![]() | | #241 | ![]() |
![]() Join Date: Apr 2013 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
| Not Ranked : 0 score
__________________ %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%% % % Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe % Next up = Custom Tune %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%% |
![]() | | #242 | ![]() |
(Thread Starter) | Not Ranked : 0 score If you want to make sure you exceed 300whp and have E85 around that is the way to go. You wouldn't even need more modifications beyond what you currently have aside from the tune.
![]() | | #243 | ![]() |
| Not Ranked : 0 score I've thought about E85, the closest station is probably 25 to 30 minutes away from me. I've looked into those 14 gallon containers, but it still becomes a nuisance.
![]() | | #244 | ![]() |
![]() Join Date: Aug 2012 Location: Columbia MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score lol, my car got close to 290whp fast....and now I'm kicking and screaming hoping to get that last little bit before the next time I'm on a dyno.
__________________ Mike [SIGPIC][/SIGPIC] |
![]() | | #245 | ![]() |
| Not Ranked : 0 score Don't know what to tell ya man, I must have a turd for an engine. Are we still using 1.01 on VD and 3 for smoothing?
![]() | | #246 | ![]() |
I don't use VD to know how much HP I have but to compare vs other logs instead...and I just use the Dynojet preset of 1.09.
__________________ Mike [SIGPIC][/SIGPIC] | |
![]() | | #247 | ![]() |
![]() Join Date: Jul 2013 Location: Orlando, FL
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score Just got done breaking in my hpfp internals and immediately loaded the Stage 2 93oct map. I feel a noticeable bump in performance from the stage 1 OTS map and the couple brief WOT pulls look good on boost/hpfp press/KR. Will run complete logs this weekend before and after I install my CX FMIC. Thanks a lot Stratified! By the way, is there a problem running the OTS stage 2 93oct with the CX FMIC, or is that OTS+ territory? I'm going to do OTS+ anyways to kill some CEL codes but just wondering what to expect. Thanks guys Last edited by DocBrown; 06-17-2014 at 08:29 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to DocBrown For This Useful Post: | Lex (06-17-2014) |
![]() | | #248 | ![]() |
![]() | | #249 | ![]() |
__________________ 06 Speedsex - built engine - JBR Stage 2 intake - Unicorn 2013 K04 - Stratified OTS stage 2 - Autotech internals - Cx FMIC - JBR RMM - Forge V2 - VTCS delete - EGR delete - BSD - JBR OCC - JBR TIGs + coolant bypass | |
![]() | | #250 | ![]() |
![]() Join Date: Nov 2010 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score any idea why I am getting a unable to load base map Invalid base map file. Please verify vehicle and vendor of map file 5:1208 ? |
![]() | | #251 | ![]() |
Is this for the free sots maps? THis just means there is a mismatch between your vehicle market and year and the map. If you are trying to load these in atr you won't be able to because they are locked down maps.
| The Following User Says Thank You to Lex For This Useful Post: | Ewind (06-25-2014) |
![]() | | #252 | ![]() |
| Not Ranked : 0 score Ahh I see that makes sense. I wanted to look at some of the data on your maps. Makes sense. |
| The Following User Says Thank You to Ewind For This Useful Post: | Lex (06-25-2014) |
![]() | | #253 | ![]() |
![]() Join Date: Jun 2014 Location: Santa Cruz, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score Is there any issue with running the stage 2 91 map with both cats intact? I have internals, but I'm in California so my only option is gutting my midpipe.. which I do not have time to do for a while. |
![]() | | #254 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
![]() You should lose at least 1 cat if you want to run a Stage 2 map.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
| The Following User Says Thank You to himurax13 For This Useful Post: | googlebutt (09-28-2014) |
![]() | | #255 | ![]() |
![]() Join Date: Nov 2011 Location: Houston Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 117
| Not Ranked : 0 score Just read the entire thread, and it wasn't asked. Can the stock MAF/airbox be used with the S-OTS tune with the JBR intake elbow and TIH? It's my understanding both the JBR and stock MAF are 68mm.
__________________ 2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks 2003 A4 1.8TQ APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars. |
![]() | | #256 | ![]() |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Nope... If it can't be used on different intakes, it can't be used on stock air box
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
| The Following User Says Thank You to SarcasticOne For This Useful Post: | texasboy21 (05-23-2015) |
![]() | | #257 | ![]() |
| Not Ranked : 0 score It can't be used on different intakes due to a different MAF diameter; JBR is 68mm. Stock is also 68mm. Assume the correct TIH and intake elbow are used (JBR), can the S-OTS be run safely?
