![]() | | #201 | ![]() |
And also write that you have read and understand the liability statement. That is all that is needed.
![]() | | #202 | ![]() |
![]() Join Date: May 2013 Location: white sulphur springs, west virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score sent.
__________________ 2011 MazdaSpeed3 |Cobb AP|Cobb RMM| |Corksport SRI/TIP|Corksport TMIC| |Autotech internals|FreekTuned |Rally Armor flaps| |
![]() | | #203 | ![]() |
| Not Ranked : 0 score I would like to thank and recommend Stratified to any perspective MS3 owners looking to get an affordable/safe e-tune. Their OTS+ maps are a vast improvement over the preloaded Cobb OTS maps. On top of the noticeable gain in power, the drivability is even more enjoyable and the power delivery is linear. For $25, I can't recommend a more worth while expense (aside from a full custom tune i'm sure) for the MZR platform. Big smile from this guy.
| The Following User Says Thank You to it's toasted For This Useful Post: | Lex (04-13-2014) |
![]() | | #204 | ![]() |
![]() | | #205 | ![]() |
![]() Join Date: Jul 2013 Location: Orlando, FL
Groaned at 6 Times in 4 Posts
Thanks | |
![]() | | #206 | ![]() |
![]() | | #207 | ![]() |
I definitely have a lot of headroom for power on this engine. Once I do some more upgrades (HPFP internals and DP next) I'll talk to you about a custom tune. | |
| The Following User Says Thank You to DocBrown For This Useful Post: | Lex (04-17-2014) |
![]() | | #208 | ![]() |
![]() Join Date: Apr 2013 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
| Not Ranked : 0 score I just took this log today after installing the JBR SRI/TIP last week. Looks like my LTFTs are off. I'm assuming the MAF cal is unnecessary, or you included it in the MAP? Maybe I have a boost leak?
__________________ %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%% % % Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe % Next up = Custom Tune %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%% |
![]() | | #209 | ![]() |
![]() Join Date: Aug 2012 Location: Columbia MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
If you are seeing large LTFT in the +, check for leaks after the MAF but before the turbo (likely since you just installed these parts). If you are seeing large LTFT in the -, check for leaks after the turbo. Hope I got those two right. I get them mixed up in my head all the time.
__________________ Mike [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to iammike For This Useful Post: | Lex (05-02-2014) |
![]() | | #210 | ![]() |
![]() | | #211 | ![]() |
| Not Ranked : 0 score I tightened down the clamps on the intake this morning and drove around for like 50 miles. The STFT seem to stay within + or - 4% with the occasional blip up or down. The LTFT are still a bit off. I guess I should do a pressure test, I just can't see how I could have a boost leak. Here's another log.
| The Following User Says Thank You to MechEnix For This Useful Post: | Lex (05-04-2014) |
![]() | | #212 | ![]() |
![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I am currently being stratified tuned by Stan. Great experience so far. I too appeared to have a slight intake leak with JBR stage 2 power path. Everything seemed tight. I ended up switching to the JBR three inch intake just prior to starting the tunning process. |
| The Following User Says Thank You to aforst For This Useful Post: | Lex (05-04-2014) |
![]() | | #213 | ![]() |
That being said, you have nothing to worry about in terms of safety. The AFRs under WOT are right on target and under part throttle you are far away from throwing a CEL or having any such issues.
![]() | | #214 | ![]() |
| Not Ranked : 0 score My PP intake was awfully tight if not touching the batery box/ ECU. Almost like the T.I.P. Was longer before it made the 90 deg turn if that makes sense. I felt like I needed a 51r batery box. I sent Jamie pics. |
![]() | | #215 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7119 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
I think we talked about this? That it was most likely due to the motor be more towards the drivers side vs. the passenger side. There is almost 1" of side to side adjustment in the motor mounts. If the motor is more towards the drivers side it can make the TIP tighter to fit in between the motor and the ECU/battery box. Last edited by JBR; 05-04-2014 at 07:33 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to JBR For This Useful Post: | Lex (05-12-2014) |
![]() | | #216 | ![]() |
| Not Ranked : 0 score Yes Jamie and I discussed the position of the motor and the position of the intake. I thought that maybe if Lex was seeing variation in MAF cal that maybe something changed in production. Jamie has been very helpful and responsive. I never did find leak or deformity in MAF housing from over tightening. I am very happy with my three inch intake bypass hose intercooler boost tubes and egr delete from JBR. Side note / vent had oil change at dealer Friday noticed oil spot on ground tonight. Popped hood no dip stick. Oil on front of motor and plastic under tray. Of course dealer closed. Should make a interesting morning tomorrow. |
![]() | | #217 | ![]() |
![]() Join Date: Aug 2013 Location: Round Rock, Tx.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 85 Times in 26 Posts
