E-Tuners / Custom Hardparts
Like Tree17Likes
 Old 01-21-2014, 04:02 PM   #161
Originally Posted by speedaholic View Post
Here are my first three, 4th gear pulls with the S-OTS 91 stage 1 map. This is on a "false flat" stretch of road. Two pulls on the incline (NW), one down (SE).
They all look good to me but any input is appreciated.
- Ambient temp: -2°F
- Wind: NW/6mph
- Atm. Pressure: 101.6kpa
- Rel. Humidity: 53%
I now know my tach is off by 250rpm as the log shows I started the pulls at 2.7/2.8k to end at 6.2/6.3k instead of 3k to redline. From now on I’ll rely on the AP’s tach.
I'm getting internals, a test pipe and an upgraded top mount in a couple of months so I’m eager to get tuned by Stratified! @Lex;
Everything in the logs looks just fine. The fact that you're logging at 3 degrees F is crazy! Haven't seen many logs at these temperatures.
speedaholic likes this.
speedaholic (01-22-2014)
 Old 01-22-2014, 11:20 AM   #162
speedaholic's Avatar
Posts: 154   (View Stats)
speedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the world
Great! I supposed that if the fuel pump kept up and there's no knock all is good?
With the Cobb CS 91 v231 map I got plenty over 1° so I lightened my foot substantially, but with yours...
2015 Black Mustang GT
RIP 2015-06-27
2013 Liquid Silver MS3
speedaholic is offline   Reply With Quote
The Following User Says Thank You to speedaholic For This Useful Post:
Lex (01-22-2014)
 Old 02-11-2014, 03:54 PM   #163
novice_01's Avatar
Posts: 92   (View Stats)
novice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud of
Hi, i'm planning on installing jbr sri+tip and jbr egr delete plate this saturday. I was wondering if you made any changes to s-ots map regarding egr delete dtc. I downloaded v 1.10 i believe. Thanks
JBR SRI+TIH
JBR SSP+Shift Knob
CP-E 60D RMM
Autotech HPFP
AP V3 S-OTS 2 map
novice_01 is offline   Reply With Quote
 Old 02-11-2014, 07:45 PM   #164
PM sent.
 Old 02-12-2014, 07:48 PM   #165
aromig's Avatar
Posts: 289   (View Stats)
aromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the world
Curious about this too, as this is a very common mod and one I am wanting to do before I rack up too many miles. BTW, your maps rock. They definitely illustrate how badly the Cobb ots maps blow.
Sent from my Nexus 7 using Tapatalk 2
"I apologize for nothing!" - Hedonismbot
aromig is offline   Reply With Quote
The Following User Says Thank You to aromig For This Useful Post:
Lex (02-15-2014)
 Old 02-14-2014, 05:29 PM   #166
jtday's Avatar
Posts: 650   (View Stats)
I've been running the JBR stage 2 and S-OTS stage 1 map for about a month now and have REALLY enjoyed the results. I've done a few logs here and there to make sure everything was ok, and while I seem to be running a bit lean, everything else looks great.
So today I decided to log a 2nd to 3rd gear pull. I know this isn't how it works but I wanted to do it anyways just to take a look at a different scenario.
Well, my AFR's are totally fucked up, fuel pressure dips to dangerous levels, and my timing just looks odd. I've been reading logs here and there to figure out what I should be looking for but all of these things combined are just beyond my scope of knowledge.
Internals are now on the list but I'm not convinced that's the problem here. Maybe spill or relief valve issue?
So with that, I've attached the log.
Yellow - AFR
Orange - Boost
Blue - HPFP
Red - KR
Green - Spark Advance
@Lex; I'd love for some input. I was hoping to stay away from a custom tune for a little while but I'd happily spend the coin as a preventative measure.
Thanks,
Josh
 Old 02-15-2014, 11:44 AM   #167
Well, my AFR's are totally fucked up, fuel pressure dips to dangerous levels then hangs at 1800+ after I let off throttle, and my timing just looks odd. I've been reading logs here and there to figure out what I should be looking for but all of these things combined are just beyond my scope of knowledge.
Yellow - AFR
Orange - Boost
Blue - HPFP
Red - KR
Thanks,
Josh
Hi Josh, the rich AFRs and high boost point to a possible leak in the system or an incorrect MAF reading.
