E-Tuners / Custom Hardparts
Like Tree54Likes
 Old 06-08-2012, 03:33 PM   #81
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
No, you definitely need the vac line hooked up. Some of the pics above were just taken before everything was put back together.
You need to hook that line up, or you'll get bad compressor surge.
Thanks for clarifying. That was throwing me off. Didn't look right so i thought I'd ask.
this forum serves 2 purposes
The Following User Says Thank You to Dash08 For This Useful Post:
djuosnteisn (06-08-2012)
 Old 06-08-2012, 03:39 PM   #82
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
NP amigo. I'm glad when people just ask, cause if you were a lil confused, that means several other people probably were too... which means there's a good chance someone is going to try it, hahaha.
Fuck fridays are so slow at work.... ugh.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Broxer (06-08-2012), Dash08 (06-08-2012), helmetface (06-08-2012)
 Old 06-08-2012, 03:48 PM   #83
ewg vta without the dump tube
djuosnteisn (06-08-2012), josurr (06-11-2012), rghispanic88 (06-08-2012), sleepyspeed6 (06-08-2012)
 Old 06-08-2012, 03:57 PM   #84
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
I have the ultimate VTA gates... but i has no picture at work lol
860whp/677wtq
2.7 V6 Ecoboost
 Old 06-08-2012, 04:00 PM   #85
@PapaSmurf
djuosnteisn (06-08-2012), Monotonous ONE (06-10-2012), PapaSmurf (06-08-2012)
 Old 06-08-2012, 04:05 PM   #86
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I want to VTA my DNP ewg manifold and my turbosmart kompact bpv.
So the GA is mandatory to run bpv vta?
 Old 06-08-2012, 04:16 PM   #87
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
Video of sweet ass TIAL Q (VTA Im running speed density) compressor surge on the Evo uploaded soon. Gonna go take a video on the GoPro LOL
2003 Evo VIII
 Old 06-08-2012, 04:21 PM   #88
Captain
You're getting surge? With a bov that big?
I'll be running a tial q on my ms3 once i got top mount
www.permtuning.com
 Old 06-08-2012, 04:23 PM   #89
This thread got filled up fast!
Let me quickly explain what's going on with this VTA business.
The OEM, Forge, Greddy, etc. push type of valves have 3 forces acting on them:
1. Spring pressure always acting to close the valve
2. Vacuum/boost at the top of the valve. When under vacuum from the manifold (idle, closing the throttle), the valve is pulled open. When under boost at the manifold, the valve is pushed closed from this point.
3. Boost pressure against the bottom of the piston itself from the charge piping. This pushes the valve open under boost and provides no force when not under boost at the charge pipes. Remember charge pipes never see vacuum.
So under boost, both charge pipes and manifold see boost. Under vacuum (idle, low load), charge pipes see no pressure, manifold sees vacuum. This is explained below
Under boost, you have the spring and manifold boost source at the top trying to close the valve, and boost in the charge pipe on the bottom trying to open the valve. The spring and boost pressure forces from the top are hopefully stronger than the boost from the bottom so the valve stays closed. This is shown below.
When you let go of the throttle, there is a spike in boost pressure from the bottom, and a pull from the vacuum in the manifold from the top (since the manifold is under vacuum when you let go of the gas). This means only the spring is trying to keep the valve closed and that's not enough acting against those other forces so it will open and let excess boost out.
At idle, you have no boost pressure at the bottom in the charge pipes. You just have the spring pressure keeping the valve closed and vacuum from the top trying to open it. Depending on how soft the spring is, vacuum will start pulling the valve open. The OEM one starts to pull open at 15 inches of mercury. At sea level we idle at 21-22 for a healthy motor. So the valve will stay open and allow air to pass causing a leak. This will happen at idle and low loads and the car will run rich and like crap.
As you apply more throttle, the vacuum at the top starts to be less strong, allowing the
valve to close and then you enter boost which I described above.
In order to stop the leak at idle (and when coasting and under light loads) you need a very stiff spring. This is all good and dandy until you realize that such a stiff spring will cause compressor surge since the valve won't open quickly enough or will close too soon when you let go of the throttle in boost since the stiff spring is keeping it shut.
Now where does the GA fit in here? Well, *most* push type valves such as the OEM one, even ones meant to VTA like the greddy have a hard time tuning the spring so that they don't leak at idle while also not causing compressor surge. @Daddy Chinkus complained about this and it sparked the idea of using the Guardian Angel to control the valve not just as a failsafe, but also to control it so that it stays shut under the idle and low throttle conditions. It also shuts if off quicker when letting off the throttle causing less backfiring etc. That way you can have your cake and eat it too. You can have a push type BPV such as the OEM one and run it VTA. You can even run the OEM one VTA which you won't be able to otherwise.