| Not Ranked : 0 score Just recently installed the stage 3 power path intake from JBR and flashed the s-ots stage 1 93 map to my speed. First things first.. Love this fucking intake.. this thing is dripping with win. The sound of the turbo spooling up, the sound of the intake sucking air when I get on it... pure sex. The map to go with it was just over the top. This JBR and stratified partnership for the intake is so money. I must admit it is what tipped the scales for me to purchase the JBR intake (not that it isn't worthy in its own right). The difference between cobb map and s-ots map is night and day! On a side note.. also installed the JBR rear sway bar and again... this shit is tits.... so money. On to my question.. after driving for a week all was good till last night when I got a cel pop up.. seems like the random genpu luck of the draw p0101 bank 1 too lean. Chalked it up to installer fail and went ahead and triple checked everything on my ride. Let me fuel trims settle after about a 60 mile drive to work so on the way home I thought I'd take a couple logs (these are my first and I just realized I only took it to about 6k rpm's instead of 6.5) Would really appreciate any input on the logs to let me know if something looks off that might trip a cel. Really hoping it was just my failure of an installation and didn't tighten everything down correctly. Any input is appreciated.. Thanks! Last edited by Malbosia; 05-11-2014 at 05:11 PM. Reason: File attachment fail |
![]() | | #218 | ![]() |
| Not Ranked : 0 score Oops forgot attachments! |
![]() | | #219 | ![]() |
| Not Ranked : 0 score I'm very happy to hear you like the new parts. I don't see anything too out of the ordinary in the 4th gear log. LTFT's are just a teency bit high. How many miles did it have on it before the light came on? Let me know if the light comes back on. -Jamie |
![]() | | #220 | ![]() |
| Not Ranked : 0 score I'd say probably about 500-600 miles before light popped after install. Re-installed everything this morning so I unplugged battery. 74 miles on it today with no cel but will keep an eye on it. |
![]() | | #221 | ![]() |
| I'm a caveman ![]() Join Date: Jun 2008 Location: Pittsburgh, PA
Rep Power: 308 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 561
Groans: 68
Groaned at 22 Times in 16 Posts
| Not Ranked : 0 score My car pulls hard on the stratified tune but I'm dissapointed that there is still boost limiting in low gears when steering. Can that be changed?
__________________ 2015 MUSTANG GTPP |
![]() | | #222 | ![]() |
| Not Ranked : 0 score Unplug SWAS...though there are side effects.
![]() | | #223 | ![]() |
(Thread Starter) | Not Ranked : 0 score Everyone, Just wanted to make this absolutely clear since I have heard that some people are using these maps with COBB intakes or similar. Running an S-OTS map with an intake OTHER than a JBR PowerPath will result in load, boost, air/fuel, and timing calculations to be incorrect. This can cause the car to run lean, too much boost, and in general not run safely. These maps are to be used with the JBR PowerPath intakes only and should not be used with other intakes. If you want an S-OTS built for your intake then your option is the S-OTS+ and the S-OTS+ E85 Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune [Stratified Mazda S-OTS+ Tune] - $40.00CAD : Stratified Automotive Controls Stratified MazdaSpeed / Mazda MPS S-OTS+ E85 Tune [Stratified Mazda S-OTS+ E85 Tune] - $50.00CAD : Stratified Automotive Controls
| The Following User Says Thank You to Lex For This Useful Post: | Mike@Stratified (05-20-2014) |
![]() | | #224 | ![]() |
![]() Join Date: Dec 2013 Location: Mountain House, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 596
| Not Ranked : 0 score So I'm looking at picking up a JBR power path stage 2 intake and running the stage 1 S-OTS map with stock fuel pump internals... Most of the local nator guys are telling me to continue using the Cobb stage 0 OTS map until i get upgrade internals and not flash over to stage 1 stratified OTS map. Would I be safe running the OTS map with stock internals or should I wait?
__________________ 2013 Mazdaspeed3 Crystal White Pearl [Damond Motorsports RMM & SSP] [Maisonvi Grooved Dessert Beagle Knob] [COBB AP V3] [CorkSport HPFP Internals, SRI, TIP, TMIC & LEDs] [Sure M3 TP] [cp-e Triton CBE] [GFB BOV] [91 Octane Purple Drank Tuned - 260whp/290wtq - VDyno] Parts to Install: [JBR 3" TRU-3" Intake & Solid Shifter Bushings] [DDM HID Kit] |
| The Following User Says Thank You to my2k13speed3 For This Useful Post: | JBR (05-22-2014) |
![]() | | #225 | ![]() |
-Jamie | |
| The Following User Says Thank You to JBR For This Useful Post: | my2k13speed3 (05-22-2014) |
![]() | | #226 | ![]() |
![]() Join Date: Feb 2013 Location: Green Bay, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 945
| Not Ranked : 0 score It isn't in cold weather. Sent from my iPhone using Tapatalk
__________________ 2013 CWP Mazdaspeed3 - SOLD 2014 Mitsubishi Evo X - time for some fun. |
| The Following User Says Thank You to anodizedeeznutz For This Useful Post: | LumberJack (05-23-2014) |
![]() | | #227 | ![]() |
| Not Ranked : 0 score I'll probably just wait it out get internals and flash over to stage 2 Sent from my HTC One using Tapatalk
![]() | | #228 | ![]() |
(Thread Starter) | Not Ranked : 0 score If you have extensive flow modifications such as a catless setup or even a well flowing catted downpipe and exhaust it's probably going to overwhelm the OEM pump. But then again that's not a stg1 car anyways. If you have data to show that the OEM pump is not fine with a stg1 car and tune then I'd like to see these.