I would check a few things:
1. There are no leaks in your intake system. Do this using a pressurized source right where the filter connects:
2. Check that your MAF sensor is seated correctly and the o-ring is not damaged.
3. Check that the air straightener in the intake is not in any way damaged or loose.
jtday (02-15-2014)
 Old 02-19-2014, 05:19 PM   #168
carfreakMS3's Avatar
Posts: 30   (View Stats)
carfreakMS3 is a name known to allcarfreakMS3 is a name known to allcarfreakMS3 is a name known to allcarfreakMS3 is a name known to allcarfreakMS3 is a name known to allcarfreakMS3 is a name known to all
I installed the s-ots stage 1 91 octane tune today ran AMAZING saw zero knock in the 4-5 pulls i did. Only down side was my afr was in the 12.3 range wot and boost was peaking 19+. fuel pressure was in the 1700 range wot on the stock internals. I feel the afr is a little on the lean side would you rec. I reinstall the cobb ots until I can get e-tuned?
2009 True Red Mazdaspeed 3
Cobb Intake/TIP
Res. Delete
cp-e stage 2 RMM
Tein S-tech Springs
Cobb AP V.3
carfreakMS3 is offline   Reply With Quote
The Following User Says Thank You to carfreakMS3 For This Useful Post:
Lex (02-20-2014)
 Old 02-19-2014, 05:22 PM   #169
iammike's Avatar
Posts: 1,415   (View Stats)
I would recommend you get upgraded internals IMHO.
Mike
The Following User Says Thank You to iammike For This Useful Post:
Lex (02-20-2014)
 Old 02-19-2014, 05:26 PM   #170
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
The S-OTS maps are calibrated for the JBR PP intakes.
The Cobb intake is slightly larger in diameter, hence your lean condition.
The Following 2 Users Say Thank You to Agent_Orange For This Useful Post:
Lex (02-20-2014), theurgy (02-19-2014)
 Old 02-19-2014, 05:51 PM   #171
damn it lol i really love the way it feels cause the cobb ots maps blow major ass nobody likes 10.2 afs wot
Cobb Intake/TIP
Res. Delete
cp-e stage 2 RMM
Tein S-tech Springs
Cobb AP V.3
Lex (02-20-2014)
 Old 02-19-2014, 06:03 PM   #172
theurgy's Avatar
Posts: 2,580   (View Stats)
Then pay @Lex; the cash and get yourself a custom e-tune.
WELL worth the money, trust me!
The Following 2 Users Say Thank You to theurgy For This Useful Post:
jtday (02-19-2014), Lex (02-20-2014)
 Old 02-19-2014, 07:29 PM   #173
untitledav's Avatar
Posts: 189   (View Stats)
untitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond repute
Hello,
I recently installed JBR SRI+TIP and flashed ecu with stage 1 S-OTS 93 map. im total noob to tuning, but learning fast on this forums.
Today i finally was able to do some logging at wot in 3rd gear. Also i noticed today 1.03KR, that was not on wot i read here that anything below 2.0 is acceptable? Let me know.
Please take a look at my logs and see if everything is happy as far as parameters.
Much appreciated
untitledav is offline   Reply With Quote
The Following User Says Thank You to untitledav For This Useful Post:
Lex (02-20-2014)
 Old 02-19-2014, 08:29 PM   #174
jtday's Avatar
Originally Posted by untitledav View Post
Hello,
Much appreciated
You need to add accelerator position to your logs. You dont seem to be hitting boost targets. Lex will chime in eventually and give you some better insight.
2009 MS3 GT
The Following User Says Thank You to jtday For This Useful Post:
Lex (02-20-2014)
 Old 02-19-2014, 10:21 PM   #175
TheDukeZip's Avatar
Posts: 51   (View Stats)
TheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond reputeTheDukeZip has a reputation beyond repute
Thanks for the S-OTS maps! I've been running the maps for a week and a half with the JBR stage 2 intake and have been super impressed - it feels like a new car.
I finally got a chance to do some 4th gear pulls tonight. Started a little late on pull #2 and didn't get to redline on either - some improvements I need to make for myself for next time.
Mods are autotech internals, JBR stage 2 intake, JBR boost toobs & bypass valve hose, CPE stage 2 RMM, and Corksport race pipe. I'm running the S-OTS stage 2 93 octane.
My weight is 235 lbs. and I'm running my winter setup right now of 205/60R-16. Outside temp was 34 F. So I think I did VDyno right but for anyone looking here for future reference they can take a look at my logs.
