E-Tuners / Custom Hardparts
  • 1 Post By Hush
 Old 06-01-2013, 03:54 PM   #1
Speed3_BigV's Avatar
Posts: 23   (View Stats)
Speed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to behold
Default Tried the OTS Stage 2 Map with stock HPFP
I recently got a test pipe with resonator delete done on my 2010, and I've seen some people having success running the OTS Stage 2 map. Now it's highly recommended to have HPFP upgraded internals but I tried it with the stock one to see.
I have a SRI with TIP, test pipe with resonator delete, stock DP, stock CBE, stock HPFP.
Keeping my face planted on the accessport live feed, I slowly started some 4th gear pulls, to my surprise, the fuel pressure was in the 1750-1850's and never dipped below that... Almost too good to be true.
Boost is around 18-18.5 psi, AFR's in the mid 11's tappering down to 11 near redline, injector duty cycle never goes over 67%, zero KR
I went back to the stage 1 map afterwards just to be safe while I get the downpipe and HPFP internals sorted, but I thought I'd share my story here. How is it possible the car is taking stage 2 like a boss when I've seen horror stories from others? Do you guys think it's safe to run stage 2 on my car judging from these readings?
| 2010 Mazdaspeed with Tech Pkg / 18x8.5" Enkei T6S w/ Nitto NT05 245/40
| Cobb AccessPORT / Self Tuned
| Ultimate Racing Turboback Exhaust (Catted, Non-resonated) / Ultimate Racing FMIC
| Grimmspeed EBCS / Turbosmart Dual Port BPV / Denso ITV22 / Autotech Internals / JBR EGR Delete / Corksport OCC
| JBR Chrome-Moly 88A RMM / Corksport TMM Insert / Corksport Shifter Bushings
| Prosport Halo Boost Gauge / Corksport LED DRL and Foglight Bulbs / Rally Armor Mudflaps
Speed3_BigV is offline   Reply With Quote
 Old 06-01-2013, 03:58 PM   #2
Police - Grammarhead
Vansquish's Avatar
You have no way of knowing unless you're monitoring HPFP actual pressure as well.
 Old 06-01-2013, 04:04 PM   #3
That's what I was monitoring at 1st, when I saw the HPFP fuel pressure was good, I started to monitor other readings as well.
 Old 06-01-2013, 04:04 PM   #4
Hoyoman's Avatar
Posts: 302   (View Stats)
Hoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the world
Groans: 43
Groaned at 6 Times in 3 Posts
Too risky. flash back to a safer map until you get internals. It might run okay for a short amount of time and before you know it, you'll blow your a hit sky high.
2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck
E35 meth d012 26psi 420/451 self tuned/built
Hoyoman is offline   Reply With Quote
 Old 06-01-2013, 04:10 PM   #5
Vansquish's Avatar
When I said, "monitoring," I was too non-specific. You need to be monitoring your HPFP actual pressure live AND taking logs whenever you do a pull if you're going to stick with a Stage 2 map and stock internals. Basically, the refresh rate for the data that you see while you're driving is likely too slow to tell you if something is actually wrong.
In any case, you're playing a very dangerous game. I would strongly recommend sticking with a Stage 1-style map until you have HPFP internals installed.
cshunter (06-02-2013)
 Old 06-01-2013, 04:10 PM   #6
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
Don't look at this as a "is it safe" type of thing, look at it as "do I want to baby sit my hpfp ever time I step on the gas" type of thing.
You might have the one in a hundred pump that keeps up, until stuff gets a little dirtier, a little hotter, maybe some gas issues. Will that be the day you see it go? Maybe. Maybe not. Why worry? Motors are expensive.
sharksinspace likes this.
-2012 CWP MS3 -
- COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50
- JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB -
- Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob -
- Self Tuning 91 octane of fail with 50/50 WMI of win -
Hush is offline   Reply With Quote
The Following User Says Thank You to Hush For This Useful Post:
 Old 06-01-2013, 04:15 PM   #7
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
It may work while it is warmer out, but in cooler temperatures, I bet your fuel pressure will drop. Mine did with only an intake/TIP in the winter months.
Hush (06-01-2013)
 Old 06-01-2013, 04:16 PM   #8
I understand what you guys are saying, hence why my initial post also states I went back to stage 1 until I sort that stuff out (I'm also scared something might go wrong) I don't wanna blow the car up either lol, I just wanted a few opinions.
Thanks for the input so far
 Old 06-01-2013, 04:33 PM   #9
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Can you bare back a hooker and not catch anything... Sure. Can you do it multiple times before you catch something...sure. But sooner rather then later you're going to end up with some shit.
It's something that has been proven and explained time and again. No need for another thread from a brownie who thinks he has a unicorn.
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
big angry bird (12-17-2013), cshunter (06-02-2013)
 Old 06-01-2013, 04:44 PM   #10
I don't think I have a unicorn, in fact far from it, at 65000 miles on the odometer the car has most likely seen better days, I bought it second hand and it had 59k on the clock.
Yes it's risky, somewhat stupid, I knew that beforehand. I've done the research, I know what I need to get so it doesn't blow into a million pieces, I simply wanted to try this once, for 20 mins and share my story. I do have 5 years of payments left on it, wouldn't want to lose it now.
I'm sure you've heard this type of thing hundreds of times from other noobies and I appologize if I'm annoying you. But, I'm no noob to the world of turbocharged engines and tuning. Just on this forum since I've never owned a speed before. But thanks for your input! Just wanted to have a bit of fun.
 Old 06-01-2013, 05:01 PM   #11
shadow102's Avatar
Posts: 971   (View Stats)
Even having that cat delete on the car your playing the waiting game on if something is going to happen.
i also notice you have LC and FFS but your running the stratified tune? As far as i was aware the tune was locked and you couldnt use those options
2013 CWP MS3 w/tech package
 Old 06-01-2013, 05:12 PM   #12
It is locked, but there is a tool on the Cobb website to add LC and FFS to locked, custom, and protune maps. You simply browse to your map on your pc, then input limits for LC, FFS and the threshold speed at which LC turns off. The tool then sends you an exact copy of that map with both features enabled. The map remains locked still.
The Following User Says Thank You to Speed3_BigV For This Useful Post:
shadow102 (06-01-2013)
 Old 06-02-2013, 01:45 AM   #13
Some OEM pumps are stronger than others but as a general rule for safety, I do recommend and HPFP ASAP if you plan on modifying this car in general.
A good test for the HPFP is to do a multi gear pull. Take a 2, 3, 4 multi gear pull shifting quickly and taking each gear to redline and log all this. Watch HPFP Act. Pressure right after the shift as the turbo spools back up and you're on the throttle. Does it dip below 1500-1600psi while under WOT? If it does, it's time for an HPFP.
cshunter (06-02-2013), ms3rick (06-02-2013)
HPFP + Stage 1 sparks5314 2010 MS3 - ECU Computer Tuning 5 01-07-2013 09:39 PM
Stage II with DP, HPFP, FMIC, RP mrmonk7663 2010 MS3 - ECU Computer Tuning 11 09-22-2011 05:50 PM
HPFP STAGE 1, 2, and 3! ptperformance Mazdaspeed3/6 General Discussion 58 02-14-2010 03:19 PM
Page generated in 0.35657 seconds with 27 queries
