E-Tuners / Custom Hardparts
  • 1 Post By Mortose
 Old 08-03-2013, 03:43 PM   #1
ape_ck's Avatar
Posts: 18   (View Stats)
ape_ck will become famous soon enough
Default Stratified Tune?
Recently bought and installed the last of the planned bolt ons, I planned a tune as the last bit of the process.
The question is... I'm running the Stratified OTS Stage 2 map, will I see as healthy a gain as people see over the Cobb Stage 2 OTS map?
I've got:
Cobb Catted DP
PTP Internals
JBR PowerPath Stage III CAI
I've done my research and I'm pretty much ready to pull buy the tune.
ape_ck is offline   Reply With Quote
 Old 08-03-2013, 03:59 PM   #2
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
No motor mounts?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 08-03-2013, 04:18 PM   #3
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
An actual tune will be heads and shoulders over an OTS map. But you should look into motor mounts as stated above. And I would personally recommend an upgraded IC, to help with BATs.
Give it a little tappy, a tap tap tap-a-roo
memin likes this.
99 miata: sold
ape_ck (08-03-2013)
 Old 08-03-2013, 04:42 PM   #4
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
A custom tune is specific for your car, mods, environment and fuel so you will see power gains and it will be safer.
The Following 2 Users Say Thank You to Mike@Stratified For This Useful Post:
ape_ck (08-03-2013), Sid3wayS (08-03-2013)
 Old 08-03-2013, 05:14 PM   #5
ape_ck's Avatar
Originally Posted by Playaj View Post
No motor mounts?
I just listed the power mods.
I have JBR RSB, SSP, Rear and Passenger motor mounts.
I'm not doing the IC because it would take me out of the class I autocross in.
EDIT: Guess I should probably do a sig a some point.
 Old 08-03-2013, 05:24 PM   #6
Mortose's Avatar
Groans: 39
Curious, why no trans mount?
And stratified will hook you up. They will even do separate maps for autoX and everything.
99 miata: sold
ape_ck (08-03-2013)
 Old 08-03-2013, 05:45 PM   #7
ape_ck's Avatar
Dunno, cost? Haven't gotten around to it?
Thanks for the heads up, was planning on doing the E85 and autox map.
Sent from my Galaxy Nexus using Tapatalk 4 Beta
The Following User Says Thank You to ape_ck For This Useful Post:
Lex (08-04-2013)
 Old 08-04-2013, 08:21 AM   #8
When you sign up make sure you know the rules of your autox class very well as we will try and maximize what we can do without breaking them. We've done a few race tunes where we were limited in terms of what we could do with boost control for example.
ape_ck (08-09-2013)
How To: Stratified Tune Lex Stratified Automotive Controls 1 07-24-2014 12:22 PM
Stratified Tune List Lex Stratified Automotive Controls 46 04-22-2014 10:26 AM
Stratified Tune phahengpro MazdaSpeed 3/6 - ECU Computer Tuning 42 03-07-2014 03:29 PM
Stratified tune done. MS309 Stratified Automotive Controls 57 08-04-2012 05:39 PM
Stratified (Lex) Tune! (330/393 VD) psychophyr Stratified Automotive Controls 11 02-23-2012 04:39 PM
Page generated in 0.28907 seconds with 24 queries
