E-Tuners / Custom Hardparts
Like Tree17Likes
 Old 04-27-2013, 05:46 PM   #41
iammike's Avatar
Posts: 1,415   (View Stats)
Originally Posted by Tronix View Post
here are datalogs from today. I'm a little concerned, should I try the 91 map to compare? Looking for a second pair of eyes. This is stage 1
Thanks
I'm not sure why your fuel pressure dropped in that range. It kind of dipped down then went back up over the course of 8 or so cells. Also, you should really be logging Knock Retard as well.
Disclaimer: I'm no pro by any stretch of the imagination.
Mike
The Following User Says Thank You to iammike For This Useful Post:
Lex (04-28-2013)
 Old 04-27-2013, 05:49 PM   #42
Thanks
You're seeing some slight pressure drops during spool but nothing too drastic. The 91 octane map differs in timing, not load, so you will see the same requested loads.
This is just telling you that if you are looking for more boost or want to add anything more in terms of flow to the car, you will need to upgrade the HPFP as it is on the edge.
 Old 04-27-2013, 06:10 PM   #43
Tronix's Avatar
Posts: 24   (View Stats)
Tronix is a splendid one to beholdTronix is a splendid one to beholdTronix is a splendid one to beholdTronix is a splendid one to beholdTronix is a splendid one to beholdTronix is a splendid one to beholdTronix is a splendid one to beholdTronix is a splendid one to behold
ya sorry, I striped some data out because the log was large. I attached the original.
Ok that's good to know, that was my suspicion also just wanted to make sure. I appreciate you looking.
2012 Crystal White Speed 3 w/ Tech
JBR SRI | JBR TIP
Tronix is offline   Reply With Quote
The Following User Says Thank You to Tronix For This Useful Post:
Lex (04-28-2013)
 Old 04-28-2013, 10:51 PM   #44
bbrownderville's Avatar
Posts: 124   (View Stats)
bbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant futurebbrownderville has a brilliant future
I just swapped to your 91 stage 1 and wow what a difference from Cobb's ots. Given I dont have a jbr intake, i still feel a huge difference with the butt dyno and love the different boost contol/throttle sensing. I will be a paying customer someday from this experience!
2011 Celestial Blue Mica MS3
AT Internals | Cobb AP V3 | Cobb SRI | CS LEDs | CS Hood Light | CS Hood Struts | Enkei M52 Rims | JBR SSP | JBR Boost Tubes | JBR Bypass Hose | JBR Trilogy Mounts 80 Duro | M2 Downpipe | PG TIH | Sure AGS Knob | Sure Anchors | Sure Wiper Delete | TS BPV | UR CBE| Stratisfied Tune.
bbrownderville is offline   Reply With Quote
The Following 2 Users Say Thank You to bbrownderville For This Useful Post:
Lex (04-28-2013), Worbit (05-09-2013)
 Old 05-09-2013, 01:49 PM   #45
Tronix's Avatar
So just an update:
Been driving around with stage 1 93 for a few weeks, very happy with it still. So i filled up today and calculated my mpg. I honestly thought it was gonna drop by alot because I have been flooring it all over the place.
24.6 mpg
I bet I can get 26 if I dont hammer on it all the time. I'm impressed. The stock tune must be really shitty then.
JBR SRI | JBR TIP
Lex (05-09-2013)
 Old 05-09-2013, 01:52 PM   #46
Very happy you like the tune and how the car drives! The fuel economy is icing on the cake
 Old 05-09-2013, 03:11 PM   #47
Worbit's Avatar
Posts: 2,552   (View Stats)
Groans: 142
Subbing....thanks Lex for making these OTS maps available. I plan on ditching my Cobb stage 1+ for your stage 2 later on today.
Zoom-Zoom-Coons on 05/10/16
BUILT BY CORKSPORT
The Following User Says Thank You to Worbit For This Useful Post:
Lex (05-09-2013)
 Old 05-09-2013, 03:19 PM   #48
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
I know this is a shot in the dark, but will you be offering maps for people who installed 3 BAR MAP sensors?
Pickles Tune in progress
Lex (05-09-2013)
 Old 05-09-2013, 03:40 PM   #49
Those kind of modifications fall into the custom tune category. Otherwise the permutations and number of maps to maintain becomes unmanageable pretty quickly.
 Old 05-14-2013, 08:44 PM   #50
Speed3_BigV's Avatar
Posts: 23   (View Stats)
Speed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to behold
I recently bought a SURE SRI and TIP, so I went ahead and loaded up the Cobb stage 1 map for the SURE SRI/TIP intake.
It ran ok but I had alot of KR (between 1.0 and 2.5 about) in 1st gear wot pulls or something was acting up cutting power but it wasn't happening all the time, 2 thru 6 was perfectly fine, logs had great readings and all but for some reason it didn't like 1st gear.