![]() | | #229 | ![]() |
I made this statement because with only an intake on the stage 1 map a good friend of mine was dropping below 1600 psi with a 2013 in sub 40 degrees. Sent from my iPhone using Tapatalk
__________________ 2013 CWP Mazdaspeed3 - SOLD 2014 Mitsubishi Evo X - time for some fun. | |
![]() | | #230 | ![]() |
Was he dropping below 1400psi? Or just around 1500.
![]() | | #231 | ![]() |
| Not Ranked : 0 score It was in the 1500s. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to anodizedeeznutz For This Useful Post: | Lex (05-23-2014) |
![]() | | #232 | ![]() |
(Thread Starter) | Not Ranked : 0 score It is on the edge but still acceptable. Anything lower than this?
![]() | | #233 | ![]() |
| Not Ranked : 0 score Not from what I recall. Sent from my iPhone using Tapatalk
![]() | | #234 | ![]() |
| Not Ranked : 0 score so as long as I don't dip below 1600 psi I'm good? Are there other parameters that should be looked at to ensure everything is running properly and safely?
![]() | | #235 | ![]() |
HPFP (High pressure fuel pump) pressure: Under WOT (wide open throttle) your fuel pressure should not drop below 1500psi. If this is not the case, upgrade the high pressure fuel pump or a custom map is needed for your particular car. Boost Pressure: Under WOT, boost pressure should not exceed 22psi. Boost pressure will vary depending on the map you have as well as the environmental conditions. Stg1 boost should be 16psi+/-2psi and Stg2 boost should be 18psi +/-2psi. However this may be higher in the summer and lower in the winter due to ambient temperatures. LTFT (Long term fuel trims): Your long term fuel trims should not exceed +/-15%. If this is not the case there is either a boost leak or the map is not well suited for your intake setup and a custom map is needed. Air-Fuel Ratios: AFRs should be between 12.0 and 10.8 AFR under WOT operation. If this is not the case there is either a boost leak or the map is not well suited for your intake setup and a custom map is needed. Knock Retard: If knock retard exceeds 2+ degrees under regular WOT operation, the fuel quality is not sufficient for the map used. Either increase the fuel quality or a custom map is needed for your fuel quality. Remember that knock will happen sometimes. What you are looking for is consistent knock retard under WOT operation. High values of knock retard under part throttle are normal in this vehicle. Spark plug gap: If you are experiencing any misfiring or spark blow-out make sure the spark plugs are gapped to 0.026". We recommend a step colder plug with these calibrations but it is not required.
| The Following 5 Users Say Thank You to Lex For This Useful Post: | aromig (05-23-2014), gsolo85 (12-21-2015), Jebus (11-24-2014), my2k13speed3 (05-23-2014), theurgy (05-23-2014) |
![]() | | #236 | ![]() |
| Not Ranked : 0 score Took a log and just wanted your opinion @Lex;
| The Following User Says Thank You to MechEnix For This Useful Post: | Lex (06-05-2014) |
![]() | | #237 | ![]() |
![]() | | #238 | ![]() |
![]() Join Date: Dec 2012 Location: Thornton, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 109
| Not Ranked : 0 score i just wanted to thank stratified for their super fast responses. i received my map a couple hours after i sent the form in. Ive attached a few logs comparing the cobb ots stage 1 maps that were for the CS intake and TIP, and the first few logs i took on the S-OTS+ map i received earlier this week. i still have a minor boost leak somewhere but have not had time to diagnose were. anyway Thank You so Much Stratified for the huge difference the car has made in a week!!! |
| The Following User Says Thank You to deasuma For This Useful Post: | Lex (06-06-2014) |
![]() | | #239 | ![]() |
__________________ %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%% % % Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe % Next up = Custom Tune %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%% | |
| The Following User Says Thank You to MechEnix For This Useful Post: | Lex (06-06-2014) |
![]() | | #240 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/stratified-s-ots-maps-jbr-power-path-135125/ | ||||
| Flat foot shift - Mazda 3 Quebec | This thread | Refback | 07-28-2013 06:23 PM | |
| Forum Mazda Performance Series - Zobacz temat - Stratified OTS Maps | This thread | Refback | 03-23-2013 05:44 AM | |
| Intakes Now Available! | HTP | HTP (Hi-Tuned Performance) | 354 | 10-14-2014 08:21 AM |
| Mod path for me | eksces | Mazdaspeed3/6 General Discussion | 19 | 07-31-2012 03:26 PM |
| Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps | FreeFlyFreak | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 08-18-2011 11:03 PM |
| Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) | steven88 | Cobb Access Port/Maps | 8 | 10-15-2008 06:48 AM |