I was hoping this map would hold me over until spring/summer when I get a FMIC and meth setup and do a custom tune - but I have a feeling there is room for some gains and will be itching to take advantage of them sooner
TheDukeZip is offline   Reply With Quote
The Following User Says Thank You to TheDukeZip For This Useful Post:
Lex (02-20-2014)
 Old 02-20-2014, 05:29 AM   #176
untitledav's Avatar
I do have Acc Pedal log its 74 on wot
Lex (02-20-2014)
 Old 02-20-2014, 09:03 PM   #177
Glad to hear everyone is enjoying the driveability and feel of the S-OTS maps. Worked a long time on that particular aspect. They are not meant to maximize power since they are on the safe side so they can be enjoyed by everyone. The custom tune is where we turn things to 11 ... a safe 11 .
aromig (02-20-2014), TheDukeZip (02-21-2014)
 Old 02-20-2014, 09:45 PM   #178
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
I'm ready to turn things to 12
The Following User Says Thank You to timmcc02 For This Useful Post:
Lex (02-20-2014)
 Old 02-20-2014, 09:52 PM   #179
darthxar's Avatar
Posts: 560   (View Stats)
So much good feed back on these. I might have to break down and try one even though I will get an CEL from my EGR delete. I have been thinking of doing a Stratified tune once I'm done modding.
May be worth the CEL for a while to "try out" the Stratified Tuning style.
The Following User Says Thank You to darthxar For This Useful Post:
Lex (02-20-2014)
 Old 02-20-2014, 10:02 PM   #180
Absolutely - give it a shot.
I am working on what will hopefully be a solution for these CELs but it won't hurt the car to run with the CEL currently.
aromig (02-20-2014), darthxar (02-21-2014)
 Old 02-20-2014, 10:30 PM   #181
aromig's Avatar
Once I get a few more parts bolted on, a custom tune is definitely in the cards for me.
Sent from my Nexus 7 running Pac ROM nightlies
Lex (02-21-2014)
 Old 04-02-2014, 11:04 PM   #182
DocBrown's Avatar
Posts: 167   (View Stats)
DocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the world
Groaned at 6 Times in 4 Posts
Hey guys, first I want to say thanks to Stratified and JBR for providing the free map files.
I recently installed a JBR stage 2 PP intake and loaded the stage 1 93 octane map and DAMN it made a huge difference. My car drives like it has a purpose in life now. My other mods are RMM and forged short block internals (ZZB recovery). Side note, I'm 2500mi into my engine break in and running Rotella.
Also, I am a noob at tuning/logging but I'm learning...
I drove it for a couple weeks and just recently logged it and found that I had some KR. I researched and found that this is fairly common due to questionable actual octane in the 93 rated stuff here in FL so I loaded the 91 oct map. I went out on a run and logged the stage 1 91 oct, 93 oct, and stage 0 maps so I could do a side by side comparison. Conditions were 75F outside, near sea level, and I waited a good 10 mins at highway speeds between runs to try to let the engine cool off. All logs are WOT in 4th gear.
I noticed that I'm still getting KR on the 91 oct map and there's nothing in the logs that's jumping out to my noob eyes. I was wondering if you guys would mind taking a look at my logs and seeing if you can shed some light.
Much thanks
DocBrown is offline   Reply With Quote
 Old 04-02-2014, 11:08 PM   #183
DocBrown's Avatar
Accidentally loaded the jank CSV for the stage 0, here's the excel
 Old 04-03-2014, 08:18 AM   #184
DocBrown's Avatar
Also, my fuel economy dropped from about 24mpg at stage 0 to about 19mpg on the 93 oct map, so far the 91 doesn't seem much better. That seems very uncharacteristic of what I've heard with these maps, something must be up
 Old 04-03-2014, 12:42 PM   #185
Much thanks
You're actually not getting any knock in the 93 oct tune runs.
The little bit you see at the end of Run1 is simply the engine making noise as you let off the throttle.
So you can definitely safely run the stg1 93 map while you still have the OEM HPFP.
As for the fuel economy - I do notice some LTFT trims that are a little high in the low load regions. Make sure that you have no intake leaks by pressurizing the intake from the filter side and listening for them.
DocBrown (04-03-2014)
 Old 04-03-2014, 12:55 PM   #186
Chief_Wiggum's Avatar
Posts: 419   (View Stats)
My MPGs went down too, but it was a direct result of a newly invigorated driving style (meaning lots of WOT) after loading up the S-OTS maps! On long trips with a steady moderate throttle, I saw no loss of MPGs.
The Following 2 Users Say Thank You to Chief_Wiggum For This Useful Post:
Lex (04-03-2014), theurgy (04-03-2014)
 Old 04-03-2014, 03:36 PM   #187
DocBrown's Avatar
On 91oct runs 1 and 2 and 93oct run 1 I'm hitting KR of 1.05 shortly after going WOT, then tapering down from there. What are your thoughts on that?
I'll double check the intake sealing. I think I may have a vaccum problem elsewhere because of a variable swirl control system failure to actuate, but that's another story.
Thanks for taking a look
 Old 04-03-2014, 10:50 PM   #188
This is very minor. Spool up KR of this magnitude is not something I worry about. Every internal combustion engine knocks at one point or another and minor knock will not harm it.