So I decided to try the Stratified OTS stage 1 map. Even tho it's meant to run with the JBR intake, good god!! It's SO much better than the Cobb map for some reason, the 1st gear hesitation is completely gone, 0 KR in every gear, and it pulls ALOT harder and LTFT's are perfect!
Just throwing the word out that the Stratified OTS stage 1 map works perfectly with the SURE SRI/TIP combo. Definitely sticking with this map until I get a custom tune, nice job Lex!
| 2010 Mazdaspeed with Tech Pkg / 18x8.5" Enkei T6S w/ Nitto NT05 245/40
| Cobb AccessPORT / Self Tuned
| Ultimate Racing Turboback Exhaust (Catted, Non-resonated) / Ultimate Racing FMIC
| Grimmspeed EBCS / Turbosmart Dual Port BPV / Denso ITV22 / Autotech Internals / JBR EGR Delete / Corksport OCC
| JBR Chrome-Moly 88A RMM / Corksport TMM Insert / Corksport Shifter Bushings
| Prosport Halo Boost Gauge / Corksport LED DRL and Foglight Bulbs / Rally Armor Mudflaps
Speed3_BigV is offline   Reply With Quote
The Following 2 Users Say Thank You to Speed3_BigV For This Useful Post:
atvfreek (05-15-2013), Lex (05-14-2013)
 Old 05-14-2013, 10:09 PM   #51
Thanks
You're on the edge but ok. You have SWAS interacting there so your AFRs went very rich to 9.x and the demand on the fuel system was therefore very high but it was also unnecessarily rich.
 Old 05-14-2013, 10:16 PM   #52
Andrewbox's Avatar
Posts: 667   (View Stats)
Andrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the worldAndrewbox is the leader of the world
I've been running the OTS stage 2 map for a few weeks now and i fucking love it! Thanks lex for a quick FREE tune.
Black Mica 2013 Mazdaspeed 3 w/ tech
GTX3076r EWG | CP-E ΔCore | CP-E Triton | CP-E LTRmani | CP-E DP
AUTOTECH HPFP | HTP 3.5" | GFB RESPONS
GRIMMSPEED EBC | CORKSPORT SSP | K-SPORT COILS
JBR CAMBER ARMS | JBR SWAY BAR | JBR MOUNTED
JBR TIGs | JBR ERG | JBR 51r TRAY
Andrewbox is offline   Reply With Quote
The Following User Says Thank You to Andrewbox For This Useful Post:
Lex (05-14-2013)
 Old 05-14-2013, 10:18 PM   #53
Glad to see people using and enjoying the S-OTS maps!
himurax13 (05-17-2013)
 Old 05-16-2013, 11:08 PM   #54
JgamB's Avatar
Posts: 2,566   (View Stats)
Any chance we could see some 25%-30% E85 base maps? It certainly seems to be more prevalent and with summer heat incoming the KR from corn will sure be nice.
Lex (05-17-2013)
 Old 05-17-2013, 08:23 AM   #55
You mean LESS KR from corn .
You can safely put in 1-2 gallons of E85 per full tank with these maps to avoid KR and run a higher octane map if you're seeing KR.
However to push power further with E85 blends, the way to go is a custom tune since there are large variances from vehicle to vehicle and setup to setup.
 Old 05-17-2013, 08:38 PM   #56
swerv0428's Avatar
Posts: 10   (View Stats)
swerv0428 is a jewel in the roughswerv0428 is a jewel in the roughswerv0428 is a jewel in the rough
Groaned at 4 Times in 1 Post
Just got my AP and flashed the stage one 93 map. Running a jbr stage one intake. Have internals waiting to go in as well. What are the target numbers for afr's, etc.
2012 Speed 3. All stock for now. Purchased: 10-10-2012
swerv0428 is offline   Reply With Quote
The Following User Says Thank You to swerv0428 For This Useful Post:
Lex (05-17-2013)
 Old 05-17-2013, 08:52 PM   #57
LumberJack's Avatar
Groans: 57
I've meant to comment sooner, but @Lex; do it again. Always providing the goods for us mod lovers!
