E-Tuners / Custom Hardparts
Like Tree17Likes
 Old 03-01-2017, 09:56 AM   #281
TXGenPu's Avatar
Posts: 14   (View Stats)
TXGenPu will become famous soon enough
Is there a power increase range I can expect with this S-OTS map?
I have the Powerpath stage 2 and HPFP internals coming in this week and am just curious to see what other people are getting. I'm not expecting crazy gains, just mainly curious.
TXGenPu is offline   Reply With Quote
 Old 03-03-2017, 05:17 PM   #282
The tune should offer an improvement in performance as well as drivability.
 Old 03-03-2017, 09:32 PM   #283
distortion's Avatar
Posts: 66   (View Stats)
distortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud of
I would definitely recommend checking out the Flash tune on Stratified's website. $50 very well spent and you will see a power increase for sure.
2011 Black Mica W/Tech Package
Cobb AP|CP-E HPFP|Corksport SRI/TIP|Corksport TMIC|UR Test Pipe|Corksport Cold Air Box|Corksport Rear Sway Bar|JBR Shifter Bushings|Corksport RMM|Techna Fit Stainless Brake Lines|Ultraguage|Stratified E85
distortion is offline   Reply With Quote
 Old 03-07-2017, 11:04 AM   #284
TXGenPu's Avatar
Update:
I've pulled 4 datalogs and all readings are within their safe ranges and only differ by fractions of a value. As for STFT and LTFT, I've had absolutely no issues and my car is very happy with this new tune/mod set-up!
JBR likes this.
2012 GenPu Pearl White
Engine: Cobb AP V3/JBR Power Path Stage2/Autotech HPFP internals/NGK Iridium IX LTR7IX-11/CP-E CBE
Mounts and such: CP-E Stage2 RMM/JBR STS/JBR Solid Shifter Bushings
Brakes: Hawk HPS pads/Stoptech SS lines/Motul RBF600
The Following User Says Thank You to TXGenPu For This Useful Post:
JBR (03-07-2017)
 Old 07-18-2017, 04:45 PM   #285
NeXuS772B's Avatar
Posts: 9   (View Stats)
NeXuS772B is an unknown quantity at this point
If i'm seeing high LTFT (14.06% under heavy throttle) on the Stratified OTS and I purchase a Flash Tune....would my trims be closer to 0? I ask because my trims on the mentioned tune - despite it being tailored for the JBR intake installed - are farther from 0 than what I experienced when I was on the COBB Intake + COBB Stg 1+ tune.
I checked for leaks and reinstalled the intake multiple times but no luck. Even flashed the COBB tune with the JBR hardware and got LTFTs within +/- 5%. I like the way the Stratified tune feels and don't mind paying for a flash tune...but would it improve my trims? From the attached logs despite high LTFTs I'm still seeing good AFRs and fuel pressure at max boost stays above 1600 PSI at all times.
'13 MS3 - The Red Kind
COBB RMM
COBB SRI --> Uninstalled
COBB Accessport
JBR Powerpath Stage II Intake
Stratified OTS Tune
NeXuS772B is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/stratified-s-ots-maps-jbr-power-path-135125/
Flat foot shift - Mazda 3 Quebec This thread Refback 07-28-2013 06:23 PM
Forum Mazda Performance Series - Zobacz temat - Stratified OTS Maps This thread Refback 03-23-2013 05:44 AM
Intakes Now Available! HTP HTP (Hi-Tuned Performance) 354 10-14-2014 08:21 AM
Mod path for me eksces Mazdaspeed3/6 General Discussion 19 07-31-2012 03:26 PM
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 11:03 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
Page generated in 0.26635 seconds with 24 queries