The Following 26 Users Say Thank You to Lex For This Useful Post:
4G63 (06-09-2012), ak_spray (06-15-2012), anavrinIV (06-08-2012), atvfreek (06-09-2012), AZSPEED3 (06-16-2012), BlueStreak (06-08-2012), daafisch (06-14-2012), Dano (06-08-2012), Dash08 (06-08-2012), djuosnteisn (06-08-2012), ESB Jiu JItsu (07-05-2012), Fobio (06-26-2012), helmetface (06-08-2012), IMASA (06-18-2012), Ingle (06-11-2012), josurr (06-11-2012), kgb (06-12-2012), mayer (06-11-2012), NJSPEED3 (06-10-2012), Nliiitend1 (06-08-2012), Rcn_MPS3Zoom (06-21-2012), SLOWHATCH (06-09-2012), SpeedRebirth (11-19-2012), TiGraySpeed6 (06-08-2012), Tokay444 (06-09-2012), uncorked11 (06-10-2012)
 Old 06-08-2012, 04:26 PM   #90
I <3 your mom
Dash08's Avatar
Groans: 293
Fuck, hate being a noob to certain things, but what are you guys using to cap off the recirc inlet on the TIP?
I'm thinking a silicone or rubber hose cap with a clamp. Ace hardware, Lowe's?
EdgeAutosport.com (06-08-2012)
 Old 06-08-2012, 04:28 PM   #91
Use one of these if using an inlet pipe and clamp it down. They come in all sizes.
I am just testing now and I put a small plastic container and clamped it down in my recirc hose. That will be cleaned up later though.
Dash08 (06-08-2012), SLOWHATCH (06-08-2012)
 Old 06-08-2012, 04:31 PM   #92
Or get a plastic pvc plug. They sell them at home depot or lowes for a buck, thats what I did with mine or we have these in stock if you wanna be all pretty
ak_spray (06-15-2012), Dash08 (06-08-2012), djuosnteisn (06-08-2012), Lex (06-08-2012), SLOWHATCH (06-08-2012)
 Old 06-08-2012, 04:31 PM   #93
First off let me say I am not an advocate of rice...ur I mean VTA...my Forge sounds just fine and I can hear plenty of woosh out of my SRI....but riddle me this.
Would it make sense to do some work with the shift control tables to reduce the rich condition/backfire on clutch in/out. I have not really messed with the tables much and don't know how bad the rich condition gets and how much backfiring goes on...
I have changed a few things to reduce my own backfiring due to all the meth left over on throttle lift. It helps but not all the time...lol I don't know how far they can compensate but it might be worth trying. You could alter both the IGN comp to reduce ign retard and reduce the addition of fuel with clutch in...IDK these tables may not be able to compensate that fast or that much...lol
Care should be taken when altering the max ign retard and you might always want it negative..I am running the cobb suggested -3 which does make the car respond faster post shift and has reduced my backfires. Haven't altered the load comp tables enough to get any conclusive results.
just thinking out loud here but you might tweak those load based fuel comp tables to add less fuel since you will already get plenty of fuel by VTAing. Not sure WTF you would do with the Load/RPM table since you may shift at different RPMs but the load only table would be a good place to start.
anyway I may be totally off base since I have no VTA experience and very little with these new tables.
now the bigger question....brown or white?
edit: well I guess nevermind if you are actually running a BOV there might not be any rich condition issues.
There are actually some differences in the 2d and 3d tables that I matched on one persons map to help with a rich condition.
I think you are onto something for sure with one of the tables adding some fuel that may be taken out.
Dano (06-08-2012), SLOWHATCH (06-09-2012), Tokay444 (06-09-2012)
 Old 06-08-2012, 04:36 PM   #94
4G63's Avatar
Groans: 123
I got the spring for the vacuum pressure I'll have after I install my GSC S2 cams. Therefore it's currently the wrong spring by a little bit. I think I got the 10psi spring in there now
Edit: I have the Precision billet surge protector on the turbo. Not a huge deal for a bit I'll swap out springs soon
2003 Evo VIII
 Old 06-08-2012, 04:38 PM   #95
ms3rick's Avatar
Posts: 2,959   (View Stats)
So a crushed 1g dsm should be good? I wanna rice to scare walking foes
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
 Old 06-08-2012, 04:38 PM   #96
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
@Lex
is this change going to happen in a FW or software update for the GA and how do existing users get it loaded?
maybe a premature question...lol
I too have put in my red spring to keep my Forge closed but is causes waaay too much surge. back on the famous "blue 2 shims" setup
Fobio (06-26-2012), Lex (06-08-2012)
 Old 06-08-2012, 04:43 PM   #97
@Lex
This is a software/FW change for now. I am going to build it in as a feature users can turn on or off as they choose. I need to do more testing. I actually need some different BPVs to test on.