DocBrown (04-03-2014), jtday (04-03-2014)
 Old 04-03-2014, 11:23 PM   #189
DocBrown's Avatar
Ok I see, that makes me feel a lot better. Coming up: HPFP internals and stage 2
The Following 2 Users Say Thank You to DocBrown For This Useful Post:
jtday (04-03-2014), Lex (04-04-2014)
 Old 04-04-2014, 12:44 AM   #190
lx_diego's Avatar
Posts: 42   (View Stats)
lx_diego is a name known to alllx_diego is a name known to alllx_diego is a name known to alllx_diego is a name known to alllx_diego is a name known to alllx_diego is a name known to all
Groaned at 13 Times in 5 Posts
I truthfully just want to be 100% sure. First of all I want to say thanks for the free maps and from all the positive feedback I definitely want to try it. I want to try the Stage 1 s-ots map but I have the cobb sri and tih. Is it safe? what should I be logging?
2013 Mazdaspeed3 | Cobb AP, Cobb SRI, Cobb TIP, Ultimate Racing Catless Test Pipe, Autotech HPFP Internals, JBR Rear Motor Mount 88 Duro, Forge BPV, NGK LTR7IX-11, XT-M5-QS, Stratified E85 S-OTS.
lx_diego is offline   Reply With Quote
The Following User Says Thank You to lx_diego For This Useful Post:
Lex (04-04-2014)
 Old 04-04-2014, 07:43 AM   #191
DocBrown's Avatar
Both of those have already been answered in this thread. READ READ READ
aromig (04-04-2014), Lex (04-04-2014)
 Old 04-04-2014, 11:14 AM   #192
The MAF calibration is wrong so it is not a good idea to do so.
However just for this we have this product:
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune [Stratified Mazda S-OTS+ Tune] - $25.00CAD : Stratified Automotive Controls
jtday (04-04-2014), lx_diego (04-04-2014), theurgy (04-04-2014)
 Old 04-04-2014, 12:47 PM   #193
lx_diego's Avatar
thanks I will definitely be purchasing one later on today when i get home. I'm soon to get an UR uncatted dp and from there I will sure be looking forward to getting a custom tune from you. thanks again!
Lex (04-04-2014)
 Old 04-07-2014, 02:16 PM   #194
it's toasted's Avatar
Posts: 114   (View Stats)
it's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud of
Lots of positive feedback on the S-OTS tune. With CS SRI/TIP, CS TMIC, and Autotech internals, would you recommend giving the stg.1 map a shot?
it's toasted is offline   Reply With Quote
The Following User Says Thank You to it's toasted For This Useful Post:
Lex (04-07-2014)
 Old 04-07-2014, 02:35 PM   #195
theurgy's Avatar
These are made for JBR intakes.
If you're looking for a decent OTS map for your setup, check out Stratified's OTS+ maps.
A steal for $25.
Lex (04-07-2014)
 Old 04-07-2014, 05:52 PM   #196
a steal indeed! I went ahead and flashed the JBR S-OTS map, I experienced some impressive results.
4th gear log, any comments?
jtday (04-07-2014)
 Old 04-07-2014, 06:52 PM   #197
jtday's Avatar
That log pretty looks good. Your OL/CL transition is a little late but I've noticed that with these maps. Impressive you can hit load at ~14 psi.
2009 MS3 GT
 Old 04-07-2014, 08:03 PM   #198
Very nice and clean. Boost will climb once the temperatures increase as it takes more boost at higher temperatures to hit the same load targets.
 Old 04-08-2014, 02:50 PM   #199
just purchased your S-OTS + map. I'm really looking forward to it!
Lex (04-08-2014)
 Old 04-09-2014, 04:46 PM   #200
@Lex; having some trouble with open office and submitting the form to get my OTS+ tune, I'd like to give you my info ASAP. I've already set up my account on your site and received the conformation emails.
2011 MazdaSpeed3
|Cobb AP|Cobb RMM|
|Corksport SRI/TIP|Corksport TMIC|
|Autotech internals|FreekTuned |Rally Armor flaps|
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/stratified-s-ots-maps-jbr-power-path-135125/
Flat foot shift - Mazda 3 Quebec This thread Refback 07-28-2013 06:23 PM
Forum Mazda Performance Series - Zobacz temat - Stratified OTS Maps This thread Refback 03-23-2013 05:44 AM
Intakes Now Available! HTP HTP (Hi-Tuned Performance) 354 10-14-2014 08:21 AM
Mod path for me eksces Mazdaspeed3/6 General Discussion 19 07-31-2012 03:26 PM
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 11:03 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
Page generated in 0.62356 seconds with 37 queries
