside the charge pipe and can be checked periodically. Also I have the older style 90* elbow that has a fairly large surface against the silicone. Newer ones may need a washer.
I have used both the new and old DO nozzles. I preferred the old since they protruded less in the pipe but the new ones work fine.
To clean the filter, I just remove the coupler and take the assembly to the bench.
Addikted To Boost (11-06-2014), DSIT995 (01-22-2013), FreeFlyFreak (01-24-2013), Pointless (01-22-2013)
 Old 01-22-2013, 09:59 AM   #82
DSIT995's Avatar
Posts: 1,768   (View Stats)
Exactly what I wanted to know, Thanks a bunch
99 Miata NB - Stock for now
 Old 01-22-2013, 10:18 AM   #83
KevMS6's Avatar
Posts: 316   (View Stats)
Left side is aquamist silicone hose adaptor with aqaumist jet
Right side is devils own silicone hose adaptor
No risk of anything falling off as its a solid peice and the jet sprays perfectly
Tuned with by
The Following 3 Users Say Thank You to KevMS6 For This Useful Post:
BobtailedSnail (01-22-2013), DSIT995 (01-22-2013), Pointless (01-22-2013)
 Old 01-22-2013, 12:04 PM   #84
DSIT995's Avatar
Worked like a charm... This feels much more secure than the DO adapter... With a dab of loctite its ready to go
Thanks again Lex
The Following 4 Users Say Thank You to DSIT995 For This Useful Post:
Lex (01-22-2013), Pointless (02-02-2013), Rich990 (01-23-2013), Vader (01-22-2013)
 Old 02-04-2013, 12:15 PM   #85
Dr. Speed's Avatar
Posts: 610   (View Stats)
Dr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the world
@Lex; What kind of fluid check valve do you use when hooking up the lines to the OEM washer tank on a Gen2? (where should I get it?)
| 2012 CWP | Cobb AP + AT Internals | HTP 3" Intake | 91oct + DO WMI (D07, 50/50) + 3gal E85 | UR Test Pipe | cp-e TMIC | JBR Trilogy, OCC, EGR Block, SSB | TBC Bypass |
Freektuned - 313/351 - Stock DP
Dr. Speed is offline   Reply With Quote
The Following User Says Thank You to Dr. Speed For This Useful Post:
Pointless (02-04-2013)
 Old 02-04-2013, 01:51 PM   #86
Here are a few choices:
SWF Windshield Washer Check Valve : Amazon.com : AutomotiveSWF Windshield Washer Check Valve : Amazon.com : Automotive
ScanTech Windshield Washer Check Valve : Amazon.com : AutomotiveScanTech Windshield Washer Check Valve : Amazon.com : Automotive
Or just go to local parts store and ask for windshield washer check valve.
Dr. Speed (02-04-2013), Pointless (02-04-2013)
 Old 02-04-2013, 02:47 PM   #87
Dr. Speed's Avatar
Great, thanks
One more thing... if I was to drill and tap the washer fluid tank, where would be the best place in your opinion? (just above where the factory pump sits or on the front down low?... is there room between the tank and the bumper to tap the front?)
 Old 02-04-2013, 02:56 PM   #88
Great, thanks
If you wanted to tap the factory tank I would find the thickest area and use epoxy and do it at the bottom of the tank not on its side.
 Old 02-04-2013, 03:42 PM   #89
DuBz's Avatar
Posts: 238   (View Stats)
DuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the world
Subbed.......deff going this route when I'm ready
GenWin Mazdaspeed 3: HTP 3", CP-E RMM: HKS SSQV : masonville knob, JBR SSP, bushings, RSB: COBB AP: STRATIFIED: Saikou Michi OCC: CP-E DP & FMIC: Autotech Internals: Koni FSD's: DO Meth A La WW tank style
DuBz is offline   Reply With Quote
 Old 02-04-2013, 04:10 PM   #90
bryansawiseone's Avatar
Posts: 594   (View Stats)
bryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the world
On the 2nd gen couldn't you just hook the meth line to the rear ww port instead of connecting the front and rear with a tee and not have to worry about the rear ww coming on while using the front?
