E-Tuners / Custom Hardparts
  • 1 Post By Lex
 Old 06-03-2013, 11:21 PM   #1
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
Default Stratified OTS Maps for JBR WP won't open in ATR
Hopefully you can help @Lex;
I should be getting my JBR 3" WP tomorrow and I went and downloaded the stage 1 map for the intake. My problem is that it won't open in ATR because I was going to set LC and FFS for that map. Here is the screen I'm getting everytime i try to load the map.
Do I have to flash the map to my car when I get the intake on then go back and change LC and FSS or what?
Thank you and I'm looking forward to more power from Stratified.
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
 Old 06-03-2013, 11:25 PM   #2
yomyster67's Avatar
Posts: 262   (View Stats)
yomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond reputeyomyster67 has a reputation beyond repute
Stratified maps are locked.
Stratified Tuned: cobb - ap - fmic - sri - xle bpv - rmm - shift knob - shift weight / corksport - tip - bpv hose / twm - full replacement sts / autotech - hpfp internals / cnt - downpipe / hks - exhaust /
yomyster67 is offline   Reply With Quote
The Following 3 Users Say Thank You to yomyster67 For This Useful Post:
cshunter (06-05-2013), Lex (06-04-2013), memin (06-03-2013)
 Old 06-04-2013, 05:29 AM   #3
shadow102's Avatar
Posts: 971   (View Stats)
the maps are locked, however if you go to cobb's website you can add LC and FFS to anymap locked or not through a link they provide
Accessport Off The Shelf Maps
2013 CWP MS3 w/tech package
The Following 3 Users Say Thank You to shadow102 For This Useful Post:
cshunter (06-05-2013), Lex (06-04-2013), rymanmazda (06-04-2013)
 Old 06-04-2013, 09:48 AM   #4
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
I'm pretty sure that the Stratified maps are for the PowerPath intakes, not the 3" WP. You might want to double check that. It's my understanding that the MAF calibration would be different for the different intakes.
On deck: VG Sharkfin Antenna
The Following User Says Thank You to jk_ms3 For This Useful Post:
Lex (06-04-2013)
 Old 06-04-2013, 09:59 AM   #5
These are all correct statements:
- The S-OTS maps are locked down.
- The maps are meant for the powerpath intake and not the WP or any 3" or larger intake. The 3" intake will not work with these and the car will run lean.
cshunter (06-05-2013), jk_ms3 (06-04-2013)
 Old 06-04-2013, 10:21 AM   #6
rymanmazda's Avatar
Groans: 122
Would a MAF CAL set it right or is there another way I would have to go. Is there any OTS map for this intake (if i remember right there isn't).
-Autocross Setup-
Other Rides:
 Old 06-04-2013, 11:05 AM   #7
There isn't and for good reason. Big intakes generally require custom tunes to get the most from them. Also cars are generally further from stock/OTS map territory when they have bigger intakes.
cshunter (06-05-2013), JBR (06-04-2013), jk_ms3 (06-04-2013), rymanmazda (06-04-2013)
 Old 06-04-2013, 12:17 PM   #8
SparkySparks's Avatar
Posts: 1,314   (View Stats)
@Lex; has some good MAF Cal numbers to start you off with so you can modify the COBB OTS map for the new intake. Just search for his post about big intake maf cal.
On Order:
Coming Soon:
DIY Projects:
The Following 2 Users Say Thank You to SparkySparks For This Useful Post:
cshunter (06-05-2013), Menace1 (06-04-2013)
 Old 06-04-2013, 12:24 PM   #9
Yes you can use those MAF cal numbers. However be aware that you are likely to overboost with the COBB OTS maps and an opened up intake/exhaust system.
atvfreek (06-04-2013), JBR (06-04-2013), SparkySparks (06-04-2013)
 Old 06-04-2013, 12:46 PM   #10
Agreed, I was meaning as a starting point for the maf cal only. I should have also stated you would need to adjust your tune as you start to open things up and adding mods. Or just get an E-tune and start smiling sooner if you find self tuning to much.
On Order:
Coming Soon:
DIY Projects:
 Old 06-04-2013, 06:57 PM   #11
rymanmazda's Avatar
Groans: 122
Ok thanks for all the help
Most likely ill have about a thousand dollars freed up in about a month so ill get a couple more mods then get a e-tune.
I found the maf calibrations for the intake. I'm a noob at tuning so how would I apply those numbers? And what tune should I apply these to.
I'm getting my wallet to donate right now btw.
-Autocross Setup-
Other Rides:
 Old 06-04-2013, 09:04 PM   #12
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
The How To is right in the opening post dude.
MAF calibrations for bigger intakes
2012 Velocity Red Mica
The Following 2 Users Say Thank You to Dimenus For This Useful Post:
 Old 06-04-2013, 09:08 PM   #13
rymanmazda's Avatar
Groans: 122
I was on tapatalk and I didn't see it. opps.
-Autocross Setup-
Other Rides:
 Old 06-05-2013, 11:20 AM   #14
rymanmazda's Avatar
Groans: 122
Ok so I know how to do a MAF CAL and I read lex's article and I understand how to apply that. The main question I have now is what map do I apply these to? Do I grab one of cobb's ots maps and input the variables for the jbr 3" intake or do I just input it on my current tune?
I'm just trying to find a good temporary solution for normal driving until I get my DP and AT internals.
-Autocross Setup-
Other Rides:
 Old 06-05-2013, 11:44 AM   #15
If your current tune drives well then apply them to that and watch for any hpfp pressure drops at WOT in the low RPMs (spool) and during fast shifting.
rymanmazda likes this.
rymanmazda (06-05-2013)
 Old 06-07-2013, 09:57 PM   #16
rymanmazda's Avatar
Groans: 122
So far I'm at 40 miles on the intake and everything is looking good! Just curious, i will be getting AT internals and ATP turbo DP soon, so how much hp should I expect after I get a professional tune by you? I didn't want to start a whole thread to ask this.
Thank you!
-Autocross Setup-
Other Rides:
 Old 06-07-2013, 10:44 PM   #17
Every car behaves differently since there are many parameters involved including health of engine, fuel used, modifications, etc. etc.
We have a small database of Dyno results posted for you to check out:
Dyno Results : Stratified Automotive Controls
rymanmazda (06-07-2013)
Stratified S-OTS maps for the JBR Power Path Intakes Lex Stratified Automotive Controls 284 07-18-2017 04:45 PM
Stratified---- wiggles93 Stratified Automotive Controls 9 01-12-2013 02:06 PM
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 11:03 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
Open Arms in Open Wheels: reunited IndyCar season kicks off at Homestead Haltech Automotive News 0 04-01-2008 09:20 AM
Page generated in 0.38797 seconds with 27 queries