![]() | | #258 | ![]() |
| Not Ranked : 0 score It's been said before, can't even use this on a COBB/corksport/whatever else other "stock sized" intake is available...
![]() | | #259 | ![]() |
| Not Ranked : 0 score It's been said it can't be run without a JBR intake bc of MAF diameter. Cobb and Corksport are 70mm and 66mm respectively, not the stock diameter.
![]() | | #260 | ![]() |
(Thread Starter) | Not Ranked : 0 score The MAF calibration for the JBR intake is indeed different from the OEM MAF calibration. So this will throw off the load calculations in the ECU.
![]() | | #261 | ![]() |
![]() Join Date: Nov 2014 Location: Falls Church
Rep Power: 0 ![]() ![]() Thanks: 3
| Not Ranked : 0 score I just loaded these maps up yesterday and have been driving around on them. They feel wonderful, but I've been having weird large LTFT problems. The map started out with good trims, but got worse as I drove it along. I just double-checked everything and all the hoses on the intake seem tight, does anyone have any ideas or do I just need to give it more time? I've driven about 80 miles or so.
__________________ 2011 Silver Speed3 JBR RMM | JBR OCC | JBR SRI | JBR Rear Sway Bar | Moog Endlinks Corksport HPFP internals | AP | UR Catted Test Pipe | CBE |
![]() | | #262 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score What intake do you have on the car?
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Mike@Stratified For This Useful Post: | texasissouth (06-01-2015) |
![]() | | #263 | ![]() |
| Not Ranked : 0 score Hi Mike, Right now I have the jbr intake and the stock TIP
![]() | | #264 | ![]() |
| Not Ranked : 0 score Check to make sure the o-ring on the MAF sensor isn't broken or torn. +10 isn't ideal, but it isn't going to hurt anything either. Sent while Stratified.
![]() | | #265 | ![]() |
| Not Ranked : 0 score I just checked the maf, the o-ring is good, it sits in there nice and snug and it's tightened down pretty good. I had an issue originally where one of the hoses to the BPV got crimped and it would actuate at 9 psi, but I fixed that and reflashed the map to make sure it wouldn't affect anything, so it shouldn't be that right? I had logs up there, but if you think it's fine LTFTing along at like +8 (idle) to +11 (throttle) I won't worry about it.
![]() | | #266 | ![]() |
| Not Ranked : 0 score Like I said, it isn't ideal, but also not a big deal. Just ensure no leaks pre-compressor. If you are certain of that, I wouldn't worry about the trims.
![]() | | #267 | ![]() |
![]() Join Date: May 2014 Location: Winnipeg
| Not Ranked : 0 score Just to confirm, These maps do not have the EGR delete code disabled? Right now im running the S-OTS stage 1 91oct and would like to delete the EGR valve.
__________________ 2010 Mazdaspeed3 Tech JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings Cobb Accessport v3 / XLE BPV / Cobb Knob Damond Motorsports License Plate Tow Mount / EGR Delete Ultimate Racing Test Pipe Autotech Fuel Pump Internals CP-E XFlex Stage2 RMM Stratified Stage 3 93oct OTS+ |
![]() | | #268 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is correct for the free JBR maps. Our flash tunes you can spec to have any codes disabled.
| The Following User Says Thank You to Lex For This Useful Post: | JBR (06-10-2015) |
| The Following User Says NO Thank You to Lex For This Un-useful Post: | jdspeed (06-21-2015) |
![]() | | #269 | ![]() |
| Not Ranked : 0 score Since these maps are locked is it still possible to disable SWAS and set launch control?
![]() | | #270 | ![]() |
Setting LC and FFS will depend on if the OTS maps have been updated to the later ATR version and you AP is on the later firmware. Cobb no longer provides a website to adjust LC and FFS on locked maps but instead made it part of the flashing process on your AP.....but if the OTS file is too old, it will not be compatible and will only flash as a normal file with no LC or FFS.