2012 MAZDASPEED3 W/ TECH PACKAGE - BNRS3 - HTP 3.5" - GRIMMSPEED EBC - COBB FMIC - COBB AP - CP-E RMM - JBR 80 DURO PMM AND TMM - AUTOTECH FUEL PUMP INTERNALS - JBR SOLID BUSHINGS - CP-E CATTED DOWNPIPE - CP-E TRITON CBE - FORGE V2 BPV - CORKSPORT OCC - DEVILS OWN DVC-30 WMI D10 50/50 - NGK LTR7IX-11 PLUGS - EVOX WHEELS - FREEK TUNED
bryansawiseone is offline   Reply With Quote
 Old 02-04-2013, 06:20 PM   #91
Tested this and it didn't work out with hooking up to just a single outlet of the pump.
 Old 02-26-2013, 02:01 PM   #92
pwned's Avatar
Posts: 762   (View Stats)
pwned has disabled reputation
Do it matter if the check valve is right at the cowl area? Or can it be down by the tank?
Sold
-12' Ms3 // 305hp 336tq SAE
-13' CWP MS3
JBR 88a Trilogy // Full3 Aeros ID300 Intake // At Internals // UR Catless Tbe // JBR Occ // Forge V2 // Cobb FMIC // Ngk(6510)@.026 // Devils Own WMI // Freek Tune // Swift Springs // JBR Rsb
323hp/351tq SAE
Current..
02 Regal GS-Go fast stuff-286hp/314tq 12.8 @ 108.....248k original motor/trans(Broken........Trans failed at 249,334 12/6/15)
16' Mazda 6 GT (sonic silver)
pwned is offline   Reply With Quote
 Old 02-26-2013, 02:32 PM   #93
I would have it as close to the nozzle as possible to keep the line filled as close to the nozzle as possible.
 Old 02-26-2013, 07:03 PM   #94
pwned's Avatar
Would the best spot be where the red circle is? I was asking about the added check valve needed when tapping into the 2010+ washer tank..
Sold
-13' CWP MS3
323hp/351tq SAE
Current..
The Following User Says Thank You to pwned For This Useful Post:
atvfreek (02-27-2013)
 Old 02-26-2013, 08:35 PM   #95
Ah sorry, a good place for that is where the line comes up from the fender on the driver's side cowl but really it doesn't matter as long as it sits between the T fitting and the washer nozzles.
atvfreek (02-27-2013), pwned (02-26-2013)
 Old 02-28-2013, 11:06 AM   #96
pwned's Avatar
I am getting everything together to run the actual feed line. I have the tee as pictured and I am going to tee in the same spot as pictured by you. Now when I spray my washers isn't the fluid going to try and go up my line to the meth pump? Should I be worried about anything? Try a different tee? Add another check valve? All I found were plastic tee's and nothing fancy like your metal one.
Sold
-13' CWP MS3
323hp/351tq SAE
Current..
 Old 02-28-2013, 11:27 AM   #97
The meth pump and single check valve at the nozzle will prevent fluid from being injected when you use the washers.
Make sure the connections are solid. Not sure what is going on with the one small T but what I do is use a larger T and fit a piece of larger hose over it. Then that hose fits over the meth feed hard line.
Remember that mine is a Gen1. Your Gen2 setup will look different. Below is a gen2 setup:
Menace1 (03-31-2013), Pointless (02-28-2013), pwned (02-28-2013)
 Old 02-28-2013, 12:10 PM   #98
pwned's Avatar
I really don't know where I was going with that tee I made lol I was wrong. That gen 2 image helps a lot! I was going to just block off my rear washer line since I never use it.
Sold
-13' CWP MS3
323hp/351tq SAE
Current..
 Old 03-08-2013, 05:53 PM   #99
DSIT995's Avatar
I made some slight changes to my nozzle setup to combat any slight leaks at higher boost levels
I decided to use a McMaster-Carr Nozzle part# 3178K75 DO Nozzle are the 2 on the left and McMaster on the right. McMaster is on $7.16 Vs $20. The McMaster nozzle's seems to have the same type of mesh screen as the DO's. According to there pressure chart this nozzle should flow the same as a D05
Main benefit isit has more threads(9.6mm) Vs the standard DO nozzle (7.75mm) The slight increase made it possible to use 2 washers inside & outside 3-ply silicone to combat any leaks at higher boosts. Also for those w/ 4-ply couplers this will give you a extra bit of thread to work with..