10.36@148 Fastest Gen 2
Lex (05-17-2013)
 Old 05-17-2013, 09:11 PM   #58
WOT AFRs are 11.7 tapering to 11 by redline
 Old 05-17-2013, 09:18 PM   #59
tc0308's Avatar
Posts: 95   (View Stats)
tc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond repute
So there is a place by me that advertises 100 octane fuel. If i am noticing kr, would it be safe to try that? The closest e85 station is a lot further away. Im installing my racepipe tomorrow and then loading the s-ots stage two map tomorrow! Also i noticed that my afr after shifts can be in the 9s. If that dangerously rich? It tapers back into the 10 s. During a single gear pull they will be in the 11 s
CWP 2012 MS3
JBR SRI/TIP // Cobb AP // Autotech internals // CP-E Stage 2 RMM // CS racepipe (still in box)
tc0308 is offline   Reply With Quote
The Following User Says Thank You to tc0308 For This Useful Post:
Lex (05-17-2013)
 Old 05-17-2013, 09:27 PM   #60
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
Not completely sure, but the AFRs in the 9s during shift might be due to turbulence....Lex would know better....
Stealth01
2006 Mazdaspeed6 GT
The Following User Says Thank You to Stealth01 For This Useful Post:
tc0308 (05-17-2013)
 Old 05-17-2013, 09:28 PM   #61
If you are seeing a lot of KR you may need to step down to a 91 octane or even a stage1 since that targets less load/boost.
Using higher octane fuel is always helpful and mixing a little E85 (1-2 gallons) or race fuel should make the 93 maps usable even if using 91.
During shifting you will see AFRs drop with any map and wheelspin/SWAS will also affect these. Higher BAT/IATs will also pull the AFRs into the 10s and that's not a problem.
tc0308 (05-17-2013)
 Old 05-25-2013, 03:14 PM   #62
zeroecco's Avatar
Posts: 223   (View Stats)
zeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the worldzeroecco is the leader of the world
Put the 91 stage 2 S-OTS map on today, feels very strong. As stated by others before, the throttle feels better and the progression in the power is way smoother.
Mods:
Cobb AP (obviously)
CS test pipe
CS TIH+SRI
Silicon Boost tubes
Forged BPV v1
CS RMM
JBR SSK stage 2
Second gear is virtually useless now (tires spin at roll if you hit it), third can't hold either, fourth and your gone.
Current:
2008 Mercedes CLS 550 (AMG Sport package, Luxury P2 package, iPod package, Nav, etc)
382HP/391TQ
Previous:
2010 Mazdaspeed 3
268HP/320TQ
zeroecco is offline   Reply With Quote
 Old 05-27-2013, 10:42 AM   #63
Bananastand's Avatar
Bananastand is a jewel in the roughBananastand is a jewel in the roughBananastand is a jewel in the roughBananastand is a jewel in the rough
Quick question: I seem to not boost at all in 1st gear (AP showed -1 at its highest at WOT) even at WOT. I was just wondering if that was normal. Also I've read people running the Stage 2 with just the SRI/TIP and upgraded internals, do you think that's ok?
2nd gear limited to 7-8 lb and all the other gears are fine. FP 1800+ WOT, KR 0.5 at it's highest.
Edit: forgot to mention I have the JBR SRI/TIP and the Stage 1 OTS 93 with upgraded AT internals
Bananastand is offline   Reply With Quote
 Old 05-27-2013, 10:47 AM   #64
anodizedeeznutz's Avatar
Posts: 2,796   (View Stats)
anodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the world
Something is wrong. You should be seeing 16 +\- 2 lbs
2013 CWP Mazdaspeed3 - SOLD
2014 Mitsubishi Evo X - time for some fun.
anodizedeeznutz is offline   Reply With Quote
 Old 05-27-2013, 10:54 AM   #65
Do you think I should uninstall and reinstall? Or do you think it's more of a hardware problem?
 Old 05-27-2013, 10:59 AM   #66
It's just weird that its only in the first two gears.
Ill let @Lex; share his thoughts considering its his map
The Following User Says Thank You to anodizedeeznutz For This Useful Post:
Bananastand (05-27-2013)
 Old 05-27-2013, 11:47 AM   #67
JgamB's Avatar
Seems obvious - but did you turn off traction control?
 Old 05-27-2013, 12:02 PM   #68
I'm going to try that when I run some errands today.
 Old 05-27-2013, 12:27 PM   #69
Post up a log. Hard to diagnose anything without seeing some data.
 Old 05-27-2013, 12:29 PM   #70
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
i have jamies ssp, what map should i run?
 Old 05-27-2013, 12:32 PM   #71
MS6 Sanchez's Avatar
Posts: 405   (View Stats)
MS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the world
Groaned at 7 Times in 4 Posts
Stage 14 1/5 + 198 oct
'06 Mazdaspeed6 Sport | LPM
MODS:
COBB SF | COBB TIP | SURE RMM | CXRacing FMIC | M2 DP | NGK Laser Iridiums | Magnaflow CB | COBB AP Stg 2 SF+TIH+IC 93 | Autotech FP Internals | JBR SSP, SSB, and Heavy Knob | EBC Ultimax Rotors | EBC Red Stuff Pads | Plastidipped Grill | 20% Tint all around 50% Windshield
I'm SO stock it HURTS
MS6 Sanchez is offline   Reply With Quote
 Old 05-28-2013, 02:44 PM   #72
I've been running this map for about 3 weeks and its wonderfull!