![]() | | #271 | ![]() |
| Not Ranked : 0 score It's too bad I can't use this with my intake.. I had loaded the map just to see how it felt and it felt absolutely amazing. My FP and knock was pretty close to perfect. I'm going to assume i have to go the custom route in other to be able to get map similar to this that will work best for my vehicle? |
![]() | | #272 | ![]() |
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. | |
![]() | | #273 | ![]() |
![]() Join Date: Aug 2011 Location: Lake Jackson, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score @Lex; I'm looking to optimize my current set-up. I've been on the fence with the CS turbo and thinking about just biting the bullet and putting the new CS turbo on and having it tuned. However, from what I've seen thus far, the turbo torque curve is quite linear with the HP curve. I like the sudden burst of torque with the K04 and love the E85 Flash Tune. I would like some input on what I can do next. I'm leaning towards a JBR 3" or 3.5" WP intake and a pnp intake manifold and custom tune with my mods. If I were to add a catless downpipe to the mix, is it possible/safe to run 25psi spike and taper to 20 psi at redline on the k04. I know it would really be pushing it beyond it's design, but can it be done? I'm just looking for a little advice on which direction to go for the next 25hp.
__________________ 2008 Mazdaspeed 3 64k Miles AP, AT Internals, JBR TRU 3" Silicone Intake, CS TMIC CS Race Pipe, Autolite Iridiums 1 step colder & gapped at .026 Stratified E85 Flash Tune, CP-E Stage 2 RMM Last edited by tfusch4; 07-25-2015 at 02:35 PM. Reason: Correction |
![]() | | #274 | ![]() |
From there one of us will be able to give you a direction quite clearly based on the datalog and information.
![]() | | #275 | ![]() |
![]() Join Date: Sep 2016
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score i see everyone on here talking intakes and such on stage 1, i just got my genpu ms3 about 6 weeks ago and my AP will be here wednesday. Can i safely flash the S-OTS stage 1 map on a bone stock vehicle? after reading about cobbs maps its safe to say ill stay away from those to avoid a little ZZB possibility. |
![]() | | #276 | ![]() |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Can someone recommend good tires for a mazdacx7. |
![]() | | #277 | ![]() |
Need a JBR intake for this tune. There are also OTS tunes which Stratified sells on their website where you can put in your vehicle configuration and then the cost to update them I believe is lower than a brand new one. I'd suggest that route, or buying a JBR intake soon and using the provided S-OTS tune.
__________________ 2011 Silver Speed3 JBR RMM | JBR OCC | JBR SRI | JBR Rear Sway Bar | Moog Endlinks Corksport HPFP internals | AP | UR Catted Test Pipe | CBE | |
| The Following 2 Users Say Thank You to texasissouth For This Useful Post: | GreenieMS3 (09-05-2016), Lex (09-05-2016) |
![]() | | #278 | ![]() |
__________________ '12 MS3 -Cobb AP | |
![]() | | #279 | ![]() |
![]() Join Date: Sep 2016 Location: Canada
Rep Power: 0 ![]() ![]() Thanks: 5
| Not Ranked : 0 score Installing anything larger than stock sized intake (i.e. 3" or bigger) will not work with the S-OTS. You will get a lot of stuttering as the ECU mis-calculates the intake (thinking it is a stock intake but actually pulling in more air with a 3" or larger intake) The S-OTS maps are for the JBR short ram intakes (stage 1 or 2) or the cold air intake (stage 3). Note that Stratified calls the stages differently - stage 1 = JBR intake + stock HPFP; stage 2 = JBR intake + upgraded HPFP see Stratified MazdaSpeed / Mazda MPS Off The Shelf (S-OTS) Maps [Stratified Mazda S-OTS Maps] - It's Free! : Stratified Automotive Controls |
| The Following User Says Thank You to BoostedHatch For This Useful Post: | Lex (09-05-2016) |
![]() | | #280 | ![]() |
Stratified MazdaSpeed / Mazda MPS Flash Tune [Stratified Mazda Flash Tune] - $50.00USD : Stratified Automotive Controls
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/stratified-s-ots-maps-jbr-power-path-135125/ | ||||
| Flat foot shift - Mazda 3 Quebec | This thread | Refback | 07-28-2013 06:23 PM | |
| Forum Mazda Performance Series - Zobacz temat - Stratified OTS Maps | This thread | Refback | 03-23-2013 05:44 AM | |
| Intakes Now Available! | HTP | HTP (Hi-Tuned Performance) | 354 | 10-14-2014 08:21 AM |
| Mod path for me | eksces | Mazdaspeed3/6 General Discussion | 19 | 07-31-2012 03:26 PM |
| Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps | FreeFlyFreak | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 08-18-2011 11:03 PM |
| Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) | steven88 | Cobb Access Port/Maps | 8 | 10-15-2008 06:48 AM |