Also using a hollow punch(5/16th) made a much cleaner hole. Found here
Again thanks to Lex for showing this method for nozzle placemnet
The Following 3 Users Say Thank You to DSIT995 For This Useful Post:
CosmicArkie (03-10-2013), Lex (03-08-2013), Pointless (04-19-2013)
 Old 03-08-2013, 09:08 PM   #100
Dust's Avatar
Posts: 192   (View Stats)
Dust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the world
I did the same thing for a preturbo nozzle installed into a cone filter
Dust is offline   Reply With Quote
 Old 03-09-2013, 07:43 AM   #101
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I have been using the Mcmaster carr "M" nozzles for 7 years...
They work great.
 Old 03-09-2013, 08:09 AM   #102
Dust's Avatar
I have a few left from my first kit. The far left brass ones are still cheaper. Devil's own nozzles were $6 for a while. Glad I grabbed some, even though it will probably bring me up to 25 nozzles from 4 different companies for two different kinds of kits.
 Old 03-09-2013, 03:36 PM   #103
Keep an eye out - we might have something very elegant for mounting for you guys ...
The Following 13 Users Say Thank You to Lex For This Useful Post:
atvfreek (03-10-2013), BigRedSpecial (08-20-2013), bstover17 (04-16-2013), CosmicArkie (03-10-2013), Dr. Speed (03-30-2013), DSIT995 (03-09-2013), El_Diablo (03-12-2013), IMASA (03-15-2013), mituc (03-10-2013), Nliiitend1 (03-09-2013), Pointless (03-31-2013), radbrad (08-13-2013), sidekick (03-31-2013)
 Old 03-30-2013, 01:58 PM   #104
pwdunmore's Avatar
Posts: 368   (View Stats)
How soon?
I just order my SP stage 2 kit and was looking for some silicone mounting adapters or figuring out how to do this washer method.
I was planning to install my meth kit then get a tune from Stratified
The Following User Says Thank You to pwdunmore For This Useful Post:
Lex (03-30-2013)
 Old 03-30-2013, 09:00 PM   #105
Originally Posted by pwdunmore View Post
How soon?
I'm not promising timeframes at the moment as things are in development at the moment. After this there will be testing and if all works out; it will be out for sale.
The tunes however are always available
 Old 03-30-2013, 09:48 PM   #106
pwdunmore's Avatar
Ahhh true, might be a little wait then. Guess I will go with a DO nozzle and using washers to seal it in the silicone.
Definitely want to get my meth installed before I get a tune though, unless there not much point waiting but I am sure the meth will give more room for tuning for you guys.
For my set-up should I get a solenoid or check valve? I am a little confused as to when they are needed/used. I haven't mounted or installed anything so I can change the arrangement of my set-up, all I have right now is the Snow Performance Stage 2 MAF.
Lex (04-01-2013)
 Old 03-31-2013, 03:12 PM   #107
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
So does the OEM washer pump keep a constant supply in the window washer lines/WMI lines by default? Or does the OEM wiring need to be messed with?
Lex (04-01-2013)
 Old 03-31-2013, 10:39 PM   #108
I haven't seen any issues with running a check valve and there are fewer things that can fail. And yes, WMI does certainly give you more headroom, especially in the summer and in areas with poorer quality fuel.
The wiring does not have to be touched.
 Old 04-01-2013, 11:18 AM   #109
crazyspeed6's Avatar
Posts: 74   (View Stats)
crazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud of
I'm in, you know I'm ready for WMI, and as the temps rise, things arent going to get any better.
2006 Speed 6 - GTX3071, Cobb AP, CPE HPFP, CPE DP, HTP 3" Turbo Inlet, HTP 3" MAF Housing, CX FMIC, Greddy BOV, 3 Port EBC, JBR IM TIG, 3 Bar MAP, Corksport OCC, Stratified Tuned by Lex
STOCKING OUT
crazyspeed6 is offline   Reply With Quote
The Following User Says Thank You to crazyspeed6 For This Useful Post:
Lex (04-01-2013)
 Old 04-01-2013, 11:30 AM   #110
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Ug guess I'll put my check book back...thought this was a new product release.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
Lex (04-01-2013)
 Old 04-01-2013, 11:33 AM   #111
Not just yet
86AmishMs3 likes this.