Anyone willing to let me borrow a Forge, a Greddy, and anything else they are using?
Dano (06-08-2012), Fobio (06-26-2012)
 Old 06-08-2012, 04:48 PM   #98
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Borrow logs or borrow them physically?
I know this is a dumb question and you mean physically but I know they aren't a ton of people running mine so I figured I'd ask...lol
 Old 06-08-2012, 04:49 PM   #99
Captain
Looks like @PapaSmurf's condom collection.
www.permtuning.com
Dano (06-08-2012), IshiKage (06-11-2012), Tomas (06-09-2012)
 Old 06-08-2012, 04:51 PM   #100
Borrow physically. I'll pay shipping both ways and a little extra for the trouble.
 Old 06-08-2012, 04:56 PM   #101
Trail of Fail
Dano's Avatar
cool...BTW I have been inadvertently testing my GA while ratcheting up my boost with the new MAP. I am confident enough that I no longer use my Boost limit tables....not that the throttle close ever did anything but the FC did and I prefer the "softer" cut the GA provides.
Its cool to see that the product may already be expanding its functionality with the BPV leak control.
Borrow physically. I'll pay shipping both ways and a little reach around for the trouble.
fixed
Last edited by Dano; 06-08-2012 at 04:57 PM. Reason: MSF Database - Automerged Doublepost
Fobio (06-26-2012), helmetface (06-08-2012), Lex (06-08-2012)
 Old 06-08-2012, 04:59 PM   #102
PapaSmurf's Avatar
I DONT USE CONDOMS
860whp/677wtq
2.7 V6 Ecoboost
The Following 8 Users Say Thank You to PapaSmurf For This Useful Post:
ak_spray (06-15-2012), Dash08 (06-08-2012), djuosnteisn (06-08-2012), EdgeAutosport.com (06-08-2012), IshiKage (06-11-2012), kylec_2003 (06-09-2012), Monotonous ONE (06-10-2012), rghispanic88 (06-08-2012)
 Old 06-08-2012, 05:00 PM   #103
helmetface's Avatar
Groans: 219
PM'ing
 Old 06-08-2012, 05:05 PM   #104
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
you're creative bastard @Lex
This is great fun to watch, and to see somebody play who has the skills to play, it's really just fun to watch.
I love having forced induction.
340hp / 371tq
Lex (06-08-2012), rfinkle2 (06-08-2012)
 Old 06-08-2012, 05:07 PM   #105
Awesome to hear Dan! The FC tables do work but soooo slowly if shit really hits the fan. BTW, the throttle close works, you just need to have 80s or lower in your DBW tables. That's even slower though, it's more for fine control.
I hope this feature will be pretty cool and functional. You will also ALWAYS know the GA is working properly since it's always activated. If I can see a difference in spool that will be even better. We'll see.
Dano (06-08-2012), Fobio (06-26-2012), TiGraySpeed6 (06-08-2012)
 Old 06-08-2012, 05:31 PM   #106
4G63's Avatar
Groans: 123
@djuosnteisn
Fast forward to 0:30 seconds. Runs for 2 mins middle part of video you can hear it. Don't know how to edit videos on the GoPro yet I'm a noob
@Lex is this how BOV's are supposed to work?
Evo VIII Compressor Surge TIAL Q - YouTube
2003 Evo VIII
The Following 2 Users Say Thank You to 4G63 For This Useful Post:
djuosnteisn (06-08-2012), fooqr (06-08-2012)
 Old 06-08-2012, 05:34 PM   #107
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Mother of god. That hurts to here.
And yes sounds like definitely comp surge.
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
The Following User Says Thank You to TRSpeed For This Useful Post:
 Old 06-08-2012, 05:44 PM   #108
Originally Posted by 4G63 View Post
@djuosnteisn
You needs softer spring or perhaps the plumbing is not correct.
 Old 06-08-2012, 06:20 PM   #109
FY&quot;IED&quot;N
dMuze's Avatar
Posts: 506   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
i know i would get a lot of afterfire between shifts when running my hybrid in 50/50. car would shift a lot less smooth than it does now in full recirc.
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is offline   Reply With Quote
 Old 06-08-2012, 06:43 PM   #110
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I'm finding that running vta on my ssqv3 yields smoother shifts (under part throttle conditions) than running it in recirc did. definitely a few afterfires now (subtle, which is why I wasn't hearing them before) but the car runs fine. Of course, I have a valve meant to run vta so with the exception of complete throttle liftoff it holds fine.
Blue Pu.