One thing that bothers me tho, I sometimes experience some hesitation at WOT during cornering, not an extreme corner but enough to push you to the side of your seat a bit when you take it.
In 2nd or 3rd, if I punch it or roll on the throttle in such a corner the boost kicks in but there's severe hesitation, as if im hitting the rev limiter and the car barely pulls forward, shifting to a higher gear solves the problem. There's no KR and nothing seems out of the ordinary appart from running very rich when it happens (9.0 AFR's with AP display)
Could it simply be the SWAS being gay?
I'm probly going to get flammed for this but I also added LC and FFS to the map using the tool found on Cobb's website, could adding LC/FFS to the map also cause this problem? I haven't tried the map without LC/FFS. The LC I can live without but I do like the FFS set at 6k and despite seeing some people say theres possible boost spikes using FFS, I don't see many of them. Boost does peak around 19 psi but its short lived and it does the same even if I don't use FFS.
Thanks for any input, Cheers!
 Old 05-28-2013, 02:49 PM   #73
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
If you watch your AFRs during one of these corners where you get the hesitation and it goes into the 9s, that is SWAS.
Sent from my Nintendo DS using Tapatalk 2
The Following User Says Thank You to Mike@Stratified For This Useful Post:
Lex (05-28-2013)
 Old 05-28-2013, 02:51 PM   #74
The stuttering is like the result of SWAS unfortunately especially if it happens only in corners.
FFS and LC are fine but be aware that sometimes the car will have unpredictable AFRs in the next gear after FFS.
Prufio (06-30-2017)
 Old 05-28-2013, 03:11 PM   #75
iammike's Avatar
Has LC been known to cause any of these problems? I always hear about FFS.
Mike
 Old 06-12-2013, 04:54 PM   #76
For those wanting to enable FFS/LC on our S-OTS maps you can do this using COBB's online utility here:
COBB Tuning - MAZDASPEED Accessport
 Old 06-12-2013, 05:57 PM   #77
elroes's Avatar
Posts: 52   (View Stats)
elroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud ofelroes has much to be proud of
I saw a couple of you guys ran the s-ots map with the Cobb sri so I thought I'd give it a try. Gotta say I immediately could tell the difference in driveability. Car just felt smoother. Also was WAY up on power. Vdyno showed a ~25hp increase. Unfortunately I also found lean afrs at WOT (12.2 or even higher) and consistent kr. Sadly went back to the Cobb ots. Oh well, would have been too good to be true haha. This just made me more determined to get a custom etune, most likely stratified :-)
Sent from my Nexus 7 using Tapatalk HD
2009 True Red Mazdaspeed3
HTP 3.5" Intake -- JBR RMM -- AccessPort -- Autotech HPFP Internals
CP-E Catted DP -- GFB Respons -- Denso ITV22s -- Cobb Catback
elroes is offline   Reply With Quote
The Following 2 Users Say Thank You to elroes For This Useful Post:
Lex (06-12-2013), Playaj (06-13-2013)
 Old 06-12-2013, 06:56 PM   #78
himurax13's Avatar
Groans: 255
I also experienced the same thing with the Corksport Stage 2 SRI.:-(
 Old 06-13-2013, 06:43 PM   #79
theurgy's Avatar
Posts: 2,580   (View Stats)
Hey Lex,
I'm looking at getting a custom tune with you in the very near future. I know I've been saying this for a while now, but my final bits might finally be going in (got my downpipe finally going in this weekend).
I wanted to use your Stage 2 S-OTS maps using the 91 Octane (as you know how crappy our 94 octane is here), as I feel it might be a safer base map to run that the stock Cobb Stage 2 OTS maps.
My problem is, would there be a way to get this same map with the EGR and VTCS codes disabled?
Thanks.
 Old 06-13-2013, 11:29 PM   #80
Originally Posted by theurgy View Post
Hey Lex,
Thanks.
E-mail me and we can discuss.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/stratified-s-ots-maps-jbr-power-path-135125/
Flat foot shift - Mazda 3 Quebec This thread Refback 07-28-2013 06:23 PM
Forum Mazda Performance Series - Zobacz temat - Stratified OTS Maps This thread Refback 03-23-2013 05:44 AM
Intakes Now Available! HTP HTP (Hi-Tuned Performance) 354 10-14-2014 08:21 AM
Mod path for me eksces Mazdaspeed3/6 General Discussion 19 07-31-2012 03:26 PM
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 11:03 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
Page generated in 0.60617 seconds with 41 queries