86AmishMs3 (04-01-2013)
 Old 04-01-2013, 11:55 AM   #112
86AmishMs3's Avatar
Groans: 338
Not just yet
Well hopefully soon, because I have some tax return money, and I've been closer to pulling the trigger for some meth to help supplement. But I would like something that is well integrated.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 04-05-2013, 06:40 PM   #113
pwned's Avatar
Few quick questions.
The setup with the t's as pictured. Is this the correct way for my 2013? Along with the inline check valve connection? (Note I left my rear washer line feed unhooked because I do not use it.)
In the other image could I just use the rear line by itself as a feed (unhook from the white connection) or is there not enough flow by itself? Or other issues?
Sold
-13' CWP MS3
323hp/351tq SAE
Current..
 Old 04-05-2013, 07:59 PM   #114
pwned's Avatar
I think I made a mistake. Does this look more like it??
Sold
-13' CWP MS3
323hp/351tq SAE
Current..
 Old 04-06-2013, 01:25 PM   #115
As long as the WMI us drawing from both pump outputs then that is all you need. So it looks like both were going to work.
 Old 04-07-2013, 08:25 PM   #116
pwned's Avatar
I am having an issue using my d07 nozzle in the cobb coupler. There is no way two washers can be used. Im looking into getting a fitting from mc master.
This is right from DO's website
7 GPH (441ml/min) Micro Droplet Methanol
On mc master I found a nozzle that resembles the DO specs
part # 3178K52 in stainless steel
40psi 4.43 flow rate gph
100psi 7 flow rate gph
McMaster-Carr
I see it only comes in hollow cone so this wont work? I will need full right?
Sold
-13' CWP MS3
323hp/351tq SAE
Current..
DSIT995 (04-07-2013)
 Old 04-07-2013, 08:38 PM   #117
DSIT995's Avatar
McMaster-Carr
D07 appears to only be offered in the hollow cone... Idk what effects that could cause. Good question for lex..
But you would have zero issues using the McM nozzle with 2 washers, I'll post up a pic w/ 4ply coupler using 2 washers and it feels solid..
 Old 04-07-2013, 09:09 PM   #118
pwned's Avatar
McMaster-Carr
Sold
-13' CWP MS3
323hp/351tq SAE
Current..
 Old 04-08-2013, 10:13 AM   #119
Remember to use very thin washers. Mcmaster sells some very thin units.
 Old 04-08-2013, 11:42 AM   #120
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I am having my spare cold tube tapped for the WMI injector this week. If there is enough material, perhaps tapping it alone will be enough, otherwise the machine shop will have to fashion a bung. On the MS6, there's a great place on the cold tube right before the coupler to get a straight shot to the throttle body. I'll post pics when I am done.
I am a little frustrated with DO; their boost controller was on backorder even though they were showing in stock; I have had a couple unanswered emails since and finally got an answer when I called today. If all goes well, I will be installing my WMI this weekend.
I bought 4 gallons of the snow premade meth/water to start, but I already sourced a local place that sells VP M1 so I can mix my own.
MINI H1 6.0 - CAR LED TAILS
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/stratified-meth-kit-install-using-stock-washer-25050/
Water/Meth - Mazda 3 Quebec This thread Refback 07-16-2013 01:08 PM
W/M pour un DD ? - Forced Induction - Club Civic Quebec :: Forum This thread Refback 02-26-2013 10:45 AM
Meth Kit - How to Tap the stock WWF reservoir This thread Refback 01-21-2013 08:33 PM
EGR Delete = Bad Ass Meth Install?? jhershorin MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 23 02-21-2009 09:52 AM
SUPER's Labonte Water/Meth Install superskaterxes MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 14 02-19-2009 10:22 AM
Dont be dumb with meth install wassup61 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 02-05-2009 02:52 PM
Meth kit install questions Stan-O MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 01-24-2009 08:21 AM
Mazda3Mods Meth Install Buildabong MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 35 01-19-2009 07:38 AM
Page generated in 0.66369 seconds with 34 queries