 Old 06-08-2012, 07:11 PM   #111
m4tic's Avatar
Posts: 4,928   (View Stats)
@Lex on the first point with boost pressure acting on both sides of the valve... i should point out that with pressure on both sides this is essentially a net pressure differential of 0; so its up to the spring to hold the valve closed.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 06-08-2012, 10:30 PM   #112
IMASA's Avatar
Posts: 209   (View Stats)
Hey Lex,
My Forge V1 is available if you need it.
 Old 06-08-2012, 11:44 PM   #113
Captain
... is this how BOV's are supposed to work?
Definitely surgey sounding. Softer spring is indeed required.
Hopefully it doesn't open under vac with the softer spring, cause that's the norm on our platform. People have to shim them to get them just right, and it's a bitch.
Here's how a clean blow off should sound (kinda hard to hear, crank volume):
Note, my car blows off this clean even at 0 psi most the time. But if you can get your's to the point where it blows off clean at ~5psi of boost, i'd call it decently good. Surge below that point probably won't be enough to damage the turbo as long as it's a decently built turbo.
www.permtuning.com
86AmishMs3 (06-09-2012), atvfreek (06-12-2012)
 Old 06-09-2012, 12:59 AM   #114
VTA on the top mount s300sx perm dragon.MP4 - YouTube
I am playing around with timing transitions just right ... we will see how this differs on different BPV/BOVs but I found that if I wait for the valve to crack open at 80 Kpa (still not boost, boost starts at 100 Kpa) there will be part throttle surge. There's definitely a happy place to blow off at part throttle and it's interesting to see how narrow the window is (hence the difficulty to get just right with shims).
Originally Posted by IMASA View Post
Hey Lex,
Yes sir, I will need it thank you and it will work out great since you're local.
Last edited by Lex; 06-09-2012 at 12:59 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-09-2012, 01:07 AM   #115
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Also another good thing to point out about surge, is that surge is not as bad a thing for ball bearing turbos then it is for journal bearing turbos. Journal bearing turbos you're overloading the thrust bearing and causing metal, metal contact since you're pushing away that oil film.
Ball bearings the thrust force is distributed pretty well across the ball bearings.
For me I just tuned my bpv/bov to the point where I'm not slamming my face into the windshield when I let off the throttle at partial boost. Otherwise NCE about the turkey living under my hood. Only really get surge from 0-3ish psi.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 06-09-2012, 04:27 AM   #116
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
VTA! MCY!
Nator is what it does.
 Old 06-09-2012, 05:40 AM   #117
4G63's Avatar
Groans: 123
Yea I know it needs the softer spring like I was saying the one in their currently was for the vacuum I'd have at idle with the 274 cams in there. Wasn't going to install it til the cams but had to hear it lol. With a softer spring it should be fine I haven't seen anyone use any shimming to get it to work it's just the right spring that matters as you know.
My pipe setup like @Lex said isnt plumbed wrong but it is terrible now I'm gonna have to spend another $400 on some upper piping setup The pipe I got for cheap is hitting my Optima RedTop battery (it's a little wider than stock)
(piping wasn't all clamped for pic, speed density sensor is also resting on my valve cover because of the pipe being pushed over by the battery. Had to wrap it with krampton tape rated to 3000 degrees lol)
I'm done didn't mean to hijack I'm sorry Lex!!!
2003 Evo VIII
 Old 06-09-2012, 10:39 AM   #118
I <3 your mom
Dash08's Avatar
Groans: 293
Well, this is bullshit.
Nobody sells those vinyl plastic end caps to cap off the recirc inlet. I wanted to use something soft so I can throw a hose clamp on it for a good seal.
I see the hard PVC plastic plugs and caps, but how do you keep the fucker on there? Can't put a hose clamp on PVC, that won't do shit.
Any other suggestions?
 Old 06-09-2012, 10:44 AM   #119
anavrinIV's Avatar
Groans: 63
home depot has copper pipe caps, 1", for under $3. cut a short length of recirc hose, cram the cap in one end, and put the other end of the hose on the TIP. clamp both sides. done. that's how I have mine and no leaks, and as tight as the cap is in the hose it won't come out, especially with a clamp on it.
Blue Pu.
Dash08 (06-09-2012), JBR (06-09-2012)
 Old 06-09-2012, 10:54 AM   #120
^^^This is a great idea.
I used a rubber plug from Ace Hardware and wrapped the exposed portion with a little electrical tape.
Dash08 (06-09-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/vta-115811/
General Speed 6 Build & Product Thread - Page 3 This thread Refback 07-25-2012 01:14 PM
intake bov sound. This thread Refback 07-14-2012 04:01 AM
What have you done to your Mazda today? This thread Refback 07-13-2012 12:56 AM
Blow off valve 2010 ms3 This thread Refback 06-13-2012 07:34 AM
Page generated in 0.65870 seconds with 39 queries
