> MSF KB - Mazdaspeed 3/6 - General
 Old 05-03-2012, 03:05 PM   #81
MoKaP's Avatar
Posts: 190   (View Stats)
MoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the worldMoKaP is the leader of the world
THE SMALLER FASTENER IS PART NUMBER GD7A-50-EA1
THE SCREW IS 9CF60-0516B YOU WILL NEED 5
THE OTHER SCREW WITH FASTENER IS PART NUMBER 90720-0620 SAYS YOU NEED 3
HOPE THIS HELPS
MATT
2006 Silver Speed6
sold
Cobb AP
CP-E TMIC
CP-E Nano
CP-E TIP
Sure RMM
ATP Catted DP
CP-E dual exhaust
NGK 6510
Autotech internals
HKS Gen1 SSQV
JBR 80Duro TMM/PMM
277hp/343tq freektune
MoKaP is offline
 Old 05-20-2012, 06:22 PM   #82
rolanblack's Avatar
Posts: 2,110   (View Stats)
NEED HELP ON FINDING OUT WHAT THE PART NAME IS/PART NUMBER
installed a corksport TIP and right where the vaccum hose goes from the brass nipple to the plastic nipple, the plastic nipple completely broke off. best pictures i took of it. located next to the boost tubes closes to the turbo. PLEASE HELP
rolanblack is offline
 Old 05-20-2012, 07:19 PM   #83
MS6FL's Avatar
Posts: 1,753   (View Stats)
MS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the world
Groans: 43
Boost control solenoid. Lots of threads on it. Time for a grimspeed!
“From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley
MS6FL is offline
 Old 05-20-2012, 08:49 PM   #84
rolanblack's Avatar
Thanks dude for your help
 Old 05-30-2012, 10:09 AM   #85
LOZ
LOZ's Avatar
Posts: 150   (View Stats)
LOZ has much to be proud ofLOZ has much to be proud ofLOZ has much to be proud ofLOZ has much to be proud ofLOZ has much to be proud ofLOZ has much to be proud ofLOZ has much to be proud ofLOZ has much to be proud ofLOZ has much to be proud ofLOZ has much to be proud of
Groaned at 9 Times in 6 Posts
Could you add the OEM cam follower or "collar" as Mazda calls it.
L3K9-12-615
LOZ is offline
 Old 06-10-2012, 07:36 PM   #86
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
MS3 front caliper bolt (bolt that screws into caliper itself)?
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
 Old 06-11-2012, 07:39 AM   #87
rabble rabble
802MS3's Avatar
Groans: 221
also the front brake caliper bracket for MS3.
802MS3 is offline
 Old 06-11-2012, 07:56 AM   #88
MAZ
MAZ's Avatar
MAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the world
nice. thank you.
What does matter is: length times diameter, plus weight over girth, divided by angle of the tip squared.
"Feel how hot I am through my pants." (Singleflusher, MNM 2013)
"My pants are so hot they're melting?!" (Jenneh, EMWNM 2013)
"Heeeeeeeeeeeey!!! Boooooooooooooobs." (NATOR National, ENM 2014)
"SCUUUUMMMMMBAAAAAAAAGGGGGGG!" (NATOR National, ENM@MDC 2015)
MAZ is offline
 Old 06-13-2012, 06:20 AM   #89
JP_Playboy's Avatar
Posts: 228   (View Stats)
JP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the world
Can some one help me out with the 09 speed 3 hose that comes off the turbo inlet pipe just before the turbo as well as the little black piece it connects to?
JP_Playboy is offline
 Old 06-13-2012, 08:48 AM   #90
rabble rabble
802MS3's Avatar
Groans: 221
The stock boost controller? its just standard vacuum line
802MS3 is offline
 Old 06-13-2012, 09:52 AM   #91
JP_Playboy's Avatar
Ok, do you by chance have a part number for it? When I was taking out my turbo inlet pipe yesterday to do my fuel pump internals, I forgot and didn't see it was there and snapped the hose right off the black piece and there is no way to salvage it without buying a new one.
 Old 06-13-2012, 10:52 AM   #92
MS6FL's Avatar
Groans: 43
Get a grimspeed!
MS6FL is offline
 Old 06-13-2012, 12:57 PM   #93
rabble rabble
802MS3's Avatar
Groans: 221
its in the first post buddy
boost solenoid - L3K918741
though, this has happened to a lot of people. check out online if you can wait, onlinemazdaparts.com has it for ~$54
802MS3 is offline
 Old 06-14-2012, 05:30 AM   #94
JP_Playboy's Avatar
Thanks for the help. Anyone know what size the vacuum line is that it attaches to?
 Old 06-14-2012, 06:12 AM   #95
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
BPV Recirculation hose part number?
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
mrmonk7663 is offline
 Old 06-14-2012, 08:00 AM   #96
rabble rabble
802MS3's Avatar
Groans: 221
1/4" maybe, but thats a guess. just take the old hose to advace auto or autozone, you can get a foot for a dollar or two which should be plenty,
802MS3 is offline
 Old 06-15-2012, 05:02 AM   #97
JP_Playboy's Avatar
That makes sense. Thanks
09 Mazdaspeed 3 - Mazdaspeed CAI V2, COBB TIP, COBB DP, COBB CBE, Corksport TMIC, CP-E HPFP, COBB RMM, COBB AP, Stoptech slotted rotors, HAWK break pads, tuned by LEX (Stratafied).
Semper Fi
 Old 09-19-2012, 01:33 PM   #98
Discuss
http://www.mazdaspeedforum.org/forum/foru...numbers-28485/
Raider is offline
OEM MS6 engine part numbers 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 47 02-07-2016 01:34 AM
Looking for part numbers help Necro_1015 Mazdaspeed3/6 General Discussion 1 03-28-2011 08:32 AM
Need help with part numbers Blackspeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 02-21-2011 03:39 PM
Someone Hit my car need part numbers!! KoleDeRacer MazdaSpeed 3/6 - Appearance 7 06-02-2010 09:56 AM
Page generated in 0.37405 seconds with 29 queries
